Calibrating HDR on Epson 5040/6040 projectors - Page 38 - AVS Forum | Home Theater Discussions And Reviews
 137Likes
post #1111 of 1145 Old 02-13-2019, 09:01 AM
monkaquinas's Avatar
Quoted: 90 Post(s)
Liked: 41
Originally Posted by siuengr View Post
Here are my settings.
Settings
Color Mode: Natural
Brightness: 59
Contrast: 43
Color Saturation: 50
Tint: 50
Color Temp: 5500K
Skin Tone: 4
Offset: 48,50,52
Gain: 53,50,57
Gamma: 0,-2,-9,-8,-10,-2,0,32,0
RGBCMY
R: 69,30,96
G: 55,78,0
B: 41,34,64
C: 80,92,15
M: 67,20,100
Y: 32,52,44
I started over a couple more times, and this was as flat as I could get the RGB levels with gamma. The blue seems a little off at 30, but if you adjust the Blue offset down to 51 it throws everything else out of whack.
I also don't know why I have to set it to 5500K to get it calibrated to 6500K, but it seems to work.
Here is a quick shot from my phone or my settings.
Here is the same using Orcus' settings.
Hmm, 55k, that's warm but I know that the menu here is more limited than the 6040. I'll give this a try this weekend when I have time to sit down. Thanks for sharing and doing a comparison with Orcus. Would the rest of the settings be the same as Orcus? So I can just load those and adjust it to yours?
Epson5040UB - DragonFly DFM Tab 92HC High Contrast (.9 gain) 16:9 Screen - Denon AVRS740H - Klipsch Quintet V +
Klipsch KHC-6 In-Ceiling (Atmos 5.1.2) with SVS PB-1000 - Panasonic UB820 - PS3
monkaquinas is offline
post #1112 of 1145 Old 02-13-2019, 09:17 AM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
5500K is just the setting on the projector, but actually measures a little above 6500K. I didn't post the graph of the color temp, but it tracks close to 6500K.
There are a couple differences from Orcus
Superwhite Off
Power Medium
I'll update my post with the full list of settings.
JOjr likes this.
My Theater Build: The Underground Apolkalypse Theater
Marantz SR7010, Monolith 7 Amplifier, Pro-Ject - Debut Carbon Esprit SB
Epson 5040ub, Oppo UHD-203 Player, Xbox One, nVidia Shield
Atmos 7.3.4 - Polk 2x RTiA9, CSiA6, 2x FXiA6, 2x RTIA3, 4x 70-RT
PowerSoundAudio XS30, Sunfire 2x - HRS-12 12" Subwoofers
siuengr is offline
post #1113 of 1145 Old 02-13-2019, 09:28 AM
AdamAttewell's Avatar
Quoted: 825 Post(s)
Liked: 205
Superwhite Off
Power Medium
So you have got me interested in having a go at calibrating my own CMS. Up to now I have just been using others settings with just tweaking the two point grayscale.
What is your workflow?
AdamAttewell is offline
post #1114 of 1145 Old 02-13-2019, 10:07 AM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
This is my first time calibrating, so I am learning as I go. My numbers seem odd compared to some of the other settings, so I still trying to figure out if I should "trust the meter." The two settings that I had used the most were Orcus and Jbartelli. If I switch between mine, Orcus, and jbartelli, they look a little red, a little green, or a little blue, respectively. They measure that way on my meter. I am also using a Dark Energy Abyss ALR screen, with a .9 gain.
I am using the i1 Display Pro meter, and mainly follow viperlogics workflow in post 344 with a couple of changes.
I started with the grayscale sweep and color temp at 6500k, for me it had green at 100%, blue at 120%, and red at 80%.
I kept reducing the color temp until they were all close to 100%, which ended up being 5500K.
Once that is set, in HCFR, right click in the RGB levels window to see the results w/gamma. This will skew the line all over the place.
Then I adjusted Brightness and Contrast to straighten the line as much as possible, then used the gamma to fine tune.
Only after I got the line at flat as possible did I start adjusting colors.
monkaquinas likes this.
siuengr is offline
post #1115 of 1145 Old 02-13-2019, 10:14 AM
Quoted: 5557 Post(s)
Liked: 2244
Presumably you mean RGB Gain and Offset. In any case, they should not be adjusted using the “w/gamma” option.
The objectives of those adjustments are to balance R/G/B. The gamma is adjusted using the 10/20-point controls.
Dominic Chan is online now
post #1116 of 1145 Old 02-13-2019, 11:22 AM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
I didn't use the RGB Gain and Offset to adjust gamma. I just adjusted the gamma before adjusting the colors compared to viperlogic's tutorial which adjusted the colors before gamma. I just found that changes in gamma affected the colors more that changes in color affected gamma.
I think I did adjust the offset and gain w/gamma option enabled. What issues does that cause?
Looking at the charts I don't think it would have changed my settings. I attached both with and without gamma. Still a mess below 40, but tracks great above. I also threw in my color temp chart. It tracks right at 6500K.
ID:	2525148   Click image for larger version
ID:	2525150   Click image for larger version
siuengr is offline
post #1117 of 1145 Old 02-13-2019, 02:08 PM
Liked: 2244
My comment was directed at your statement
Brightness control is used to set the black level. I do not know what you mean by using it to “straighen the line” when looking at the RGB graph with gamma.
Offset and gain should be adjusted using only two of the three colours. When using “without gamma”, the adjustment will make all three colours read 100%, which simply means all three colours are equal. If you use the “w/gamma” option, in all likelihood you will have to change all three colours to make them all read 100%, which would result in some undesirable side effects.
post #1118 of 1145 Old 02-13-2019, 04:26 PM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
Brightness control is used to set the black level. I do not know what you mean by using it to “straighten the line” when looking at the RGB graph with gamma.
I was just basing it off your original comment that said I needed to look at it w/gamma, and I would have seen my target luminescence was off. I didn't realize it would throw it off the color changing it with gamma.
By straightening the line on the RGB Levels, I mean that if you you match the luminance curve then the RGB line will be straight with or without gamma on. I was using the grayscale, watching the numbers, and the green line on the rgb levels while adjusting the gamma controls to get the green line at 100%.
If the luminance curve match the target curve 100% would the RGB Levels with and without gamma be the same?
Here is an example of what I mean. All the the other settings and built in setting have huge luminance errors that cause the same wave in the RGB Levels chart w/gamma.
These setting look pretty good and flat without gamma.
But if you look with gamma, you get a nice wave.
Looking at the luminance chart, you can see it is way off.
ID:	2525306   Click image for larger version
ID:	2525308   Click image for larger version
siuengr is offline
post #1119 of 1145 Old 02-13-2019, 05:38 PM
Liked: 2244
Which post are you referring to? I need to revisit it and see if the wording was misleading, as what you're doing is not what I was suggesting.
That is correct assuming you're adjusting the 10-point (gamma controls), but not for adjusting the gains and offsets (or Brightness, maybe Contrast).
Yes. "RGB w/gamma" provides the same information presented in the "RGB w/o gamma" as well as the gamma curve (or luminance difference)
Yes, that's why you need to look at "RGB w/gamma" when adjusting gamma, but not when you're adjusting gain and offset.
post #1120 of 1145 Old 02-13-2019, 05:59 PM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
Here is what I was referring to. I took it to say I should be adjusting w/gamma so I could take the luminance errors into account.
The luminance is well below the target - 5% is the same as black (0.016 nits), 10% is at 0.027 nits compared with the target of 0.084 nits, etc.
You will see the luminance errors very clearly if you set the RGB graph option to “w/gamma” by right-clicking on it.
Since your black level is quite high, you should changed the reference black level.
I think we agree, I just wasn't stating it clearly. I am only using the gamma controls to adjust the luminance curve. I didn't realize there would be an issue adjusting the Gain and Offset w/gamma.
siuengr is offline
post #1121 of 1145 Old 02-15-2019, 09:28 AM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
So I went back to check some settings last night because my settings seem very warm. I measured Natural default setting at 6500K, 6000K, and 5500K. I can post the graphs later, but 6500K was very cool with blue way above the green line, and red below. 6000K was better, but I still couldn't bring the red up to 100%. I also tested viperlogic's settings, since he posted his calibration files as well. His calibration file show everything calibrated correctly, but when I took the measurements, I got blue around 120% over green.
That means that either my screen runs cool, the patterns aren't working right with chormecast through the shield, or the meter is wrong. I tried some video calibration files played through my Oppo, and go the same results, so I don't think it is the generator. I also had some Elite gray screen material samples laying around. I tried those, and while they were better, they still present a little on the cool side. I don't really know how to test the meter. I can try it on another display, but I don't have anything else calibrated, so I don't know if that will help me out.
I did an SDR calibration, which I calibrated at 6000K. Again, everything on the calibration file looks great, but when I watch something skin tones look a little red. Sometime they look ok, but sometimes it looks like too much.
siuengr is offline
post #1122 of 1145 Old 02-15-2019, 11:00 AM
Quoted: 90 Post(s)
Liked: 41
I'm seeing something similar using the Harpervision settings. I was watching Passengers and it had a great dynamic look. When it got to Jim, he would look fine for most scenes and then in other scenes, like the bar, he would look like he had a sunburn. I tried dialing back Color Sat and Skin Color and it helped to tame it but it was still present. I hope to give yours a try this weekend and see what it looks like on my 1.0 CineGray.
post #1123 of 1145 Old 02-16-2019, 01:15 PM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
I used my meter on my OLED TV today to see if the same blue shift was present. It wasn't, so now I am pretty confident that it is just that my screen runs very cool. I did have a sample of the CineGray screen, and ran a grayscale sweep on it. It was the most neutral of all the samples I checked, but still had a little blue push. If you try out my settings, you will probably want to change the color temp to 6000K or 6500K so the red isn't too saturated.
siuengr is offline
post #1124 of 1145 Old 07-31-2019, 07:28 AM
quazl's Avatar
Liked: 0
Question Newb tripping over his own feet
A few questions from a newb stumbling through this:
When the guide says this:
Dial in using 30% and 80% points using continuous measure (HCFR: F8) and adjusting Red and Blue offset for 30% and Red and Blue gain for 80% so as to get a dE of 2 or lower, though lower than 1 should be easily achievable.
Does this mean that after I do the 21 point sweep, that I press the 30% column in the top half of the software and then start doing a continuous sweep? Do I look at the deltas and adjust the red and blue offsets to get it as close to zero as possible? Then select the 80% column which changes the auto generated pattern to the 80% greyscale and then adjust the red and blue gains to get that delta as close to zero as possible?
Next question pertains to the settings right before adjusting the gamma curve
Set “Target MaxL” to your 100% measure from the grayscale run.
What does this actually mean? What was my "100% measure" from the grayscale run?
I am struggling on what to set the Target MaxL at?
I set my diffuse white[nits] to 25 and set the MaxL to 150 (just used someone else's numbers). I set the Master MaxL to 4000 and was successful with my gamma curve, but I would like to know what to appropriately set the Target MaxL to?
Is this the brightest my Projector will get?
Also how do I determine what my firmware is at? I found the entries in the Information area of the menu, but the top set of numbers end with 111 but the bottom set of numbers end with 112.
Thanks for any help,
~Q
quazl is offline
post #1125 of 1145 Old 07-31-2019, 10:25 AM
Liked: 2244
You can try to minimize the dE, but for this adjustment it's easier to try to get R/G/B all closest to 100% (as shown in the lower left window).
100% measure is simply the measured luminance at 100% input, i.e., white.
Which MaxL? There are four of them.
That's the easiest one to set. It should be auto-populated; if not, set it to the measured 100% white luminance.
This is the brightest your highlights can be. However, the overall brightness is determined by the diffuse white setting.
post #1126 of 1145 Old 08-26-2019, 12:13 PM
DavidinGA's Avatar
Quoted: 508 Post(s)
Liked: 188
I'm considering getting a meter and was wondering what is the end result benefits? I have a 5040 and have been using the harpervision hdr settings and/or running madVR (plus the HDR Optimizer app) for tone mapping.
Could anyone estimate an approximate level of "gain" in going down the calibration path? I mean would you estimate your overall image quality improved 20% from before/after your calibration? 10% 50% How would you estimate your improvement level?
Source: HTPC w/madVR, Video: Epson 5040, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofers: 1 MiniMarty um18 w/NX3000D. 2 VBSS 18" Subs w/NX3000D.
DavidinGA is online now
post #1127 of 1145 Old 08-31-2019, 04:35 AM
yiepyiep's Avatar
Liked: 0
Hi, I have bought the tw9400 for a couple of weeks. It has been a great. However, i have noticed that the movie freezed when i access to the gamma menu for making adjustment. The movie continue to play again, after i have exited the gamma menu. Is it normal, ir the projector is faulty? Thanks fir helping me clarifying this
yiepyiep is offline
post #1128 of 1145 Old 08-31-2019, 06:53 AM
Liked: 2244
This is normal.
post #1129 of 1145 Old 08-31-2019, 07:53 AM
yiepyiep's Avatar
Liked: 0
Thank you so much, dominic. Glad to hear this.
yiepyiep is offline
post #1130 of 1145 Old 10-02-2019, 01:41 PM
DavidinGA's Avatar
Quoted: 508 Post(s)
Liked: 188
Does anyone have any before and after calibration images to see how much can be gained through the process?
post #1131 of 1145 Old 10-23-2019, 10:34 AM
Quoted: 23 Post(s)
Liked: 8
Settings
Color Mode: Natural
Brightness: 59
Contrast: 43
Tint: 50
Color Temp: 5500K
Skin Tone: 4
Offset: 48,50,52
Gain: 53,50,57
RGBCMY
R: 69,30,96
G: 55,78,0
B: 41,34,64
C: 80,92,15
M: 67,20,100
Y: 32,52,44
Super White: Off
Lens Iris: 0
Power Consumption: Med
Auto Iris: High
HDMI Video Range: Auto
Color Space: Auto
Dynamic Range: Auto(Bright)
Image Processing: Fine
These settings have been the closest to looking perfect on my setup using the 5040ub and xbox one s. I messed with some adjustments here and there but these seem to have been very close, though i should mention I don't have any tools going by my eyes but it looks amazing. The skin tones look great.
JOjr is offline
post #1132 of 1145 Old 10-23-2019, 11:56 AM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
Thanks, I think my screen tends to make everything a little blue, hence my 5500k setting. It is tough to get skintones looking right. I am still tweaking mine a lot. I may start from scratch and try again to see what I come up with. I have noticed that I have to the the color temp depending on the movie. Some movies seem fine at 5500K, but others seem overly red and I change it to 6000 or 6500 before it looks correct.
siuengr is offline
post #1133 of 1145 Old 10-23-2019, 01:51 PM
DavidinGA's Avatar
Quoted: 508 Post(s)
Liked: 188
I'm glad I'm not the only one who does that lol! I tend to move my color temp around depending on the movie to get it just right. Just doesn't seem to be a perfect spot for all movies....
Sent from my Pixel 2 XL using Tapatalk
siuengr likes this.
post #1134 of 1145 Old 11-05-2019, 09:26 AM
DavidinGA's Avatar
Quoted: 508 Post(s)
Liked: 188
Settings
Color Mode: Natural
Brightness: 59
Contrast: 43
Tint: 50
Color Temp: 5500K
Skin Tone: 4
Offset: 48,50,52
Gain: 53,50,57
RGBCMY
R: 69,30,96
G: 55,78,0
B: 41,34,64
C: 80,92,15
M: 67,20,100
Y: 32,52,44
Super White: Off
Lens Iris: 0
Auto Iris: High
Color Space: Auto
Do these settings seem to address the red face issues? I still have problems with skin tones...
post #1135 of 1145 Old 11-05-2019, 09:53 AM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
I end up changing the color temperature up to 6000k or 6500k because a lot of the time the image looks too red. It calibrated correctly at that temperature, but it just doesn't look correct all the time. Some movies are fine, but I get others where I get red skins tones.
siuengr is offline
post #1136 of 1145 Old 11-05-2019, 11:01 AM
DavidinGA's Avatar
Quoted: 508 Post(s)
Liked: 188
That's my problem; most movies look excellent and others have a big issue with skin tones looking too red. Did anyone ever come to a conclusion on why the Epson seems to have this common problem?
post #1137 of 1145 Old 12-08-2019, 07:45 PM
jt7272's Avatar
Quoted: 75 Post(s)
Liked: 61
What are you using as a pattern generator? And how are you setting up Hcfr?
I had serious issues with red until I started using my PC as the pattern generator and I stopped calibrating colors with the saturation measurement. Utilizing the 50_50 color checker to dial in the CMS yielded much better results.
What kept happening was that dialing in the CMS with saturation targets yielded too much Y for red at lower luminance targets. Utilizing 50% targets resulted in more accurate colors at 0-75% luminance, and less accuracy at 100%. This is a much more pleasing picture.
Epson 6040ub
Denon AVR-X3400H + Mirage OMD-5 surrounds
Home-made Hybrid PCB Electrostatic Floorstanding L+R Speakers (with built-in DSP + amps)
Home-made sub with 15" Ultimax woofer, Dayton SA1000 Amp
Sony PS4, Sony UBP-X800, Panasonic DP-UB820
jt7272 is offline
post #1138 of 1145 Old 12-08-2019, 08:58 PM
siuengr's Avatar
Quoted: 246 Post(s)
Liked: 269
I was using a nVidia Sheild to chromecast the patterns. I followed a tutorial to set it up. Not sure what specific settings you are looking for. The color space is UHDTV - Rec2020/P3. I used the 50_50 color checker. I'm pretty sire it is my screen. When I would try other peoples settings the red was way off until I changed the color temp, then it would fall into line.
siuengr is offline
post #1139 of 1145 Old 12-29-2019, 09:15 AM
thelonghop's Avatar
Quoted: 24 Post(s)
Liked: 5
Hello! I consider myself fairly 'techie' but display calibration is quite the rabbit hole.
The Idiot's Guide to Manual Display Calibration on lightillusion.com is the most straightforward guide to calibration that I've found for SDR. I like how it lays out everything you need in the process- LightSpace ZRO (when CMS is mentioned here is it referring to LightSpace?), probe, patch generator (LightSpace ZRO can be used), calibration discs, and then the steps to follow.
Is there a similar straight forward you need A,B,C and then do 1,2,3 for UHD/HDR?
thelonghop is offline
post #1140 of 1145 Old 02-14-2020, 12:37 PM
Liked: 1
Hi All,
I am trying to calibrate my 5040UB for HDR. I get about 63 nits peak @ medium lamp on digital cinema. I tried high lamp which gets me a little more than 10 nits over medium, but then the projector, which is right over my head, is obnoxiously loud... I tried Natural and Bright Cinema which get me closer to ~110 nits with medium lamp, but I found the highlights to be a little too bright to be honest, so I figured I would stick with Digital Cinema and get the wider color gamut.
I had horrible errors on the low end for grayscale (way too much blue and red, way too little green). The only way I could get these under control at the low end was messing with the color uniformity.
The problem is that at the end of my calibration for 1000 nits, 27 nits diffuse white, I am having trouble dialing in the CMS. I tried using the 50% saturation targets but the other saturation levels are not really falling in line. If I try to get those closer to target then the 50% goes haywire... Is there anything I should try to get all the levels to hit their target more closely, or am I just out of luck with my display and screen?
I also see weird color gradients on skin tones with this calibration as well. It seems to be from the custom gamma settings I had to use to get the EOTF under control.
I've got a silver ticket grey screen. I am using an X-Rite i1Display Pro to measure and a CCast Ultra for getting HCFR internal patterns. I chose 'Projector' as the display type and left everything else alone. I manually set my projector to BT2020 color space and HDR 2.
My HCFR calibration is attached if that helps.
File Type: zip DigitalCinema_HDR2_MediumLamp_CCast.zip (58.8 KB, 4 views)
ordivergens is online now
Reply Display Calibration
