New Color Measurement Tool - ArgyllPRO ColorMeter - AVS Forum | Home Theater Discussions And Reviews
 11Likes
  • 4 Post By gwgill
  • 1 Post By WiFi-Spy
  • 3 Post By Steffen Goerlich
  • 2 Post By gwgill
  • 1 Post By gwgill
post #1 of 18 Old 10-28-2014, 03:42 PM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
After over 2 years of development, I'm pleased to announce the release
of the ArgyllPRO ColorMeter application.
ArgyllPRO ColorMeter is an Android application that lets you use all your USB connected color measurement instruments on the go. If you need to measure light or color in Printing, Photography, Lighting, Graphic Design, TV, Film or Video, then you will want to check it out.
For complete product details, please see the ArgyllPRO website.
gwgill is offline
post #2 of 18 Old 10-28-2014, 04:20 PM
WiFi-Spy's Avatar
Quoted: 1781 Post(s)
Liked: 2383
Works with Galaxy Note 4 + OTG Cable & Retail i1D3
gwgill likes this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3 of 18 Old 02-28-2015, 01:46 PM
Steffen Goerlich's Avatar
I tested ArgyllPro in detail and found it a very powerful color measuring tool, for display measurement as well as for other color applications. It allows to measure almost all known colorimetric values and color differences. 8 gamut definitions are included, the graphics can be tuned with different options and the operation is very intuitive.
The test was done with a JETI 1211. The app connected very fast to the probe and also the speed of the measurement including the adaption of integration time is very high.
The result of my test is that ArgyllPro is a very versatile and useful tool for mobile color measurement.
Steffen Goerlich is offline
post #4 of 18 Old 03-01-2015, 05:49 PM
Quoted: 1709 Post(s)
Liked: 738
Does this app have the ability to generate patterns, access patterns in external pattern generators or do you manually display the necessary patterns in your pattern source?
JimP is offline
post #5 of 18 Old 03-02-2015, 03:37 AM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
The current version depends on an external source (i.e. a test disk, or some other signal generator you can use), if you want to measure or adjust TV/Video.
I do have in mind something to add signal generation capability in a future release :-)
gwgill is offline
post #6 of 18 Old 03-03-2015, 12:41 PM
N3W813's Avatar
Quoted: 48 Post(s)
Liked: 84
Cool app Graeme, now I just need to find an Android device to play with...
Question, I went to the website and went through the documentation but I didn't find anything on creating a meter offset. Ie. profiling an i1D3 to an i1Pro2.
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #7 of 18 Old 03-03-2015, 04:38 PM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
This is not a capability of the current version of ColorMeter, but of course you can create .ccmx and .ccss files using ArgyllCMS and DispcalGUI and uploading them to Colormeter. See here for how to do this with the OEM files, or for single files you can dump them in the Downloads folder on Android - see here.
It's certainly crossed my mind to add a feature to allow creating .ccmx and .ccss files using ColorMeter, but to be practical it would depend on having a connected signal generator, and I'm not quite sure how it would work from a UI point of view. Priority of such a feature will depend on feedback (thanks for yours!), and how popular the application becomes amongst display measurement users.
gwgill is offline
post #8 of 18 Old 03-03-2015, 07:14 PM
Liked: 738
So if you have a Klein K10, will you be able to access the profiles in it's memory locations?
Thinking here is I can use chromasurf to generate profiles and put these profiles into the K10 memory for ColorMeter to use.
I have a Google Nexus 7 coming from Amazon which should be here tomorrow. Looking forward to giving ColorMeter a spin.
JimP is offline
post #9 of 18 Old 03-03-2015, 08:41 PM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
Yes, they show up in the Display Type spinner.
I'll be updating the app in the next week or so to fix some bugs & improve accessibility.
gwgill is offline
post #10 of 18 Old 03-22-2015, 06:45 PM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
ArgyllPRO ColorMeter V1.1 Released.
I'm pleased to announce the release of ArgyllPRO ColorMeter Version 1.1.
http://www.argyllpro.com.au
This version features greatly improved accessibility with the introduction of
application area Presets, and an accompanying demonstration Video:
There is better Android V5 (Lollipop) compatibility and numerous other
bug fixes and improvements.
ConnecTEDDD and fhoech like this.
gwgill is offline
post #11 of 18 Old 06-28-2015, 05:50 AM
Liked: 738
Any progress in this area such as a chromecast function?
JimP is offline
post #12 of 18 Old 06-28-2015, 04:05 PM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
I'm still working towards it - there are a couple of new instruments and other changes in the pipeline ahead of it.
(The functionality is present in ArgyllCMS V1.7).
gwgill is offline
post #13 of 18 Old 08-20-2015, 05:01 AM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
ArgyllPRO ColorMeter V1.2 Released.
V1.2.0 includes ChromeCast support.
See http://www.argyllpro.com.au for more details of the release.
JimP likes this.
gwgill is offline
post #14 of 18 Old 11-16-2015, 09:04 AM
fhoech's Avatar
Quoted: 582 Post(s)
Liked: 386
Works nicely with OnePlus X smartphone and 3rd party OTG cable. Tested i1D3 (i1 DisplayPro), i1D2 and Spyder5.
DisplayCAL - Display Calibration and Characterization powered by ArgyllCMS
Current stable version 3.8.9.3 released 2019-12-14 | Changelog
DisplayCAL on Facebook
fhoech is offline
post #15 of 18 Old 11-16-2015, 09:58 AM
CalWldLif's Avatar
Quoted: 339 Post(s)
Liked: 85
amazing that phone battery could drive the spectros
Loving D65
CalWldLif is offline
post #16 of 18 Old 03-11-2020, 02:08 PM
Iron Mike's Avatar
Quoted: 146 Post(s)
Liked: 481
Graeme,
are you ever gonna add support for the CRI meters ? (at least the spectros)
And, is it possible to save the spectrum to the device ?
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools, Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
meter: CR-300, Klein K-10 A, i1Pro 2, i1D3
Iron Mike is offline
post #17 of 18 Old 03-11-2020, 05:53 PM - Thread Starter
gwgill's Avatar
Quoted: 384 Post(s)
Liked: 276
Only if they are interested in having support. Buying one of their meters and RE'ing the USB protocol is outside my financial and time constraints.
SDK's for desktop platforms don't provide a solution for Android, and I can't say something works if I haven't tested it.
Bottom line - they don't appear to be interested in support for their instruments. Go talk to them about it.
[ In distinct contrast, Klein and JETI have provided the necessary support to make this happen. So buy one of their instruments instead! ]
Unfortunately not at present. It's something I revisit every time I prepare a new release since a number of people have requested this, but I'm struggling to allocate any time to it at the moment.
Author of ArgyllCMS and ArgyllPRO ColorMeter
gwgill is offline
post #18 of 18 Old 03-11-2020, 06:10 PM
Iron Mike's Avatar
Quoted: 146 Post(s)
Liked: 481
have Klein and CRI spectro and also i1Pro 2... need spectrum files from CRI or i1Pro 2 saved to device.
CRI has their own, free Android app, but have not yet included the feature to save measured spectrum to device. Btw, X-Rite's free ColorTrue Android app does also not yet have that feature.
Yours is a commercial app, hence a feature like that would be a reason to buy the app !
Re meter support: you need to get after that, but it seems your not interested... ;-)
Reply Display Calibration
