Spectracal C6 meter - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By ConnecTEDDD
  • 1 Post By Franin
  • 1 Post By Rolls-Royce
  • 1 Post By chmiel2k
post #1 of 10 Old 10-11-2014, 01:07 AM - Thread Starter
Franin's Avatar
Quoted: 3048 Post(s)
Liked: 1998
Spectracal C6 meter
Hey all
Just curious are these meters meant to be updated every now and then? If so where can I update them?
_________________________
God Bless,
Franin is offline
post #2 of 10 Old 10-11-2014, 08:11 AM
Rolls-Royce's Avatar
Quoted: 1047 Post(s)
Liked: 1173
There is nothing user-updatable. Spectracal can recertify the meter and add new tables as they become available.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3 of 10 Old 10-11-2014, 08:17 AM - Thread Starter
Franin's Avatar
Liked: 1998
God Bless,
Franin is offline
post #4 of 10 Old 10-11-2014, 08:48 AM
ConnecTEDDD's Avatar
Quoted: 2921 Post(s)
Liked: 3569
Hey all
Hi, SpectraCAL is periodically adding new tables for C6 users. These tables are added by installing the latest version release of CalMAN 5, for example:
CalMAN 5.3.0
Added a blue/green LED table for SpectraCal C6 colorimeters.
CalMAN 5.1.1
Added support for the DCI/P3 Gamut (CCFL) target display type for the C6 meter. This is for the FSI monitors.
CalMAN 5.0.3
Added Direct Drive OLED table for the SpectraCal C6 colorimeter.
Franin likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #5 of 10 Old 10-11-2014, 08:49 AM - Thread Starter
Franin's Avatar
Liked: 1998
CalMAN 5.3.0
CalMAN 5.1.1
CalMAN 5.0.3
ConnecTEDDD likes this.
God Bless,
Franin is offline
post #6 of 10 Old 07-05-2019, 09:06 AM
Liked: 1
Hi!
Just received second hand C6 and getting hard times trying to install it on my win10 PC. Just after pluging it, I'm getting "USB device not recognized". In device menager it's listed in "Universal Serial Bus controlers" as "Unknown USB Device (Device Descriptor Request Failed)". Trying different USB prots, my first colorimeter, X-Rite i1Display works on the same ports. I also have Calman Driver Pack Installed but when trying to install drivers manually, can't see it on the drivers list. Maybe I should looking for some different name? Photos attached. Thanks!
ID:	2587804   Click image for larger version
ID:	2587806   Click image for larger version
chmiel2k is offline
post #7 of 10 Old 07-05-2019, 10:48 AM
Liked: 1173
Originally Posted by chmiel2k View Post
Hi!
It uses the same Windows system "HID" (Human Interface Device) drivers as the I1 Display Pro. If you have X-Rite software such as I1 Profiler installed, check if the X-Rite Device Services Manager is running. If it is, try turning it off, as it can block CalMAN's access to the meter. The other possibility is that the meter itself is bad.
chmiel2k likes this.
...Royce...
post #8 of 10 Old 07-05-2019, 11:35 AM
Liked: 1
No X-Rite software installed, it was plug&play for my i1 Display Pro. So I will try it with another PC and if it's still dead, I'm gonna contact the seller.
Thanks a lot!
Rolls-Royce likes this.
chmiel2k is offline
post #9 of 10 Old 07-05-2019, 12:06 PM
Liked: 1173
Thanks a lot!
Good luck!
...Royce...
post #10 of 10 Old 07-06-2019, 12:48 PM
WiFi-Spy's Avatar
Quoted: 1363 Post(s)
Liked: 2015
Hi!
I would ask for a refund. This is typically what happens when the USB cable is damaged.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
Reply Display Calibration
