Panasonic EZ1000 3D LUT - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 33 Old 02-06-2018, 04:26 AM - Thread Starter
Liked: 0
How can I access it? and what lut format does it accept? I have been emailing panasonic support for a while with no luck. I have searched this forum and couldnt come across anything. I have searched other forums and no luck. Is it a marketing gimmic or there is an option to have 3d luts uploaded into an EZ1000 OLED tv?
thanks
dude05 is offline
post #2 of 33 Old 02-06-2018, 06:55 AM
Rolls-Royce's Avatar
Quoted: 1290 Post(s)
Liked: 1369
Suggest you PM #ConnecTEDDD here on the forum directly. He's a calibrator, based in Europe (Greece), and is highly knowledgeable about LUTs, the software that creates them, and the different displays and external boxes that employ them. He would likely know more than anyone here about the EZ1000.
ConnecTEDDD likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 33 Old 02-06-2018, 09:27 AM
ConnecTEDDD's Avatar
Quoted: 3479 Post(s)
Liked: 4331
Hi guys,
Panasonic EZ1000 support *.cube DaVinci Resolve format file type, you can use LightSpace to export that kind of file format (any of these 4 cube size below will work, 1D LUT is not working):
...then copy the 3D LUT file to the SD card (doesn't matter what file name you will give) and then use Panasonic menu to upload it.
There no published instructions from Panasonic about that 3D LUT upload feature generally.
Rolls-Royce likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration S/W: LightSpace ZRO / HCFR
S/W: ColourSpace INF, LightSpace XTP, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, ChromaPure
V/P: eeColor 3D LUT Box P/G: Murideo Six-G, DVDO AVLab TPG
Meter: JETI Specbos 1211, Klein K-10A
ConnecTEDDD is offline
post #4 of 33 Old 02-06-2018, 01:45 PM
Liked: 1369
Thanks, Ted!
...Royce...
post #5 of 33 Old 02-07-2018, 01:07 AM
<^..^>Smokey Joe's Avatar
Quoted: 84 Post(s)
Liked: 109
Or you can use calman, the 1D works for them.
http://www.spectracal.com/Documents/...SetupGuide.pdf
Masterpiece Calibration Ltd
Lincolnvilleshire
New Zealand
<^..^>Smokey Joe is offline
post #6 of 33 Old 02-07-2018, 01:46 AM
Liked: 4331
I was talking about 1D LUT upload of 1024-point (10-bit) uploading (you can measure and profile 100-Point grayscale for example; so 100 meter reads; and generate that table with LightSpace), not 10-Point DDC, where to calibrate 10-Point Grayscale you have to take ~100 meter reads with CalMAN, since it's AutoCAL procedure calibrating one-by-one each of those 10-Point Grayscale Points.
post #7 of 33 Old 02-07-2018, 03:15 AM
Quoted: 84 Post(s)
Liked: 109
Does that 3D method wipe the defaults? If it does, well I have a real issue with advising anyone to use it, that would be irresponsible.
Lincolnvilleshire
New Zealand
post #8 of 33 Old 02-07-2018, 04:12 AM
Liked: 4331
RGB balance or any other adjustment has to be at default positions when you will use the 3D LUT upload.
post #9 of 33 Old 02-06-2019, 12:19 PM
Liked: 0
Thumbs up
But where in the TV-menu is it? Been looking for how to do this for months now so really appreciate your previous answer here! :-)
So bad that they are braging about it but there is no documentation how to do it... 🤪🤯🤬
Marcus CF. Tinnerholm is offline
post #10 of 33 Old 02-06-2019, 04:23 PM
Liked: 4331
See @ Others -> 3D LUT Settings
post #11 of 33 Old 02-07-2019, 04:05 AM
Liked: 4331
You save the 3D LUT as Resolve file format and you put it on a USB Stick or SD Card, then you select it from the configuration menu.
See there: https://hdtvpolska.com/funkcja-3d-lu...metoda-3d-lut/
post #12 of 33 Old 02-07-2019, 04:05 AM
Liked: 0
Thanx mate! &#x1f44a;&#x1f44d;&#x2764;&#xfe0f;&#x1f618;
Setup > Others > 3D LUT Settings
(i dont have it in my 2018 950E)
i only have ”Power Saving” there...!?&#x1f631;&#x1f629;
Do you have a good contact at Panasonic?
Ask them please if there is a way to ”unlock” or upgrade to the menu/feature?
Or a hidden secret menu or some special pgm. or trick way to do it for a ”licenced calibrator” or ”service technitian”...?
or if they acually took that away from the NEWER ”TX-65FZ950E” ??&#x1f92f;&#x1f92c;��&#x1f62d;
I dont belive so... all the ”Picture” settings must be 3D LUTs right!? And they need to be able to upload new, corect and calibrate right!?
I have been promised by the retailers that it had ”ALL the features of the OLD EZ1000/1002 and
some extra new improvements like HDR10+ etc”
Especially asked about the 3D LUT feature like 10times to be sure as the official info is verry bad.
Highly appreciate you taking your time! &#x1f64f;&#x1f3fc;
//All the best// Tinnerholm
post #13 of 33 Old 02-07-2019, 04:11 AM
Liked: 4331
1D/3D LUT capability was a feature only for EZ1000/1002 models, 2019 models (like flagship GZ2000) will not have it.
post #14 of 33 Old 12-14-2019, 11:17 AM
Jeroen1000's Avatar
Quoted: 98 Post(s)
@ConnecTEDDD Have you per chance measured (as in a full profile) a GZ1500 or 2000? Going from reviews, it looks like they are quite accurate without a lut (at least the grey scale is) but with regards to colour they do not perform thorough measurements (only the 100% sat and stim points usually).
I very much like the fact the Panasonic has no just above black issues like flashing or posterisation and also do not exhibit the a cyan tint. L9 supposedly still does. Just parroting reviews here this is not from my own experience.
My gear: Panasonic TH-42PF11EK pro plasma display + TX-P55VT60E -- Iscan Duo video processor -- i1 display 3 colorimeter -- i1 pro 2 spectrometer -- Apple TV 4K -- WD LIVE TV gen 3.
Jeroen1000 is offline
post #15 of 33 Old 12-14-2019, 12:28 PM
D-Nice's Avatar
Quoted: 2116 Post(s)
Liked: 3984
They do have above black chrominance issues just like all other 2018/2019 LGD OLED modules.
D-Nice is offline
post #16 of 33 Old 12-15-2019, 11:04 AM
Quoted: 173 Post(s)
Liked: 78
Do you tested one?
If they have it Panasonic has done a great job to hide it.
Vincent confirms this and on my 2018 fz800 I don’t see it also.
Near black looks very clean as does the hole picture. The LGs have more issues and you see this.
Panasonic OLED55FZW 804
i1 Display Pro OEM 2018 profiled by Jeti 1501
i1 Pro 2, DVDo AVLab TPG, HD Fury Integral
Oppo UDP203
baller02 is offline
post #17 of 33 Old 12-15-2019, 11:15 AM
Jeroen1000's Avatar
Quoted: 98 Post(s)
@baller02
Did Vincent use a 3Dlut on yours or just the standard Panasonic controls? The 3Dlut feature is no longer there on newer Panasonics.
Such a lut is currently the only way to 'deal' with the non-additive nature of WRGB oled displays in order to achieve the best colour accuracy. However, unless you have the top dog's gear (Klein colorimeter, Jeti or equivalent spectro) I do not think it is worth it anymore and you can do more harm than good. It's too expensive to stay in the game:-)
So for me Panasonic is still quite an attractive option.
post #18 of 33 Old 12-15-2019, 11:17 AM
Quoted: 173 Post(s)
Liked: 78
The Panasonic factory 3dluts are very good.
I've verified my manual calibration on my Panasonic FZW804(FZ800) with a 1000 Point Lightspace measuring.
Only minor CMS changes are required for this result.
ID:	2654380   Click image for larger version
ID:	2654384   Click image for larger version
Oppo UDP203
baller02 is offline
post #19 of 33 Old 12-15-2019, 11:23 AM
Jeroen1000's Avatar
Quoted: 98 Post(s)
Very interesting. What did you manually calibrate to get to this? Just grey scale?
post #20 of 33 Old 12-15-2019, 11:26 AM
Quoted: 173 Post(s)
Liked: 78
@baller02
Vincent did not calibrate my TV and he and I did not use 3dlut calibration on the Panasonic.
As you see from my calibration, 3dlut is not really necessary on the Panasonic's to get very good measured and most important optical results.
L30Z3N likes this.
Oppo UDP203
baller02 is offline
post #21 of 33 Old 12-15-2019, 11:32 AM
Quoted: 173 Post(s)
Liked: 78
Grayscale and this CMS settings.
Oppo UDP203
baller02 is offline
post #22 of 33 Old 12-15-2019, 11:42 AM
Jeroen1000's Avatar
Quoted: 98 Post(s)
Thanks. I got it wrong there that Vincent did your display. Sorry for that:-) Very good result with just the 'old school' controls.
Just out of interest, how long does a 1000 point profile take with the i1 Display Pro?
I may be tempted into getting a better spectro, but a better colorimeter may set me up for a divorce haha.
post #23 of 33 Old 12-15-2019, 12:11 PM
D-Nice's Avatar
Liked: 3984
Do you tested one?
Sure have
Not really. You just need to know what stimuli range to to look in.
What does Vincent have to do which what I have seen? I don’t care what Vincent has or has not seen. Perhaps he needs to revisit the GZ series. There is an owner on this forum who has seen flashing also.
D-Nice is offline
post #24 of 33 Old 12-15-2019, 12:15 PM
Quoted: 173 Post(s)
Liked: 78
The 1000P Profile took 24-28minutes with 0,75 Integration time and pattern insertion.
Miki got the same repeatable results on his LG C8 with 0.25s Integration time compared to 1 sec Integration time.
So on WOLED's you can measure also with the id3 very quick down to 5%.
Oppo UDP203
baller02 is offline
post #25 of 33 Old 12-15-2019, 12:18 PM
Quoted: 173 Post(s)
Liked: 78
Sure have
Interesting on my 2018 FZW804 I don't see it in real content.
Do you have a test video which we can use to see if a TV is affected?
On the LG Oleds, I'owned before, I have seen a lot of problems in real content.
The Panasonic fzw804 has no problems with real content and this counts for me.
Oppo UDP203
baller02 is offline
post #26 of 33 Old 12-15-2019, 12:44 PM
D-Nice's Avatar
Liked: 3984
Who are the individuals defined in your ‘we’?
I don’t think we are on the same page. My comments are specific to the GZ series not FZ series. If you don’t see it on your FZ series, I don’t understand what is the point of any of the posts between you and I. Just enjoy your TV.
D-Nice is offline
post #27 of 33 Old 12-15-2019, 12:57 PM
Quoted: 173 Post(s)
Liked: 78
Maybe I misunderstood your post, I thought you think all TVs which use 2018/2019 LGD Woled Panels are affected from the black chrominance issues.
Oppo UDP203
baller02 is offline
post #28 of 33 Old 12-15-2019, 01:00 PM
Quoted: 173 Post(s)
Liked: 78
Who are the individuals defined in your &#226;€˜we&#226;€&#x2122;&#xfe0f;
With we all user who want to test it ment.
Oppo UDP203
baller02 is offline
post #29 of 33 Old 12-15-2019, 02:09 PM
WiFi-Spy's Avatar
Quoted: 1722 Post(s)
Liked: 2314
@baller02
WOLED are essentially additive in SDR panel mode. Non-additivity is only really present in HDR panel mode.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #30 of 33 Old 12-15-2019, 03:19 PM
Jeroen1000's Avatar
Quoted: 98 Post(s)
@WiFi-Spy
Hi Tyler, not trying to be a wise fellow here, however, I believe I have read on multiple accounts that the white subpixel cannot be deactivated. Hence, the panel would essentially always be be non-additive? This may be negligible at lower brightness levels (but that begs the question as to what is 'low').
Can you elaborate on what you mean?
Reply Display Calibration
