Calman MobileForge for External Displays- Can it really be? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #61 of 215 Old 08-12-2015, 03:21 PM
WiFi-Spy's Avatar
Quoted: 1157 Post(s)
Liked: 1759
Originally Posted by mac1guru View Post
One more quastion, the Fire TV Stick is it correct with that device also?
And is the MobileForge application installed directly to the stick?
The FireTV/FireTV Stick doesn't have the color gamut error like some other devices. Yes, MobileForge app runs directly on the FireTV/stick itself, so no mirroring from any other device. You can search for "MobileForge" in the FireTV app store to find the app.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #62 of 215 Old 08-12-2015, 03:35 PM
mac1guru's Avatar
Quoted: 75 Post(s)
Perfect, then I'll order one right away.
SpectraCal CalMan 5.5.2 Enthusiast @ Windows 10
i1Display Pro
MobileForge @ Amazon Fire TV stick & AppleTV 3
DVE Bluray / AVSHD709 / Ted's LightSpace CMS Calibration Disk
Samsung UE48H6275 (XXE) European model)
Playstation 4 / AppleTV 3 / iPad Air 2 (128GB) / iPhone 6 (16GB)
mac1guru is offline
post #63 of 215 Old 08-13-2015, 03:19 PM
mcjimsey's Avatar
Liked: 27
Using Airplay Mirroring to the AppleTV is the best option, as the HDMI-Lightning adapter has larger than acceptable gamut errors that are not there when you use the AppleTV.
I spoke w Joel Barsotti @ SpectraCal & confirmed that the Lightning to HDMI adaptor has a large Gamut error. I tried it myself and the error w the adaptor on My Panasonic 65ZT60 had the CMS controls maxed out on Cyan and Yellow (And we all know how well Panny's ZT series dials in ) so Apple TV is the way to go. I'm going to pick one up.
Bob
mcjimsey is offline
post #64 of 215 Old 08-15-2015, 06:21 AM
FastM's Avatar
I'm a very new Calman user that tried calibrating my P55VT50 last night using the Lightning>HDMI adapter with my iPhone 6 and had a lot of trouble.
Among the other problems I had which I'll start another thread about (or keep searching) I'm guessing I was being affected by this problem as well.
I bought the HDMI adapter yesterday so I can recently return it.
Which is the #1 hardware choice to run MF for calibrating a plasma.
Fire TV, ATV, Chromecast? Something else? ( the fire TV seems interesting as it de-complicates the setup slightly and is smaller in general)
FastM is offline
post #65 of 215 Old 08-15-2015, 07:39 PM
WiFi-Spy's Avatar
Liked: 1759
I think the FireTV Stick is the easiest for your setup. You can PM me if you need any VT50 CalMAN related tips.
WiFi-Spy is offline
post #66 of 215 Old 08-16-2015, 08:20 AM
FastM's Avatar
Thank you! That was the answer I was hoping for.. I actually picked up a FireTV Stick already and will make another attempt tonight. Hopefully will go better but I will definitely be putting together a shopping list of questions for you at one point, thanks for the help.
Another question, since the FireTV bypasses a mobile device, should we not be checking the "Expand Video to PC levels" under the Source settings tab? And then leave the Workflow basic options to "Video (16-235)"
I was also wondering where the "Expand Built-in Patterns to PC levels" fits in under the Application Preferences tab? (my guess is it applies to that button next to the controls in the bottom right and since the mobileforge app has limited built in patterns its not important at the moment?)
FastM is offline
post #67 of 215 Old 08-16-2015, 08:35 AM
mcjimsey's Avatar
Liked: 27
Bob
Picked up the Apple TV and everything fell into place so if your going to use iOS DON'T use the Lighting to HDMI adaptor. Apple TV mirroring worked perfect!
Also downloaded the latest CalMan5 update and the "Expand to video levels" is checked by default now, Nice!
Bob...
mcjimsey is offline
post #68 of 215 Old 09-08-2015, 03:03 PM
ConnecTEDDD's Avatar
Quoted: 2901 Post(s)
Liked: 3490
Originally Posted by sotti View Post
The output gets compressed, so you need to check that if you're running video levels via the output device..
Since Mobile Forge is compressing 0-255 to 16-235, how you suggest to adjust Brightness, because the below black will not be visible (1-15), for example if one user will add +5 to his Brightness to see the 17 Flashing bar the same time he will have lift his black but he will not be able to notice this because 1-15 will be black... When we will playback later a movie from his player he will have a problem, a problem that will be no visible with Mobile Forge.
How do you check also the Above Reference White Clipping or Color Luminance Clipping?
Since it will not be possible to see 236-254, If you set your Contrast by checking that the near the 100% White the bars are flashing and you have no clip....if you later load a Contrast Pattern with Flashing Bars, the above reference white bars will clip or have pink shade etc... since you are able to check for clipping only the levels below 235 and not above 235.
Do you suggest the user to use a calibration disk to set Contrast/Brightness/ Check for Color Clipping and later use Mobile Forge only as a patch color generator?
Setting Contrast-Brightness accurately before starting calibration is the first priority tasks before starting a calibration, what's your view/solution you suggest about these issues?
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #69 of 215 Old 09-08-2015, 03:53 PM
Quoted: 4205 Post(s)
Liked: 1497
Ted,
I haven't found it essential to be able to see BTB during brightness setting. Using your example, if the users sees 17 flashing at +5 for Brightness Control, he should reduce the Brightness one step at a time until 17 cannot be seen (e.g., at +2), and then go back up to the previous step (+3).
While it is possible that 15 would also be visible at +3 (which the user would not know due to lack of BTB), that is still the best setting as +2 would be too low. In addition, he can also check that the black level is not lifted at +3.
Just my 2 cents.
Dominic Chan is offline
post #70 of 215 Old 09-08-2015, 04:12 PM
Liked: 3490
Originally Posted by Dominic Chan View Post
Ted,
Just my 2 cents.
The most of the users, since there is no guidance to see which settings of their Brightness slider is the correct, they will choose the one that may not correct. One will choose for example the +2 setting, the other user the +3 etc....while the correct one can be only the +1 or Zero.
About Contrast is a problem also, since they can't see when they have above white clipping.
I don't think the users that will move to that Mobile Forge solution is calibration experts to do further tests. They will choose that solution because it will be simpler from them to use.
post #71 of 215 Old 09-08-2015, 04:29 PM
Liked: 1497
Not if you use the approach I was describing. You would end up with the same setting, regardless of whether you can see BTB or not; i.e., BTB is not the only guidance available to the user. Using the previous example, if 17 is not visible at +2, how can +1 or 0 be the correct setting?
post #72 of 215 Old 09-08-2015, 04:36 PM
Liked: 3490
There displays where the 17 is very very barely visible, most of the users will think that is not the correct setting....but if you add another one brightness value, then the 16 is flashing too. This forces to wrong decisions.
How about the above reference white? Most of the displays will not clip below 234 when you have the contrast at max value.
post #73 of 215 Old 09-08-2015, 09:10 PM
Liked: 1497
If you're postulating that some users do not see the dim 17 at level 0, then the same users may also not see the dim 16 at the +1 level. These subjective approaches can always be confirmed by the measurements of the black level, i.e., the Brightness should be set such that the black level is not elevated.[EDIT: Typo corrected as pointed out by ConnecTEDDD]
post #74 of 215 Old 09-08-2015, 09:25 PM
WiFi-Spy's Avatar
Liked: 1759
MobileForge's main feature is automated pattern switching. If MobileForge was my only pattern generator, I would use a test disc to set my brightness , contrast, and sharpness.
Rolls-Royce and SpenceMan01 like this.
WiFi-Spy is offline
post #75 of 215 Old 09-09-2015, 12:21 AM
Liked: 3490
Modern LED's will deactivat their backlight when you will display a full field black pattern, so it always measure 0 cdm/2. These ideas are known for expert calibrations, you will still need a calibration disk to check Contast/Brightness/Color Clipping etc.
the contrast should be set such that the black level is not elevated.
You mean bightness, not contrast.
post #76 of 215 Old 09-09-2015, 12:27 AM
Liked: 3490
100% Agree with this, to use a calibration disk to do the basic calibration work Contrast/Brightness/Clipping/Sharpness and then use Mobile Forge for all the patch generation work with measurements.
jrref likes this.
post #77 of 215 Old 09-10-2015, 11:50 AM
Quoted: 4058 Post(s)
Liked: 4797
And the FireTV is cheaper that purchasing the Apple hdmi adaptor!
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G
Calman Ultimate, ISF Level III Certified
jrref is offline
post #78 of 215 Old 09-10-2015, 12:14 PM
Quoted: 1708 Post(s)
Liked: 735
Is MobileForge usable in LUTs calibration?
If so, how does its speed compare to hardware pattern generators?
JimP is offline
post #79 of 215 Old 09-21-2015, 05:22 PM
Liked: 735
Well?
JimP is offline
post #80 of 215 Old 09-21-2015, 06:10 PM
sotti's Avatar
Quoted: 339 Post(s)
Liked: 342
Well?
It's really fast, but it only can measure between 16-235.
sotti is offline
post #81 of 215 Old 09-22-2015, 06:27 AM
Liked: 4797
I also found that if you use MobileForge on the Fire TV stick, you need to go into the Display settings on the stick and change the video setting from Auto to 1080P/60Hz before you launch MobileForge. If it's set to Auto, the grayscale levels will be high.
John
jrref is offline
post #82 of 215 Old 09-23-2015, 02:15 PM
mac1guru's Avatar
Quoted: 75 Post(s)
Amazon are releasing a new Amazon Fire tv with 4K support (UHD) I do hope that spectracal are going to make a 4K MobileForge application for it
i1Display Pro
mac1guru is offline
post #83 of 215 Old 10-01-2015, 06:15 AM
mac1guru's Avatar
Quoted: 75 Post(s)
I did get a answer from spectracal and MobileForge should work as a 4K pattern generator directly on the Amazon Fire tv 4K.
i1Display Pro
mac1guru is offline
post #84 of 215 Old 10-13-2015, 09:15 AM
kkpro's Avatar
Quoted: 194 Post(s)
Liked: 92
I wonder if that is my problem
I noticed that using the internal patterns of my JVC projector agreed with the AVCHD disc but not with the Fire Stick/Mobile Forge patterns. I will try this setting and see if that is my problem.
ConnecTEDDD likes this.
kkpro is offline
post #85 of 215 Old 10-20-2015, 10:10 AM
Liked: 735
I'm having a problem with gambit using chromecast. Anyone else seeing this? I posted about this on the spectracal forum didn't get a response.
JimP is offline
post #86 of 215 Old 10-20-2015, 12:43 PM
WiFi-Spy's Avatar
Liked: 1759
The chrome cast is only accurate for Grayscale currently. The Amazon FireTV stick is correct for both Grayscale and Color Gamut and any other RGB triplet you want.
WiFi-Spy is offline
post #87 of 215 Old 10-30-2015, 04:40 PM
neogeosnk's Avatar
Quoted: 12 Post(s)
Has anyone tested the Nvidia Shield TV? I sideloaded mobileforge and it seems to work, but not sure how accurate it is.
neogeosnk is offline
post #88 of 215 Old 11-02-2015, 04:28 PM
WiFi-Spy's Avatar
Liked: 1759
I would compare it to a pattern disc by measuring 70% and 100% white patches to see if the luminance is the same from both.
WiFi-Spy is offline
post #89 of 215 Old 11-03-2015, 05:31 AM
bankroot's Avatar
Liked: 7
When can we suppose full funcionality via Chromecast ?
bankroot is offline
post #90 of 215 Old 11-16-2015, 06:34 AM
bankroot's Avatar
Liked: 7
Hi,
I can see that you have Fire Stick and I suppose that you use it for mobile forge PG.
Have you ever calibrate any display using this tandem ?
Is it accurate both for grayscale and gamut CMS ?
Did you compare it with Ted's disk running from your PS4 ?
thank you in advance for your answer
bankroot is offline
Reply Display Calibration
