LG 2017 OLED Calibration Thread and Settings - Page 104 - AVS Forum | Home Theater Discussions And Reviews
 3285Likes
post #3091 of 3124 Old 12-25-2018, 06:35 AM
ConnecTEDDD's Avatar
Quoted: 2921 Post(s)
Liked: 3569
Originally Posted by TitusTroy View Post
I'm still confused about two things with the C7...I've read many posts with differing opinions on this...right now I have Sharpness set to 10 across all modes and Edge Enhancer turned ON for all modes...is there a definitive answer to this:
1) what should Sharpness be set to?...meaning what is the best setting is with no additional Sharpness added to the image...normally the answer would be 0 (zero) but many people on here have stated to keep it at 10 because anything below 10 softens the image...even a well known calibrator on here stated to keep it at 10 ( @jrref )...is 10 the correct setting?
2) Edge Enhancer...this is another one giving me a headache...earlier in this thread some people tested this and stated that Edge Enhancer OFF disables the Sharpness control and Edge Enhancer ON enables the Sharpness control...somebody tested it with all the Picture Modes and stated the following: "Set Sharpness to 0 and then switch back and forth between Edge Enhancer ON/OFF and you'll see no change to the picture. Next, max out Sharpness to 50. Now switch back and forth between Edge Enhancer ON/OFF. You'll see a normal unsharpened image with OFF and ugly sharpening with ON. If you want to bypass artificial sharpening, keep Edge Enhancer OFF"
the 2nd question goes hand in hand with my first question about Sharpness...so if I set Sharpness to 10 and disable EE then that means that my Sharpness setting of 10 will not be recognized...I hope some of the experts on here can give me a definitive answer to these questions...thanks!
Hi, use a sharpness pattern and test the settings, its very easy to find out what is happening.
LG has informed about this recommendation: ''The ‘Edge Enhancer’ setting in the Expert Picture Mode Settings does not increase sharpness; the default ‘On’ setting is a bypass function, and is therefore recommended''
Probably LG want to say that in Expert mode this setting is not working, so even if you set it to OK, that enhancement (which amplifies the high-frequency components of a signal) processing is bypassed. I haven't checked if it makes any difference (On/Off) to other modes.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3092 of 3124 Old 12-25-2018, 06:41 AM
Liked: 3569
Originally Posted by Megalith View Post
Can anyone comment on what the most accurate correction file is for DisplayCal?
Hi, There is a CCSS LG OLED 2017 spectral correction table for i1Display PRO instrument users, it will work from ColorMunki Display also. (both meters can read spectral corrections).
But when you are using CCSS correction, you assume that the internal spectral data of X-Rite meter from the factory hasn't drifted, since the internal meter spectra + CCSS spectra data are used to create a correction matrix.
Don't use any other user CCMX file for LG OLED, it will not work, only if you have your own meters combo (colorimeter+spectro) for creating a matrix based correction (CCMX = Colorimeter Correction Matrix) which will be only valid for your current meters/display.
post #3093 of 3124 Old 12-25-2018, 07:52 AM
Megalith's Avatar
Quoted: 86 Post(s)
Just so I'm clear, are you talking about the WRGB_OLED_LG.ccss that is included with HCFR? I used that last week and am pretty happy with the results.
Megalith is offline
post #3094 of 3124 Old 12-25-2018, 09:46 AM
Terry B's Avatar
Quoted: 12 Post(s)
Red face
When you are applying such large adjustments with LG CMS, always use a color ramp pattern to validate for issues.
A good way of testing what is happening with CMS adjustments enabled/disabled, is to copy paste all your ISF-Dark settings to ISF-Bright, including all 2/20-Point RGB balance but not copy CMS settings. Then using TV remote swap between the 2 picture modes while you will display some color ramp patterns to see if the picture mode with CMS adjustments is adding banding/false contouring/clipping or other issues.
Thanks for that useful tip. Where can I get the colour ramp patterns from. I am using HCFR with AVCHD709 patterns in MP4 on USB stick.
Terry B is offline
post #3095 of 3124 Old 12-25-2018, 10:10 AM
Liked: 3569
If I remember well, AVSHD has color steps patterns, not color ramps.
https://www.avsforum.com/forum/139-d...l#post56539952
https://www.avsforum.com/forum/139-d...l#post57237412
post #3096 of 3124 Old 01-11-2019, 09:21 AM
thaiusmle's Avatar
Quoted: 26 Post(s)
Originally Posted by P40L0 View Post
An update for LG 2017 OLEDs - Calibrated Settings for Xbox One X / Gaming:
  • Added V5 - EXPERIMENTAL HDR Game profile tuned for HIGH Dynamic Contrast: it's a totally new proposal for a MUCH brighter HDR (even more bright than HDR Technicolor with Active HDR) trying also to eredicate most of HIGH DC negative effects and be as accurate as possible at the same time. FEEDBACK IS WELCOMED
To eliminate/compensate HIGH Dynamic Contrast negative effects on PQ:
EDIT (14/12/2018):
  • Raised Brightness from 50 to 53: this will fix most introduced black crush, while some will remain very slightly. It's the highest value that can be set before loosing "perfect blacks" of OLEDs;
  • Color Gamut set from Auto to WIDE + Color 44: when DC is set to High, I noticed that Auto color gamut will suddenly show wrong/muted colors (especially muted oranges/yellows and magenta) and all of them become undersaturated. Switching to WIDE made oranges/yellows back to normal, and considering WIDE is oversaturated with same settings compared to Auto, setting its Color to 44 gave back a very comparable accuracy to Technicolor
  • Color Temperature is back to W50
I'm very impressed by far with this new experiment, as I was able to achieve an even brighter image than HDR Technicolor with Active HDR, but with no highlights clipping (typical of PC HDR Standard) and mostly accurate colors. The only visible downside is a very very slight black crush, that can not be fixed without losing also perfect blacks, but it's not bad at all.
Both Battlefield V and Forza Horizon 4 look mind blowing with this new setup, but any FEEDBACK to further improve it is always welcomed.
Give it a spin and let me know what you think
Can I use your settings with Apple TV or Nvidia Shield source? Thank you for sharing!
thaiusmle is offline
post #3097 of 3124 Old 01-13-2019, 01:39 PM
Quoted: 17 Post(s)
Liked: 1
Originally Posted by MrFlooD View Post
When performing the 2 point HDR calibration. What are the recommend points? Is it still 30 & 80 like SDR?
Bump
Sent from my Pixel 3 using Tapatalk
Tucker Smash is offline
post #3098 of 3124 Old 01-13-2019, 03:45 PM
Quoted: 388 Post(s)
Liked: 195
Originally Posted by Tucker Smash View Post
Bump
For SDR only 100 High then 20 points. For HDR I do 100/30. Only subtract.
LG OLED 55 B7v | LG SK10Y Soundbar | Samsung 55KS8000 | LG Plasma 50PZ550 | i1D3 OEM | Calman Enthusiast
MrRobotoPlus is online now
post #3099 of 3124 Old 01-16-2019, 12:58 AM
Liked: 3569
Bump
100% is 10000nits, the display is already clipping at that level, try to use a lower percentage like 70% (which is 619 nits) or 65% (which is 389 nits) to fix only RGB balance errors or take a full grayscale sweep and then apply the RGB-High adjustments you believe they will reduce your White Balance errors at the top end of your grayscale.
With HDR mode is not a good idea to keep the same pattern (with high luminance) static for real-time adjustments, because the panel's are unstable at HDR10 it's better idea to display the pattern you like to measure and after measuring it... to display a black pattern (or 5/10% Gray) and then open the LG OSD to apply the adjustments you believe they will reduce your errors. (so the panel will cool down).
post #3100 of 3124 Old 01-16-2019, 05:47 AM
Quoted: 17 Post(s)
Liked: 1
So you're recommending a 70/30 point rgb adjustment?
post #3101 of 3124 Old 01-17-2019, 03:45 AM
Liked: 3569
You can test and see what way works better with your display, but always check color reproduction patterns and real content, because large adjustments can introduce issues.
If 70%/30% or 70% only or 65% only works, post your results of the method you followed.
post #3102 of 3124 Old 02-07-2019, 12:40 PM
Quoted: 17 Post(s)
Liked: 1
When looking at your color ramps vertical and horizontal, what am I looking for? Is it just a smooth gradation of color that I want?
post #3103 of 3124 Old 02-11-2019, 03:36 AM
Liked: 3569
Hi Tucker,
There 2x Color Ramps Horizontal/Vertical, you can find them to the Color Reproduction Page 5.
There models from Sharp/Toshiba/LG, were they have problematic CMS controls, they are not designed well, each CMS setting has its own 'safe working range' (for example +-2 max) where you can adjust without to introduce to you issues with real content. Even specific combination of adjustments between different calibration controls can introduce banding/posterization/false contouring/noise/distortions/no smooth gradation, clipping etc...
When you performing CMS calibration, start with Primary Colors, and when R,G,B promaries are fine, then move to secondary colors.
But always check if there issues with gradation after the CMS or grayscale adjustment, using gray/color ramps patterns.
After the end of your grayscale adjustment display a grayscale ramp pattern to see if there no any strange color tint and that your grayscale gradation is OK.
Then before starting your CMS adjustments display a color ramp (look here an example of issues) to see about your color gradation and at this stage change randomly some CMS adjustments controls to see if they are introduce any error to your color ramps, if you see that all are fine (until at a specific adjustment range +-5 for example) reset the CMS and then start your measurements to improve your CMS. At the end of your CMS adjustments display again a color ramp pattern to see that all are fine, then recheck again your grayscale for micro-adjustments.
There some LG models where their 'Luminance' controls are adding some issues, see there an example: https://www.avsforum.com/forum/40-ol...l#post45436297
For that reason you have to always check color gradients/ramps after performing adjustments and then using actual Blu-Ray movie content.
A good pattern to quickly reveal issues before spending some time with real movies and while you have your meters connected and calibration software open to decide quickly what to do next...are these Color Ramps Vertical/Horizontal patterns, BTW Vincent from HDTVtest.co.uk are using them also (see 5:11):
Because of these issues coming from poor design of CMS processing (or complex/huge usage of calibration controls); by only looking the post-calibration low dE numbers is not enough to guarantee to you a successful calibrated picture, for that reason, calibration 'art' is required, beyond instruments and measurements, to make these displays look and measure good the same time.
Here are some user findings testing these patterns:
https://www.avsforum.com/forum/139-d...l#post52261769
https://www.avsforum.com/forum/139-d...l#post50194449
About your CMS adjustments, beyond charts, take a look a these gradation pattern with CMS adjustment ON/OFF to verify that no issues are introduced by using these controls.
Tucker Smash likes this.
post #3104 of 3124 Old 02-19-2019, 06:55 PM
analog8's Avatar
Quoted: 116 Post(s)
Liked: 85
Originally Posted by latet View Post
Spectracal is out there, call them and ask them to recommend someone. That OTC-1000 is very old technology, not to say that it's bad or anything. Just that things have come quite a ways since that meter came out.
You can also check the ISF site. Look under the dealers header.
Following up on my earlier post, I got Kris Deering to come out and do a new calibration and the results are sensational, night and day to my previous issues.
Some of you will remember Kris from his association with Sound and Vision and Home Theater magazine. His new website is http://www.deepdiveav.com/ - he's in the Seattle area but travels as well.
Highly recommended, he knows what he is doing and has the equipment and dedication to getting the optimal results!
WiFi-Spy likes this.
analog8 is offline
post #3105 of 3124 Old 02-23-2019, 08:32 AM
P40L0's Avatar
Quoted: 189 Post(s)
Liked: 110
After playing A LOT of new, additional HDR contents (Games, 4K HDR/Blu-Rays, 4K/HDR Streaming) using HDR Game v5.3.2, I decided it's now time to do a partial step back from High Dynamic Contrast suggestion...
If High DC performed GREAT in many occasion with HDR Game (brighting up noticeable dimmer sequences, especially in particular movies and games' static menus and HUD), it showed too much color artifacts, black crush and/or highlights clipping to be considered universally accurate now.
Therefore, I updated again the HDR Game profile to v5.5:
  • Going back to Dynamic Contrast: MEDIUM
  • Going back to Brightness 50 (no need to raise it outside High DC)
  • Going back to Color Gamut: AUTO
  • Raising Color value to 60 (to offset a slight color desaturation of Medium DC)
This provided a consistent, more accurate calibration for an universal, mixed usage of HDR Game profile.
Cheers
-P
P40L0 is offline
post #3106 of 3124 Old 02-26-2019, 03:13 PM
spwill's Avatar
Quoted: 80 Post(s)
Liked: 70
Has anybody calibrated hlg on these oleds? On my b7a, the white balance is not carried over from the hdr picture modes and the controls are locked up. This is a problem since my tv has a green tint in the grayscale which can be fixed only using the white balance controls. It's not a big deal yet but I'm thinking of getting direct tv which uses hlg for its 4k hdr broadcasting.
spwill is offline
post #3107 of 3124 Old 04-04-2019, 03:59 AM
sevenz's Avatar
Quoted: 74 Post(s)
Liked: 52
Originally Posted by nodtmf View Post
Hi,
Here are my HDR settings after calibration setting on my 65B7. (I said I would post about a month ago...been busy)
TV is about a year old
Using Calman Business bundle and Technicolor mode on the TV. For calibration everything off.
My largest issue is with Red, could not fix it with CMS. I checked with content I caught from a studio colorist to see if anything as wacked as it seems my 20 point greyscale is extreme.
Looked comparable to the $30K monitor.
I will go back through this thread and others to see if I figure why my Red seems so recalcitrant.
I may go and touch up the midrange greyscale.
20Point
Format Level, R,G,B
277 0,0,0
345 0,0,0
412 -3,-1,1
446 -12-9-11
480 -18,-14,16
498 -27,-23,-30
513 -26,-23,-25
530 -33,-26,28
544 -33,-29,-31
561 -39,-32,-35
571 -43,-36,-44
584 -45,-39,-44
604 -43,-40,-40
617 -45,-42,-45
632 -45,-36,-42
647 -45,-41,-44
663 -45,-39,-41
678 -40,-32,-40
693 -45,-37,-44
1023 -5,6,-2
CMS
Format Color S,T,L
Red 0,0,0 Nothing I did here did anything much, so left it a 0 in fear of it messing something up
Green 20,30,17
Blue 9,0,5
Cyan 14,-5,12
Magenta 5,0,6
Yellow 6,2,12
could u share what issues were u seeing on your B7 for red color?
I'm using the C7 and recently started to calibrate it for SDR. After SDR calibration, some white patterns looks pinkish for some reason and I CANNOT SOLVE it.
sevenz is offline
post #3108 of 3124 Old 04-04-2019, 04:14 AM
sevenz's Avatar
Quoted: 74 Post(s)
Liked: 52
Red face
Hi guys, *wave* thanks for this great thread.
Need some help over here. I'm very new here to display calibration.
I've just completed SDR calibration, so now moving on to HD calibration.
But the HDR calibration seems quite different from SDR and more complicated than i can understand....
My Equipment: LG OLED 65C7, Chromapure, Xrite Display 3 Pro meter, Ray Masciola's HDR patterns.
Qn 1) I understand i need to calibrate HDR white level to output of 540 nits for 100% white. Do i need to set the peak white output level to 540 nits before i move on to greyscale calibration? But i understand that anything above 65%, there are issues? How do i do that?
Qn 2) For SDR, on the initial 2-point calibration on the white levels, i use IRE20 on my TV with a 20% grey pattern, and IRE80 on my TV with a 80% grey pattern. Then I go to and fro before I move onto 12 point calibration. For HDR, what do i use for the 2-point calibration and what pattern should i use for the high and low point? Understand that above 65% video it is crap.
Qn 3) Can someone help me understand, what is happening to video above 60-65% grey that renders it problematic? I still can't get a hang of the technicalities. It just goes over my head. haha...
Qn 4) LG released some custom values for the 2017 OLEDs. How should i use this and must it be used for HDR calibration?
Qn 5) Is 21-point calibration necessary for HDR and also SDR; or can i just do a 12 point? Currently for SDR, I'm just doing a 2-point followed by a 12 point.
Thanks in advance!
sevenz is offline
post #3109 of 3124 Old 04-14-2019, 05:25 PM
JustaPlacebo's Avatar
Quoted: 71 Post(s)
Liked: 83
Alternative HDR Game Mode Settings
I think I've found something that no one seems to have realized. It's nowhere in the forums that I can find, and Rtings haven't noted it.
As known, it can be annoying when some HDR content in Game HDR mode looks substantially dimmer than Cinema HDR mode (and Technicolor Expert Mode) can when Active HDR is on (Active HDR = Dynamic Contrast set to low). Game mode has a very minimal input latency, so it's not easy to give up. Under high precision PC gaming it feels great even when side by side with a 1ms TN panel.
I have found when using "Home Theater" HDMI label for HDR content using "Cinema Home" preset and disabling all processing options can produce a similar low input lag... even while Active HDR10 is on (Dynamic Contrast Low). What seems to be causing the vast majority of lag is when Real Cinema is ON, which can't be disabled in the "Cinema" and "Expert" modes, but can be disabled under the "Cinema Home" mode. That Real Cinema setting introduces tons of lag.
For SDR, the same applies to the Technicolor Expert mode which is the only option outside of Game Mode that lets you disable Real Cinema.
Performance doesn't seem to be quiiiite as fast as Game Mode or "PC" input icon mode, but it's definitely acceptable and far better than the poor looking Game mode and default input lag.
Another oddity is that when comparing HDR console titles with HDR PC titles, PC titles are almost always brighter, even in HDR Game mode. Here are titles I've noticed:
PS4 PRO:
Horizon Zero Dawn (Game Mode HDR, relatively dim)
Spiderman (Game Mode HDR, Relatively dim).
The Last of Us (Game Mode, very dim to the point of being disappointing. Active HDR dramatically increases ABL. Controls are super acceptable with custom Home Cinema settings and Active HDR enabled).
Xbox One X:
Forza 4 (Game Mode HDR, relatively dim)
RTX 2080 Ti PC:
Forza 4 (Game Mode HDR looks amazing, active HDR rarely increases ABL (Average Brightness Level).
Farcry 5 (Game Mode HDR looks amazing - probably the best.. not even compelled to tinker with Active HDR it looks so contrasty.
Assassins Creed Odyssey (Game Mode HDR, amazing)
I suspect that consoles, even their "pro" variants process HDR in a lower fidelity way than PC GPUs. This was also true on my 1080Ti.
Has anyone been able to test the input response changes between all menu settings with a Leo Bodnar tool? I'm only going off controller and mouse responsiveness in games and on desktop.
Displays: LG 65" C7 | LG 34UM95 | LG 27UD88 | Asus VG248QE 144Hz | DELL S2240m
Sound: Yamaha HS7's | Onkyo TX-NR 646 5.1.2
Custom PC: i9-9900x, RTX 2080Ti, Mastercase SL600m
Blu-ray Player: Sony UBP-X800
JustaPlacebo is offline
post #3110 of 3124 Old 04-15-2019, 08:35 AM
onaga's Avatar
Quoted: 226 Post(s)
Liked: 72
hi @JustaPlacebo , its been a while!!
yes was you said was very discussed years ago, Cinema Home with post disabled produces a less input lag that normal modes, but some pros say that the reduced lag was minimum others evens ay that was the same.
at the end, many peolple ditched it because "its doesnt feels like game mode"
also about the brightness, yes, this was also very discussed back in the day, the problem its that consoles dont send any kind of metadata to the tv, its all made by the tv(and OLEDs assume 4000nits for eveything) this make the image very dim on consoles, in order to preserve all the detail.
PC Games send static 1000nits metadata to the tv, making it way more brigther that consoles.
all of this was discussed in more focused gaming forums like NEOgaf or Resetera.
onaga is offline
post #3111 of 3124 Old 04-15-2019, 02:56 PM
Quoted: 71 Post(s)
Liked: 83
Hey there!
Oof! How embarrassing.. haha. I guess I've just been so busy over the last couple of years I forgot all these details! Sheesh.. Thanks though!
post #3112 of 3124 Old 04-22-2019, 03:04 AM
P40L0's Avatar
Quoted: 189 Post(s)
Liked: 110
Lightbulb LG 2017 OLEDs - All Profiles Re-Calibration (April 2019)
  • ALL PROFILES UPDATED TO V7 ULTIMATE
  • Firmware 5.80.xx or above is required
  • Completely new re-calibration of all SDR/HDR/DV picture modes with new tools and after 4.000+ hours usage (based on new sonoftumble settings)
  • New Dolby Vision Custom Calibration file to apply via USB patch (updated on April 2019)
  • HDR Game mode back to a new custom profile based on HIGH Dynamic Contrast to match the new improvements
  • Added new in-game HDR suggested settings
Please not that this re-calibration goes in-depth also for all White Balance + CMS values, so do not forget to also update those sections when possible (and do not forget to also update the entire DV profile using the new USB Patch!)
Then give those completely fresh settings a try and let me know what you think...
P40L0 is offline
post #3113 of 3124 Old 04-26-2019, 08:06 AM
Liked: 0
I'm trying to calibrate my B7 using HCFR. The problem I have is that HCFR's internal patterns are producing different results than MadTPG. Shouldn't they both be producing the same result? Why would the same test pattern, let's say 10% grey, be different between them? There are no LUT's in use with MadTPG.
divvy82 is offline
post #3114 of 3124 Old 04-26-2019, 10:27 AM
P40L0's Avatar
Quoted: 189 Post(s)
Liked: 110
Just made some improvements on top of new V7 profiles (which are now based on new "sonoftumble" re-calibration), bringing them to V7.1:
Changelog:
  • SDR Technicolor and SDR Game brightness lowered a bit from 53 to 51 (after noticing very slightly raised black in some patterns);
  • X1X Only: DV Cinema was switched with DV Game profile by default (with mostly same settings and basically identical PQ and Luminance to calibrated DV Cinema, but with 21ms input lag and same good motion): this was done to "future-proof" in case someday Microsoft will allow Dolby Vision gaming on X1X or Next-Gen Xbox One to be released next year, while still providing great PQ for Streaming TV/Movies;
  • HDR Technicolor White Balance was reset to its default as I noticed a blue tint with new sonoftumble's values, and a yellow tint with older ones;
  • webOS only: if you notice a dimmer Dolby Vision compared to X1X (or Apple TV) Dolby Vision luminance, I added the suggestion to switch to DV Game profile also there
  • HDR Game Color value was slightly raised from 44 to 48 to align to the HDR Technicolor improvement above
OddyOh likes this.
P40L0 is offline
post #3115 of 3124 Old 05-12-2019, 04:53 AM
P40L0's Avatar
Quoted: 189 Post(s)
Liked: 110
Ok, after playing with PC mode and a dozen of HDR games for a couple of days:
  • ALL PROFILES UPDATED TO V7.2 ULTIMATE (with minor tweaks, and all aligned with the goal to have the same PQ switching between them)
  • ADDED 2 OPTIONS FOR X1X/GAMING (Option 1: based on regular SDR/HDR Game; Option 2: based on PC Input/Mode + Input lag FIX!)
  • Firmware 5.80.15 or above is required
  • Added new in-game HDR suggested settings for Option 2
See the OP for more details and new Option 2 links, and let me know which is the Option you like the most.
Have fun!
-P
P40L0 is offline
post #3116 of 3124 Old 05-14-2019, 11:16 AM
P40L0's Avatar
Quoted: 189 Post(s)
Liked: 110
Big news for Red Dead Redempion 2 owners: Rockstar fixed its HDR in the latest patch!
​​​​New suggested settings for:
Option 1:
  • HDR Style: Game
  • Luminance: 4.000
  • White point: 120
Option 2:
  • HDR Style: Game
  • Luminance: 2.000
  • White point: 120
Click here or on my signature for more info and calibrated settings for both Consoles, LG 2017 OLED TVs and Games.
It's so much better now, so better late than never...
Enjoy!
P40L0 is offline
post #3117 of 3124 Old 06-18-2019, 08:56 PM
confinoj's Avatar
Quoted: 1201 Post(s)
Liked: 1009
I had my C7 calibrated by Chad B over a year ago. He calibrated SDR isf dark, sdr isf bright, hdr cinema user and DV cinema user.
I have found that DV can be too dark for daytime or lights on viewing. The DV cinema home mode is much brighter but that mode was not calibrated and my understanding is that it’s not as accurate. Is there any recommendations to get DV brighter for daytime viewing and maintain reasonable accuracy? Thanks.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #3118 of 3124 Old 06-19-2019, 03:32 AM
bob brennan's Avatar
Quoted: 349 Post(s)
Liked: 337
Go into - SETTINGS - Picture Mode and you should have 2 DV settings - CINEMA(USER) & CINEMA HOME (USER) - The Cinema Home (User) should be the "brighter" of the two!
LG OLED 77G7P - Panasonic TC-P65ZT60 – OPPO UDP-203/103D - Toshiba HD-DVD-3A – Harmony ONE
Marantz SR7011 - Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 55 (2) - Super Cube 6000
bob brennan is online now
post #3119 of 3124 Old 06-19-2019, 04:17 AM
Chad B's Avatar
Quoted: 691 Post(s)
Liked: 1575
In DV Cinema mode you can turn OLED light up from the default of 50. In that mode it just acts like a mid level brightness control. 50 is most accurate, but try setting it to 70-80 for daytime viewing.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS540, JVC RS3000, Sony VPL-VW695ES
Copied settings measured, Review archive
Chad B is offline
post #3120 of 3124 Old 06-19-2019, 05:20 AM
confinoj's Avatar
Liked: 1009
Thanks! Straight from the man himself. Will give that a try.
confinoj is offline
Reply Display Calibration
