The Official ChromaPure 3 thread - Page 63 - AVS Forum | Home Theater Discussions And Reviews
 358Likes
post #1861 of 1891 Old 04-22-2020, 03:07 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
Updated to the latest software. Latest disc. Trying to run pre cal Gamut. Now there are even more color variants in the SW, 80%, 60, 40, 20 and I don't see those in rev 006 disc. What am I missing? I just want to smoothly run through a pre cal in order the SW is asking for?
bob
spongebob is offline
post #1862 of 1891 Old 04-22-2020, 03:12 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
Originally Posted by RickD_99 View Post
Hey spongebob:
The place to enter your AWP settings in ChromaPure 3 is in the settings box. Just open up one of the CP3 modules (e.g. White Balance) and click on the round settings wheel icon. Then click on the gamut tab and you will see a box to enter your AWP values. Then click on "Apply" and those AWP values will be in effect for the remainder of your CP3 calibration session. See attached file...
Rick,
Do I enter those offsets in every module? WB, Color, etc?
thx
bob
post #1863 of 1891 Old 04-22-2020, 03:18 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
Originally Posted by TomHuffman View Post
The disc does not have test patterns for the tertiary colors. Primary, secondary and ColorChecker only. If you want to measurement the tertiary colors, use the built-in test pattern generator.
Ok. I chose Cal disc as the source. Shouldn't that change the pattern options/ sequence? How do you use the built in patterns?
thx
bob
post #1864 of 1891 Old 04-22-2020, 03:26 PM
RickD_99's Avatar
Quoted: 316 Post(s)
Liked: 233
Originally Posted by spongebob View Post
Rick,
thx
bob
Nope just have to enter them once in whatever module you choose and the settings will apply to all modules thereafter for as long as your calibration session lasts...
LG 55C6P OLED Display/Apple TV 4K/2019 Roku Ultra
Oppo UDP-203 UHD Blu-ray Player (65-0131 firmware)
ELAC unifi B5 Speakers
NAD C316BEE Stereo Amplifier
Nakamichi Shockwafe 9.2 Sound Bar (3.2 firmware)/Xbox One X 4K Gaming Console
RickD_99 is offline
post #1865 of 1891 Old 04-22-2020, 04:07 PM - Thread Starter
TomHuffman's Avatar
Quoted: 1040 Post(s)
Liked: 852
bob
The software is selectable between 25% and 20% increments. If you are using the disc, select the 25% increments.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #1866 of 1891 Old 04-22-2020, 04:09 PM - Thread Starter
TomHuffman's Avatar
Liked: 852
thx
bob
From the Help file
Built-in Signal Generator
On the Initial Setup module, select Built-in from the Signal Source drop-down..
Select the desired test pattern size.
Connect the PC's HDMI output to the display you wish to calibrate.
Setup your PC for an Extended Desktop. The PC's screen should show the ChromaPure application and the calibration display will show the test patterns.
TIP: If you setup the extended desktop prior to displaying any test patterns, then the first one you display will appear on the calibration display automatically. Otherwise, just drag the test pattern onto the calibration display. Then right-click the test pattern and select Maximize.
Tom Huffman
Springfield, MO
post #1867 of 1891 Old 04-22-2020, 04:34 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
From the Help file
Thanks, Tom
I'm just using an older Win 7 laptop, no HDMI so I'll stick with the disc for now
bob
post #1868 of 1891 Old 04-26-2020, 05:05 AM
Liked: 2
@TomHuffman : does ChromaPure 3 support the i1Pro 3 spectrophotometer? Couldn't find anything in the release notes or supported meters page, but was wondering if it might already be supported, because it seems more of an iteration of the i1Pro 2 rather than a completely new design like it was with i1Pro > i1Pro 2.
Kid Jansen is offline
post #1869 of 1891 Old 04-26-2020, 07:42 AM - Thread Starter
TomHuffman's Avatar
Liked: 852
No, it is not really a new design. It works with the same SDK support as the i1Pro 2, so yes we support it.
Tom Huffman
Springfield, MO
post #1870 of 1891 Old 05-02-2020, 06:48 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
I thought you were talking about the Kuro. Use window test patterns. Calibrate levels and grayscale. Choose desired gamma preset. Use the Extended gamut and the Cinema Picture mode. The default color is very good but you can touch it up a little. LG OLEDs are really easy to calibrate. Some people have trouble because they use the OLED internal mode in the i1. This is one of the modes that is horribly inaccurate. The default mode on the meter measures the panel quite well.
Tom
Could you explain why Extended gamut vs auto or wide?
thx
bob
post #1871 of 1891 Old 05-02-2020, 07:04 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
Do my pro cal offsets work in OLED mode?
bob
post #1872 of 1891 Old 05-02-2020, 10:25 PM - Thread Starter
TomHuffman's Avatar
Liked: 852
Tom
On the LG displays, the Standard gamut is closest to SMPTE-C, which you would use for DVD. Extended is closest to 709, which you would use for HD. Wide is closest to P3, which you would use for UHD.
Tom Huffman
Springfield, MO
post #1873 of 1891 Old 05-02-2020, 10:27 PM - Thread Starter
TomHuffman's Avatar
Liked: 852
bob
No. You had this done in 2012, which was before the OLEDs were available. You should send your meter in for re-calibration. After 8 years it would be a good idea even if it weren't missing the OLED mode.
Tom Huffman
Springfield, MO
post #1874 of 1891 Old 05-02-2020, 10:57 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
THanks, Tom
What is the cost for that?
bob
post #1875 of 1891 Old 05-02-2020, 11:01 PM - Thread Starter
TomHuffman's Avatar
Liked: 852
THanks, Tom
bob
$199 for a re-calibration of PRO meters.
Tom Huffman
Springfield, MO
post #1876 of 1891 Old 05-03-2020, 08:16 AM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
How do I export a report to pdf? Can't find it anywhere!
bob
post #1877 of 1891 Old 05-03-2020, 08:17 AM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
So, how much is new pro meter and what improvements?
bob
post #1878 of 1891 Old 05-03-2020, 08:42 AM - Thread Starter
TomHuffman's Avatar
Liked: 852
bob
There is a toolbar at the top of the report window. There is a printer icon. Click that and select a pdf printer.
Tom Huffman
Springfield, MO
post #1879 of 1891 Old 05-03-2020, 08:44 AM - Thread Starter
TomHuffman's Avatar
Liked: 852
bob
$448. It syncs to the display's refresh rate and can read higher luminance values.
Tom Huffman
Springfield, MO
post #1880 of 1891 Old 05-03-2020, 09:05 AM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
I don't have a pdf printer option, just my printer, fax, or ms xps doc. (win 7 pro)
bob
post #1881 of 1891 Old 05-03-2020, 10:02 AM - Thread Starter
TomHuffman's Avatar
Liked: 852
bob
You can download one. There are several that are free.
Tom Huffman
Springfield, MO
post #1882 of 1891 Old 05-03-2020, 12:54 PM
Liked: 0
I have a question regarding the impact of display driver settings in Windows when using Chromapure's built in signal generator to do an SDR calibration.
To back up for a sec, I was pulling my hair out for the last few days trying to figure out why I was getting very abnormal Gamma readings (extremely high gamma at the low IRE end and extremely low gamma at the high IRE end) when doing an SDR gamma calibration of my B7A display. After some trial and error I realized this was ONLY happening when my display had Deep Color (Enhanced HDMI capabilities) enabled. If Deep Color was off, Gamma was fine. After quite a bit of troubleshooting, I realized that enabling YCbCr in the Intel Control Panel of my laptop resolved the Gamma issue when attempting an SDR gamma calibration (using Chromapure's built in signal generator), while my Display had Deep Color enabled.
I don't know enough about calibration to fully understand the interplay between the YCbCr setting and the Enhanced HDMI capabilities of my display on an SDR calibration, but it did raise an important question for me...
What are the optimal settings I need to consider with respect to my Windows display driver when attempting an SDR calibration using Chromapure's built in signal generator, because clearly an incorrect setting there can have a hugely detrimental effect on the calibration?
abrams500 is offline
post #1883 of 1891 Old 05-03-2020, 02:01 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
Tom,
What color window pattern do I use for the C9 OLED on the CP 3 Blu ray disc?
bob
post #1884 of 1891 Old 05-03-2020, 03:28 PM - Thread Starter
TomHuffman's Avatar
Liked: 852
Tom,
Windows.
Tom Huffman
Springfield, MO
post #1885 of 1891 Old 05-03-2020, 03:44 PM
spongebob's Avatar
Quoted: 655 Post(s)
Liked: 73
Windows.
Right, but which one, 75%, sat or? Don't have it in front of me but there are multiple windows options. This is for oLED
bob
post #1886 of 1891 Old 05-03-2020, 05:17 PM - Thread Starter
TomHuffman's Avatar
Liked: 852
bob
75% saturation, 75% intensity is probably best, but there is no hard and fast rule about this.
Tom Huffman
Springfield, MO
post #1887 of 1891 Old 05-04-2020, 05:38 AM
markus767's Avatar
Quoted: 6432 Post(s)
Liked: 3392
There was so much confusion about using this third-party tool, we went back to doing it the way we did it in v2. You should no longer need to use the madVR utility. The patterns are authored in 0-255 and the laptop's HDMI port will almost always convert it to 16-235 when plugging into a TV.
Hi Tom
Is this still true for the latest release 3.1.19? Any recommendation how to properly check wether the PC converts to 16-235 or sends 0-255 via HDMI?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #1888 of 1891 Old 05-23-2020, 11:07 AM - Thread Starter
TomHuffman's Avatar
Liked: 852
Originally Posted by markus767 View Post
Hi Tom
Check it against a known reference, i.e., calibration disc.
Tom Huffman
Springfield, MO
post #1889 of 1891 Old 05-23-2020, 11:09 AM - Thread Starter
TomHuffman's Avatar
Liked: 852
Spyder and Macs
We can only support the SpyderX--and I suspect all of the Spyder meters--on the PC. We cannot get the the SpyderX to work on a Mac using PC emulation software, such as Parallels or Bootcamp.
Tom Huffman
Springfield, MO
post #1890 of 1891 Old 05-26-2020, 12:55 PM
Quoted: 21 Post(s)
Liked: 4
hi Tom, have you planned an update regarding the autocal Radiance Pro GAMMA 12 BIT?
Vinturbo is online now
Reply Display Calibration
