R.Masciola's HDR-10 UHD Test Patterns - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 1088Likes
post #1501 of 1778 Old 11-12-2018, 08:03 AM
Quoted: 4285 Post(s)
Liked: 5236
Originally Posted by mascior View Post
Working on it. The process in which it takes to create Dolby Vision test patterns is quite challenging from multiple angles vs what it takes to create HDR-10 or HLG-HDR. However, now that I have synced up with the folks over at Hybrik (now a part of Dolby), I now have a viable solution for transcoding DV. Unfortunately all of the content had to be recreated, as I'm using a different method for rendering and exporting. My current dilemma is deciding on whether to utilize "Profile 5" or "Profile 7" when transcoding. Profile 5, is typically used for streaming, utilizes full range and ICtCp. Whereas, Profile 7 is typically utilized for UltraHD BD authoring and uses a limited range. I have successfully created a few patterns for testing in both profiles...However, I'm still in the beta testing phase. Sorry for the delay. Thanks!
- Ryan M.
I would think you need both Profile 5 and 7 or the folks with Sony's and maybe future equipment will not benefit.
galonzo and panasonicst60 like this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #1502 of 1778 Old 11-12-2018, 08:12 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 411 Post(s)
Liked: 774
Agreed. However, I was thinking from a multipurpose/use case standpoint. Both profile 5 and 7 are the current standard...for now. It's that, having multiple profiles makes this challenging and expensive to create.
- Ryan M.
mascior is offline
post #1503 of 1778 Old 11-20-2018, 01:18 PM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
Hi @mascior
I just got my first OLED TV and am interested in test patterns to calibrate the picture. In my case, I am going to be limited to just adjusting the picture settings on my LG OLED TV. Is your suite of test patterns good for that, or are yours meant for use with calibration tools?
zeonstar is offline
post #1504 of 1778 Old 11-20-2018, 02:12 PM
p5browne's Avatar
Quoted: 3991 Post(s)
Liked: 3166
Originally Posted by zeonstar View Post
Hi @mascior
What are you asking here?
# 1 - Can I use the Patterns to Eye Ball calibrate my set, or
# 2 - Do I need software and a Meter ?
Answer is # 2.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #1505 of 1778 Old 11-20-2018, 02:20 PM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
Answer is # 2.
I was basically asking #1 .
zeonstar is offline
post #1506 of 1778 Old 11-20-2018, 02:28 PM
skschatzman's Avatar
Quoted: 2656 Post(s)
Liked: 1584
Hi @mascior
There isn't any picture settings on the TV you can accurately adjust with just test patters alone(Except Brightness and Contrast, but 99% of the time are accurate out of the box). Additional equipment is required. Eyeball adjustments are not accurate.
skschatzman is offline
post #1507 of 1778 Old 11-20-2018, 02:32 PM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
What about color, white balance, etc?
It use to be you could use a calibration disc, Avia, or the setup pattern on THX discs to tune your TVs. Is doing it that way not really an option anymore? That's essentially what I am looking to do. Just use some kind of test pattern to tune my picture. I don't necessarily need fine tuned perfection.
zeonstar is offline
post #1508 of 1778 Old 11-20-2018, 02:40 PM
Liked: 1584
No. The technology that people used that for has been dead for many years. With the advancement of accurate bit perfect reference patterns and measurement devices. It has shown that the old disc by eye method was never even close to giving accurate results and you are just as likely to make things worse by eye.
post #1509 of 1778 Old 11-20-2018, 02:45 PM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
Well thanks for educating me. You learn something everyday as they say.
At the risk of sounding stupid, then what is the use of picture adjustment settings on TV picture modes these days? Are those used in conjunction with calibration tools? I know absolutely nothing on the calibration process so I don't know how it's done, so forgive my ignorance.
So eyeballing wont work. What's the minimum equipment one would need to purchase to even do a basic level calibration?
Thanks for your help.
zeonstar is offline
post #1510 of 1778 Old 11-20-2018, 02:49 PM
Liked: 1584
Most of the settings require equipment. Video processing options like noise reduction, motion interpolation, black frame insertion, etc are all optional. Things like color, tint, white balance, grayscale, color management, etc require equipment for accurate changes.
post #1511 of 1778 Old 11-20-2018, 02:59 PM
zeonstar's Avatar
Quoted: 371 Post(s)
Liked: 89
Where might I get a calibration device? Hopefully inexpensive....
zeonstar is offline
post #1512 of 1778 Old 11-20-2018, 03:20 PM
Liked: 1584
The cheapest entry level device I recommend is a 2017 or newer Xrite i1 Display Pro. Runs about $250.
Use that in combination with HCFR free software.https://www.avsforum.com/forum/showt...php?p=21638248
Please take this conversation to that thread as we are getting off topic here.
post #1513 of 1778 Old 11-20-2018, 04:08 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 411 Post(s)
Liked: 774
Hi @mascior
Hi zeonstar,
As mentioned by skschatzman and p5browne, the only true way to currently calibrate HDR is by meter and software (which the cost effective recommendation by skschatzman is most likely your best bet). Unfortunately, due to the way HDR is implemented, it doesn't allow for manual adjustment by eye as with current/legacy SDR implementations. Also, as mentioned prior, it's typically recommended to keep adjustments like contrast and brightness at their defaults, whereas theses adjustment could essentially be performed by eye with SDR. The "Basic Setup" & "Miscellaneous" patterns within my patterns suite are essentially for reference on how your display deciphers specific metadata. Also, for a point of reference for before and after calibrations. I hope this helps. Thanks!
- Ryan M.
mascior is offline
post #1514 of 1778 Old 11-20-2018, 04:17 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 411 Post(s)
Liked: 774
I finally received good news from Sony DADC today regarding disc version 2.0...The first allotment shipped today and I should be able to start fulfilling orders this weekend into Monday. Sorry for the delay. There are essentially only two manufactures that replicate UltraHD Blu-ray and with it being a popular format...there is a constant backup in manufacturing. I would like to thank all of my customers for their continued patience and you should be receiving your orders soon!
- Ryan M.
mascior is offline
post #1515 of 1778 Old 11-20-2018, 04:18 PM
Liked: 1584
I finally received good news from Sony DADC today regarding disc version 2.0...The first allotment shipped today and I should be able to start fulfilling order this weekend into Monday. Sorry for the delay. There are essentially only two manufactures that replicate UltraHD Blu-ray and with it being a popular format...there is a constant backup in manufacturing. I would like to thank all of my customers for their continued patience and you should be receiving your orders soon!
- Ryan M.
post #1516 of 1778 Old 11-20-2018, 04:31 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 411 Post(s)
Liked: 774
Here is a Dolby Vision 10% test patch, 50% white, full range, utilizing profile 5. I would like to see if there are any playback issues across multiple Dolby Vision enabled devices. Also, if there are any users that utilize Dolby Vision via TPG and would like to reference, any feedback would be greatly appreciated. I have conducted multiple tests. However, I would like to compare data. Thanks!
Dolby_Vision_50_Patch.zip
- Ryan M.
mascior is offline
post #1517 of 1778 Old 11-20-2018, 11:42 PM
northrob's Avatar
Quoted: 104 Post(s)
Liked: 62
In my LG OLED 55B6 there are NO issues. I`m so much looking forward for complete pattern set. Thanks.
LG OLED 55B6V, Finnsat FST03PVR, Toshiba 1T HDD, Genelec 6010B, BK XLS200-DF MK2
JVC DLA-X35BE, PS3, Apple TV3, Yamaha RX-V383, Tannoy Mercury F2, Tannoy Mercury F1, BK Monolith
northrob is offline
post #1518 of 1778 Old 11-21-2018, 02:33 AM
northrob's Avatar
Quoted: 104 Post(s)
Liked: 62
I measured the brightness of both HDR10 and DV 50 % patterns and there is quite a difference. Main reason may be the tone mapping of the B6 but does these suppose to have same brightness because HDR10 is code 502 and DV is 512?
HDR10 105 nits 1000 nit level
HDR10 88 nits 4000 nit level
DV 140 nits
northrob is offline
post #1519 of 1778 Old 11-21-2018, 07:39 AM
JGrana's Avatar
Quoted: 150 Post(s)
Liked: 85
- Ryan M.
Test file displayed fine on my Sony XBR65X930E TV using it's USB input and built in media player.
I also tried to display the file on:
1) Apple TV 4K using Infuse - did not display/work
2) Amazon Fire TV 4K stick - I tried VLC and Kodi. Neither worked.
At this point in my setup, it will only display when on a USB device plugged into the TV.
JGrana is offline
post #1520 of 1778 Old 11-21-2018, 08:25 AM
Quoted: 392 Post(s)
Liked: 197
- Ryan M.
Please publish all the necessary patterns for Calman LG Workflow. TAKE MY MONEY!
MackGuyver and panasonicst60 like this.
LG OLED 55 B7v | LG SK10Y Soundbar | Samsung 55KS8000 | LG Plasma 50PZ550 | i1D3 OEM | Calman Enthusiast
MrRobotoPlus is offline
post #1521 of 1778 Old 11-25-2018, 09:48 AM
santodx5's Avatar
Quoted: 158 Post(s)
Hello All,
I just bought my 1st 4K TV, LG 65C8 two weeks ago. I am using Oppo 205 for my movies, via USB3 or NAS in the back panel.
Can I use the MP4/TS test pattern or should I buy the actual disc to calibrate my TV via Oppo 205's USB3/NAS input?
santodx5 is online now
post #1522 of 1778 Old 11-25-2018, 09:49 AM
richardsim7's Avatar
Quoted: 1311 Post(s)
Liked: 1682
The Oppo should be able to play the MP4/TS patterns via USB/Network, yeah
There's a sample you can download to test with
richardsim7 is offline
post #1523 of 1778 Old 11-25-2018, 10:19 AM
santodx5's Avatar
Quoted: 158 Post(s)
Halo,
I'm sure Oppo will play it fine but will it give the same accuracy from BD disc?
The reason I am asking because someone mention some player will need to be calibrated from blue ray disc to have better accuracy.
post #1524 of 1778 Old 11-26-2018, 01:48 AM
Candle's Avatar
Quoted: 54 Post(s)
My Panasonic UB900 does not play this DV file.
I probably need the coming DV Bluray disc from you, to use those.
Candle is offline
post #1525 of 1778 Old 11-26-2018, 02:09 AM
Candle's Avatar
Quoted: 54 Post(s)
A question.
The last time I received an update for the HDR10 patterns by email was end of june.
Not sure if there was a new update since than, but when I use this link (which I can still use 5 times), will it download the last version or the version from june?
Candle is offline
post #1526 of 1778 Old 11-26-2018, 03:17 AM
panasonicst60's Avatar
Quoted: 195 Post(s)
Liked: 114
That's because the ub900 is not DV compatible.
richardsim7 likes this.
TV: OLED65C8P - Receiver: Anthem MRX 710 - Blu-ray: Panasonic UB820 - Cd transport: Cambridge Audio CXC - Amp: Parasound A31 - LCR Speakers: Sierra 2s - Surrounds: Noble Fidelity L-65 mkII - Sub: Rythmik F18 - Power Distribution: PS Juice Bar II, Signal Cable Magicstrip - Power Cables: PS AC5, PS SC, Shunyata Venom 14 - Speaker Cables: Kimber 8tc, BJC 10 - RCA Cables: AQ Silver - Probe: i1 Display Pro OEM Rev.B - Software: Lightspace HTL, Calman Enthusiast - Bias Lighting - MediaLight
panasonicst60 is offline
post #1527 of 1778 Old 11-26-2018, 05:55 AM
santodx5's Avatar
Quoted: 158 Post(s)
DV patch works fine in Oppo 205
post #1528 of 1778 Old 11-26-2018, 11:25 AM
Candle's Avatar
Quoted: 54 Post(s)
Will it play on the Panny 820?
Candle is offline
post #1529 of 1778 Old 11-26-2018, 11:57 AM
Liked: 1682
That also doesn't support Dolby Vision, so no...
EDIT: or maybe it does? Weird, their website doesn't mention it: http://4khometheaterreview.com/2018/...ision-arrives/
post #1530 of 1778 Old 11-26-2018, 04:21 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 411 Post(s)
Liked: 774
Originally Posted by santodx5 View Post
Hello All,
Hi santodx5,
The digital MP4/TS files and disc based version should offer similar results when played through any of the OPPO UHD players. However, UltraHD is regulated whereas USB is not. Also, the disc based version is fully authored with a menu structure that will typically cut your calibration session time in half. Thanks!
- Ryan M.
galonzo likes this.
mascior is offline
Reply Display Calibration
