The latest generation of i1Display PRO (Rev.B) (OEM/Retail) it features a new refresh rate detection and synchronization AIO (All in One) measurement mode which can improve the measurement stability for certain displays and provide lower reading times.
AIO mode is supported only from LightSpace and ChromaPure.
HCFR/DisplayCAL/ArgyllCMS has also custom code for providing similar results with adaptive exposure times/sync modes without using AIO mode. CalMAN is using custom code also (but not adaptive exposure times for i1Display PRO)
i1Display PRO OEM meters manufactured from January 2017 or later are certified from X-Rite up to 2000nits, according to X-Rite the Retail version are certified for 1000nits.
SpectraCAL C6/C6 HDR is a OEM Branded i1Display PRO meter as we know, all i1Display PRO meters (Retail/OEM/OEM Branded) feature the exact same hardware/firmware, just C6 has different internal meter unlocking code (to make it work with CalMAN only officially....but it can work with HCFR/LightSpace/DisplayCAL/ArgyllCMS also unofficially; with exact same drivers; just with different unlocking code inside).
HCFR/Argyll is using their own custom drivers to operate the meter, the same SpectraCAL is doing also, they have written exclusive code to operate C6 (and i1D3 also) from inside CalMAN.
This is one reason why AIO mode of i1Display PRO Rev.B meters is not available from CalMAN/HCFR/Argyll, because they are not using X-Rite SDK to operate the meter, they are using their own custom code modes.
LightSpace has an additional feature called 'Intelligent Integration' where you set a nits value below which the i1Display PRO will perform a second, third, fourth, etc. reading, with increasing integration times, up to the maximum integration time of 6 seconds. The readings will stop as soon as a stable and valid reading is achieved. If no valid and stable reading is achieved a 'zero' value will be returned, enabling LightSpace to intelligently calculate a replacement value when generating a calibration LUT.
SpectraCAL has equipped the C6's meters with additional EDR (Emissive Display Reference) tables for various consumer or professional display types, which are installed to your PC every time you will install CalMAN. They can add new tables in a future software release also.
C6 or i1Display PRO, both are field upgrade-able, so X-Rite can add new EDR tables when they will release new SDK files to calibration software developers. (but X-Rite hasn't released something new from 2012).
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box
- P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
