CalMan 5 Release Notes and Discussion - Page 236 - AVS Forum | Home Theater Discussions And Reviews
 1972Likes
post #7051 of 7070 Old 11-22-2019, 10:09 PM
AnotherDude's Avatar
Quoted: 1057 Post(s)
Liked: 655
Originally Posted by Y2JDMBFAN View Post
Where do I find the AutoCal workflows in Calman Home Enthusiast 2019? I'm on 5.10.1.113.
When I installed Home Enthusiast I got a bunch of workflows installed, didn't you? Most of them work with Enthusiast.
And if you feel adventurous you can try mine
mrtickleuk likes this.
Samsung 75Q9FN, OPPO UDP-205, Radiance 2143
Win 10 Pro x64 1909
HT Enthusiast Extended Custom WF v21.0.0 - 10/26/2019
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is offline
post #7052 of 7070 Old 11-23-2019, 11:16 AM
Y2JDMBFAN's Avatar
Quoted: 877 Post(s)
Liked: 286
Originally Posted by WiFi-Spy View Post
You can download them from the CalMAN resource center:
https://kb.portrait.com/help/calman-home-assets-pack
Found them! Thanks!
Sony 75" XBR-75Z9D
Denon AVR-X4400H
(4) Klipsch RP-280FA Dolby Atmos Enabled Towers
(1) Klipsch RP-450CA Center Channel
(1) SVS 12" PC-2000 Subwoofer
Y2JDMBFAN is online now
post #7053 of 7070 Old 11-26-2019, 10:22 AM
Y2JDMBFAN's Avatar
Quoted: 877 Post(s)
Liked: 286
Next question, is it a best practice to calibrate a LG C9 OLED with C6 and Calman in the complete dark? I've read conflicting reports, but maybe they are outdated at this point, maybe someone from SpectraCal can chime in. Thanks!
Sony 75" XBR-75Z9D
Denon AVR-X4400H
post #7054 of 7070 Old 11-26-2019, 05:19 PM
Quoted: 1083 Post(s)
Liked: 706
Every time I have had my TVs calibrated the pro always turns all the lights off when taking measurements.
Sony 77A9G (Also XBR65X900E and XBR55X900E)
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #7055 of 7070 Old 11-27-2019, 05:42 AM
Quoted: 4589 Post(s)
Liked: 5577
You want to calibrate in a dark room because you don't want reflections affecting your readings. Even with the meter in contact mode with the screen, you can get reflections, etc.. You want to use normal viewing room lighting both dark and bright Before calibrating to better determine the brightness setting to calibrate with.
Y2JDMBFAN likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #7056 of 7070 Old 11-27-2019, 01:03 PM
thoth's Avatar
Quoted: 181 Post(s)
Liked: 87
VFPro 1.13 firmware is available on the PD site.
chunon, skat137321 and jrref like this.
thoth is online now
post #7057 of 7070 Old 11-29-2019, 11:46 AM
mrtickleuk's Avatar
Quoted: 5174 Post(s)
Liked: 7494
There doesn't seem to be support for Autocal on the 2019 GX Panasonics in Calman. Only the GZ, so this is a bit disappointing. Is there a technical reason for this, could it be added in future?
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #7058 of 7070 Old 11-29-2019, 06:23 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1625 Post(s)
Liked: 2208
I will share this feedback with Panasonic .
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #7059 of 7070 Old 12-01-2019, 05:00 PM
pbz06's Avatar
Quoted: 1168 Post(s)
Liked: 946
Take a step back here. "Expand to PC levels" is for when you are using devices with a video output circuit that compresses the full 0-255 range down to the 16-235. It's to tell Calman that that is going to happen, so Calman pre-expands these 16-235 patterns it creates, because it knows they are going to get compressed by something else in the chain afterwards. This is used for devices such as the Amazon Fire running Mobileforge, like this:
If your PC is "set to full", in that you are saying your PC has the ability to output 0-255, then you do not need this option (and should not use it). You will also have the advantage of being able to output the "super-white" range of 236-255 (where Calman shows this 255 as 109% because 235 is 100% white).
Ok found this older post and it's helpful. I'm assuming this is true also for MobileForge running on my phone with an HDMI cable out.
On my A9G, I should set the HDMI setting to "Limited"...
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is online now
post #7060 of 7070 Old 12-02-2019, 12:59 AM
kuniu's Avatar
Quoted: 13 Post(s)
No cyber Monday in portrait.com ? Nothing?
Wysłane z iPhone za pomocą Tapatalk
kuniu is offline
post #7061 of 7070 Old 12-02-2019, 07:08 AM
Rolls-Royce's Avatar
Quoted: 1199 Post(s)
Liked: 1282
Almost never. Sometimes Spectracal would offer a bundle with one of their meters along with a license upgrade for a discount, but that was years ago.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #7062 of 7070 Old Yesterday, 07:18 PM
Liked: 0
Hi,
I picked up Calman 5 Home for Sony a couple days ago. First night I loaded it appeared to be stable. Didn't do much with it other than make sure the DDC was connecting to Calman for Bravia as well as look through the workflow. Two days later I start it up and it crashes within 30 seconds of initiating load. I repeat this error couple times and then try to repair and reinstall. The error persists. The error log doesn't mean much to me but I have yet to connect the application to a source or meter. I have escalated the issue to Portrait support but while I am waiting I thought I'd ask someone here if they might have a straightforward solution to the problem. I can load error logs if that would be helpful (all identifying/license-related data will be stripped, of course).
Bilo Smith is offline
post #7063 of 7070 Old Today, 06:02 AM
Liked: 3
Do you happen to know where we could find the release notes for the new firmware?
skat137321 is online now
post #7064 of 7070 Old Today, 07:11 AM
thoth's Avatar
Quoted: 181 Post(s)
Liked: 87
Nope. I assume YCbCr is now accurate, but the Guide still hasn't been updated.
thoth is online now
post #7065 of 7070 Old Today, 11:03 AM
Liked: 655
Any news on a new CalMAN beta?
Win 10 Pro x64 1909
post #7066 of 7070 Old Today, 11:39 AM
thoth's Avatar
Quoted: 181 Post(s)
Liked: 87
I got email on Nov 26 that one was "coming soon", but no other info.
thoth is online now
post #7067 of 7070 Old Today, 11:44 AM
Liked: 655
Same here, was wondering
Win 10 Pro x64 1909
post #7068 of 7070 Old Today, 11:46 AM
Liked: 5577
What feature are you waiting for that's not there now?
John
jrref is offline
post #7069 of 7070 Old Today, 11:51 AM
Liked: 655
Improved handling of the DDCs for one, and overall improved algorithms. There's always room for improvement
Win 10 Pro x64 1909
post #7070 of 7070 Old Today, 12:47 PM
mrtickleuk's Avatar
Liked: 7494
I want the brand new LUT algorithm, mention in the helpdesk ticket that a user posted in one of the recent threads*, confirmed as coming in the R3 version by Tyler. The new one that measures many more points than the 101 in the so-called "Lightning" LUT (which is a terrible and more than slightly misleading name IMHO! it's not as fast as a bolt of lightning at all, not even compared with the iRP LUT) - but crucially, NOT using the drift algorithm of the IRP LUT, which was designed many years ago, and has some serious problems with OLEDs. I hope it will contain some volumetric data, too.
*found. Phew.
https://www.avsforum.com/forum/139-d...l#post58721700
The IRP measurement option is not suggested for LG OLED TVs. For best results please use Lightning LUT (SDR) or Matrix LUT (HDR).
IRP LUT takes more measurements, but the non-additivity of the display really breaks it's (sic!) AI.
PDI is investigating less dynamic measurement options like fixed LUT in future releases for users that just want to take more measurements."
_______________
Reply Display Calibration
