R.Masciola's HDR-10 UHD Test Patterns - Page 48 - AVS Forum | Home Theater Discussions And Reviews
 1071Likes
post #1411 of 1765 Old 07-10-2018, 07:28 AM
jwhn's Avatar
Quoted: 653 Post(s)
Liked: 163
Originally Posted by Dominic Chan View Post
HCFR expects its own target values, unless you treat them as custom patterns rather than saturation sweep patterns.
Exactly - it would require custom patterns for HCFR
jwhn is offline
post #1412 of 1765 Old 07-10-2018, 07:45 AM
Quoted: 4371 Post(s)
Liked: 1608
I don’t expect that to provide any advantage over the standard saturation sweep patterns. The luminance gets higher as saturation gets lower, so youre calibrating closer to full luminance relative to white.
Dominic Chan is online now
post #1413 of 1765 Old 07-10-2018, 08:03 AM
jwhn's Avatar
Quoted: 653 Post(s)
Liked: 163
Probably not. But in some cases colors look over saturated even though they measure well. I'm wondering if these targets might help with that.
jwhn is offline
post #1414 of 1765 Old 07-10-2018, 06:38 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Originally Posted by chhanthony View Post
Dear Ryan M,
Thanks for your reply.
May I know what is the mean 50% Amp (50% Sat) in BT2020 Gamut HDR,
it is absolute luminance i.e. 50% = around 93 nits; or
related luminance i.e. 50% = 50% of measured peak?
Thank you.
Anthony
Hi Anthony,
Within ST2084, 50% White 126,126,126 = 92 nit. This breaks down to 50% Red (24 nit), 50% Green (63 nit) and 50% Blue (5 nit). (24 nit + 63 nit + 5 nit = 92 nit)
The constant luminance utilized by ChromaPure is currently based off this 50% point for color saturation sweeps, as it's an attainable range for current HDR displays. Lets use 50% Red for example:
Red 50% Amp/100% Sat....................126,16,16 (50%,00%,00%) = 24 nit
Red 50% Amp/75% Sat......................121,75,75 (48%,27%,27%) = 24 nit
Red 50% Amp/50% Sat......................115,86,86 (45%,32%,32%) = 24 nit
Red 50% Amp/25% Sat......................108,93,93 (42%,35%,35%) = 24 nit
The color red maintains a constant value of 24 nit throughout the entire saturation sweep. I hope this helps. Thanks!
- Ryan M.
* Edit: HCFR utilizes 50.23% White 126,126,126 = 94.378 nit. This breaks down to 50% Red (24.793 nit), 50% Green (63.988 nit) and 50% Blue (5.597 nit). (24.793 nit + 63.988 nit + 5.597 nit = 94.378 nit)
galonzo likes this.
mascior is offline
post #1415 of 1765 Old 07-10-2018, 06:47 PM
chhanthony's Avatar
Quoted: 181 Post(s)
Liked: 108
Originally Posted by mascior View Post
Hi Anthony,
The constant luminance utilized by ChromaPure and HCFR is currently based off this 50% point for color saturation sweeps, as it's an attainable range for current HDR displays. Lets use 50% Red for example:
- Ryan M.
Dear Ryan,
Very clear, thanks a lot!
Anthony
Anthony Chan
AV Blog: http://www.avnewbie.com
System: 5.3.4
Panasonic DMP-UB900EBK, Egreat A5, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, Benq HT1075, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #1416 of 1765 Old 07-10-2018, 07:08 PM
chhanthony's Avatar
Quoted: 181 Post(s)
Liked: 108
Hi Anthony,
- Ryan M.
I am mainly using the CalMAN to calibrate projector, as the luminance of the projector will not reach the ST2084 standard.
May I have your advice that should I use multiplier of the measured white to calibrate 50% color 50% Amp in BT2020 color gamut? If the answer is positive, which figure of the measured white I should multiplier, peak white or 50% white (i.e. measured 50% white is 23 nits then 23/92 = 4). It's make me very confuse.
Thank a lot!
Anthony
Anthony Chan
System: 5.3.4
post #1417 of 1765 Old 07-19-2018, 05:37 AM
eganz1's Avatar
Quoted: 119 Post(s)
Liked: 109
Dolby Vision calibration Patterns
Using an Oppo 205 or 203, you can now use the convert to Dolby vision
mode to convert a standard HDR-10 4K set of calibration patterns into
Dolby vision.
I've done this using the R. Masciola HDR-10 4K calibration disc.
It works very well, although I'm hoping that the experts will test this
and confirm that the patterns are accurate.
Eric
Theater: Sony A1E OLED 4K Ultra HD, Oppo-205, Anthem AVM60, 7.1.4 B & W CM 7 LR,CDM-cse, CM 1, CM 1 S2, Silverline minuet , SVS SB13 Ultra, Rotel RMB 1555, Parasound A23, Naim NAP 100, EEcolor lut box. Calman, MobileForge, I1D3 & I1pro 2.
Stereo: Aurender N100H, Auralic Vega DAC, Focal Chorus 836 W, BAT VK-3ix, Pass XA 30.5, PPP.
eganz1 is offline
post #1418 of 1765 Old 07-24-2018, 03:03 PM
panasonicst60's Avatar
Quoted: 195 Post(s)
Liked: 114
I'll be getting the LG C8 very soon and I am interested in calibrating Dolby Vision. I only have experience with calibrating HDR10, but not DV. Will this work for calibrating DV or not? If not, will you be releasing a DV version? Thanks!
TV: OLED65C8P - Receiver: Anthem MRX 710 - Blu-ray: Panasonic UB820 - Cd transport: Cambridge Audio CXC - Amp: Parasound A31 - LCR Speakers: Sierra 2s - Surrounds: Noble Fidelity L-65 mkII - Sub: Rythmik F18 - Power Distribution: PS Juice Bar II, Signal Cable Magicstrip - Power Cables: PS AC5, PS SC, Shunyata Venom 14 - Speaker Cables: Kimber 8tc, BJC 10 - RCA Cables: AQ Silver - Probe: i1 Display Pro OEM Rev.B - Software: Lightspace HTL, Calman Enthusiast - Bias Lighting - MediaLight
panasonicst60 is online now
post #1419 of 1765 Old 07-24-2018, 03:19 PM
richardsim7's Avatar
Quoted: 1269 Post(s)
Liked: 1635
Not yet, later this year I believe
panasonicst60 likes this.
richardsim7 is online now
post #1420 of 1765 Old 07-24-2018, 03:22 PM
Quoted: 195 Post(s)
Liked: 114
How much later this year . Sooner is better.
post #1421 of 1765 Old 07-24-2018, 03:23 PM
Liked: 1635
Not as soon as you want them, I imagine
post #1422 of 1765 Old 07-24-2018, 03:25 PM
Quoted: 195 Post(s)
Liked: 114
I'll be getting my c8 tomorrow. Will it be out by then?
post #1423 of 1765 Old 07-24-2018, 03:30 PM
mrtickleuk's Avatar
Quoted: 4349 Post(s)
Liked: 6594
No.
richardsim7 likes this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #1424 of 1765 Old 07-24-2018, 09:14 PM
p5browne's Avatar
Quoted: 3976 Post(s)
Liked: 3133
November
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #1425 of 1765 Old 07-25-2018, 02:13 AM
Quoted: 195 Post(s)
Liked: 114
Asking if it would be available by tomorrow was a joke. Nice knowing that Ryan is working on the dv version. Thanks Ryan!!
mrtickleuk likes this.
post #1426 of 1765 Old 07-30-2018, 07:43 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Diversified Video Solutions UltraHD|HDR-10 Test Pattern Suite (.mp4/.ts) update REV_023 Released!
**NOTE: This revision was compresses with 7-Zip. To extract, please utilize the 7-Zip extracting utility found at http://www.7-zip.org/ (PC) or The Keka extracting utility found at http://www.kekaosx.com/ (MAC)
Description
I am excited to announce the release of revision 23 of The DVS HDR-10 Test Pattern Suite. This is considered a staple release and is recommended to disregard any previous release, as this revision encompasses numerous pattern modifications, changes and additions. All Revision 23 test patterns will be featured in my soon to be released “version 2” UltraHD Blu-ray HDR-10 Test Pattern Disc. I would also like to thank Alan Brown (aka GeorgeAB), The President of CinemaQuest, Inc. regarding the co-design of the newly implemented ambient light test patterns available within the miscellaneous section of the suite! The new and/or modified patterns are listed below and please be sure to reference the newly updated instruction manual for further details. As always, thank you for your continued support!
- Ryan M.
New and Modified Pattern Description
Basic Setup Patterns
- Title (REV_023)
- Black Clipping (1 & 2) (The APL has been further lowered from 21 nit down to 5 nit on both black clipping patterns)
- White Clipping (1, 2, 3 & 4) (A new low APL White Clipping test pattern has been added for further observation of white clipping)
- Color Clipping (Color Clipping Mix, Color Clipping Low & Color Clipping High) (Patterns have been further graded for accuracy)
- Sharpness & Overscan (Sharpness & Overscan/Resolution Mix Pattern) (Patterns have been further graded for accuracy and modifications to the sharpness bars)
Miscellaneous Setup Patterns
- Contrast Ratio (2%, 5%, 10%, 15%, 20%, 25%, 30%, 35%, 40% & Full Field) (All patches have been updated and Full Field Patterns have been added)
- Grayscale Ramps (Grayscale Steps, Grayscale Ramp, & Grayscale Ramp Mix) (Patterns have been further graded for accuracy)
- Color Ramps (Color Steps, Color Ramps, & RGBYCM Single Color Ramps) (Patterns have been further graded for accuracy)
- Grayscale Sweeps (2% Window Patterns, 5% Window Patterns, 10% Window Patterns, 15% Window Patterns, 20% Window Patterns, 25% Window Patterns, 30% Window Patterns, 35% Window Patterns, 40% Window Patterns & Full Field Patterns) (All patches have been updated and Full Field Patterns have been added)
- Different nit Levels (10% Window Patterns @ 1,000 nit, 2,000 nit, 3,000 nit, 4,000 nit, 5,000 nit, 6,000 nit, 7,000 nit, 8,000 nit, 9,000 & 10,000 nit levels) (New nit levels have been added. Now encompass 1,000 nit to 10,000 nit in 1,000 nit increments)
- Resolution Patterns (Resolution Mix Pattern, Resolution Vertical Pattern 1 Pixel, Resolution Vertical Pattern 2 Pixel, Resolution Vertical Pattern 3 Pixel, Resolution Horizontal Pattern 1 Pixel, Resolution Horizontal Pattern 2 Pixel, Resolution Horizontal Pattern 3 Pixel, & Resolution Black Pixels Single) (Patterns have been further graded for accuracy)
- HDR Clipping Test Patterns (Patterns have been modified and further graded for accuracy)
- Digital Zone Plate Patterns (Patterns have been further graded for accuracy)
- Radial Gradient Patterns (WRGBYCM) (Patterns have been further graded for accuracy)
- Chroma Subsampling Patterns (Chroma Subsampling 100 nit, 500 nit, & 1,000 nit) (Patterns have been further graded for accuracy)
- Ambient Light Test Patterns (A newly added test pattern. Please reference the instruction manual for further details)
Pattern Suite File Size
8.18 GB (8,793,893,318 bytes) Zipped/Compressed
26.5 GB (28,526,987,303 bytes) Unzipped/Uncompressed
(All customer download limits will be reset and new links will be distributed)
turbe, GeorgeAB, galonzo and 1 others like this.
mascior is offline
post #1427 of 1765 Old 07-30-2018, 08:13 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
I would also like to provide a brief update regarding version 2 of my UltraHD Blu-ray HDR-10 test pattern disc. The new disc menus and pop-up menus have been completed. I'm in the process of combining the elementary streams and all authoring should be completed by the end of August. We are still looking good for an early Fall release. Thanks!
- Ryan M.
GeorgeAB and galonzo like this.
mascior is offline
post #1428 of 1765 Old 07-30-2018, 08:27 PM
skschatzman's Avatar
Quoted: 2573 Post(s)
Liked: 1539
- Ryan M.
Great stuff man. Thank you for all you do.
Is version 2 an add-on to version 1 or is it a complete suite?
If it is a complete suite, will there be a price discount for version 1 owners?
skschatzman is offline
post #1429 of 1765 Old 07-30-2018, 08:39 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Hi skschatzman,
Version 2 will be a complete suite, encompassing all of REV_023. I redesigned the entire disc from the ground up and there will definitely be a discount for existing customers. Thanks!
- Ryan M.
mascior is offline
post #1430 of 1765 Old 07-30-2018, 08:45 PM
Liked: 1539
Hi skschatzman,
- Ryan M.
post #1431 of 1765 Old 07-31-2018, 02:36 PM
Quoted: 195 Post(s)
Liked: 114
Any plans on having LightSpace workspace?
post #1432 of 1765 Old 08-01-2018, 01:31 AM
chhanthony's Avatar
Quoted: 181 Post(s)
Liked: 108
Description
- Ryan M.
- Title (REV_023)
The new email sent out already?
As I haven't receive any update email yet.
Thank you!
Anthony Chan
System: 5.3.4
post #1433 of 1765 Old 08-01-2018, 07:31 AM
p5browne's Avatar
Liked: 3133
Left to download overnight, and it said it was finished this morning.
But, the file is only 25 Meg ?
UN65KS9800 - Mine
p5browne is offline
post #1434 of 1765 Old 08-01-2018, 07:41 AM
Liked: 1539
Must be a corrupt download. Try again. Mine downloaded perfectly.
post #1435 of 1765 Old 08-01-2018, 09:07 AM
Rolls-Royce's Avatar
Quoted: 1018 Post(s)
Liked: 1154
Mine, too.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #1436 of 1765 Old 08-01-2018, 02:04 PM
galonzo's Avatar
Quoted: 1288 Post(s)
Liked: 1582
Originally Posted by Rolls-Royce View Post
Mine, too.
No problem here, either; I even tried the "Save to DB" feature, which normally fails, but this time the file was in there (even though it still gave the error message that it didn't save); already unpacked and loaded onto a thumb drive.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is online now
post #1437 of 1765 Old 08-01-2018, 02:33 PM
Liked: 1635
@mascior why not split the download into TS and MP4, surely this would save you bandwidth costs?
post #1438 of 1765 Old 08-01-2018, 04:39 PM
p5browne's Avatar
Liked: 3133
Good old Windows XP and an older Google - took 3 tries but finally downloaded. (1.2 hour just to download !)
Meantime, went on my wife's computer, with Windows 7, whole file downloaded, extracted and copied in less than 1/2 hour.
Edit:
Ooops - Senior's moment - the file that was downloaded last night was OK. Some dummy on the keyboard, was looking at the wrong file ! (And we won't mention any names.)
UN65KS9800 - Mine
p5browne is offline
post #1439 of 1765 Old 08-01-2018, 05:39 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Hi richardsim7,
I have offered separates for quite some time now. However, they're only available upon request. That may change in the future. Thanks!
- Ryan M.
galonzo and richardsim7 like this.
mascior is offline
post #1440 of 1765 Old 08-02-2018, 10:00 AM
neverwish's Avatar
LightSpace
Yes that would be perfect, Steve will gladly help out with this I guess!
mascior and panasonicst60 like this.
neverwish is offline
Reply Display Calibration
