R.Masciola's HDR-10 UHD Test Patterns - Page 56 - AVS Forum | Home Theater Discussions And Reviews
 1145Likes
post #1651 of 1863 Old 03-22-2019, 09:05 AM
p5browne's Avatar
Quoted: 4095 Post(s)
Liked: 3258
I hope Dolby is not trying to hit you up for a sizable contribution to their war chest!
UN65KS9800 - Mine
QN49Q70R / UN65HU9000 + SEK-3500U / UN75JU7100 (JS9000 Mod Mode) / UN55HU7250 with SEK-3500U (JS9000 Mod Mode) / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #1652 of 1863 Old 05-06-2019, 01:49 PM
panasonicst60's Avatar
Quoted: 223 Post(s)
Liked: 121
I have the C8 and by the time I get to calibrate my Dolby vision the C12 will be out...
panasonicst60 is offline
post #1653 of 1863 Old 05-06-2019, 05:50 PM - Thread Starter
mascior's Avatar
Quoted: 415 Post(s)
Liked: 787
I truly appreciate everyone's patience. For what it's worth, The Dolby Vision project revision 001 is finally complete. However, I just received an updated DV workflow from Tyler and I need to update the saturation sweep module. Also, Dolby is currently reviewing some sample files, which I'm currently waiting on feedback. If I had to guess and if everything goes as planned, the pattern suite should be released this month!
- Ryan M.
mascior is offline
post #1654 of 1863 Old 05-07-2019, 04:29 AM
Quoted: 223 Post(s)
Liked: 121
Of course my post above was a joke . Just wanted to revive the thread! I'm looking forward to it!!
post #1655 of 1863 Old 05-07-2019, 09:01 AM
Quoted: 121 Post(s)
Liked: 51
- Ryan M.
Looking forward to getting the HDR-10, HLG, DV suite from you (already purchased the HDR-10). Let us know if you are going to do pre-orders, early access, or when it is ready to drop. Thank you again for all of your hard work!
ajc9988 is offline
post #1656 of 1863 Old 05-07-2019, 12:58 PM
Quoted: 13 Post(s)
Liked: 1
Hi!
I just found about this test patterns and I would like to ask If I can use it for my projector Optoma UHD51a? I really need something to calibrate HDR, because I have this projector for 6 months and I still haven't found the right settings. Thanks for any reply.
teidybugi is offline
post #1657 of 1863 Old 05-07-2019, 02:50 PM
Quoted: 223 Post(s)
Liked: 121
Originally Posted by teidybugi View Post
Hi!
You will need calibration software, colorimeter, 4k player, and this disc.
Edit: Your projector has usb input so you don't need a 4k player.
TV: OLED65C8P - Receiver: Emotiva XMC-1 - Blu-ray: Panasonic UB820 - Cd transport: Cambridge Audio CXC - Amp: Parasound A31 - LCR Speakers: Ascend Towers & Luna Duo - Surround: Noble Fidelity L-65mkII - Sub: Rythmik F18 - Power Distribution: PS Juice Bar II, Furman PST8D - Power Cable: PS AC5, PS SC, Shunyata Venom 14 - Speaker Cable: Kimber 8tc, BJC 10 - RCA Cable: RCA & XLR Pure Silver - Probe: i1 Display Pro OEM Rev.B - Software: Lightspace HTL, Calman Enthusiast - Bias Lighting - MediaLight
post #1658 of 1863 Old 05-08-2019, 11:36 AM
Quoted: 13 Post(s)
Liked: 1
So you can't use this test patterns on its own without colorimeter? I though the point of this patterns is to calibrate it on your own without all the expensive gear. Otherwise I have 4k player since the projector won't play remux files with atmos (as many other players).
post #1659 of 1863 Old 05-08-2019, 11:55 AM
Quoted: 223 Post(s)
Liked: 121
Nope. The point of Ray's test patterns are so you don't have to invest in buying an expensive pattern generator. A good colorimeter, say the x-rite display pro is fairly cheap at about $200. You have to remember that any calibration done without a colorimeter is NOT accurate. Invest in one and you'll never regret it. They have free software like the hcfr that will get the job done. But for a better calibration experience I recommend lightspace or calman.
galonzo likes this.
post #1660 of 1863 Old 05-08-2019, 11:58 AM - Thread Starter
mascior's Avatar
Quoted: 415 Post(s)
Liked: 787
Hi teidybugi,
A meter is required for HDR video calibration in general, not just limited to our products. What we offer is an extremely inexpensive solution to generate reference HDR test patterns for video calibration. "Expensive" is subjective. However, $25 - $50 for reference HDR test patterns vs $1,500+ for a TPG is quite an attainable option. With quality colorimeters under $300 and freeware calibration software like HCFR, it has never been cheaper to DIY. I hope this helps. Please let me know if you have any further questions or concerns. Thanks!
- Ryan M.
richardsim7 and ajc9988 like this.
mascior is offline
post #1661 of 1863 Old 05-08-2019, 12:40 PM
p5browne's Avatar
Liked: 3258
Member spends hundreds of dollars to have a professional come in and calibrate his set with professional equipment.
After calibrator has gone, Member, then re-tweaks the results because he doesn't like how it looks! (Hope he kept a settings record of what the hundreds of dollars paid for!)
An old expression around these parts `The Meter never lies.' But eye ball calibrators will live forever.
richardsim7 and mrtickleuk like this.
UN65KS9800 - Mine
p5browne is offline
post #1662 of 1863 Old 05-08-2019, 04:31 PM
Quoted: 13 Post(s)
Liked: 1
Hi teidybugi,
- Ryan M.
Aah, thanks for explaining that up guys. And here I thought I finally found something "cheap" to calibrate my projector. I am mostly looking to get better HDR colors than I have atm, but it doesn't need to be "professional" level, at least not at the budget I have right now (I would like to have it someday). I'll try to check if any local projector store does any sort of calibration that is not too much expensive. Maybe even one of you guys have any recommendation for UHD51a. Yes I know it varies from person to person, but at least something that I can try and maybe it's even better than what I have right now. I'm thanking you all for the support.
post #1663 of 1863 Old 05-08-2019, 06:48 PM
p5browne's Avatar
Liked: 3258
It would help if you had info as to where you're located in case someone can help in your area.
(Upper right > User CP > to the left, Edit Details)
mrtickleuk likes this.
UN65KS9800 - Mine
p5browne is offline
post #1664 of 1863 Old 05-08-2019, 09:13 PM
Quoted: 223 Post(s)
Liked: 121
Hi teidybugi,
- Ryan M.
I honestly don't think you can get a professional to come by for under $250, which is the cost of a new colorimeter and Ray's software. Any setting from the internet for your projector will more than likely be worst then what you have stock at the moment. I suggest saving up and investment in the diy equipment. I'm sure this will not be the only projector you will own for your entire life, so it's a great future proof option.
post #1665 of 1863 Old 05-08-2019, 10:58 PM
p5browne's Avatar
Liked: 3258
For projectors, add to this - how old was the lamp when the reference setting was calibrated, versus age of lamp some Member is going to use the settings for his projector?
I'm assuming, calibration frequency for projectors is more frequent than a flat panel? Another reason for DIY.
UN65KS9800 - Mine
p5browne is offline
post #1666 of 1863 Old 05-10-2019, 12:47 PM
Quoted: 13 Post(s)
Liked: 1
Well... looks like it I'll have to add another thing to my wishlist to buy. I still need to get some proper speakers and then I can get a colorimeter and when it comes to that I'll ask you again for suggestions if anything will change by then. Thank you all again for clearing everything up and offering your amazing support.
Optoma UHD51A - 106" EliteScreen projector screen- Zidoo X10 - Sony UBP-X800
post #1667 of 1863 Old 05-21-2019, 12:49 PM
santodx5's Avatar
Quoted: 196 Post(s)
Liked: 33
Halo,
It is almost at the end of the month, Ryan can you update when DV pattern will be available?
MrRobotoPlus likes this.
santodx5 is offline
post #1668 of 1863 Old 05-22-2019, 09:12 AM
Liked: 0
Should i adjust "color" or just "contrast" in the CMS when using the color clipping pattern for HDR 10?
buzz68 is offline
post #1669 of 1863 Old 05-22-2019, 10:07 AM
roxiedog13's Avatar
Quoted: 2838 Post(s)
Liked: 1506
Quick Brown Fox 4K download needed
Can someone share this download or advise where I can get a copy please .
Tks
Dedicated Theater: Sony VPL VW5000 , Panamorph DCR & ISCO III L Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 134" diagonal curved , Denon AVR-X8500 , 9.2.6 Atmos, Panasonic UB900, Oppo 203, Lumagen Pro 4440 , (3) Paradigm CI Elite E7-L+C+R fronts, , (2) CI Pro P80-IW Rear, (2) Paradigm SA-ADP In-wall Surround, (6) SIG-1.5R-30 v.3 In-Ceiling, Subwoofers: (2) SVS SB-16 Ultra , (1) SVS PC13-Ultra .
roxiedog13 is offline
post #1670 of 1863 Old 05-22-2019, 12:20 PM
Rolls-Royce's Avatar
Quoted: 1322 Post(s)
Liked: 1397
Tks
I'm sorry, but this is in the wrong thread. It has absolutely zero to do with display calibration or the product being discussed here.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #1671 of 1863 Old 05-22-2019, 12:33 PM
skschatzman's Avatar
Quoted: 2871 Post(s)
Liked: 1668
Neither. Color clipping is used to see if there are any preexisting errors or to check for new errors after calibration.
The color setting adjusts the overall saturation levels of all colors. It should only be adjusted after taking measurements with a colorimeter. In almost all cases these days color should be accurate by default.
Contrast adjusts the content peak brightness to the display peak brightness. This should only be adjusted by using a contrast pattern.
skschatzman is offline
post #1672 of 1863 Old 05-22-2019, 12:36 PM
Liked: 1668
Tks
That would be illegal. It isn't smart to advertise a crime in an open forum. Good luck avoiding criminal charges.
post #1673 of 1863 Old 05-22-2019, 12:45 PM
roxiedog13's Avatar
Liked: 1506
Well , not sure I agree with your comment , the pattern I asked for is definitely used hand in hand during most calibration , in-fact , the R.Masciloa'sHDR-10 test patters also have 4K test patterns. I know because I have paid for and use the same . Now I could agree this may not be the best place to have asked , then again I did a search for the same , there is no dedicated thread for QBF pattern that I could find, so I just posted this here . I'll start a new thread if I can, although I'm sure a few active home calibrators may have a copy to share .
post #1674 of 1863 Old 05-22-2019, 12:51 PM
Liked: 1668
You are going about this all wrong. If you really did pay for the suite and need a download link, then you need to contact the owner. Doing what you are doing is intentionally illiciting someone to commit a crime.
post #1675 of 1863 Old 05-22-2019, 01:01 PM
Liked: 1397
I was looking for a link, and the only "Quick Brown Fox 4K" that came up in a Google search is a game apparently based on Guitar Hero. Hence my comment.
...Royce...
post #1676 of 1863 Old 05-22-2019, 01:05 PM
roxiedog13's Avatar
Liked: 1506
Calibrations not going as planned possibly ? You guys need to lighten up ( pun intended) a little . Absolutely not worried about criminal charges my friend, but I also didn't realize the pattern was under license . If you know that it is , maybe you could have simply suggested where to buy instead of throwing the fear of legalities in my direction . I simply thought it was a free clip provided by a fellow member. Besides, I can ask for anything, "legally" those that provide it would be in the wrong if indeed the copy right police are on duty.
Thanks for nothing , moving on!
post #1677 of 1863 Old 05-22-2019, 01:12 PM
Liked: 1668
Incorrect. Illiciting a crime is still a crime.
If I higher a hitman to murder someone, then I would be held just as liable as the hitman.
If you didn't know the suite was licenced then I can understand that, but it isn't the first time we have seen someone try to get a licensed product for free. Hopefully you can understand that.
post #1678 of 1863 Old 05-22-2019, 01:25 PM
roxiedog13's Avatar
Liked: 1506
If you didn't know the suite was licensed then I can understand that, but it isn't the first time we have seen someone try to get a licensed product for free. Hopefully you can understand that.
I bet you don't have any music files or any other licensed copyright products at all that you have not paid for I assume. I asked a simple question, next time maybe you could try being polite and just offer a solution or direction instead of assuming I was looking for a fee copy. Would have likely taken less time , you could have even been helpful. Have to ask, do you work for Masciola ? Your OVER reaction to a simple request must have some level of reasoning .
post #1679 of 1863 Old 05-22-2019, 04:48 PM
p5browne's Avatar
Liked: 3258
And here I thought he was looking for a Movie. Probably why, if most of us have never heard of it, thought the same, hence you're in the wrong Forum.
After a search, came up with this URL:
http://www.geeks3d.com/20141203/how-...our-4k-uhd-tv/
Which leads to this URL with the download:
https://forums.geforce.com/default/t...oma-hdmi-2-0-/
Despite the author saying 4K in the first URL, the download is actually only 2k. Going through the Forum in URL 2, a Member offers to produce a 4K version, but was ignored, and no further discussion was made about a 4K Version.
Did find these 2 URLS that may be of interest:
https://www.extron.com/article/testpattern
https://www.churchmotiongraphics.com...eo-image-test/
UN65KS9800 - Mine
p5browne is offline
post #1680 of 1863 Old 05-22-2019, 06:17 PM
Quoted: 5576 Post(s)
Liked: 2250
Here’s the link. Patterns courtesy of forum member Javs.
https://photos.smugmug.com/TEST-PATT...UBSAMPLING.png
Dominic Chan is offline
Reply Display Calibration
