The Official ChromaPure 3 thread - Page 60 - AVS Forum | Home Theater Discussions And Reviews
 350Likes
post #1771 of 1784 Old 01-02-2020, 01:07 PM
Keith AP's Avatar
Quoted: 118 Post(s)
Liked: 90
Originally Posted by TomHuffman View Post
If you have a disc player and test pattern disc,(free ones are available) test the output from your video card relative to that. They should be essentially the same.
Stay with the default 235.
I have the 1i display pro 3 + ChromaPure 3.1.19.31 setup w/ disk. I'll check.
Marantz AV7702mkII | Emotiva XPA-5 Gen3 | miniDSP 2x4HD for BEQ/BOSS filters
PSA MTM-210 (L/C/R) | Polk Monitor 35B (SR/SL)
Epson 5050UB - BenQ W1070 w/ Panamorph CineVista Lens | Oppo BDP-103
HSU VTF-3MK5 (dual subs)
Seymour Center Stage UF 2.40 AT Screen
Keith AP is offline
post #1772 of 1784 Old 01-02-2020, 01:43 PM
jbrinegar's Avatar
Quoted: 372 Post(s)
Liked: 289
Hi Tom,
will chromapure have an autocal option for the upcoming MadVR Envy ? (similar to the autocal feature with Lumagen?)
Thank you!
JVC RS2000//JVC RS540 in Triple Black Velvet batcave
Anthem mrx1120
Klipsch Ref series 7.2.4 setup
Oppo 203 //Xbox one X // Apple 4k TV// PS4 Pro
Stewart Filmscreen 135" 16x9 Cima Neve
jbrinegar is offline
post #1773 of 1784 Old 01-07-2020, 05:32 PM
BiggShooter's Avatar
Quoted: 345 Post(s)
Liked: 114
I purchased the I1 Display Pro 3 + ChromaPure Standard a few years back (January 2017). I haven’t used it in a few years to calibrate my TV’s. I recently purchased a Sony 77” A9G OLED TV, and a Sony 55” A8G OLED TV. I found out both can be calibrated using Bravia workflow, but require CalMAN Home For Sony 2019 R3 software and a compatible meter. Two compatible meters listed are the X-Rite i1Pro and X-Rite i1Pro 2.
I just want to confirm whether or not my meter (X-Rite i1 Display Pro 3) is indeed compatible.
Thanks for the replies
BiggShooter is offline
post #1774 of 1784 Old 01-07-2020, 05:37 PM - Thread Starter
TomHuffman's Avatar
Quoted: 1015 Post(s)
Liked: 845
Originally Posted by jbrinegar View Post
Hi Tom,
Thank you!
At this point I don't know anything about it.
jbrinegar likes this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #1775 of 1784 Old 01-07-2020, 05:40 PM - Thread Starter
TomHuffman's Avatar
Liked: 845
I just want to confirm whether or not my meter (X-Rite i1 Display Pro 3) is indeed compatible, since according to the curtpalme web site (http://www.curtpalme.com/forum/viewtopic.php?t=36772), my meter is actually using the the X-Rite i1Pro hardware?
I am not sure what you mean by "my meter is actually using the the X-Rite i1Pro hardware". Your meter is the X-Rite i1 Display Pro 3. Sometimes X-Rite uses the 3 in its designation of this meter and sometimes it doesn't. It is the same meter.
Tom Huffman
Springfield, MO
post #1776 of 1784 Old 01-07-2020, 06:25 PM
Rolls-Royce's Avatar
Quoted: 1290 Post(s)
Liked: 1370
You misquoted them. This is the line: "Both meters use the exact same X-Rite i1Display Pro hardware"
The Display Pro is what you have. It is a colorimeter. The I1 Pro and I1 Pro 2 are spectrophotometers. They are apples and oranges.
dwaleke likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #1777 of 1784 Old 01-07-2020, 09:19 PM
Quoted: 345 Post(s)
Liked: 114
I apologize for the confusion. I'm just wanted to know whether or not it was compatible. I'm assuming it is not?
post #1778 of 1784 Old 01-08-2020, 07:09 AM
Liked: 1370
I honestly don't know. If it did, it would be treated as a plain-Jane I1D3 by the other program. None of the display profiles created by Mr. Huffman for use within ChromaPure would be available to it there.
BiggShooter likes this.
...Royce...
post #1779 of 1784 Old 01-24-2020, 09:57 AM
Liked: 0
Hi, folks. I'm an absolute newbie to calibration. I recently bought an i1 Display Pro Plus to calibrate my Sammy QLED along with ChromaPure 3. And now the newbie questions:
1. It's recommended to perform first a 100% white measurement. In ChromaPure initial setup I have the option of 75% intensity. Do I have to change that value in order to obtain a 100% intensity? And for the rest return to 75%? I use a calibration disk where I already use the 75% colour and 100% white patterns.
2. Is that normal to obtain by the first white measurement a dE of 4? What impact has that value of the overall image quality or colour?
3. By calibratin white ballance I obtain by 0% and 5% gray extremely high dE values. Is this normal? Can I ignore them?
4. The Sammy has a 21 point white balance. I read the curtepalm guide where it's recomended to make mainly an adjustement by 20 and 80%. Should I calibrate 21 points only if I'm not satisfied with the picture? Or should I always go for a maximal point setting?
Thanks guys for help.
uranos is offline
post #1780 of 1784 Old 01-24-2020, 04:52 PM - Thread Starter
TomHuffman's Avatar
Liked: 845
1. It is not a recommendation. The initial white point measurement MUST be at 100% regardless of what Color Intensity setting you have.
2. Yes, that is not an unreasonable number. I would try to get that down to below 2.
3. You can ignore 0% entirely. That is just for contrast data. 5% is difficult. If you can get it below 4, then I would count that as a victory.
4. Try the 2- point first and then see what the dE is throughout the grayscale. If it deviates significantly, then proceed to the 21-point.
Tom Huffman
Springfield, MO
post #1781 of 1784 Old 01-25-2020, 12:33 AM
Liked: 0
Thanks Tom. So in order to make a white point measurement, should I raise the color intensity to 100% in the "Initial Setup" page (default 75%), and then revert back to 75% for the rest? Or I leave it on default and start a 100% white pattern? I'm a little bit confused about the option "color intensity" option.
I'll try to reduce the dE on my white point measurement. Should I here adjust contrast or better gamma?
uranos is offline
post #1782 of 1784 Old 01-25-2020, 02:12 AM - Thread Starter
TomHuffman's Avatar
Liked: 845
No. Color intensity refers just to that, the intensity of color test patterns. Use 75% color intensity setting. All use use 100% white for the reference white reading.
Tom Huffman
Springfield, MO
post #1783 of 1784 Old 01-25-2020, 03:36 AM
Liked: 0
Thanks. So I leave the color intensity on the initial setup page untouched by 75%.
uranos is offline
post #1784 of 1784 Old 01-26-2020, 02:52 PM
Liked: 0
With my QLED-Sammy I use the built-in sjgnal generator. The problem is that I'm not able to use "Fields" as recomended, because I observed that during continous measuring I obtain different result when the OSD in on or off. Would be the use of "windows" an option?
uranos is offline
Reply Display Calibration
