R.Masciola's HDR-10 UHD Test Patterns - Page 63 - AVS Forum | Home Theater Discussions And Reviews
 1145Likes
post #1861 of 1863 Old 02-04-2020, 07:58 AM
Craig Peer's Avatar
Quoted: 7596 Post(s)
Liked: 9358
Originally Posted by skschatzman View Post
Have you tried putting them on a thumb drive?
That’s what I do. I just plug it into my Panasonic UB820.
Craig Peer is offline
post #1862 of 1863 Old 02-06-2020, 01:38 PM
p5browne's Avatar
Quoted: 4076 Post(s)
Liked: 3250
Thumb drive directly into the TV: calibrates for USB and APPS.
Thumb drive into BD player, then TV: calibrates the HDMI Input
UN65KS9800 - Mine
QN49Q70R / UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #1863 of 1863 Old 02-06-2020, 04:58 PM
anevard's Avatar
Quoted: 29 Post(s)
So my concern is that supposedly there is a difference in output levels between the USB port and Blu-rays on the 820.
As it turns out, the 820 can read .mkv files from a burnt disc but not .mp4 or .ts.
So I solved the problem by doing a lossless conversion with ffmpeg from .mp4 to .mkv. Burnt a disc and, voila, it works. Only issue is all the filenames are truncated to 8 characters. I will have to see if there is an ImgBurn setting that can remedy this.
Andrew
Craig Peer and galonzo like this.
anevard is offline
Reply Display Calibration
