MadVR - ArgyllCMS - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 592Likes
post #5041 of 5179 Old 01-18-2019, 10:43 AM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
@floe ch, i've just executed the process you specified:
1 - All dynamic features where already disabled
2 - Small profile without madTPG and without creating a 3D LUT
Spoiler!
Result:
3 - With madTPG, do the same:
Spoiler!
Result:
Creating the 3D LUT from this result and installed on madVR worked perfectly.
The only thing that i've changed, was to have the madTPG as small window, as opposed to full window (as i was working at the same time )
So i executed the exact same process i did yesterday, this time with madTPG as small window, and now it worked.
And then i did it again with the full window, and it also worked.
So basically, i did exact the same process as yesterday, but now everything worked ...
I'm clueless, but what meters is that its now working, and when i receive my HTPC next week, i will be able to do a 3D LUT.
Thank you very much for your help.
chros73 likes this.
neo_2009 is online now
post #5042 of 5179 Old 01-19-2019, 06:34 AM
Sittler27's Avatar
Quoted: 1127 Post(s)
Liked: 86
Originally Posted by chros73 View Post
No, if you want to use a 3dlut. If you have multiple presets in your projector, then leave the calibrated settings in one of them then use another for 3dluts.
The idea is this during creating a 3dlut:
- reset all the device settings back to default (using an available preset)
- only modify the necessary settings in your device (color gamut, black level (0-255, 16-235), gamma, etc)
- you only (!) modify the controls of 100% White in your device (R, G, B; by offsets) during interactive measurement
- DisplayCal/ArgyllCMS will do the rest
Got it, thanks.
Another question: does using a 3D LUT for HDR files via madvr consume considerably additional CPU power?
I seem to suddenly have dropped frames etc. playing files via madvr that were previously about 30-32ms rendering time, that now since using 3D LUT are dropping frames like crazy.
Sittler27 is offline
post #5043 of 5179 Old 01-20-2019, 04:22 AM
fhoech's Avatar
Quoted: 572 Post(s)
Liked: 377
Using the smallest possible patch size is always recommended. Many TVs cannot deal with full screen patterns. madTPG has a patch area slider for that reason.
neo_2009 and chros73 like this.
DisplayCAL - Display Calibration and Characterization powered by ArgyllCMS
Current stable version 3.8.2 released 2019-06-09 | Changelog
DisplayCAL on Facebook
fhoech is online now
post #5044 of 5179 Old 01-21-2019, 03:36 AM
chros73's Avatar
Quoted: 230 Post(s)
Liked: 101
It does, the question is how much. But you can easily test it: just "disable" the 3dlut in madvr by setting the display is already calibrated and set it back later to see the difference.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(04.10.25+PC4:4:[email protected]/24/25/29/30/50/59/60Hz)
chros73 is online now
post #5045 of 5179 Old 01-21-2019, 12:04 PM
Sittler27's Avatar
Liked: 86
Understood. I will test that out for the CPU.
As for the idea of creating 3DLUT, that's great for playback on my HTPC with madvr. But for playback of other content (satellite TV and Apple TV 4K for streaming services) I would still need to use some kind of calibration for those unless I'm just going to use what I did for the 3D LUT which would in essence be uncalibrated modes on the projector.
post #5046 of 5179 Old 01-22-2019, 06:21 AM
chros73's Avatar
Quoted: 230 Post(s)
Liked: 101
You are right, that's why I wrote that use a different preset in the TV
post #5047 of 5179 Old 01-23-2019, 06:51 AM
Onkyoman's Avatar
Quoted: 893 Post(s)
Liked: 548
Got it, thanks.
The 3D LUT is using the GPU that is shared for other madVR settings, not the CPU. I wouldn't think it would add another 7-9 ms to the rendering times, though. But maybe it is possible. Determine which queue in the OSD is empty when this happens for more information on the possible cause.
To make room for the 3D LUT, I would lower the value for chroma upscaling (e.g. NGU low or medium, or even Bicubic60 + AR).
Onkyoman is online now
post #5048 of 5179 Old 01-23-2019, 09:04 AM
mightyhuhn's Avatar
Quoted: 1140 Post(s)
Liked: 418
i get 20+ ms for the 3D LUT all the time.
2-8 ms is normal.
HDR->SDR conversation eats far more.
mightyhuhn is offline
post #5049 of 5179 Old 01-24-2019, 11:21 AM
Sittler27's Avatar
Liked: 86
2-8 ms is normal.
Yeah, I'm wondering if the 1070 is enough to do madvr + 3D LUT both fully on all settings. I think I may invest in a 1080 card.
post #5050 of 5179 Old 02-06-2019, 03:23 PM
Quoted: 17 Post(s)
Liked: 4
Hey guys, I want to make the best of my Pioneer Kuro PRO-101FD and it sounds like 3D LUTs are the way to go. I have an i1 Display Pro but I still don't understand the "profile" aspect. Can I do a 3D LUT calibration without needing a spectrometer? edit: Where can I find a "corrections" file for a 9.5G Pioneer Kuro?
zoglover is offline
post #5051 of 5179 Old 02-07-2019, 02:15 AM
chros73's Avatar
Quoted: 230 Post(s)
Liked: 101
Yes, you can.
There's a small search button beside of the correction dropdown box, where you can browse/search for it.
But note that who knows that it's good for your device. If you don't find any then use your i1 without it.
post #5052 of 5179 Old 02-07-2019, 09:14 PM
Quoted: 17 Post(s)
Liked: 4
Thanks for the reply. So you mean I should use the generic plasma profile from X-rite?
zoglover is offline
post #5053 of 5179 Old 02-08-2019, 01:36 AM
chros73's Avatar
Quoted: 230 Post(s)
Liked: 101
No, I meant this in DisplayCal:
post #5054 of 5179 Old 02-25-2019, 12:18 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
I'm getting this error when trying to generate a 3DLUT for madVR:
I have the following chain:
- LAV Filters - Use limited color range (16-235) -> (madVR) TV levels (16-235) -> KODI - Use limited color range (16-235) -> (GPU) Full Range RGB 0-255 -> (Display) Output as RGB 16-235
What am i missing?
post #5055 of 5179 Old 02-25-2019, 01:41 PM
mightyhuhn's Avatar
Liked: 418
download this image load it in madVR and tell me what you see.
http://www.lagom.nl/lcd-test/black.php
neo_2009 likes this.
post #5056 of 5179 Old 02-26-2019, 07:58 AM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
I'm sorry for the late reply.
The error was due a dumb mistake i made
My home theater has a velvet black tent, and i cannot see anything, so as i was testing ArgyllCMS, i has the lights ON, thus the black level error
post #5057 of 5179 Old 03-02-2019, 11:27 AM
Icaro's Avatar
Quoted: 108 Post(s)
Liked: 40
To create a 3DLUT with Displaycal for the projector Epson laser LS10000/LS10500, what is better to select in "Mode" ?
LCD (Generic),
LCD (Hi Res),
or Refresh... ?
Sorry for my bad English
Epson LS10500 - AMD RX580 - LightSpace CMS
Icaro is online now
post #5058 of 5179 Old 03-04-2019, 02:17 AM
Icaro's Avatar
Quoted: 108 Post(s)
Liked: 40
Hi, I created a 3DLUT,
I have a problem with "Applly calibration (vcgt)"
with vcgt active the 3DLUT seems to apply a "green filter"
Here Profile+Log:
http://s000.tinyupload.com/index.php...75358773566973
3DLUT vcgt ON
http://oi66.tinypic.com/1zpqm4z.jpg
3DLUT vcgt OFF
http://oi68.tinypic.com/drfdb6.jpg
Icaro is online now
post #5059 of 5179 Old 03-08-2019, 08:57 AM
fhoech's Avatar
Quoted: 572 Post(s)
Liked: 377
If you don't apply the calibration to the 3D LUT, the result will be incorrect (in your case, too blue).
post #5060 of 5179 Old 03-09-2019, 10:56 AM
Icaro's Avatar
Quoted: 108 Post(s)
Liked: 40
Ok, but if you see,
why does the calibration turn to green?
Icaro is online now
post #5061 of 5179 Old 03-11-2019, 07:17 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
@fhoech , If i'm understanding the "Advanced Options" correctly (please see below), users that have the following chain, should use the '-E' switch:
- (3) Display wants 16-235. GPU is set to 0-255. madVR is set to 16-235.
Originally Posted by N3W813 View Post
Notes/Advanced Options
Parameter '-E' Usage ScenariosQuote:Originally Posted by madshi
There are 3 possible HTPC level configurations, when using madVR:
This is the recommended setup for best image quality if your display can't do 0-255. This setup results in banding-free madVR image quality. However, levels for desktop and games will be incorrect, because desktop and games will render black at 0,0,0, while the display expects black at 16,16,16. This is a problem for ArgyllCMS, because Argyll will create test patterns with black at 0,0,0, and the display will also receive these at 0,0,0. So basically Argyll test patterns will have wrong levels, which will screw up the whole calibration.
It is my understanding that Graeme implemented the -E switch specifically for (3) ...
So my understanding is that -E should be used only for (3) and in no other situation. If you use the -E switch for (1), Argyll will create test patterns with black at 16,16,16 which would be incorrect!
I assume that when using DisplayCal, we would need to set this via:
- Options -> Advanced -> Set Additional command Line Arguments
And set the -E switch on dispcal:
Is this correct?
post #5062 of 5179 Old 03-12-2019, 01:47 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
When using the above option (dispcal -E), i'm getting the following error:
This is from the Logs:
Spoiler!
My chain is: Optoma HD87 16-235, RTX 2060 set to 0-255, madVR is set to 16-235.
Without the -E switch, it works correctly.
Am i missing anything?
post #5063 of 5179 Old 03-12-2019, 03:13 PM
fhoech's Avatar
Quoted: 572 Post(s)
Liked: 377
Originally Posted by Icaro View Post
Ok, but if you see,
The calibration makes the grayscale have the same hue as the whitepoint. If your whitepoint looks greenish to you (reasons for this can include using an unsuitable colorimeter correction or measurement mode, or metameric failure i.e. your colorimeter "sees" a neutral color where you perceive a tint), then you can calibrate to a different whitepoint that looks neutral to you.
So what is not clear about the error message?
post #5064 of 5179 Old 03-12-2019, 03:47 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
From your response i assume that the -E switch is correct.
Regarding the error message, i don't understand what i need to do regarding: "Video encoding requested for MadVR display - use MadVR to set video encoding".
Is this a configuration in madVR i need to change?
I have the levels configured in madVR as:
post #5065 of 5179 Old 03-12-2019, 05:15 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
After reading the Optoma Manual, there is a black level setting.
As such, i can use a full 0-255 chain, so i no longer need the -E parameter.
Thank you.
post #5066 of 5179 Old 03-13-2019, 12:20 PM
fhoech's Avatar
Quoted: 572 Post(s)
Liked: 377
Thank you.
You cannot use the -E parameter with madVR (madTPG). When using madVR, it deals with the output range via its own settings. That's why I was asking what was unclear about the error message.
post #5067 of 5179 Old 03-13-2019, 03:25 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
I'm not a native speaker, and sometimes i might miss some language nuances
Thank you for clarifying.
post #5068 of 5179 Old 03-13-2019, 03:44 PM
fhoech's Avatar
Quoted: 572 Post(s)
Liked: 377
Me neither :-) Currently I'm just passing through some of the less common error messages from ArgyllCMS in DisplayCAL, i.e. those are also not localized. To me it is always interesting to know whether or not error messages transport enough information for the end user.
You're welcome.
post #5069 of 5179 Old 03-13-2019, 04:29 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
I've performed a Video 3DLUT calibration for madVR on an Optoma HD87, using an I1 Display 2 Colorimeter, using a 35m profiling sequence (833 patches).
According to this Optoma HD87 review:
Next is Colour Gamut and we have a choice listed based on industry standards. First up we have native which is the natural colour gamut of the projector which is almost identical to the DCI standard for digital cinema
The reviewer recommend the use of the Native mode for calibration, which i use here.
This was the result from DisplayCal:
The CIE chart without 3DLUT applied:
Spoiler!
The CIE chart with 3DLUT applied:
Spoiler!
Is it possible to improve the result?
1. By using a larger number of patches?
2. By using the HDTV (Rec.709) Colour Gamut on the Optoma?
post #5070 of 5179 Old 03-13-2019, 04:36 PM
neo_2009's Avatar
Quoted: 309 Post(s)
Liked: 225
If you allow me the suggestion, on this specific error:
Video encoding request for madVR display - use MadVR to set video encoding.
Wouldn't the following description be more informative to the end user?
-E parameter cannot be used with madVR (madTPG)
Reply Display Calibration
