i1lt has been sitting in a draw for years. Still ok to use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-24-2017, 09:48 PM - Thread Starter
beekermartin's Avatar
Quoted: 97 Post(s)
Liked: 31
I have an Eye One LT that has been sitting in a dark draw since that last time I used it back in 2009. I assume at this point it won't be accurate since I know calibration drifts with time. Should I just throw it away or does it have any useful purpose at this point? Can it still measure lumens accurately or serve any other useful purpose?
I am planning on buying a new meter soon but I wanted to ask about the i1lt before I just junk it.
beekermartin is offline
post #2 of 5 Old 01-25-2017, 06:18 AM
ivan2011's Avatar
Quoted: 26 Post(s)
I have one that is about a year newer, I am hoping to do a comparison with an i1d3 a bit later, I will post results once done. I did this about a year or so ago (did not document) the i1lt was way off from the i1d3.
ivan2011 is offline
post #3 of 5 Old 01-25-2017, 12:59 PM
ivan2011's Avatar
Quoted: 26 Post(s)
Fire tv test is i1d3
ivan2011 is offline
post #4 of 5 Old 01-25-2017, 02:25 PM
ConnecTEDDD's Avatar
Quoted: 2910 Post(s)
Liked: 3545
Hi, Eye One LT (aka i1Display 1) had 3 exposed filters, low grade quality (to keep the price low); natural aging (even when stored well)/humidity had already discolored them, this has degrade the meter accuracy a lot, making it un-usable I believe.
Since you don't have a spectro to use as a reference to do a comparison, it's unknown how much has been drifted.
Now with i1Display PRO (i1Display 3); it has dichroic filters which are sealed with rubber o-rings. Due to it's design, the meter's life is extended and this prevents drifting also.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #5 of 5 Old 01-25-2017, 04:45 PM - Thread Starter
Quoted: 97 Post(s)
Liked: 31
It sounds like buying a new meter is what I should do. Thanks for the responses!
Reply Display Calibration
