The Official ChromaPure 3 thread - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 347Likes
post #421 of 1763 Old 02-17-2016, 05:18 AM - Thread Starter
TomHuffman's Avatar
Quoted: 1010 Post(s)
Liked: 842
Originally Posted by Knd View Post
Will do. Does the reset effect the 125 pt calibration?
Yes, so export that to a file, and then re-import after the toolbar is working again.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #422 of 1763 Old 02-17-2016, 05:58 AM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 32
Thanks Tom.
Knd is offline
post #423 of 1763 Old 02-18-2016, 09:16 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
ChromaPure 3.0.6 Released
ChromaPure 3.0.6 is now available for download for licensed 3.x users.
This small release fixes a couple of issues with the 75% of Rec. 709 gamut and the Lumagen manual control toolbar.
You can read the Release Notes on our News page.
Tom Huffman
Springfield, MO
post #424 of 1763 Old 02-19-2016, 07:53 AM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 32
Tom,
With the release of 3.06, do I still need to do the reset and reload of the configuration files as you indicated you couldn't duplicate my issue with 3.05.
Knd is offline
post #425 of 1763 Old 02-19-2016, 10:45 AM - Thread Starter
TomHuffman's Avatar
Liked: 842
Tom,
Only if you see some problem. I found a problem with the toolbar that we fixed. I don't know if this is what caused your issue or not.
Tom Huffman
Springfield, MO
post #426 of 1763 Old 02-19-2016, 12:35 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
User Manual
BTW, I have posted the user manual for v3 on our Support page.
Tom Huffman
Springfield, MO
post #427 of 1763 Old 02-20-2016, 10:19 AM
Chad B's Avatar
Quoted: 698 Post(s)
Liked: 1592
There is a level issue with the Quantum Data 801 and 882 series. Black windows are reproduced above black. Measured gamma is also incorrect. CP2 does not have the issue and measures gamma correctly.
Other generators I've tried, VideoForge and DVDO TPG, do not have the issue.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS540, JVC RS3000, Sony VPL-VW695ES
Copied settings measured, Review archive
Chad B is offline
post #428 of 1763 Old 02-20-2016, 12:55 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
I'll look into this and report back.
Chad B likes this.
Tom Huffman
Springfield, MO
post #429 of 1763 Old 02-20-2016, 03:41 PM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 32
5 IRE white balance
Tom,
I'm having a very difficult time trying to get a white balance @ 5 IRE through my Lumagen. With the increment at 1 unit on the manual controls, one click on blue has swung from 40% to over 110%.
I'm using an i1D3 that I bought from you (pro version) that I have setup as per your new user manual, CRT, 0.8 seconds, 1 low light, 3 readings.
I got these swings using the manual controls in CP, and also using the Lumagen remote, so I think it may be the i1D3 setup. The Y value is very repeatable, just the white balance. Is this just an issue with this probe at low light levels?
Knd is offline
post #430 of 1763 Old 02-20-2016, 11:14 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
Tom,
There's very little that can be done about this. Large swings with tiny adjustments is a fact of life at very low light levels. The only thing I can suggest is to increase from 3 readings to 5. This might help a little.
Tom Huffman
Springfield, MO
post #431 of 1763 Old 02-21-2016, 06:44 AM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 32
Thanks Tom, I suspected this, but glad to hear it from an expert.
Knd is offline
post #432 of 1763 Old 02-21-2016, 06:57 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Tom,
What I do at low light levels (20% and below) is take continuous readings and watch the RGB/gamma values and adjust accordingly so that the average value of the swings is your target point (eyeball averaging ).
Knd likes this.
Geof
Geof is offline
post #433 of 1763 Old 02-21-2016, 08:41 AM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 32
I just did an autocal via Lumagen because I wanted to try a 2.3 gamma and lowered my peak light output to about 52 cd/m^2. Even without checking the box to perform a gamma autocal, the post cal gamma was very close to 2.3. I was using 125 pt auto cal.
The manual controls worked perfectly to touch up a couple of points white balance.
Knd is offline
post #434 of 1763 Old 02-21-2016, 11:52 AM - Thread Starter
TomHuffman's Avatar
Liked: 842
Chad, I found the problem.
Are the 801 and 882 supposed to output PC levels? That's the difference between v2 and v3. At 10% grayscale v2 outputs 26,26,26 and v3 outputs 38,38,38 which is the difference between PC and video levels.
Tom Huffman
Springfield, MO
post #435 of 1763 Old 02-21-2016, 12:38 PM
Chad B's Avatar
Quoted: 698 Post(s)
Liked: 1592
I am not positive, but I do know the 802/882 outputs BTB, because I had a pluge pattern for it with BTB strips. It worked correctly in v2.
Chad B is offline
post #436 of 1763 Old 02-21-2016, 01:05 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
It looks like the 801 only works in PC mode and the 882 will work in PC or video mode. So it appears that your 882 is set to PC levels, which is why v2 works with both. We will have to change the output levels for the 801 in v3 and probably that's the easiest thing to do with the 882 as well, though we might try setting the 882 to output in video mode and then leave the levels alone.
I'll get back.
Tom Huffman
Springfield, MO
post #437 of 1763 Old 03-03-2016, 06:44 AM
rolling01's Avatar
Quoted: 23 Post(s)
Gee this threads gone quiet. Will there be a "calibration for dummies" for V3?
BiggShooter likes this.
rolling01 is offline
post #438 of 1763 Old 03-03-2016, 07:46 AM
desray2k's Avatar
Quoted: 488 Post(s)
Liked: 233
Help files in the s/w itself should be able to give you an idea.
desray2k is offline
post #439 of 1763 Old 03-03-2016, 02:58 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
Yes, this is something I want to work on. Look for this next month.
BTW, we are working furiously on various issues.
- 3.0.7 will be out in the next few days that fixes some stability and installation issues and adds support for the Murideo generator
- 3.1 should be out in April. It is shaping up to be a major release. It will have several new features and a significant UI enhancement that I hope will please people.
Tom Huffman
Springfield, MO
post #440 of 1763 Old 03-03-2016, 04:08 PM
desray2k's Avatar
Quoted: 488 Post(s)
Liked: 233
More importantly... Its free?
Sent from my Nexus 6P using Tapatalk
desray2k is offline
post #441 of 1763 Old 03-03-2016, 06:12 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
Point upgrades are always free. We won't charge for another version until 4.0 comes out, which if history is any guide, will be years from now.
desray2k, rolling01 and firefox15 like this.
Tom Huffman
Springfield, MO
post #442 of 1763 Old 03-05-2016, 07:14 PM
drapp1952's Avatar
Quoted: 16 Post(s)
For those using a Radiance Mini-3D, have you had problems running auto-calibrate using the Advanced Color Gamut 125 point matrix? My Mini-3D goes blank-screen and the power LED flashes in mid-calibration, and this did not occur under CP2. Using Color Gamut and 75% of Rec. 709 in auto-cal leads to excellent results with my JVC RS6710, although manual adjustment of gamma is needed at higher IREs.
I use CP3 on my MacBook Pro Retina using VMware Fusion and Windows 7 and it looks excellent (1400x900 res).
drapp1952 is offline
post #443 of 1763 Old 03-05-2016, 11:34 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
Is this repeatable? Other than adding 21pt support, we made no changes to auto-cal in v3, so it should work the same as v2.
Do a clean reinstall of CP3, select Repair Settings under the File menu, and try again. Select "Reset to Lumagen Factory Default" and run 125 pt again.
No one else has reported this problem. Is anybody else seeing this?
Tom Huffman
Springfield, MO
post #444 of 1763 Old 03-06-2016, 10:25 AM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 32
Tom,
In the next update, could you put the dE for the 6x6x6 measurement matrix after an auto cal? In CP2 the dE is there and I enjoyed watching these scroll by as the measurements were made.
Knd is offline
post #445 of 1763 Old 03-08-2016, 03:59 PM
svellinis's Avatar
Quoted: 42 Post(s)
Hi Tom
My i1d3 oem SN: OE-14.B-01.101486.06 is rev b but the firmware does not support the AIO method to function.
Work fine with chromapure 2.5.8 and chromapure 3.06 in CRT and LCD mode but in the last version of chromapure 3.07 my i1d3 is not recognized.
Work fine with lightspace , Calman ,Hcfr
svellinis is online now
post #446 of 1763 Old 03-08-2016, 11:11 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
Not true. The AIO method is the default read mode for the Rev B. i1D3 and works fine. I ask that users seek technical support prior to making such definitive statements.
Tom Huffman
Springfield, MO
post #447 of 1763 Old 03-09-2016, 11:59 AM
Quoted: 17 Post(s)
Liked: 4
Should AIO show up when initializing the meter? I have the same problem with my rev. B. I can select AIO in the options, but not on the main screen.
svellinis likes this.
firefox15 is offline
post #448 of 1763 Old 03-09-2016, 09:46 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
No. The Read mode (which is part of X-Rite's firmware) is not selectable on the initialize window.
Tom Huffman
Springfield, MO
post #449 of 1763 Old 03-11-2016, 03:51 PM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 32
V3.06 a couple of comments from cal session today.
1) Using the Lumagen as pattern generator, then unable this to run brightness pattern from blu-ray, I could not get the enable toggle to work again so I shut down and restarted.
2) This is very minor, during auto cal, when new settings are shown, the spacing is off. IIRC it is red, space, green, no space, blue.
Knd is offline
post #450 of 1763 Old 03-18-2016, 02:26 PM - Thread Starter
TomHuffman's Avatar
Liked: 842
ChromaPure 3.0.7 Released
ChromaPure 3.0.7 is now available for download. It is free for license v3 users.
This release adds support for the 4K Murideo signal generator. It also makes some changes that we hope will reduce errors.
The release notes are available on our News page.
Tom Huffman
Springfield, MO
Reply Display Calibration
