BasICColor DISCUS Owners thread - AVS Forum | Home Theater Discussions And Reviews
 32Likes
post #1 of 122 Old 09-23-2017, 01:34 AM - Thread Starter
aka jfinnie
Quoted: 3359 Post(s)
Liked: 2606
Although they've been out for a few years there doesn't seem to be a good repository of information about the BasICColor DISCUS colorimeter. I've just picked bought one to use with Lightspace.
So I'm creating this "Owners thread" to collect anything of use. Please contribute experience, useful information, hints, tips and questions for other owners.
The next post will be a repository for links to helpful information.
bobof is offline
post #2 of 122 Old 09-23-2017, 01:35 AM - Thread Starter
aka jfinnie
Liked: 2606
Useful links
BasICColor: Product page / Datasheet / Manual / FAQ
Light Illusion: Info Page - reading presets vs patch luminance particularly useful (bottom of page)
Spectracal: Datasheet
Reviews:
Northlight Images: Review
ColorWiki: Review
Dry Creek Photo Sensor Comparison / VS i1 Display Pro
Bruce Percy: Blog
Useful Information
Speed and low light capabilities thread - AVS Got a bit off-topic, useful posts from Manni01: Post 31 / Post 48
Experience with JVC X-series - AVF
bobof is offline
post #3 of 122 Old 09-24-2017, 12:15 PM - Thread Starter
aka jfinnie
Liked: 2606
Here are my own first impressions of the BasICColor DISCUS meter after receiving it and a couple of nights playing around. Up until now I've been using a couple of i1d3s, with an i1pro / i1pro2 as a reference. Please note I don't have any high-grade meters; but my i1d3's and the i1pro/2 all agree pretty strongly with each other. Mainly I calibrate my JVC X30 projector, though I also calibrate my old Sony CCFL daytime viewing TV.
Bought from Light Illusion Friday 15/9/17, meter was dispatched by BasICColor directly from their German office on Monday. Arrived via UPS on Thursday, well packed.
On opening the box I was greeted by a "Certificate of Performance" (valid for 18 months from date, which was the day of dispatch of the meter from what I could see). See copy of the certificate (S/N removed). Judging by the details on the certificate, the meter had read around ~1800 patches across 4 sample monitors, simultaneously with a CAS140CT lab spectrometer. The kind of numbers on it look pretty impressive. The meter and hockey-puck and tape counterweight were well presented in a custom foam insert, which is glued in the carton.
On removing the meter from the insert I immediately thought "this is a seriously engineered piece of kit". The finish was flawless, with a beautiful action on the rotating base plate which switches between closed / calibration dark measure, ambient light diffuser and open. The laser is also exposed in both ambient light and open positions.
The meter body is threaded at the "top" to take a small knurled thumbscrew, which attaches it to the tape / hockey puck assembly for contact measurements. The "bottom" of the meter has a 3/8" threaded hole, into which a 1/4" removable reducer is fitted. These two arrangements do have a couple of limitations.
The 1/4" thread reducer isn't completely flush with the bottom of the meter, which coupled to the circular nature of the bottom means that attachment to a tripod quick release plate is a little fussy, with limited contact. On my plates (Manfrotto) the reducer would bottom out before the body of the meter was tightly gripped by the rubber mat on the quick release plate. I remedied this by building up the surface of the quick release plate a little with some cloth tape. It only needed a couple of layers.
The hockey puck assembly is a nice idea, but I found that it doesn't actually work on the only TV I have - an older Sony "Picture Frame" style KDL32E4020. This has an (abnormally) deep Aluminium bezel assembly (probably 12-15mm from the bezel to the screen surface). In fairness my i1display pro is not super secure on it either, but it does just about sit flush. The i1pro2 mount works great on it, however, so clearly a good universal mount can be designed to cope with such sets. In any case I'd probably limit myself to non-contact measurements on a tripod, so it isn't really a big deal.
Connecting the meter up it worked straight away with Lightspace HTP (the minimum license needed to do 3DLUT with DISCUS). On connection you are asked to rotate the cover to take the required dark measurement, less than half a minute later it lets you know it is done, and you rotate the cover to open the lens. The Lightspace "Enable Visual Feedback" button toggles the aiming laser on / off (the manual explains the offset from the measurement centre).
My findings on performance of the DISCUS mirror those of @Manni01 .
Straight away when doing the contrast measure off screen you could see this meter was effortless in reading dark patches, and it felt quick in operation. There are 4 preset modes for taking readings, with either "short" or "long" integration, averaging a lower or higher number of measures. In preset 0 - the fastest - it was easily able to read the JVC black at <0.003cd/m2. In doing a 21pt grey + primary sweep you could clearly see the lamp colour temperature bias coming through in the very dark patches. I'd not easily been able to make this out previously on the i1d3 meter - the readings in the very lowest 5% patches would be all over the place usually, and getting a reading at all from black was challenging.
Preset 0 readings took 4m07s to read the 81 patches for 21ptGS /RGB. This was with a 0.5s patch delay. With 0.75s reads configured on the i1d3 this could be completed in 3m05s with the same delay. However on the i1d3 the black reading was miles off (about 3 times too large), the dark patches seemed to only approximately be reflecting what you'd expect to see as a lamp bias (the x,y varied quite a lot from what you'd expect) and the resulting measured RGB separation up to around 15% white had a noticeable difference between the white patches and the expected RGB values. On the DISCUS the RGB separation was basically perfect down to 0.
Increasing the i1d3 reading times (either using the new beta auto integration time, or setting a large fixed time) would yield better results - but the reading time would increase to somewhere between 8 and 9 minutes, and the results still didn't look very clean at the very low 0-10% end.
A larger optimised patch sequence of approximately 4000 patches took a little over 3hrs to read on the DISCUS.
So I think re: reading times; it is safe to say that you can drive an i1d3 faster than the DISCUS, the dark readings will definitely be poor. The quickest reading mode on the DISCUS yields slower performance than the fastest possible on the i1d3, but you gain dark readings that look very sensible. Trying to get good dark readings out of the i1d3 and you rapidly end up with much worse reading times than the DISCUS, and still don't have the quality of dark readings of the DISCUS.
@Manni01 thought his meter was faulty due to the discrepancy to his spectro - and having played with the meter I'm not sure his was particularly bad to be honest. A post in the ArgyllCMS mailing list from a previous DISCUS owner says he found the same ( https://www.freelists.org/post/argyl...DISCUS-meter,6 ). None of the built-in presets seem to be particularly good matches for my i1pro2 when measuring the "probe matching" patches for my Sony CCFL or JVC X30 projector, whereas my i1d3 meters did correlate strongly.
There is an extensive database of (mostly pro graphics) monitors which have detailed matching done, with matrixes built in, and some "generic" LCD profiles for various backlight types. A utility allows you to swap in additional calibrations (though these are called user calibrations, I'm yet to find how to create them myself). The matrix upload utility came with some "LCOS" matrices, but these also didn't seem to be great matches for my JVC.
Of course this doesn't matter if you have an i1pro/2 spectro for profiling (and I can't imagine anyone going for a high-end colorimeter doesn't already have a spectro). I have the i1pro so I'll gladly take the improved dark performance in exchange for creating my own profiles.
One other little gripe is that there isn't support for the device in ArgyllCMS. These days I mostly use Lightspace (and CALMAN is also supported), but it would be nice to have the option to use the meter within HCFR / displayCAL / etc, which ArgyllCMS support would facilitate.
In summary - I think from what I can tell that if you want quality very dark readings this is probably the only game in town until you get up to the dizzy heights of the CR100/K10A meters. I'm not going to be able to justify one of those for my hobby purposes any time soon - even this was a bit of a stretch - so the above are probably all best thought of as acceptable compromises given the performance, rather than issues.
In a bit of daytime downtime I made myself up a little calibration kit with the i1pro2, DISCUS and an i1d3 for good measure, using the great value Peli-knockoff MAX430 case ( https://www.amazon.co.uk/Max-MAX430S...words=max+case ). See attached. Really good case for the money, made in Italy no less.
I'll try and upload some useful data at some point.
bobof is offline
post #4 of 122 Old 09-30-2017, 12:23 PM - Thread Starter
aka jfinnie
Liked: 2606
In case anyone is interested in timings for profiles; a 21^3 cube with 0.25s delay per patch, and drift patches every 20 patches (9725 patches total) takes just over 5 hours in preset mode 0 with a JVC DLA-X30 display going between 0.002cd/m2 and 60cd/m2. So averaging a reading every 2s all-in over this luma range.
bobof is offline
post #5 of 122 Old 10-24-2018, 05:00 AM
dziemian's Avatar
Quoted: 37 Post(s)
What in your opinion is better to buy nowadays as a daily use colorimeter? Basiccolor Discus or a new i1dipslay pro oem with 2000 nits range? Assuming you still need a xrite pro2 spectro as a reference.
Macmini | minidsp nanoAVR HDA | MSB-MVC- 1 | Cinepro 2k6 | Gedlee Abbey 12c + 4 Aurasound ns10-794-4a subs + 2 JBL W12Gti subs
Macmini | Hdfury Integral | eecolor box | HDfury Vertex | Ruipro 10m HDMI | JVC RS400 | Stewart Studiotek 130 screen
dziemian is offline
post #6 of 122 Old 10-24-2018, 05:35 AM - Thread Starter
aka jfinnie
Liked: 2606
For Discus you absolutely need a spectro; for i1display pro you may be OK(ish) without.
If you need to use software based on the excellent ArgyllCMS (HCFR, Displaycal, etc) then the decision is made for you - there is no Discus support.
Discus readings of very dark patches are without parallel in the sub $1K region. Often if I just want to do a quick reading of something I'll grab the i1d3 as it is a little more versatile - no need to do dark cal step, can set very fast integration times so long as you are conscious of what you are doing.
If Lightspace is your poison then for 3DLUT Discus condemns you to the much more expensive Lightspace HTP license, which has some nice bells and whistles but is a lot more money than HTL.
If I could only have 1 meter I'd get the i1d3; in fact I'd probably always want one to be able to use the tools that don't support Discus. If you can afford the extra meter and software licenses then the Discus allows you to add useful readings in regions the i1d3 simply cannot reach.
Manni01 likes this.
bobof is offline
post #7 of 122 Old 02-16-2019, 09:26 AM
dlinsley's Avatar
Quoted: 706 Post(s)
Liked: 566
How is everyone profiling their Discus? Do you have a jig or two tripods, or just swap which meter is on the tripod? Is the viewing area/angle the same as the i1Pro2 or do we need to use different distances from the screen?
I'd previously been using the LCOS 709 profile, which I think Manni provided to Basiccolor, with good results (by eye and a C6 trained with the i1Pro2, using the diy jig from the two Spectracal mounts) but I'd like to profile to see if with the 4k JVCs there is a difference.
dlinsley is offline
post #8 of 122 Old 02-16-2019, 11:48 AM
Manni01's Avatar
Quoted: 5925 Post(s)
Liked: 6507
These profiles are better than the old factory presets, but there don't replace a proper profile made in situ with a spectro.
I use a single tripod with a dual mount. In the past I used to use two tripods to match the viewing angles (they are different, I had the Discus at 2ft and the i1pro2 at 3 feet) but frankly as I use full patterns (to match the size of internal patterns of the JVC used during the autocal) I've stopped as it makes no difference except it's a real pain.
I highly suggest, when profiling, to set the Discus to high average, long integration and to enable the low light handler of the i1pro2 set to 30 samples and a trigger of 500nits (which means likely all measurements!). That way, the profile is good every single time, especially if you run a dark cal on the discus and a white cal on the i1pro2 just before profiling, as they both drift even within their calibration window.
If you have any JVC 4K specific question, please post them in the new calibration thread (see my sig). I've just answered bobof there and mentioned the different meter profiles I use for the Discus with the JVCs. I also posted detailed measurements and first impressions of my rs2000 that you might find interesting
dlinsley likes this.
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
JVC Macro feature on Vertex/Vertex2/Integral2/Maestro/Diva
Manni01 is offline
post #9 of 122 Old 02-16-2019, 12:19 PM
dlinsley's Avatar
Quoted: 706 Post(s)
Liked: 566
Thanks Manni, and will do.
I've seen those dual mounts posted before, I can't recall who sells them, and may look into that. I think they were the price of my decent tripod though, so I'll probably just pick up another of those locally
dlinsley is offline
post #10 of 122 Old 03-22-2019, 10:00 PM
mywaycn's Avatar
Liked: 1
Hi Everyone.
may i ask there is good points out BasICColor DISCUS is better than Spectracal C6 HDR-2000 besides BasICColor has 500 cd/m2 better than the other.
My i1Display pro bought on 2012, thinking to upgrade it.
mywaycn is offline
post #11 of 122 Old 03-23-2019, 12:49 AM
Anger.miki's Avatar
Quoted: 597 Post(s)
Liked: 774
Shortly: With Discus you get more consistent measurements in low light reading (0-5%), for all the rest you have the same i1D3/C6 readings but (really) slowly &#x1f609;
Let’s say that Discus is the child of a Klein k10a and a turtle.
Manni01 likes this.
T.U.C. Master | TVs: Pioneer PDP-LX5090H, LG OLED55C8PLA | AV Receiver: Pioneer VSX-921 | BD Player: Panasonic DMP-BDT260EG | External LUT box: Entertainment Experience eeColor | Softwares: Light Illusion Lightspace HTP,, ColourSpace HTX, CM Enthusiast, HCFR, DisplayCAL | Probes: Klein K10-A, Jeti spectraval 1501, X-Rite i1 Display Pro OEM Rev. B-02 | Test Pattern Generator: Riccardo Biasiotto’s PGenerator (RPi)
Anger.miki is offline
post #12 of 122 Old 03-23-2019, 04:11 AM
Light Illusion's Avatar
Quoted: 1005 Post(s)
Liked: 1608
Remember the C6 is just an i1D3 OEM.
No hardware/firmware difference.
The Discus is very good, but lacks a 'sync' function.
That is why it can be slow on some display technologies, as a long integration time will be required for stable readings.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #13 of 122 Old 03-23-2019, 05:31 AM - Thread Starter
aka jfinnie
Liked: 2606
A good example of this is that at 24p the Discus returns inconsistent, unstable readings from JVC projectors in Mode 0. Mode 2 is required to get stable results.
I like my Discus. I've listed the niggles and benefits above. Take particular note of the requirement to use a spectro to profile it. With other meters the built in modes are useful for many home displays. The Discus doesn't have any built in tables as far as I can see that are of any use whatsoever with consumer TV or lamp projectors, they are all miles off. So a spectro is absolutely essential.
If you don't have a spectro, don't bother with Discus, your results will not be very good at all.
What displays are you looking to calibrate with it?
bobof is offline
post #14 of 122 Old 03-25-2019, 12:13 AM
mywaycn's Avatar
Liked: 1
Well noted. then i will not consider DISCUS agin.
Here is what i done recently, you may check it.
https://www.avsforum.com/forum/139-d...l#post57799906
mywaycn is offline
post #15 of 122 Old 04-07-2019, 05:28 AM
adolfotregosa's Avatar
Quoted: 101 Post(s)
Liked: 57
Sorry to jump in like this but did any of you discus owners used it on LG Oled tv ? Does it work ok? Any recommendation?
thank you
adolfotregosa is offline
post #16 of 122 Old 04-07-2019, 10:04 AM
Anger.miki's Avatar
Quoted: 597 Post(s)
Liked: 774
As far as you use integration time settings on 2 or 3 I can’t see any reason for it to not work properly.
post #17 of 122 Old 04-07-2019, 01:20 PM - Thread Starter
aka jfinnie
Liked: 2606
Just make sure you have a spectrophotometer / spectroradiometer available to create 4 colour correction matrices. Without it the Discus won't do you much good.
bobof is offline
post #18 of 122 Old 04-07-2019, 01:26 PM
Quoted: 101 Post(s)
Liked: 57
Yes I have i1pro2 for that.
Thank you for your input, I will try to buy one to replace my i1d3. I am not confident with very low light readings of the i1d3 and the discus is the only choice and even it is expensive.
The joy of calibrating...
post #19 of 122 Old 04-07-2019, 01:48 PM - Thread Starter
aka jfinnie
Liked: 2606
Yes, there is certainly nothing that can compare for low-end reading capability outside of the "big boy" meters like the Klein and Colorimetry Research units.
What software are you using?
bobof is offline
post #20 of 122 Old 04-07-2019, 01:52 PM
Quoted: 101 Post(s)
Liked: 57
Very nice to hear because I really hope to improve the low readings.
LS-HTL, why?
post #21 of 122 Old 04-07-2019, 02:03 PM - Thread Starter
aka jfinnie
Liked: 2606
LS-HTL, why?
Good choice in LS. Just bear in mind HTL won't work with Discus. You'll have to upgrade to HTP.
bobof is offline
post #22 of 122 Old 04-07-2019, 02:14 PM
Quoted: 101 Post(s)
Liked: 57
I always mix the names. I meant LS-HTP.
bobof and Anger.miki like this.
post #23 of 122 Old 11-26-2019, 02:42 AM
Sam Ash's Avatar
Quoted: 523 Post(s)
Liked: 73
Hi Bobof, I'm glad I found this thread and thank you so much for doing a review on the Discus and sharing information that would otherwise be difficult to find.
I am interested to calibrate my DLP-projector, it may not have the black levels of the LCOS based JVC but I like the overall image. My first projector did not have a CMS but my current one does which is an advantage.
Apparently, HCFR is the only open source and free utility that is available and I'm not sure if ZOYD is supporting it any more. Although users say it works. The only other free tool is LightSpace ZRO and I'm not sure if this is sufficient. From your explanation, it is clear that the right probe for me would be the i1Display Pro. I don't need the 2,000nits version but since I don't have a probe, I might as well buy the best specification possible. The retail version is cheaper and I'm not sure if there are companies out there that can build corrections for the i1D3 for a reasonable fee. Although my projector is lamp based and works to REC709, I would definitely want corrections for laser-phosphor and DCI-P3.
I would like to be able to do this without spending a ton of cash but there are not a lot of options out there.
I love the interface of Chromapure and the fact that they do offer the i1D Pro with corrections but it costs quite a bit just like all the other tools.
Your input will be appreciated.
Sam Ash is offline
post #24 of 122 Old 11-26-2019, 08:07 AM
Quoted: 6283 Post(s)
Liked: 2642
Is that for 3D LUT?
Ted said that even the free ZRO license supports “measurements” for all instruments:
https://www.avsforum.com/forum/139-d...l#post58869608
You can check the free license version of LightSpace, called as LightSpace ZRO, where i1Display PRO's (not Plus) are supported. That license level support all high-end instruments for measurements also.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #25 of 122 Old 11-26-2019, 11:19 AM
Rolls-Royce's Avatar
Quoted: 1503 Post(s)
Liked: 1597
Originally Posted by Dominic Chan View Post
Is that for 3D LUT?
HTL does 3D LUTs for certain HT applications (Lumagen, eeColor, LG, etc), but doesn't work with all measurement gear, as it also doesn't allow most in-program LUT manipulation. You need the HTP license for the last two (I just upgraded from HTL to HTP a few months ago).
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #26 of 122 Old 11-26-2019, 11:51 AM
Liked: 2642
Thanks. Just to clarify, manual calibration supports all instruments regardless of license, and 3D LUT calibration supports different sets of instruments, depending on license?
post #27 of 122 Old 11-26-2019, 12:00 PM - Thread Starter
aka jfinnie
Liked: 2606
This isn't really the place for this discussion as it has nothing to do with Discus. In brief; if you're not looking to pay for SW then your two options for manual cal really are HCFR (free and open source) or Lightspace ZRO (free to use licensed SW). However many meters as not supported by HCFR but are supported by Lightspace ZRO. Discus is a case in point. For i1d3 meters either OEM or retail will work, though for Lightpspace ZRO you'll need a patch for retail meters. Personally, I think if using LS ZRO at no cost, you might a well spend a little coin with them which shows willing and buy the OEM meter from them which means not having to patch the SW to make the meter work (. The OEM meter is very good value I think as it has same spec as retail Plus meter for a lower delivered cost. I still think the HCFR interface is nicer in places than LS for manual cal, but the LS interface is functional and works well.
There aren't "corrections for P3". You may find corrections for Laser projectors with the Calman C6 or Chromapure versions (check their lists), and you might be able to download corrections for HCFR for lasers for i1d3 (I'm not sure). Not sure why you care though seeing as you don't have a laser PJ.
To be honest, best take the discussion to the HCFR thread and / or Lightspace thread
bobof is offline
post #28 of 122 Old 11-26-2019, 12:02 PM
Liked: 1608
You can see the different Home Cinema LightSpace options here:
https://www.lightillusion.com/lights...t_options.html
And Professional LightSpace here:
https://www.lightillusion.com/lightspace_options.html
Hover over the icons for more info, including what hardware is supported, available features, etc.
Steve
Steve Shaw
LIGHT ILLUSION
post #29 of 122 Old 11-26-2019, 12:07 PM - Thread Starter
aka jfinnie
Liked: 2606
No. If you have the LS ZRO license you can use all instruments in ZRO, subject to the limitations of ZRO (which is built in patch sets only I believe). If you have LS HTL you can only use meters supported by HTL in manual and 3DLUT. Manual mode has more capabilities in HTL than in ZRO. I don't know about having the two licenses co-exist; I've not needed to as I have HTP.
I think in general most folk with a meter that falls into pro land end up with the HTP license, not HTL only. Discus is one meter which doesn't sit very well in the scheme. I don't really regard it as a pro meter - it is much, much too slow for pro use, and the filters are a poor match for CIE which I think is a problem for matching to WRGB displays for instance. Lightspace HTP is much more expensive than the Discus meter. I felt mildly aggrieved at having to buy an HTP license for the Discus, but seeing as I now also have a Jeti I'm OK with it I guess...
Rolls-Royce and Manni01 like this.
bobof is offline
post #30 of 122 Old 11-27-2019, 07:23 AM
Sam Ash's Avatar
Quoted: 523 Post(s)
Liked: 73
Thank you for the comprehensive reply. Not sure if HCFR is still being supported, hope it carries-on as an open-source project. I'm looking into P3 for when I upgrade.
I don't mind investing in paid software and the OEM version of the i1D3 but just wanted to know the current state of HCFR.
Sam Ash is offline
Reply Display Calibration
basiccolor , calibration , colorimeter , discus , meter
