CalMan 5 Release Notes and Discussion - Page 235 - AVS Forum | Home Theater Discussions And Reviews
 1951Likes
post #7021 of 7029 Old 10-03-2019, 06:03 PM
venkatesh_m's Avatar
Quoted: 78 Post(s)
Liked: 52
Originally Posted by jrref View Post
I sent some e-mail out this morning to follow up on the Murideo and Version 3.02 firmware for the Murideo Six-G Gen2 is now on their web site. Version 2.64 for the Murideo Six-G Gen1 is being third party verified now and if good should be available in a couple of days. Gen2 is their new hardware version for the Six-G. I'm not sure of the details on Gen2. Version 3.02 is now supposed to work with the latest version of CM and I will verify that. From what I understand the process is Murideo is verifying and then they are having third parties verify to make certain the device is bit perfect in all modes.
I was not aware that they had a specific Gen2 available. Do you know what they changed?
venkatesh_m is online now
post #7022 of 7029 Old 10-04-2019, 02:13 PM
Quoted: 4474 Post(s)
Liked: 5488
Version 2.64 for the Murideo Six-G Gen1 and Version 3.02 for the Six-G Gen2 are both now on the web site for download. This firmware was verified bit perfect for all modes. Enjoy and if you find a problem let me know and i'll escalate it to their support, but it should be good now.
As far as the differences with the Gen2 hardware, I know they changed the power supply but with ver. 2.64 and Gen2 it works the same as the Gen1 unit I had. I believe there are some changes with the new 3.02 firmware and Gen2 and will report back.
venkatesh_m likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #7023 of 7029 Old 10-04-2019, 02:21 PM
thoth's Avatar
Quoted: 143 Post(s)
Liked: 71
Thank you. I hope a VideoForge Pro update follows shortly.
thoth is offline
post #7024 of 7029 Old 10-04-2019, 02:40 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1556 Post(s)
Liked: 2156
We are still in the process of testing it.
But like I said before the only thing that was wrong was SDR 422 BT.2020 No other combination was affected.
jrref likes this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #7025 of 7029 Old 10-04-2019, 03:01 PM
Quoted: 154 Post(s)
Liked: 69
Originally Posted by tarbat View Post
Originally Posted by baller02 View Post
Ycbcr is way off, higher errors.
Can you please explain how big the errors were when outputting YCbCr from MobileForge on an Amazon fire TV stick 4k? And were the errors bad for both grayscale and colours? Thanks.
Mobile forge is never bit perfect, so I tested with ted‘s patterns (on the oppo 203 with ycbcr bit perfect). Grayscale and colors are not bit perfect, If I remeber correct sometimes 6 digit off.
tarbat likes this.
Panasonic OLED55FZW 804
i1 Display Pro OEM 2018 profiled by Jeti 1501
i1 Pro 2, DVDo AVLab TPG, HD Fury Integral
Oppo UDP203
baller02 is offline
post #7026 of 7029 Old 10-04-2019, 08:29 PM
T( )( )L's Avatar
Quoted: 223 Post(s)
Liked: 114
John,if you read the text for 2.64fw it states ”do not use this on 1.X units” im a gen1 user with a current 1.88fw installed,so what is the truth behind this can the 2.64 be used on 1.x or not (I did send murideo support a message regarding this)
Calman Enthusiast,Lightspace HTP,Klein K-10A,I1pro2,Murideo 6G.
T( )( )L is offline
post #7027 of 7029 Old 10-05-2019, 05:52 AM
Liked: 5488
So 1.x and 2.x is different from the Gen2 hardware. From what I understand the original 6Gs had 1.X firmware and the later ones has 2.X firmware probably due to a hardware change so when you updated you needed to load the correct version from the web site which you still need to do. So if your 6G currently has 2.x firmware you can load 2.64 if your 6G has 1.x firmware you can load 1.88 to get the latest fix that was just tested. If your 6G specifically has the Gen2 on the back label then you can load the firmware that specifically was developed for Gen2 such as the new 3.02 firmware. There is no documentation as to what version 3.x or Gen2 brings but i'll try to find out and let you know if I see anything different when I try it. I believe Matt told me there were more test patterns since I believe there is more memory on the Gen2.
Hope this helps, BTW I only help test and do not work for Murideo. Jason Dustal can probably give us more information.
John
jrref is offline
post #7028 of 7029 Old 10-05-2019, 06:04 AM
ConnecTEDDD's Avatar
Quoted: 3264 Post(s)
Liked: 4055
John, open a thread to talk for Murideo, because you are always using CalMAN thread, if you check your post history you have used only CalMAN thread to inform about Murideo.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #7029 of 7029 Old 10-08-2019, 07:13 AM
sillysally's Avatar
Quoted: 1178 Post(s)
Liked: 1053
The new firmware for the G6 non gen 2 that is posted on Murideo download page is not correct, it's ver 2.63 not 2.64. Ver. 2.64 should be posted by 11 am
ss
Update. Still no new firmware 2.64.
Update. This is the link for firmware 2.64. https://www.murideo.com/uploads/5/2/...mware_2.64.zip
jrref likes this.
"Don't worry be happy"
LG77C8, Klein K10-A, Jeti 1211, CMS Lightspace, Calman home plus licence for K10-A, Murideo 6G.
sillysally is offline
Reply Display Calibration
