LG 2017 OLED Calibration Thread and Settings - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 3293Likes
post #751 of 3145 Old 10-24-2017, 11:29 AM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Originally Posted by Wjboshart View Post
Anyone look at/calibrate technicolor mode yet or compare it to isf modes?
They basically look the same. Need the similar adjustment in the same levels of IRE. But I’m not a professional so I’m interested as well.
You can set all the basic setting the same for each mode and switch back and forth and leave with the thought I’ll never get that time back lol.
I’ve ran though the greyscale and CMS and the pictures are very similar. I bet you could switch a picture mode on someone and they wouldn’t know the difference.
LGOLED77G7P/65B6P - Oppo 203
Denon X6300H/Onkyo Tx NR3030; Atlona HDR HDBaseT
Klipsch 7.1.4
R-3800-W II Fronts ; R-5502-W II Center
RS-42 II Surrounds ; CDT-3800-C II Heights, R-112SW Subs
jayraysaiz is offline
post #752 of 3145 Old 10-24-2017, 01:14 PM
Wjboshart's Avatar
Quoted: 1355 Post(s)
Liked: 1323
I tried researching and it basically sounds like Technicolor option is suppose to be a finer tuned color setting graded by Technicolor studios. But agreed. They look nearly identical to isf
Wjboshart is offline
post #753 of 3145 Old 10-24-2017, 01:23 PM
pazman2000's Avatar
Quoted: 216 Post(s)
Liked: 73
WB is the same as ISF before calibration , colour is the same as isf with colour control on 53 on isf
pazman2000 is offline
post #754 of 3145 Old 10-25-2017, 06:39 AM
Quoted: 161 Post(s)
Liked: 96
Originally Posted by ToD_ View Post
Is there an optimal black level override I should set? D-Nice mentions 0.0001fL is close to the recommended setting on the first page of this thread. In another thread (for 2016 OLEDs) Chad B gave a recommendation for 0.001fL (0.0034 cd/m2). Should there be different values for different gamma targets?
The 2016's don't come out of black very well and this was a trick to help them show more detail.
AFAIK the 2017s don't require this tweak. Set black level to 0.
/waiting for the correctional comments...
LGOLED55C7P - Calman Enthusiast - I1Display / I1Pro
PeteNeat is offline
post #755 of 3145 Old 10-25-2017, 08:06 AM
ToD_'s Avatar
That makes sense. However, if I set black to 0, BT.1886 is the same as gamma at 2.4. If I enter a higher value, the calibration software creates a curve. I wonder if there is a recommended value for the 2017 screens, but I guess it all comes down to preference at that point.
ToD_ is offline
post #756 of 3145 Old 10-25-2017, 10:00 AM
starr18t's Avatar
Quoted: 44 Post(s)
Liked: 5
anyone using the calibration from ratings and then using a disk to tweak it further from there? Are you seeing a lot of changes?
Yamaha 2070 l Martin Logan 60s l Martin Logan 50 l Martin Logan Dynamo 700 l Oppo 203 l LG C7 - Sony 900e l Polk Surround
starr18t is offline
post #757 of 3145 Old 10-25-2017, 10:43 AM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
What model do you have? If you don’t have the gear I’d just use the out of the box settings. The tvs are pretty good out the box. I’d choose a gamma you like best and then you’ll be good to go.
Personally I prefer bt.1886 (I’m sure 2.4 would be about the same) for satellite and 2.2 for higher quality sources.
Klipsch 7.1.4
post #758 of 3145 Old 10-26-2017, 03:42 AM
Soundizer17's Avatar
Quoted: 735 Post(s)
Liked: 163
Is there a comprehensive post that describes the features for Motion Settings?
LG OLED65C7.
Based on my Panel I keep switching between the following:
1. Clear [some Motion artifacts are introduced, but my eyes are more relaxed]
2. User: De-Judder 4 / De-Blur 0 [some Motion artifacts are introduced, but my eyes are more relaxed]
Soundizer17 is offline
post #759 of 3145 Old 10-26-2017, 05:42 AM
starr18t's Avatar
Quoted: 44 Post(s)
Liked: 5
I have the 65" LG C7...you are right it is not bad out of the box. Currently i'm 2.2 and am on satellite. I bought the Spears & Munsil HD Benchmark disk, just havent popped it in and was wondering if it provides a good before and after.
starr18t is offline
post #760 of 3145 Old 10-26-2017, 06:09 AM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Just the basics. In the advanced menus it only has 11 point greyscale so you’d need another source to do a 21 point.
Klipsch 7.1.4
post #761 of 3145 Old 10-26-2017, 06:12 AM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
LG OLED65C7.
I know there is one for the 2016’s and haven’t looked for the 2017 thread but this particular topic seems to be user dependent. I turn mine off. While it doesn’t resolve every show 100% it’s best for me so I don’t have to keep messing with the settings.
charlesrshell likes this.
Klipsch 7.1.4
post #762 of 3145 Old 10-26-2017, 07:35 AM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Not sure if I missed it or not but for HDR10 calibration what are the best slides to run the 2pt calibration? Is it the same concept as rev.709 where you use 5/100 but using the 2017 coded slides from Ryan?
Also is there a best one and done nit level to calibrate too since LG gives 540/1000/4000 values?
Would rather have one I don’t know where to get the nit level that each movie is graded to.
Klipsch 7.1.4
post #763 of 3145 Old 10-27-2017, 05:26 AM
Zygon's Avatar
Originally Posted by P40L0 View Post
Hello Everybody,
after weeks of consolidating the recommended settings from Rtings.com, this own Community, A/B testing and direct Calibration for my 55B7V, I'd like to share the setup I've finally settled with.
This setup is specifically optimized for Gaming and Media Consumption both for SDR and HDR Modes (Xbox One/S/X - WebOS, but should also work for PS4/Pro and PC Gaming):
> Xbox One/S and/or SDR Mode (Fall Creators Update Dashboard OS and above)
INPUT
HDMI1 Input Mode: GAME CONSOLE
GENERAL
HDMI ULTRA HD Deep Color: ON
Picture Mode: GAME (USER)
Energy Saving: OFF
OLED Light: 60
Contrast: 90
Brightness: 51
Sharpness: 0
Color: 50
Tint: 0
Color Temperature: W45
EXPERT CONTROLS
Dynamic Contrast: OFF
Dynamic Color: OFF
Super Resolution: OFF
Color Gamut: WIDE*
Color Filter: OFF
Gamma: MEDIUM
PICTURE OPTIONS
Noise Reduction: OFF*
MPEG Noise Reduction: OFF*
Black Level: LOW
Motion Eye Care: OFF
OLED PANEL SETTINGS
Screen Shift: ON
XBOX ONE/S - CONSOLE SETTINGS:
VIDEO OUTPUT
TV Resolution: 1080p/4K
TV Connection: AUTO-DETECT
Color Depth: 10-BIT
Color Space: Standard (Recommended)
Advanced settings: ALLOW 50HZ/24HZ
__________________________________________________ ______________________
> Xbox One S/X and/or HDR Mode (Fall Creators Update Dashboard OS and above)
INPUT
GENERAL
HDR Picture Mode: GAME (USER)
Energy Saving: OFF
OLED Light: 100
Contrast: 100
Brightness: 50
Sharpness: 0
Color: 55
Tint: 0
EXPERT CONTROLS
Dynamic Contrast: LOW
Dynamic Color: OFF
Color Gamut: AUTO
Color Filter: OFF
Gamma: MEDIUM*
PICTURE OPTIONS
Black Level: LOW
OLED PANEL SETTINGS
Screen Shift: ON
XBOX ONE S/X - CONSOLE SETTINGS:
VIDEO OUTPUT
Color Depth: 10-BIT
Advanced settings: ALLOW 50HZ/24HZ/HDR/4K
*Not editable in Game Mode
Give it a spin if you want, and let me know how it looks also for you
Cheers,
Paolo
EDIT1: Minor adjustments
EDIT2: After official release of Fall Creators Update for Xbox One, Picture Quality has changed, so settings were slightly re-calibrated!
EDIT3: Re-adjusted Color Temperature to match the default "Warm2" reference of ISF Dark Room preset.
Thanks, just what I was looking for!
P40L0 likes this.
Xbox Live GT: xxx COKE UP xxx
Zygon is offline
post #764 of 3145 Old 10-27-2017, 12:49 PM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
When calibrating HDR is the a menu on the LG where you can tell it what nit level you want to calibrate to? I am using Ryan's slides and they don't seem to numerically line up with the code values in the WB menu.
Also when adjusting the Luminance in the CMS is there a rule of thumb guideline as to how much luminance you can and can't add? When I looked at the CMS the luminace errors where quite high. I added luminance and the overall errors went down as well as the saturation errors. This seemed to pick up more detail between color transitions especially in greens and yellows and reds mainly in that order.
Klipsch 7.1.4
post #765 of 3145 Old 10-28-2017, 09:28 AM
pazman2000's Avatar
Quoted: 216 Post(s)
Liked: 73
Hi guys
My C7 does not have the screen dimming feature as my 930,950,c6 or e6 did when a still image was on screen for a prelonged period of time .
Tpc is on in the S/M but still if I leave sky q on pause for 30 mins nothing happens at all no screen saver or dimming happens to stop screen burn .
I just call LG about this and they said 2017 sets do not do this and it?s down to the connected devices to do so .
This is with any HDMI sources app are ok as the screen saver kicks in .
Are you finding the same thing ?
post #766 of 3145 Old 10-29-2017, 05:09 AM
Quoted: 735 Post(s)
Liked: 163
Following the 4.7 firmware update I have noticed significant improvement to Motion Handling on my LG OLED65C7.
I was close to getting it exchanged, but the improvement is very obvious and I realise now that previous Motion was awful in comparison.
Al Leong likes this.
post #767 of 3145 Old 10-29-2017, 01:29 PM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
Originally Posted by sonoftumble View Post
HDR-10 NOTE: In order to make settings changes to HDR,
HDR Picture Mode: Cinema (User)
Customize
OLED LIGHT: 100
Contrast: 100
Brightness: 50
Sharpness: 0
Color: 60
Tint: 0
EXPERT CONTROLS
Dynamic Contrast: Low
Super Resolution: Off
Color Gamut: Wide
Color Filter: Off
Gamma: 2.2
WHITE BALANCE
Color Temperature: Warm2
NO CHANGES TO ANY SETTINGS
COLOR MANAGEMENT SYSTEM
RED - Sat: 27, Tint: -2, Lum: 28
GREEN - Sat: 0, Tint: 0, Lum: 0
BLUE - Sat: 0, Tint: 0, Lum: 0
CYAN - Sat: 0, Tint: 0, Lum: 0
MAGENTA - Sat: 4, Tint: 12, Lum: 0
YELLOW - Sat: 0, Tint: 0, Lum: 0
For HDR10 I didn’t have any luck adjusting saturation and tint to reduce the CMS errors and x-y location on the gamut. The only thing that lowered the errors on the gamut boundary and the saturation sweeps on my end was adjusting the luminance. With this I was able to gain more detail in greens, yellows, and reds. The other colors it was hard to see any significant difference.
Klipsch 7.1.4
post #768 of 3145 Old 10-29-2017, 01:41 PM
Quoted: 4474 Post(s)
Liked: 5487
LG OLED 65” C7 Calibration ( OLED65C7P ) [ however from several things I’ve read, these should work well with any “X”7 model ]
FW: 04.70.07
For those who are not familiar with me in the LG OLED threads, I have done something similar in the 2016 Vizio M series thread. To that extent, these are actual meter based calibration settings ( vs. disc based ) using a Spectracal C6 meter, Murideo 6G pattern generator, and CalMan for Biz 2017.
NOTES: This TV was a dream to calibrate. I thought that the Vizio M series ( M70-D3 ) was an accurate and consistent responder until I had the pleasure to work with this set. As with all calibrations, getting the 2 point white balance as close to perfect meant that the 20 point needed no adjustments. ( Screenshots attached if you don’t believe me. )
An almost perfect 2 point white balance and reference white also paved the way for super accurate colors and smooth tracking through each of the color percentage reference points.
You should enjoy superb looking natural flesh tones and a nice color contrast and pop even with SDR content. Black levels are also excellent which one should expect from an OLED. I have read some post where there were complaints regarding grey backgrounds in letterbox images. This should not be an issue with these settings. HDR-10 is spectacular without any of the color or luminance exaggerations.
For those of you who like to try these settings out, I would appreciate feedback - good or bad. Personally, I am loving them. I’m posting this in both the calibration thread and the owners thread ( https://www.avsforum.com/forum/40-ole...l#post55037420 ). If I make any modifications they will be done within the same posts so this will become a living post - so to speak. I will also supply a link in my signature.
Here we go and enjoy!
START WITH the: “ISF Expert (Dark Room)” Picture Mode
Energy Saving: Off
BASIC SETTINGS:
OLED LIGHT: 40 ( SDR ) 100 ( HDR-10, DV )
Contrast: 85
Brightness: 50
H Sharpness: 0
V Sharpness: 0
Color: 50
Tint: 0
SDR
EXPERT CONTROLS
Dynamic Contrast: Low ( Personal preference - set to what you like )
Color Gamut: Wide
Edge Enhancer: Off
Color Filter: Off
Gamma: 2.2
WHITE BALANCE
Method: 2 Points
High - R: -3, G: -2, B: -4
Low - R: -3, G: -3, B: -1
RED - Sat: -12, Tint: 8, Lum: -4
GREEN - Sat: -7, Tint: -30, Lum: -1
BLUE - Sat: -3, Tint: 9, Lum: -1
CYAN - Sat: -11, Tint: 5, Lum: 0
MAGENTA - Sat: -3, Tint: -7, Lum: 0
YELLOW - Sat: -6, Tint: -6, Lum: 1
PICTURE OPTIONS
Noise Reduction : Off
MPEG Noise Reduction: Off
Black Level: Low
Real Cinema: On ( Default - greyed out )
Motion Eye Care: Off
TrueMotion: User - De-Judder: 0, De-Blur: 10 ( Personal preference - set to what you like )
HDR-10 NOTE: In order to make settings changes to HDR, you need to be playing HDR content.
Customize
OLED LIGHT: 100
Contrast: 100
Brightness: 50
Sharpness: 0
Color: 60
Tint: 0
EXPERT CONTROLS
Color Gamut: Wide
Color Filter: Off
Gamma: 2.2
WHITE BALANCE
Your CMS adjustments, especially for saturation are way too much. Best leaving them at default for HDR and just tweak a little, if necessary for SDR. If you have to move any control say 27 for example like you did, it means the control isn't working and is just going to create artifacts. Saturation should only be adjusted +-2 ish.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #769 of 3145 Old 10-29-2017, 02:04 PM
sonoftumble's Avatar
Quoted: 2717 Post(s)
Liked: 2476
With LCD panels, if I adjust the Luminance with certain primary colors ( red or green ), it will introduce block noise with certain shades of yellow or green. And that's just when making a small + or - 1 adjustment. Are you saying that with an OLED, making any Saturation adjustments greater than + or - 2 will introduce artifacts? How do you get the saturation sweeps to play nice and therefore get a great color checker result if you can't change saturation? Without adjusting the Red saturation, I get an orangish red at 100%. Shouldn't really matter at that level since most content will never put out a 100% red shade, but the scans now indicate really good color accuracy.
With the CMS in HDR, Red was the only color that was giving me fits. You may notice that I have most of the colors zeroed out. I haven't noticed any artifacts at this point, but I will certainly keep my eyes pealed. This is my first OLED, so I'm open to suggestions and pointers. Thank you for your feedback.
LG OLED65C7P 4-20-19 Calibration SDR/HDR/DV FW 05.80.15: https://www.avsforum.com/forum/40-ol...l#post57928994
VIZIO M70-D3 Calibration SDR/HDR FW 3.4.8.15: https://www.avsforum.com/forum/166-l...l#post55595700
sonoftumble is offline
post #770 of 3145 Old 10-29-2017, 04:29 PM
jayraysaiz's Avatar
Quoted: 298 Post(s)
Liked: 111
@jrref ,
For the HDR10 CMS how do you adjust the chomaticity errors for each primary and secondary colors (in particular the green and blue). Is this accomplished with the tint and saturation adjustments? It seems only the red chromaticity error for each primary and secondary color is adjusted by tweaking the luminance.
Klipsch 7.1.4
post #771 of 3145 Old 10-29-2017, 04:30 PM
oguignant's Avatar
Quoted: 29 Post(s)
Liked: 4
FW: 04.70.07
Did you create a meter profile using a spectrophotometer?
sonoftumble likes this.
oguignant is offline
post #772 of 3145 Old 10-29-2017, 07:51 PM
Liked: 5487
Red/Magenta in HDR is "broken" and it's been like that since the sets first came out. It was reported to LG but nothing has been done. For that reason alone, it's best to leave the HDR CMS at default. You can make some adjustments but it's debatable if it's really worth it given the risk of artifacts with some content. As far as the luminance errors, that's a characteristic of these OLEDs.
FYI, at the shootout, the HDR CMS was left at default on the LG and to the eye, it won as best match to the reference monitor.
Now I will say that on the 2016 LGs, you could adjust the CMS slightly to align it a little better but something changed on the 2017 sets.
sonoftumble and jayraysaiz like this.
John
jrref is online now
post #773 of 3145 Old 10-29-2017, 08:21 PM
Liked: 2476
If I had one of those in my back pocket, I'd also have a Klein for a meter. lol
post #774 of 3145 Old 10-29-2017, 08:33 PM
Liked: 2476
Thank you for the excellent explanation. I now have a better understanding with the why/how on these beasts. The errors were more saturation based than luminance, but HDR is still a moving target, so I thought I would give it a spin, and the graphs look good - but I definitely understand how artifacts seem to appear when you least expect them to. lol
For SDR, I'm pretty pleased with the results, and the adjustments are relatively minor. I'll reset the HDR CMS back to zero and go from there. I just don't dig that red looks a little too hot.
jrref and Cam1977 like this.
post #775 of 3145 Old 10-30-2017, 06:27 AM
Quoted: 161 Post(s)
Liked: 96
What source and what motion settings do you select?
PeteNeat is offline
post #776 of 3145 Old 10-30-2017, 07:21 AM
Al Leong's Avatar
Quoted: 2007 Post(s)
Liked: 2257
I agree
Al Leong is offline
post #777 of 3145 Old 10-30-2017, 08:32 AM
Quoted: 161 Post(s)
Liked: 96
^I've run a few suspect scenes and think I agree. I see less artifacts.
This is actually quite a revelation
They are still there but seem to be less intrusive. I have not adjusted my motion settings lower (or higher) to experience positive or negative changes yet.
Dejudder 2, DeBlur 10 has been my preferred previous config for all sources, including 24p.
PeteNeat is offline
post #778 of 3145 Old 10-30-2017, 09:46 AM
phakur's Avatar
Quoted: 49 Post(s)
Liked: 27
Did you do any calibration with Dolby Vision--is it different than HDR 10?
phakur is offline
post #779 of 3145 Old 10-30-2017, 10:13 AM
Quoted: 735 Post(s)
Liked: 163
I use very different Motion settings on my current LG OLED65C7 compared to the previous model which I exchanged due to banding.
I now use De-Judder 4 and De-blur 0.
By keeping De-blur to 0 it minimizes artifacts which occur as De-Judder is on 4.
My previous set was fine on De-judder 1 or 2 and De-blur i kept changing.
This set had much better Motion handling for some reason.
PS. Prior to 4.7 firmware i had to use Clear settings on my current model otherwise my eyes were strained.
It was like spinning around on the spot for 3 minutes and then trying to focus on a a rotating fan - mad.
post #780 of 3145 Old 10-30-2017, 11:06 AM
Quoted: 161 Post(s)
Liked: 96
I have not attempted HDR or DV calibration yet, although I have bought a HDFury.
PeteNeat is offline
Reply Display Calibration
