LightSpace 3D LUT Home Cinema Calibration Software - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 1103Likes
post #2371 of 2392 Old 10-04-2019, 12:03 PM
Guz911's Avatar
Quoted: 18 Post(s)
@ConnecTEDDD , does this new probe matching capability improve meter profiling with c6 and i1pro2 as spectro?
S/W: LightSpace HTL, CalMAN Home for LG
P/G: DVDO AVLab TPG, VideoForge Pro
Meters: i1PRO2, SpectraCAL C6 HDR2000
TV: LG Oled 65 c8, chinoppo udp-203, himedia q10 pro
AVR: Denon x-4500 5.1.4, SVS Prime Satellite 5.1, RSL C34E
Guz911 is offline
post #2372 of 2392 Old 10-04-2019, 12:12 PM
ConnecTEDDD's Avatar
Quoted: 3264 Post(s)
Liked: 4055
The problem with i1PRO2, for that method is that it will require to read some patches with low luminance and it may have problem to provide an accurate reading.
So if you use an inaccurate reading, this will provide later worse results.
Ideally you have to take volumetric measurements with each meter, this means you need 5-Point Cube measurements.
When you take 5-Point measurements means than you will measure with 4-Point of Luminance (25%, 50%, 75%, 100%)
Steve recommends to use a high-end spectro as you will measure patches not so bright.
For example, if you measure an OLED with 100 nits peak and native gamma 2.2:
The luminance levels of the Red patches will be:
100%: ~21 nits
75%: ~11 nits
50%: ~4,5 nits
25%: ~1 nit
The luminance levels of the Blue patches will be:
100%: ~7 nits
75%: ~4 nits
50%: ~1,6 nits
25%: ~0.4 nit
So using a better spectro, you will have better results.
But with i1PRO, I think you can try for the start the small cube, the 3-Point Cube.
Or export the 5-Point Cube patch to CVS file, open with excel and remove the lowest points (the 25%)....Steve can comment if this may work.
Rolls-Royce likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2373 of 2392 Old 10-05-2019, 12:03 AM
Anger.miki's Avatar
Quoted: 400 Post(s)
Liked: 418
As the owner of a i1 Pro 2 myself, I will test also this:
1) take 5 point cube profile with spectro and colorimeter (in my case a basICColor Discus)
2) export low luminance readings from the discus profile and correct them with FCCM (I have an excel spreadsheet to do that)
3) substitute critical low luminance readings into the spectro profile with those FCCM corrected at point 2)
That would solve the low budget spectro problem that this new feature could bring.
Question: if we want to verify our calibration, do we have to profile again probes after the TV is calibrated? A profile is not a Matrix so it will not “self-adapt” to the new TV state, right?
TVs: Pioneer PDP-LX5090H, LG OLED55C8PLA | SintoAmp: Pioneer VSX-921 | BD Player: Panasonic DMP-BDT260EG | External LUT box: Entertainment Experience eeColor | Softwares: Light Illusion Lightspace HTP, Portrait Displays CalMAN Home Enthusiast 2018 R3, HCFR, DisplayCAL | Probes: x-rite i1 Pro 2 - i1 Display Pro OEM B-02, basICColor DISCUS | Test Pattern Generator: DVDO AVLab TPG
Anger.miki is offline
post #2374 of 2392 Old 10-05-2019, 01:20 AM
aka jfinnie
Quoted: 2647 Post(s)
Liked: 1746
Seems like adding points back that you know would have errors due to FCCM vs WRGB OLED issues would likely be worse than having no points at all.
In my mind it seems that if you just don't have those suspicious points then the LUT interpolation to the closest workable values would give better results than FCCM.
mrtickleuk likes this.
bobof is online now
post #2375 of 2392 Old 10-05-2019, 03:35 AM
Light Illusion's Avatar
Quoted: 780 Post(s)
Liked: 1146
We (a user!) found a bug that had crept in, totally unrelated to the new Volumetric probe matching development.
Probe setting were not being saved!
Fixed version already uploaded.
Steve
Rolls-Royce and Manni01 like this.
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #2376 of 2392 Old 10-05-2019, 03:58 AM
Liked: 4055
LightSpace CMS 10.0.0.2988 (05 October 2019) has been released.
Release Notes
Fixed ‘save probe settings’ bug introduced in 10.0.2987.
Download Link: https://www.lightillusion.com/downloads.html
post #2377 of 2392 Old 10-05-2019, 05:15 AM
Anger.miki's Avatar
Quoted: 400 Post(s)
Liked: 418
Until we won’t test all, we won’t know what’s better.
bobof likes this.
post #2378 of 2392 Old 10-05-2019, 05:26 AM
Rolls-Royce's Avatar
Quoted: 1155 Post(s)
Liked: 1246
Steve
Steve, please check the download package or link that's being sent. I got 2987 again, and the download link is exactly the same as I received yesterday.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #2379 of 2392 Old 10-05-2019, 05:26 AM
Quoted: 780 Post(s)
Liked: 1146
Please refresh your browser cache...
Steve
Steve Shaw
LIGHT ILLUSION
post #2380 of 2392 Old 10-05-2019, 05:50 AM
Liked: 1246
Steve
That did it. What was strange about what I was seeing before was that the Changes pdf file reflected those changes for 2988 - I opened it - yet the installation folder was for 2987, and that's what it installed. Everything matches now.
Anger.miki likes this.
...Royce...
post #2381 of 2392 Old 10-06-2019, 12:58 AM
Anger.miki's Avatar
Quoted: 400 Post(s)
Liked: 418
Question: if we want to verify our calibration, do we have to profile again probes after the TV is calibrated? A profile is not a matrix so it will not “self-adapt” to the new TV state, right?
Anyone? Steve?
post #2382 of 2392 Old 10-06-2019, 01:15 AM
Quoted: 780 Post(s)
Liked: 1146
Sorry, I don't understand the question???
I have no idea what you mean by a 'Matrix' 'self-adapting'... makes no sense?
Steve
Steve Shaw
LIGHT ILLUSION
post #2383 of 2392 Old 10-06-2019, 02:32 AM
T( )( )L's Avatar
Quoted: 223 Post(s)
Liked: 114
Anyone figured out an .csv file cube yet for volumetric profiling without 25% lum and down (to be used for i1pro2/klein k-10) i cant figure out how to do it myself : )
Calman Enthusiast,Lightspace HTP,Klein K-10A,I1pro2,Murideo 6G.
T( )( )L is offline
post #2384 of 2392 Old 10-06-2019, 04:07 AM
jqmn's Avatar
Quoted: 433 Post(s)
Liked: 156
Display Calibration Tools (one word .com)-- Generated Grid_Remove Patches: No or below ___% Brightness
T( )( )L likes this.
jqmn is offline
post #2385 of 2392 Old 10-08-2019, 02:40 AM
Liked: 4055
LightSpace CMS 10.0.0.2989 (07 October 2019) has been released.
Release Notes
Added checks to Volumetric Probe Matching for invalid measurement data.
post #2386 of 2392 Old 10-08-2019, 04:28 AM
Liked: 4055
What cube file you have generated?
For example, do you want to remove the 25% from the a 5-Point Cube patchset?
post #2387 of 2392 Old 10-08-2019, 04:39 AM
Liked: 4055
The ‘Volumetric Probe Matching ‘ info has been updated to the various LightSpace website pages.
For Volumetric Probe Matching a profile will need to be cube based, or valid Quick Profile such as Primary Only, or Edge. (Volumetric Probe Matching will always work best with uniform profiles, not random ones)
Best results will be attained when the display peak white is set to be close to the target peak white. (Say, 100 nits for SDR calibration)
The Black Level of the display should also be raised to a level that both probes can read black consistently, without error. (Most probes can read around 1 nit accurately)
Profile the display with each probe in-turn as normal, with 'None' selected within the 'Active Probe/Display Data' options. (You should use a None/Bypass/Default pre-set within the Tristimulus, not a display specific matrix pre-set)
The profiles can be 'Characterisation' cube based profiles, or 'Quick Profiles'.
After profiling both probes, open the 'Manage Colour Space' library, and use 'Generate BPD' to convert the profiles into Probe Matching files.
The probe matching files can now be selected within the 'Active Probe/Display Data' drop-down menus within 'Options', exactly as for 4 colour matrix probe matching.
post #2388 of 2392 Old 10-08-2019, 06:31 AM
Anger.miki's Avatar
Quoted: 400 Post(s)
Liked: 418
Steve
Nevermind, at a first read of the new probe profiling feature I haven't read that it creates bdp from each profile.
post #2389 of 2392 Old 10-08-2019, 06:33 AM
Quoted: 780 Post(s)
Liked: 1146
Ah! no worries
Steve
Steve Shaw
LIGHT ILLUSION
post #2390 of 2392 Old 10-08-2019, 09:02 AM
T( )( )L's Avatar
Quoted: 223 Post(s)
Liked: 114
Yes Ted,is that doable? i have no time to test until weekend (maybe).
T( )( )L is offline
post #2391 of 2392 Old 10-08-2019, 09:57 AM
Quoted: 780 Post(s)
Liked: 1146
Removing patches will be unlikely to work.
The Volumetric Probe Matching requires a simple 'uniform' profile to be used.
As the User Guide info says, you will do better to just slightly raise the black of the display so both probes can read black.
Steve
Steve Shaw
LIGHT ILLUSION
post #2392 of 2392 Old 10-18-2019, 04:18 PM
Liked: 4055
LightSpace CMS 10.0.0.2996 (17 October 2019) has been released.
Release Notes
Added support for Postium displays with 3D LUT capability.
Fixed bug with Probe Matching followed by Luminance Min/Max measurement.
Added additional HDR slot Upload options to Kroma displays.
Reply Display Calibration
