R.Masciola's HDR-10 UHD Test Patterns - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 1072Likes
post #1591 of 1765 Old 01-24-2019, 03:55 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 772
Originally Posted by Brg26 View Post
Ryan, that's great news on the being able to produce the correct 2018 patterns. You say they will be included in the next revision, any idea when that will be?
Actually, I'm taking it one step further. I am redesigning the entire LG OLED pattern set. This go-round I will be utilizing 8-bit shifted to 10-bit values vs the original true 10-bit implementation, as this will align better with current calibration software and was confirmed by LG as a valid method. I was also provided updated metadata that will be implemented within the new pattern set as well. The pattern resigned will incorporate new verbiage that will state, sequence, bit values, percentage and the original Full Range values request by the display's UI for reference. Also, the on-screen text was reduced to a point that will not skew APL during measurements and will be able to stay on-screen for the duration as a reference. Here is a list of what is being updated:
- 2016 (540 nit)
- 2017 (540 nit, 1,000 nit & 4,000 nit)
- 2018 ( 1,000 nit for all 3 pattern sets) + The LG UK65xx series at 1,000 nit
- 2019 (1,000 nit & 4,000 nit)
I should have this completed by early next week and will be available shortly thereafter. I will most likely provide this as a re-release of REV_025. Thanks!
- Ryan M
ID:	2515664   Click image for larger version
mascior is offline
post #1592 of 1765 Old 01-24-2019, 05:11 PM
Gregg Loewen's Avatar
Quoted: 39 Post(s)
Liked: 97
Great work Ryan!
Founder, Professional Video Alliance
Gregg Loewen is offline
post #1593 of 1765 Old 01-25-2019, 04:14 AM
Liked: 0
Brilliant, thanks Ryan
Bob
Brg26 is offline
post #1594 of 1765 Old 01-25-2019, 11:48 AM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
Some good news the Samsung Q9FN (2018), DVS HDR10 patterns and Calman (version 5.9.2.59) autocal HDR workflow does work - well sort of.
The Pre-calibration step works fine, of course.
The 2 point white balance autocal step works fine with the manual patch prompts.
The luminance step works fine.
The greyscale starts OK, but then there is a problem - missing patches!
The following grey patches are used by the Calman Samsung QLED HDR workflow and are missing from (or at least I cannot find them) the DVS HDR10 patch set, including the Samsung 2018 patch set in the miscellaneous folder:
34.7%
40.6%
61.6%
67.0%
71.0%
73.5%
74.4%
75.3%
76.0%
76.7%
77.0%
78.0%
78.5%
All other patches used in this step can be located.
I've attached a screenshot of the 20 point Greyscale screen from Calman.
@mascior , are you able to create these missing patches for the Samsung 2018 HDR Calman workflow please?
Name:	2019-01-25 18_48_09-CalMAN 2018 CalMAN Home Enthusiast Samsung Q9 Patch Values.png
galonzo likes this.
JayAy is offline
post #1595 of 1765 Old 01-25-2019, 12:01 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 772
34.7%
40.6%
61.6%
67.0%
71.0%
73.5%
74.4%
75.3%
76.0%
76.7%
77.0%
78.0%
78.5%
Yes. I can add these to the set. I will have a copy of them in the Samsung file folder and within all of the workflow file folders as well. I'll have them available next week with the rest of the additions. Thanks!
- Ryan M.
galonzo and JayAy like this.
mascior is offline
post #1596 of 1765 Old 01-25-2019, 12:24 PM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
- Ryan M.
Thanks Ryan, that's fantastic.
JayAy is offline
post #1597 of 1765 Old 01-29-2019, 05:02 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 772
All, I just finalized the updates on the pattern suite. They will most likely be available for download this Friday! Here is what was updated and added. Thanks!
- 2016 LG OLED (540 nit)
- 2017 LG OLED (540 nit, 1,000 nit & 4,000 nit)
- 2018 LG OLED (1,000 nit for all 3 pattern sets)
- 2018 LG LED-LCD UK65xx series (1,000 nit)
- 2019 LG OLED (1,000 nit in 10 step & 22 step)
- 2018 Samsung LED-LCD (new pattern sweep)
- Ryan M.
mascior is offline
post #1598 of 1765 Old 01-29-2019, 08:43 PM
e010238's Avatar
Quoted: 20 Post(s)
I tested a few 2018 C8 patterns (USB input) from Ryan. They work!
galonzo and mascior like this.
e010238 is offline
post #1599 of 1765 Old 01-31-2019, 04:10 AM
panasonicst60's Avatar
Quoted: 195 Post(s)
Liked: 114
All,
I just got finished speaking with one of the Senior Directors of Engineering over at LG, who assisted with the implementation of the 20 point WB code specific values. He just confirmed my theory, both Full Range and/or Limited range triplet values may be utilized. If the Full Range values are to be used, then the patterns must be encoded in Full Range, not Limited Range. However, if the Limited Range values are to be utilized, you must perform a conversion from Full Range to Limited Range on all of the triplet values. Please keep in mind, when utilizing the Limited Range patterns, you will be using different triplet values vs what is being requested by the display within the UI. So even though the values do not match, the percentage values will still align. It was also mentioned that dynamic contrast must be disabled prior to calibration, as this will skew results.
With that being said, all of my 2016 and 2017 patterns are correct and I have deleted the Full Range section from the pattern suite entirely. I will still have to address the 2018 patterns, as all three sets will need to be converted from Full Range to Limited Range and encoded. These will be available within the next revision. If anyone has any further questions or concerns regarding this matter, please feel free to reach out. Thanks!
- Ryan M.
Amazing work Ryan! Thank you!
Just to be clear. Once we have the new patterns from you, as long as the percentage value matches we are good?
Quick reminder DV
TV: OLED65C8P - Receiver: Anthem MRX 710 - Blu-ray: Panasonic UB820 - Cd transport: Cambridge Audio CXC - Amp: Parasound A31 - LCR Speakers: Sierra 2s - Surrounds: Noble Fidelity L-65 mkII - Sub: Rythmik F18 - Power Distribution: PS Juice Bar II, Signal Cable Magicstrip - Power Cables: PS AC5, PS SC, Shunyata Venom 14 - Speaker Cables: Kimber 8tc, BJC 10 - RCA Cables: AQ Silver - Probe: i1 Display Pro OEM Rev.B - Software: Lightspace HTL, Calman Enthusiast - Bias Lighting - MediaLight
panasonicst60 is offline
post #1600 of 1765 Old 02-01-2019, 03:38 AM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
- Ryan M.
Hi Ryan, how can we tell when the new patterns are available for download? I don't want to use up my download limit unnecessarily - already lost a couple thanks to my AV system getting over enthusiastic ;-)
JayAy is offline
post #1601 of 1765 Old 02-01-2019, 07:02 AM
Rolls-Royce's Avatar
Quoted: 1033 Post(s)
Liked: 1158
If you're a confirmed purchaser, you'll receive an email.
JayAy likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #1602 of 1765 Old 02-01-2019, 07:39 AM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
Thanks. Only purchased a couple of weeks ago, so it's good to understand how the update process works.
Rolls-Royce and galonzo like this.
JayAy is offline
post #1603 of 1765 Old 02-01-2019, 08:59 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 772
Diversified Video Solutions UltraHD|HDR-10 Test Pattern Suite (.mp4/.ts) update REV_025 Re-released!
**NOTE: This revision was compresses with 7-Zip. To extract, please utilize the 7-Zip extracting utility found at http://www.7-zip.org/ (Windows) or The Keka extracting utility found at http://www.kekaosx.com/ (iOS)
Description
This re-release encompasses a few updates, additions and/or modifications to the existing test pattern suite. One of the main modifications are the LG Display code specific test patches which have now been updated to align with all 2016, 2017, 2018 & 2019 OLED Models, along with the UK65xx series LED-LCD’s. Secondly, we have added a secondary code value grayscale sweep to the 2018 Samsung series of LED-LCD’s. Please see the detailed description below. Thank you!
New and Modified Pattern Description
Miscellaneous Setup Patterns
- The LG OLED code specific test patch file folder has been renamed to “LG Display Test Patterns” and now includes two sub-folder, OLED and LED-LCD.
The 2016, 2017 & 2018 patterns have been re-designed and now utilize 8-bit shifted to 10-bit values vs the original true 10-bit implementation. This will align better with current calibration software and was confirmed by LG as a valid method. The new patterns also incorporate new verbiage that will state, sequence, bit values, percentage and the original Full Range values request by the display's UI for reference. Also, the on-screen text was reduced to a point that will not skew APL during measurements and will be able to stay on-screen for the duration as a reference.
A new 2019 code value set was also added and is available in both 10 step and 22 step configurations.
New 2018 UK65xx series LED-LCD code values were added as well and can be found within the new “LG Display Test Patterns” file folder.
Also, all the above patterns have been added to the available workflows under the grayscale file folder and as always, includes a combined stream for ease of use.
- 2018 Samsung code specific test patches now include a secondary code value set that align with newer firmware and models.
Pattern Suite File Size
10.1 GB (10,894,125,521 bytes) Zipped/Compressed
30.0 GB (32,301,358,642 bytes) Unzipped/Uncompressed
(All customer download limits will be reset and new links will be distributed)
- Ryan M.
WiFi-Spy, galonzo, JayAy and 1 others like this.
mascior is offline
post #1604 of 1765 Old 02-02-2019, 11:25 AM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
Hi Ryan,
Thanks for updating the Samsung 2018 greyscale patterns.
I've just tried running through an Calman autocal run with the new 20 point Samsung patches (set 2) I noticed that the 71% and 76% patches do not match the Calman patch values in 8 bit RGB as below:
Patch, Calman 8 bit, DVS 8 bit, DVS filename
71%, 171, 172, 09. Samsung 71.0%_C172_HDR10
76%, 182, 183, 15. Samsung 76.0%_C183_HDR10
I also notice that the 76.3% patch filename also suggests an 183 8 bit value, 16. Samsung 76.3%_C183_HDR10
Can you recheck the 71% and 76% patches please?
Jay.
JayAy is offline
post #1605 of 1765 Old 02-02-2019, 12:50 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 772
Hi Ryan,
Jay.
Hi Jay,
The patterns in question are correct. I just re-checked the math. I will reach out to Tyler and see if this can't be correct within their software. Thanks!
71.0% - 686/4 = 171.5 (apply round nearest) = 172
76.0% - 730/4 = 182.5 (apply round nearest) = 183
76.3% - 732/4 = 183
** As for the dual 183 triplet values, there isn't much that can be done, as everything is broken down to 8-bit.
- Ryan M.
galonzo likes this.
mascior is offline
post #1606 of 1765 Old 02-02-2019, 05:27 PM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
Hi Jay,
76.3% - 732/4 = 183
- Ryan M.
Hi Ryan,
I thought it may be a rounding/trunking issue causing the differences; thanks for checking for me.
I've also taken a look at the calman autocal CMS which is now a three pass "Samsung Multi-CMS" at three different luminance values. I've listed all the calman values below. I'm struggling to track down the right patches, can you advise please?
Patch Number Calman Patch Title Calman Luminance Calman Saturation Calman R Calman G Calman B DVS File Name
50%
1 0% White 16 16 16 10%_Patch_0_C64_C16_HDR10
2 100% White 235 235 235 10%_Patch_100_C940_C235_HDR10
3 50% Saturated Red 70% 50% 164 149 148
4 50% Saturated Green 70% 50% 153 166 149
5 50% Saturated Blue 70% 50% 149 148 166
6 50% Saturated Cyan 70% 50% 154 166 167
7 50% Saturated Magenta 70% 50% 164 150 166
8 50% Saturated Yellow 70% 50% 166 167 149
75%
9 0% White 16 16 16 10%_Patch_0_C64_C16_HDR10
10 100% White 235 235 235 10%_Patch_100_C940_C235_HDR10
11 75% Saturated Red 70% 75% 167 133 127
12 75% Saturated Green 70% 75% 145 171 129
13 75% Saturated Blue 70% 75% 133 129 172
14 75% Saturated Cyan 70% 75% 148 172 173
15 75% Saturated Magenta 70% 75% 168 135 172
16 75% Saturated Yellow 70% 75% 171 172 130
100%
17 0% White 16 16 16 10%_Patch_0_C64_C16_HDR10
18 100% White 235 235 235 10%_Patch_100_C940_C235_HDR10
19 100% Saturated Red 70% 100% 171 108 16
20 100% Saturated Green 70% 100% 141 177 90
21 100% Saturated Blue 70% 100% 109 83 177
22 100% Saturated Cyan 70% 100% 145 177 177
23 100% Saturated Magenta 70% 100% 172 113 177
24 100% Saturated Yellow 70% 100% 177 177 88
Jay
Edit - Doh! The formatting gets lost when posted so I've attached an image from my spreadsheet - may be a little easier to read
Name:	2019-02-03 01_29_27-Calman Samsung Multi-CMS - Excel.png
JayAy is offline
post #1607 of 1765 Old 02-03-2019, 09:35 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 772
Hi Ryan,
50%
75%
100%
Jay
Hi Jay,
The current DVS CalMAN workflow only incorporates 50% luminance/50% saturation CMS patches and 50% luminance saturation sweeps. I can easily add the above in the next revision. However, for the time being, you can utilize the standard HDR-10 workflow within CalMAN, which follows the pattern sequence found within the DVS CalMAN workflow file folder. Thanks!
- Ryan M.
mascior is offline
post #1608 of 1765 Old 02-03-2019, 09:49 AM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
Hi Jay,
- Ryan M.
Hi Ryan,
Thanks for the advice. Sorry, I seem to be giving you lots of work to do. I look forward to the next revision.
Jay
JayAy is offline
post #1609 of 1765 Old 02-12-2019, 03:38 AM
Quoted: 195 Post(s)
Liked: 114
Any new update on DV Ryan?
post #1610 of 1765 Old 02-13-2019, 12:49 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 772
Dolby Vision is my primary focus at the moment. However, it is taking a lot longer than anticipated. This project has been the most challenging from every aspect in comparison to the others, with the main challenge, dealing with Dolby's proprietary mapping within their workflow, followed up by multi-step encoding and extremely long transcode times. Also, I had to re-evaluate how I was going to implement this product, as most post production Dolby content targets multiple displays at different nit levels and color spaces within one file. I am still aiming for the end of the first quarter, possibly early into the second. I would like to thank everyone for their patience as I finalize the first revision of this product!
- Ryan M.
mascior is offline
post #1611 of 1765 Old 02-19-2019, 08:53 PM
mombasa123's Avatar
Quoted: 101 Post(s)
Liked: 33
Does this need a meter?
Interested in this for my Q9FN but is it like the AVS HD calibration where it can be done by eye or does it need a meter?
Some of the patterns look v similar to AVS HD so should be able to use those by eye right?
mombasa123 is offline
post #1612 of 1765 Old 02-19-2019, 09:04 PM
poppagene's Avatar
Quoted: 848 Post(s)
Liked: 715
You need a meter
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is online now
post #1613 of 1765 Old 02-19-2019, 11:10 PM
skschatzman's Avatar
Quoted: 2610 Post(s)
Liked: 1565
By eye calibration has been proven to be invalid for accuracy(Other than Contrast & Brightness). It is a complete waste of time and money spent on resources. I highly recommend you do some research. If you still want to improve picture quality, then buying the necessary tools learning a new skill or hiring a professional are the only valid paths.
galonzo and mombasa123 like this.
skschatzman is offline
post #1614 of 1765 Old 02-20-2019, 12:00 AM
mombasa123's Avatar
Quoted: 101 Post(s)
Liked: 33
Noted & thanks. Was thinking of doing that ... getting tools i mean
galonzo and mrtickleuk like this.
post #1615 of 1765 Old 02-20-2019, 10:28 AM
p5browne's Avatar
Quoted: 3983 Post(s)
Liked: 3140
By eye, to make it look the way you like.
Accuracy, not even close!
mombasa123 likes this.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #1616 of 1765 Old 02-20-2019, 11:49 AM
mrtickleuk's Avatar
Quoted: 4369 Post(s)
Liked: 6623
Yes. It can't be called "calibration" if you don't use a meter to take measurements, by definition
If it helps, imagine putting up a set of shelves "by eye" without using a spirit level.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #1617 of 1765 Old 02-20-2019, 12:03 PM
Liked: 1565
Technically contrast and brightness are considered calibrated by eye.
post #1618 of 1765 Old 02-20-2019, 12:06 PM
Quoted: 4260 Post(s)
Liked: 5186
There used to be lots of guys who calibrated by eye! It saved money on equipment, software and training and everyone always raved how great the results were. AND you could always share and use the same settings on everyone's set even across TV brands .
mrtickleuk likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G
Calman Ultimate, ISF Level III Certified
jrref is online now
post #1619 of 1765 Old 02-20-2019, 12:29 PM
Liked: 1565
Ignorance is bliss
richardsim7 likes this.
post #1620 of 1765 Old 02-20-2019, 12:36 PM
p5browne's Avatar
Liked: 3140
By eye means to make it look like the sets down where the TV was bought! (And we know how accurate they are! That's what got you to buy the set in the first place.)
UN65KS9800 - Mine
p5browne is offline
Reply Display Calibration
