JETI Spectraval VIS Spectroradiometers Announced - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #1 of 34 Old 07-09-2015, 05:26 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 3002 Post(s)
Liked: 3701
JETI has announced the addition of 2 new Spectroradiometers to the JETI probes family.
These meters has been demonstrated already at Laser World of Photonics exhibition @ Munich (22-25 Jun 2015) and they they will be available @ IBC 2015, The World's Premier Broadcast Technology Event @ Amsterdam (11-15 September 2015). I will update this thread about any further news / availability / pricing once they will be available.
JETI's Spectraval is a compact spectroradiometer for the visible spectral range.
It is available in a version without display (1501) and one with display (1511).
Both can be used for spectral Radiance measurement with a measuring angle of 2°.
The actual measuring area is marked by a red circle.
Advantages:
Compact solutions
Fast measurement
Precise results due to high quality
spectrograph and NIST traceable calibration
Comfortable handling due to Bluetooth connection
Examples for applications:
Calibration of broadcast monitors
Color adjustment of digital projectors
Measurement of LED displays
Spectraval 1511 can be operated in stand alone mode or in connection with a computer.
Spectraval 1511 displays the following values:
Luminance, Radiance
xy and u´v´ coordinates, RGB values
Dominate wavelength, color purity
Correlated Color Temperature
Color Rendering Index
Radiometric spectrum
Spectraval 1501 always needs a computer, but can be used with several special programs, e.g. for monitor calibration.
Specifications
Optical parameters
Spectral range: 380 ... 780 nm
Optical bandwidth: 4.5 nm
Wavelength resolution: 1 nm
Digital electronic resolution: 16 bit ADC
Viewing angle: 1,8°
Measuring distance/diameter: 20 cm - 6 mm; 100 cm - 31 mm
Measuring values Spectral Radiance
Total luminance / total Radiance
Chromaticity coordinates x,y; u’,v’
Correlated Color Temperature, color purity
Color Rendering Index, RGB and other
Measuring ranges and accuracies
Measuring range luminance: 0.1 ... 150 000 cd/m2 (Ill. A) / 0.1 … 100 000 cd/ m2 (typical white LED)
Luminance accuracy: 2 % (@ 100 cd/m2 and Ill. A)
Luminance repeatability: 1 %
Chromaticity accuracy: 0.002 x, y (Ill.A)
Color repeatability: 0.0005 x, y (Ill.A)
CCT repeatability: 20 K (Ill.A)
Wavelength accuracy: 0.5 nm
Other technical data
Dispersive element: Imaging grating (flat field)
Light receiving element: CCD line array 2048 pixels (binned)
Power supply: Battery and USB powered
Interface: USB 2.0 fullspeed, specbos 1501 optional with LAN
Dimensions: spectraval 1501 140 mm x80 mm x 70 mm / spectraval 1511 140 mm x115 mm x 70 mm
Weight: spectraval 1501 400 g / spectraval 1511 500 g
Operating conditions Temperature: 10 ... 40 °C
Humidity: < 85 % relative humidity at 35 °C
Accessories (included): PC software JETI LiVal for Windows 7/ 8/ XP/ Vista, DLL’s, USB cable and trigger connector, Calibration certificate, operation instructions, Tripod, transport box, Calibration NIST traceable
Recommended interval: 1 year
Chad B, W3Rman, turbe and 1 others like this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #2 of 34 Old 07-09-2015, 05:57 AM
Chad B's Avatar
Quoted: 692 Post(s)
Liked: 1575
I like the small form factor!
Sent from my SM-G900V using Tapatalk
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS540, JVC RS3000, Sony VPL-VW695ES
Copied settings measured, Review archive
Chad B is online now
post #3 of 34 Old 07-09-2015, 05:59 AM - Thread Starter
Liked: 3701
Hi Chad, it's not that small as it seems at the picture, look the dimensions and compare them with your 1211 dimensions to see
post #4 of 34 Old 07-09-2015, 07:50 AM
Rayjr's Avatar
Quoted: 198 Post(s)
Liked: 241
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Rayjr is offline
post #5 of 34 Old 07-09-2015, 07:55 AM
Chad B's Avatar
Quoted: 692 Post(s)
Liked: 1575
Ah, you're right! 140x80x70 mm and 400 g for the 1501 vs. 180x82x53 mm and 450 g for the 1211.
Looking at the specs, it appears that the only differences are spectral range and possibly chromacity accuracy, in the 1211's favor. The light receiving element is listed as "binned" on the new units, but not the 1211.
It will be interesting to find out the pricing once that is made available.
post #6 of 34 Old 07-09-2015, 08:12 AM - Thread Starter
Liked: 3701
There differences at measuring luminance range for the new units.
For 1211 is 0.1 - 2500 cd/m²
For 1511 is 0.1 - 150.000 cd/m²
As we know that kind of max luminance capabilities of 1511 are a lot higher from any peak luminance required for any calibration, so that difference it's not that important of our usage.
BTW, JETI's 1211 measuring range in Radiance mode can be shifted to higher intensities by external attenuating filters, mounted in a cap to be attached to the instrument.
Here are the available filter options:
with OD 0.5 Filter: 0.4...10 000 cd/m²
with OD 1.0 Filter: 1...25 000 cd/m²
with OD 1.3 Filter: 2...50 000 cd/m²
with OD 1.5 Filter: 3...75 000 cd/m²
with OD 2.0 Filter: 10...250 000 cd/m²
post #7 of 34 Old 07-09-2015, 08:17 AM - Thread Starter
Liked: 3701
Originally Posted by Rayjr View Post
How much?
Hey Ray, hasn't announced yet. I will update when I will have that information
post #8 of 34 Old 07-09-2015, 08:29 AM
Rayjr's Avatar
Quoted: 198 Post(s)
Liked: 241
Rayjr is offline
post #9 of 34 Old 07-09-2015, 03:33 PM
buzzard767's Avatar
Quoted: 1668 Post(s)
Liked: 2459
Thanks Tedd
I'm interested as well. I suspect I'll appreciate better accuracy than my i1Pro with the new technology displays.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #10 of 34 Old 07-09-2015, 08:47 PM
Quoted: 1709 Post(s)
Liked: 738
Ted,
Do you know how synching is handled....meaning is it automatic or do you have to enter the value manually?
JimP is offline
post #11 of 34 Old 07-10-2015, 04:36 AM - Thread Starter
Liked: 3701
Originally Posted by JimP View Post
Ted,
Hi Jim, this is handled by the software, for example with CalMAN, you can select to have a fixed refreshing rate (when you will initialize the meter) or to choose to scan for refreshing rate before each meter read. You can enter also manually any value.
post #12 of 34 Old 08-28-2015, 10:42 AM - Thread Starter
Liked: 3701
JETI will present their new Spectraval 1501 spectroradiometer @ IBC 2015, The World's Premier Broadcast Technology Event @ Amsterdam (11-15 September 2015).
The retail prices for these news meters will be:
5.500 Euros for JETI Spectraval 1501
7.000 Euros for JETI Spectraval 1511
post #13 of 34 Old 08-30-2015, 02:00 AM
Andreas21's Avatar
Quoted: 1133 Post(s)
Liked: 729
I am going for a 1501.
ConnecTEDDD and rachmat-d like this.
Andreas21 is offline
post #14 of 34 Old 08-30-2015, 03:03 AM
Liked: 738
How much does the annual recertification cost?
JimP is offline
post #15 of 34 Old 09-17-2015, 11:12 AM - Thread Starter
Liked: 3701
SpectraCAL had at their IBC booth the new JETI 1501.
Chad, here at this picture you can see it's actual size compared to a JETI 1211 (with blue case)
post #16 of 34 Old 12-19-2016, 05:35 PM - Thread Starter
Liked: 3701
New Firmware update for JETI Spectraval 1501 Owners (Version: 1.0.0) has been released @ 07 December 2016.
Download Link: http://www.jeti.com/cms/index.php/so...tware-firmware
post #17 of 34 Old 05-02-2017, 02:37 AM
OMARDRIS's Avatar
Quoted: 66 Post(s)
Liked: 110
Hi,
The current firmware version for the JETI Spectraval 1501 is 1.0.4 from February 14, 2017.
On the website is a tip error on the release date.
Peter
S/W: LightSpace CMS, Calman 5, HCFR, Colorfacts
V/P: Lumagen Radiance Pro, DVDO AVlab TPG
Meters: JETI Spectraval 1501, Klein K-10A, I1Pro2, I1D3
OMARDRIS is offline
post #18 of 34 Old 05-02-2017, 03:13 AM - Thread Starter
Liked: 3701
Originally Posted by OMARDRIS View Post
Hi,
Peter
Hi Peter,
The download link is for 1.0.0 (initial meter release firmware), I will report that to JETI.
post #19 of 34 Old 05-04-2017, 04:13 AM
OMARDRIS's Avatar
Quoted: 66 Post(s)
Liked: 110
He Ted,
Thanks for the hint. Since I do not have the permission to download, I could not notice this. My 1501 had already installed the current Firmware 1.0.4. Therefore, I know the release date.
The current Internet offer from JETI shows that a cosine diffuser (ACC 032) is now also available for the Spectraval 1501 as an additional option. I suspect that this is related to the firmware update to release 1.0.4.
In the current datasheet of Spectraval 1501 it was added that now also illuminance measurements (with the diffuser) are possible. This would be very good for contrast measurements on projectors.
Measuring range illuminance:
2 - 1.000.000 Lux (III. A)
2 - 760.000 Lux (typical white LED)
I do not know if the diffuser can be ordered easily, or if the sensor has to be sent to JETI for calibration.
Peter
edit:
If you want to use the diffuser, you have to send the sensor to JETI, because both are calibrated together. I asked this at JETI.
In addition, Steve told me that the diffuser can not be used for contrast measurements. So we can forget the Thing.
OMARDRIS is offline
post #20 of 34 Old 05-04-2017, 09:01 AM - Thread Starter
Liked: 3701
He Ted,
Peter
edit:
Hi Peter,
Correct, it needs separate re-certification for luminance or illuminance readings (or both), and the prices for that are different.
Better to use a colorimeter for contrast measurement.
The link will be fixed in the following days.
To get access to firmware downloads register and then send to JETI your username and your meter serial; they will give you access to any download after that.
post #21 of 34 Old 05-04-2017, 11:36 PM
OMARDRIS's Avatar
Quoted: 66 Post(s)
Liked: 110
He Ted,
I also did this and got an account. But there are probably 2 types of permissions.
Once for smart guys (=Ted) and others for stupid guys (= Peter)
And stupid guys are not allowed to download any firmware.
There is the message "You may need special access rights to download. Please contact the JETI support."
Peter
OMARDRIS is offline
post #22 of 34 Old 05-05-2017, 12:03 AM
<^..^>Smokey Joe's Avatar
Quoted: 84 Post(s)
Liked: 109
Contact Jeti, Steffen Görlich
Some items require download activation, I think it is their way of keeping track of owners equipment and software.
Masterpiece Calibration Ltd
Lincolnvilleshire
New Zealand
<^..^>Smokey Joe is offline
post #23 of 34 Old 05-05-2017, 12:41 AM - Thread Starter
Liked: 3701
He Ted,
Peter
Hi Peter,
You have to send to JETI (via email) your meter serial and the username you created and they will enable the access to these files for your username.
post #24 of 34 Old 05-06-2017, 10:27 AM
OMARDRIS's Avatar
Quoted: 66 Post(s)
Liked: 110
Thanks Ted and Joe for the info.
Peter
OMARDRIS is offline
post #25 of 34 Old 08-22-2017, 06:37 PM - Thread Starter
Liked: 3701
There some new firmware updates, while they released today, the have earlier dates per model because JETI was testing them before releasing them to public.
JETI Specbos 1201 Firmware Version: 2.2.3 (10 August 2017)
JETI Specbos 1211 Firmware Version: 3.2.9 (28 July 2017)
JETI Spectraval 1501 Firmware Version: 1.4.0) (07 August 2017)
rahut and OMARDRIS like this.
post #26 of 34 Old 09-05-2017, 02:43 PM - Thread Starter
Liked: 3701
JETI Spectraval 1511 Firmware Version: 1.4.1 (31 August 2017) just released...
post #27 of 34 Old 09-09-2017, 01:15 AM - Thread Starter
Liked: 3701
JETI Spectraval 1501 & 1511 Firmware Version: 1.4.3 (6 September 2017) just released...
post #28 of 34 Old 09-10-2017, 07:31 AM
OMARDRIS's Avatar
Quoted: 66 Post(s)
Liked: 110
Hi Ted,
In the meantime, we have reached JETI Spectraval 1501 & 1511 Firmware Version 1.4.4.
Is there any information about the changes?
Peter
OMARDRIS is offline
post #29 of 34 Old 09-10-2017, 07:36 AM - Thread Starter
Liked: 3701
Hi Ted,
Peter
Hi Peter,
I have never seen JETI to give details about any firmware release, so it's good to always have the latest firmware.
There some updates of JETI SDK which software developers adding to their latest releases which require specific version of firmware to work, look there: http://www.jeti.com/cms/index.php/so...re-development
''Full functionality only with firmware 2.0 for specbos 1201 or firmware 3.0 for specbos 1211.''
post #30 of 34 Old 09-10-2017, 08:56 AM
OMARDRIS's Avatar
Quoted: 66 Post(s)
Liked: 110
Hi Ted,
Many Thanks,
then I hope, that they have no function for self-destruction installed.
Peter
OMARDRIS is offline
Reply Display Calibration
