R.Masciola's HDR-10 UHD Test Patterns - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 1071Likes
post #991 of 1765 Old 10-20-2017, 05:27 AM
Rolls-Royce's Avatar
Quoted: 1019 Post(s)
Liked: 1154
Originally Posted by dlj11 View Post
Just a short question, did not find the answer or maybe I am blind.
If I buy the digital files, is it possible to make a disc with them? I mean with the menue and so on... Is it an ISO-File?
And is a DVD enough or do I need a BluRay Disc?
Sorry for the noob-questions...
The digital files aren't an ISO, so you can't burn a disc from them. They have to be run from a USB thumb drive. And a DVD is nowhere big enough.
dlj11 likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #992 of 1765 Old 10-20-2017, 05:43 AM
Frank D's Avatar
Quoted: 417 Post(s)
Liked: 101
The disc says that the MacCLL and Mastering display luminance is 1000 cd/m2 and min luminance is .0005.
Also MaxFALL 400 cd/m2.
Can you please explain what the above items mean? If the max is 1000 cd/m2 or nits then how do you get patterns above this 1000 cd/m2 max nit amt ie hitting up to 10,000 nits?
Frank D is offline
post #993 of 1765 Old 10-20-2017, 07:48 AM
Liked: 1154
The 1000 nits is the maximum luminance for the display used to master the content, and the min luminance is how dark its black is. This doesn't mean you can't have a pattern with the code value for 10K nits on the disc. Your set just won't be able to reproduce it. In fact, no current display can reach that luminance level. But that is part of the HDR ST 2084 spec, and some day you may have a display that can do it. So it doesn't hurt to have a pattern for it. This can also be used in measuring the levels which a display can resolve in its tone mapping (i.e., whether details at higher brightness levels are simply clipped/not shown or the display attempts to make them visible within the limits of what it can do).
IIRC, MaxFALL is "Maximum Frame Average Light Level", and is the maximum average light level achieved by any frame of the video, including the highlights. MaxCLL is "Maximum Content Light Level", and is the luminance of the brightest pixel found in the content.
Frank D and galonzo like this.
...Royce...
post #994 of 1765 Old 10-20-2017, 08:24 AM
Manni01's Avatar
Quoted: 5343 Post(s)
Liked: 5376
Originally Posted by Rolls-Royce View Post
The 1000 nits is the maximum luminance for the display used to master the content, and the min luminance is how dark its black is. This doesn't mean you can't have a pattern with the code value for 10K nits on the disc. Your set just won't be able to reproduce it. In fact, no current display can reach that luminance level. But that is part of the HDR specs, and some day you may have a display that can do it. So it doesn't hurt to have a pattern for it. This can also be used in measuring the levels which a display can resolve in its tone mapping (i.e., whether details at higher brightness levels are simply clipped/not shown or the display attempts to make them visible within the limits of what it can do).
IIRC, MaxFALL is "Maximum Frame Average Light Level", and sets the maximum average light level for each frame of video, including the highlights. MaxCLL is "Maximum Content Light Level", and the value for the brightest pixel found in the content.
AFAIK it's the brightest sub-pixel (R, G or B), not pixel (RGB triplet).
Rolls-Royce likes this.
Manni01 is online now
post #995 of 1765 Old 10-20-2017, 08:29 AM
Liked: 1154
The article I found explains it thusly: "Maximum Content Light Level (MaxCLL) is additional static HDR metadata that corresponds to the brightest pixel in the entire stream. The MaxCLL metadata is represented in nits."
See https://www.linkedin.com/pulse/hdr-1...carlos-carmona
mascior and Manni01 like this.
...Royce...
post #996 of 1765 Old 10-20-2017, 09:00 AM
Manni01's Avatar
Liked: 5376
Thanks. I've always heard @ConnecTEDDD mention sub-pixel, for example here: https://www.avsforum.com/forum/139-di...l#post52828705 so I thought he was correct (as he usually is).
I wouldn't trust any article, but checking the ST2084 white paper from the SMPTE here https://www.smpte.org/sites/default/...-Ecosystem.pdf seems to confirm that MaxCLL defines the brightest pixel not sub-pixel (see E.2.2.4 P42):
"E.2.2.4 Maximum Content Light Level
The Maximum Content Light Level (MaxCLL) is an additional Static Metadata item that applies to HDR Content
only. Maximum Content Light Level corresponds to the brightest pixel in the entire stream."
Maybe Ted can give us his reference? It would be good to know for sure, as it looks like I was mistaken.
post #997 of 1765 Old 10-20-2017, 09:08 AM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
I may have missed it but for the lg 2017 oled can you use the chroma pure or hfcr hdr slides now that lg has defined the adjustment as 1-21 etc instead of the 2016 naming convention.
LGOLED77G7P/65B6P - Oppo 203
Denon X6300H/Onkyo Tx NR3030; Atlona HDR HDBaseT
Klipsch 7.1.4
R-3800-W II Fronts ; R-5502-W II Center
RS-42 II Surrounds ; CDT-3800-C II Heights, R-112SW Subs
jayraysaiz is offline
post #998 of 1765 Old 10-20-2017, 09:36 AM
poppagene's Avatar
Quoted: 846 Post(s)
Liked: 715
Not an iso. After you download and extract the files, you will find a folder for TS images and a folder for MP4 images. you can burn both to a blu ray disc or choose one or the other to burn to a blank dvd. They will be data disks so no menu. You will have to navigate through the file structure to get to the test patterns you are looking for. I find using a usb drive easier, but have also burned the files to a blank dvd and they worked fine as described.
dlj11 likes this.
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is online now
post #999 of 1765 Old 10-20-2017, 09:47 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Hi Jay,
LG is still utilizing their own grayscale methodology and naming convention for HDR within their 2017 OLED model lineup. However, it has been updated from their 2016 implementation. You can reference the new code based patterns HERE. My last digital file update has these patterns available within the LG OLED Patterns file folder. Thanks!
- Ryan M.
mascior is offline
post #1000 of 1765 Old 10-20-2017, 09:56 AM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Originally Posted by mascior View Post
Hi Jay,
- Ryan M.
Ok is this update on the disc as well? I may not have noticed it since I haven’t had to look for a 2017 slide till now
Klipsch 7.1.4
post #1001 of 1765 Old 10-20-2017, 10:06 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Unfortunately, the 2017 patterns did not make it onto the disc, only the 2016 were implemented. The disc was already past the phase of add-ons and/or additions. Thanks!
- Ryan M
mascior is offline
post #1002 of 1765 Old 10-20-2017, 10:39 AM
ConnecTEDDD's Avatar
Quoted: 2919 Post(s)
Liked: 3552
Hi Manni, look @ page 44 of the PDF, it says how MaxCLL is calculated.
setmaxRGB= max(R,G,B) , so the max is one of the R or G or B value.
For MaxCLL interpretation, the unit is equivalent to cd/m2 when the brightest pixel in the entire video stream has the chromaticity of the white point of the encoding system used to represent the video stream. Since the value of MaxCLL is computed with a max() mathematical
operator, it is possible that the true CIE Y Luminance value is less than the MaxCLL value. This situation may occur when there are very bright blue saturated pixels in the stream, which may dominate the max(R,G,B) calculation, but since the blue channel is an approximately 10%
contributor to the true CIE Y Luminance, the true CIE Y Luminance value of the example blue pixel would be only approximately 10% of the MaxCLL value.
So if the brightness sub-pixel is blue, its not really be as bright in nits as the MaxCLL number is showing.
Stacey Spears mentioned this @ 26:13 of the following video:
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #1003 of 1765 Old 10-20-2017, 11:07 AM
Manni01's Avatar
Liked: 5376
https://www.youtube.com/watch?v=NcLWK4k62T0
Thanks Ted, that's what I had in mind, I guess I stopped reading the paper two pages too early
post #1004 of 1765 Old 10-20-2017, 05:37 PM
chipvideo's Avatar
Quoted: 47 Post(s)
At what level should I have my white clipping? Using a JVC 520 Projector.
chipvideo is offline
post #1005 of 1765 Old 10-23-2017, 04:45 PM
Jestered's Avatar
Quoted: 26 Post(s)
Liked: 46
@mascior - I see that you recently had a Xbox One S to do some testing of the disc with. Did you by chance look at the resolution patterns I mentioned a while back? Basically they are all "static-y" when playing through the One S on my LG E6. Let me know. Thanks!
galonzo likes this.
__________
LG OLED65E6P * Marantz AVR SR6010 (Sur. x4/FHL/FHR) * Adcom GFA7000 Amp (FL/C/FR) * Polk RTiA7 (FL/FR) * Polk CSiA5 (C) * Polk FXiA6 (Sur. x4) * Polk RTiA3 (FHL/FHR) * SVS PB-1000 (SW) * URC MX-5000 Remote *
UPDATED: 04/05/2013 - My Colormunki/HCFR calibrated settings for 65" ES8000
Jestered is offline
post #1006 of 1765 Old 10-23-2017, 05:22 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Hi Jestered,
The same anomaly that you experienced within your setup, was present during my testing as well. It sounds as though there maybe an issue with the XBOX One S decoder, as I have not experienced this on any other UltraHD player. Thanks!
- Ryan M.
galonzo likes this.
mascior is offline
post #1007 of 1765 Old 10-27-2017, 12:33 PM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Ryan,
Is there any particular reason why the 2017 codes do not numerically line up with the 21 point codes in the LG WB menus? I didn't see how any of the 540/1000/4000 slides match numerically. Is there a setting on the LG that specifies what nit level perhaps?
Klipsch 7.1.4
post #1008 of 1765 Old 10-27-2017, 12:41 PM
Liked: 1154
Ryan,
IIRC, the code values LG listed in their document are themselves incorrect.
mascior likes this.
...Royce...
post #1009 of 1765 Old 10-27-2017, 01:38 PM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Ok I just went with what I New would be 100/5 for a two point. As far as greyscale for 20 pt goes they were all under 1.0 after very minor adjustments in the 2pt.
Klipsch 7.1.4
post #1010 of 1765 Old 10-27-2017, 06:11 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Ryan,
Hi jayraysaiz,
It looks as though LG is still utilizing full range HDR code values (0-669/1023) vs the limited range code values (64-657/940) that should have been implemented. I only offer the limited range values within my current revision. However, I will most likely add the full range code values to align with current software. Thanks!
- Ryan M.
jayraysaiz likes this.
mascior is offline
post #1011 of 1765 Old 10-27-2017, 07:28 PM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Hi jayraysaiz,
- Ryan M.
Thanks that would’ve awesome! When do you think this will roll out?
Klipsch 7.1.4
post #1012 of 1765 Old 10-27-2017, 07:51 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Possibly within the next two weeks. I am currently working on other updates for REV_017 as well, including more test footage at different nit levels and a few other miscellaneous test patterns. I am also working on DV patterns in parallel...
- Ryan M.
northrob and jayraysaiz like this.
mascior is offline
post #1013 of 1765 Old 10-27-2017, 08:00 PM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
- Ryan M.
Ryan do you know if any other software will support Dolby Vision calibration other than calman in the near future?
Klipsch 7.1.4
post #1014 of 1765 Old 10-27-2017, 08:20 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Not to my knowledge.
- Ryan M.
mascior is offline
post #1015 of 1765 Old 11-04-2017, 10:37 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
R.Masciola's UHD/HDR-10 Test Pattern Suite (.ts/.mp4) update REV_017 released!
**NOTE: This revision was compresses with 7-Zip. To extract, please utilize the 7-Zip extracting utility found at http://www.7-zip.org/ (PC) or the Keka extracting utility found at http://www.kekaosx.com/ (MAC)
Description
Revision 17 brings numerous new test patterns, updates, and modifications to the suite:
  • Two new test footage patterns graded at 1,000 nit, displaying different color shades and skin tones.
  • The entire 2017 LG OLED “Full Range” code value set has been added to align with current firmware.
  • A new white clipping test pattern, encoded with four different peak nit values (1,000, 2,000, 4,000, & 10,000) were added. These patterns show how well your HDR enabled display applies tone mapping.
  • The Title slide within the “Basic Setup Patterns” section has been updated to reflect REV_017
  • A typo was corrected within the instruction manual
Modifications & Additions
01. Title
  • Title_HDR10 (updated to reflect REV_017)
Miscellaneous Patterns
13. Test Footage
  • 07. Restaurant Scene_HDR10 (added)
  • 08. Indian Market_HDR10 (added)
14. LG OLED Test Patterns -> 2017 Code Values -> 01. Full Range ->
  • 01. Code Values 540 nit (Separate) (added)
  • 02. Code Values 540 nit (Combined) (added)
  • 03. Code Values 1000 nit (Separate) (added)
  • 04. Code Values 1000 nit (Combined) (added)
  • 05. Code Values 4000 nit (Separate) (added)
  • 06. Code Values 4000 nit (Combined) (added)
15. HDR Clipping Test Patterns
  • 11. White Clipping 1,000 nit_HDR10 (added)
  • 12. White Clipping 2,000 nit_HDR10 (added)
  • 13. White Clipping 4,000 nit_HDR10 (added)
  • 14. White Clipping 10,000 nit_HDR10 (added)
Pattern suite file sizes
UHD/HDR-10 Test Pattern Suite (.ts/.mp4) unzipped 6.45 GB (6,933,854,835 bytes)
UHD/HDR-10 Test Pattern Suite (.ts/.mp4) zipped 2.02 GB (2,175,489,628 bytes)
Thank you for your continued support!
-Ryan M.
mascior is offline
post #1016 of 1765 Old 11-04-2017, 11:49 AM
skschatzman's Avatar
Quoted: 2602 Post(s)
Liked: 1557
Thanks Ryan!
Sent from my SM-G955U using Tapatalk
mascior likes this.
skschatzman is online now
post #1017 of 1765 Old 11-05-2017, 01:46 PM
Liked: 1
Hello,
I recently purchased your HDR10 Ultra HD Blu-Ray disc with the UHD test patterns. I am very happy with the product and also with how quickly the product shipped! Thank you very much for putting this together!
I was wondering if you could please help me identify which of the boxes, or between which boxes, would best represent 320 nit on the first white balance test pattern that lists boxes 502-756.
Thank you for your time!
mascior likes this.
DrRonPaul is offline
post #1018 of 1765 Old 11-05-2017, 10:10 PM
SJHT's Avatar
Quoted: 1010 Post(s)
Liked: 675
Is there any type of upgrade process for the disk that we can get for improvements when released? Understand that these don’t make it to disk right away. Thanks. SJ
SJHT is offline
post #1019 of 1765 Old 11-06-2017, 12:55 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Originally Posted by DrRonPaul View Post
Hello,
Hi DrRonPaul,
Thank you for the kind words. 320 nit would equal to 62.8728%, utilizing round nearest, patch/box "63% code value 616" would be the best representation. Thanks!
- Ryan M.
mascior is offline
post #1020 of 1765 Old 11-06-2017, 01:08 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Hi SJHT,
Disc revisions would be very costly, especially when it comes to UltraHD Blu-ray production. However, I may provide incremental releases via ISO patch. This ISO would not provide the entire contents of the original authored disc, but revisions and updates. Existing customers would be entitled to this free patch upon request as a download. Thanks!
- Ryan M.
chhanthony likes this.
mascior is offline
Reply Display Calibration
