R.Masciola's HDR-10 UHD Test Patterns - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 1069Likes
post #1621 of 1764 Old 02-20-2019, 01:10 PM
mrtickleuk's Avatar
Quoted: 4349 Post(s)
Liked: 6594
Originally Posted by skschatzman View Post
Technically contrast and brightness are considered calibrated by eye.
Adjusted correctly, perhaps. "Calibrated", no. Look it up in a dictionary
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #1622 of 1764 Old 02-20-2019, 02:15 PM
skschatzman's Avatar
Quoted: 2564 Post(s)
Liked: 1535
There are many varying definitions of the word calibrate. Including "to adjust precisely for a particular function" from Webster's dictionary.
The human eye is used to precisely adjust contrast and brightness.
skschatzman is offline
post #1623 of 1764 Old 02-20-2019, 02:34 PM
mrtickleuk's Avatar
Liked: 6594
For TVs, it means using an accurate instrument.
_______________
post #1624 of 1764 Old 02-20-2019, 02:38 PM
Liked: 1535
The human eye is an accurate instrument for precisely adjusting contrast and brightness.
post #1625 of 1764 Old 02-20-2019, 06:15 PM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
Fair points all.
looks like i am going to have to invest in Calman spectrometers and a lot of reading time
Impossible to get professional (or any) calibration in HK - they dont have a clue here ......
galonzo and mrtickleuk like this.
mombasa123 is offline
post #1626 of 1764 Old 02-21-2019, 05:00 AM
Liked: 0
Is there any specific test pattern for OLED LG display for SDR calibration ? Or windows pattern are enough ?
squall049 is offline
post #1627 of 1764 Old 02-21-2019, 05:26 AM
Liked: 0
I mean, i want to use AVS HD 709 windows pattern to calibrate SDR on my 65 FZ800, then Buy Diversified Video Solution To calibrate HDR 10.
Am I right ?
post #1628 of 1764 Old 02-21-2019, 11:44 AM
mrtickleuk's Avatar
Liked: 6594
<sits on hands>
_______________
post #1629 of 1764 Old 02-21-2019, 07:38 PM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
So I am thinking of getting a Calman C6 spectrometer. Am i correct in thinking that all I need is Calman C6, Calman software, Pattern generator (Ryan's suite), Laptop?
First step would be to use the Samsung / Calman autocal feature and then fine tune manually (not that I am at all getting ahead of myself with knowing nothing )
I see Calman are going to be releasing a cheaper Home version package soon. Will wait for that.
post #1630 of 1764 Old 02-21-2019, 09:02 PM
Rolls-Royce's Avatar
Quoted: 1018 Post(s)
Liked: 1153
The C-6 is a colorimeter, not a spectrophotometer. Completely different beast.
mombasa123 likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #1631 of 1764 Old 02-21-2019, 11:00 PM
Liked: 0
Hey guys first time posting a question so forgive me if i dont ask it clearly i have an lg oled 2016 model using hdr patterns from R.Masciola my question is as follows i imported the 2016 lg csv into my chromapure software yet when trying to use white balance the lg uhd file i downloaded says adjustment point=1 10 bit code value =127 target luminance y = 0.14 what pattern should i use from Masciola pattern found in the greyscale?
goibear is offline
post #1632 of 1764 Old 02-22-2019, 06:18 AM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
Hi goibear,
Within the miscellaneous section of the pattern suite, you should see a folder labeled "LG Display Code Value Grayscale Sweeps". Open the folder, select OLED and you will see a list of available years. Just select the 2016 folder and all of the patterns within should follow the requested sequence. I hope this helps. Thanks!
- Ryan M.
mascior is offline
post #1633 of 1764 Old 02-22-2019, 07:45 AM
Liked: 0
Thank you i will go ahead in find that, the chromapure should follow the pattern order that is found in the usb? Because on the usb it goes from 100 the goes from 0 to 90
goibear is offline
post #1634 of 1764 Old 02-26-2019, 08:43 PM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
Hi,
Following on from my previous numpty posts, would be grateful if someone could answer the below please?
1) Does Calman support these patterns directly (like it does with AVS HD), ie tells you which patterns to use step by step?
Edit : Think the answer is to upload Ryan's Calman workflow? Or is it just for checking but can;t use for calibration?
2) It looks like the AutoCal feature needs an external pattern generator like VideoForge? That's way too expensive for my use. Or, can AutoCal use the patterns disk with manual intervention?
Maybe, the upcoming Calman Home product will sort that but no details yet.
post #1635 of 1764 Old 02-26-2019, 11:23 PM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
I'm thinking XRite i1 Pro 3 & ChromaPure + Ryan's patterns is a decent option over CalMan Home if i want it now? HCFR seems too much to get into.
I don't think CalMan AutoCal will work without an external pattern generator but happy to be corrected.
post #1636 of 1764 Old 02-27-2019, 01:37 AM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
Calman AutoCal works fine with manual pattern selection - it's just a little less automatic as you need to select the approaite pattern from your chosen set.
galonzo and mombasa123 like this.
JayAy is offline
post #1637 of 1764 Old 02-27-2019, 11:25 AM
mrtickleuk's Avatar
Liked: 6594
Hi,
Answering both questions, yes you can tell Calman that your pattern source isn't automatic. You enable this option:
Then each time Calman wants to request a different pattern, it asks you to display it and describes what it wants, like this:
The issues are down to patience and practicality. Autocal is likely to repeatedly request lots of different shades of grey in random order, maybe hundreds of times. What would take a few minutes using a source which changes automatically - not just an expensive generator but also a cheaper accurate one such as the Raspberry Pi - could take you an entire day doing manually. Then at the end if you've made a mistake you might have to re-do it!
Name:	Calman-manual prompts1.png
ID:	2531834   Click image for larger version
Name:	Calman-manual prompts2.png
_______________
post #1638 of 1764 Old 02-27-2019, 11:47 AM
Quoted: 4234 Post(s)
Liked: 5146
Also I don't think you can do a 3D LUT on the LG like that unless you stay up all night manually changing patterns as well.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G
Calman Ultimate, ISF Level III Certified
jrref is offline
post #1639 of 1764 Old 02-27-2019, 06:19 PM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
Thanks! Yes would be v painful with manual intervention.
So CalMan AutoCal will support an RPi pattern generator? Where does one get that from please?
Fyi, Ted's HDTV Calibration Disk also supports semi-auto CalMan AutoCal. Which then leaves HDR 10 ......
post #1640 of 1764 Old 03-01-2019, 07:56 PM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
How to use CalMan Workflow
I have just purchased and downloaded the HDR 10 Media files but can't figure out how to use the CalMAN workflow. Is there a CalMAN workflow template or is that not how it works?
post #1641 of 1764 Old 03-01-2019, 08:27 PM
Liked: 1535
If you have an issue with Calman, then you should post in that forum.
post #1642 of 1764 Old 03-02-2019, 03:38 AM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
No, I meant does the disk come with CalMAN workflows which can be loaded into CalMan or does one have to use a standard workflow? Just looking for info on how to use the CalMan patterns on the disk. It's not very clear to me as a beginner i'm afraid.
Edit : it doesn't come with the Calman workflow templates - at least none I could see, Any instructions anywhere on how to use in Calman please?
post #1643 of 1764 Old 03-02-2019, 06:06 AM
Liked: 1535
Ah so there is the issue. You can't use file patterns in Calman. You would need a reference test pattern generator for that.
The file patterns have to be manually loaded 1 at a time after every single reading. Most TVs allow you to load images on a thumb drive inserted into the USB of the TV.
post #1644 of 1764 Old 03-02-2019, 07:05 AM
Liked: 1153
Oh, the pain, the pain...
galonzo and jrref like this.
...Royce...
post #1645 of 1764 Old 03-02-2019, 07:32 PM
mombasa123's Avatar
Quoted: 98 Post(s)
Liked: 32
I emaiedl Ryan and he sent me the CalMAN workflow template which is available on request for all purchasers. All good. Thank you, Ryan!
Now to figure out how to use CalMAN - starting with Ted's Calibration Disk for SDR.
Regards
monkaquinas likes this.
post #1646 of 1764 Old 03-02-2019, 08:04 PM
Liked: 1535
Regards
Uh. There is no special Calman workflow. Calman already comes with a workflow that Ryan built his patterns around. The workflow he sent you already comes with Calman. Also the way you worded your last post that I quoted made it sound like you were looking for a way to insert the patterns into Calman, which you can't do.
post #1647 of 1764 Old 03-10-2019, 06:33 PM
ChavesBR's Avatar
Liked: 0
Will this work with the Panasonic FZ950/952?
ChavesBR is offline
post #1648 of 1764 Old 03-10-2019, 07:01 PM
Liked: 1535
If the unit is capable of HDR10. It is just a suite of HDR10 test patterns that you use in conjunction with software & meter calibrations.
galonzo likes this.
post #1649 of 1764 Old 03-21-2019, 03:42 PM
Liked: 1535
@mascior
Been a while Ryan. Any new updates for the DV suite?
post #1650 of 1764 Old 03-21-2019, 05:49 PM - Thread Starter
A/V Addicted Member
mascior's Avatar
Quoted: 410 Post(s)
Liked: 771
@mascior
Slowly but surely...I have quite a few sections completed though, grayscale, 50/50 color, basic setup. However, I'm still working on a custom CalMAN workflow. Also, once completed, I need to get the entire pattern suite blessed by Dolby. The first revision will be limited, but encompass all necessary patterns for a complete calibration, along with basic observation, though numerous revisions are planned. The biggest challenge and the most time consuming portion of this entire project, is the verification process of each pattern once transcoded. This isn't as simple as creating a test patch and encoding with applied metadata as with HDR-10. This is an entire detailed process from beginning to end, involving a multitude of steps and processes. Also, to make it even more challenging, all patterns are interpolated from a SDR base version of the original HDR master...not to mention dealing with Dolby's proprietary IPT for color. I was aiming for the first quarter...now it's looking like mid-second quarter. I appreciate everybody's patience as I finalize this project, a lot has gone into it. Thanks!
- Ryan M.
mascior is offline
Reply Display Calibration
