CalMAN 2018 Beta 1 w/ 2018 LG OLED AutoCAL Support - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 6 Post By WiFi-Spy
  • 1 Post By WiFi-Spy
  • 1 Post By chhanthony
  • 1 Post By Rolls-Royce
post #1 of 19 Old 02-21-2018, 06:36 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1469 Post(s)
Liked: 2084
CalMAN 2018 version 5.9.0 build 23 is available for download.
Business - http://files.spectracal.com/download...N_Business.exe
Home Theater - http://files.spectracal.com/download...alMAN_Home.exe
Studio - http://files.spectracal.com/download...MAN_Studio.exe
Downloads have been updated to resolve a crash on some languages of Windows. - 2/22/2018
Notes
[*]CalMAN 2018 (5.9.0) requires CalMAN or All Access (Maintenance) purchase as of February 2017 or later.
[*]Resolved an issue where the installer's All Access check was off by one month.
[*]Added support for LG 2018 OLED and LCD displays. Support includes 1D and 3D LUTs in both SDR and HDR.
Two new workflows have been included in order to guide users through the new calibration process.
Ultimate, Studio, Video Pro, ISF, Enthusiast
Note: The new LG workflows are a work in progress.
[*]Added Matrix LUT option. An exciting new 3D LUT measurement option for gamut targeting that can generate in under 1 minute.
[*]Added the ability to disable CalMAN sound effects. This can be accessed under Settings\Application Preferences\Disable application sound effects.
[*]Added HDR10 functionality in the Unified Pattern Generator Control Interface (UPGCI)
[*]Updated Konica Minolta CA-410 support to explicitly set measurement mode on connect.
[*]Resolved compatibility issues with CalMAN editors/utilities in language regions where commas are used
Instead of periods.
[*]Resolved an issue with the Jeti Spectraval 1501 causing CalMAN to report invalid readings.
Rolls-Royce, Ips, T( )( )L and 3 others like this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #2 of 19 Old 02-22-2018, 09:02 AM
Hello, World!
Mark_H's Avatar
Quoted: 371 Post(s)
Liked: 258
Any details on the Matrix LUT option?
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #3 of 19 Old 02-23-2018, 06:19 AM
chhanthony's Avatar
Quoted: 186 Post(s)
Liked: 108
Hi Tyler,
I downloaded the CalMAN 2018 business open beta and installed it successfully, but when I open the software it shut off immediately,
It keep shut off the CalMAN even I have reinstalled it again.
After I installed the CalMAN 2017 5.8.25, it can open normally.
Any idea?
Thank you.
Anthony Chan
AV Blog: http://www.avnewbie.com
System: 5.3.4
Panasonic DMP-UB900EBK, Egreat A5, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, Benq HT1075, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #4 of 19 Old 02-23-2018, 09:35 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 2084
Originally Posted by chhanthony View Post
Hi Tyler,
Any idea?
Thank you.
We think we found a bug that causes this behavior on certain Windows Languages. We plan to release a fix ASAP.
WiFi-Spy is offline
post #5 of 19 Old 02-23-2018, 09:40 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 2084
The Matrix LUT option creates a whole 3D LUT from 5 measurements using 3x3 matrix math. This works on devices where the grayscale/gamma has already been calibrated, and the Matrix LUT just controls the color gamut mapping. This is not intended to replace iRP or Lightning LUT methods for monitors that need reference level accuracy.
L30Z3N likes this.
WiFi-Spy is offline
post #6 of 19 Old 02-23-2018, 05:10 PM
chhanthony's Avatar
Quoted: 186 Post(s)
Liked: 108
Red face
9
Thanks a lot!
Anthony Chan
System: 5.3.4
post #7 of 19 Old 02-23-2018, 08:02 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2084
9
Thanks a lot!
The fix has been posted. I updated the first post in this thread with new links.
WiFi-Spy is offline
post #8 of 19 Old 02-23-2018, 09:02 PM
chhanthony's Avatar
Quoted: 186 Post(s)
Liked: 108
It works properly.
Thanks a lot
WiFi-Spy likes this.
Anthony Chan
System: 5.3.4
post #9 of 19 Old 04-22-2018, 04:26 PM
Axel's Avatar
Quoted: 219 Post(s)
Liked: 63
....[*]Added support for LG 2018 OLED and LCD displays. Support includes 1D and 3D LUTs in both SDR and HDR.
Is this an autocal feature?
Does this also work with the 2017 LG OLEDs?
_____
Axel
Axel is offline
post #10 of 19 Old 04-22-2018, 04:34 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2084
Unfortunately it is only on 2018 models.
WiFi-Spy is offline
post #11 of 19 Old 04-22-2018, 05:53 PM
Axel's Avatar
Quoted: 219 Post(s)
Liked: 63
Bummer, but thanks for the answer.
________
Axel
Axel is offline
post #12 of 19 Old 08-02-2019, 06:33 AM
candoan's Avatar
Quoted: 17 Post(s)
Notes
Instead of periods.
Hi,
The download links are dead. Please re-upload.
Pana 60ST60, Onkyo TX-NR3009, OPPO BDP-103, Klipsch WF-35, Klipsch WS-24, Klipsch WC-24, Klipsch Reference RW-12d, BIC America DV62si.
candoan is offline
post #13 of 19 Old 08-02-2019, 09:12 AM
Rolls-Royce's Avatar
Quoted: 1103 Post(s)
Liked: 1210
Originally Posted by candoan View Post
Hi,
That's because the SpectraCal website is no longer in operation, and that version is now obsolescent as well. Check the portrait.com website.
candoan likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #14 of 19 Old 08-02-2019, 03:55 PM
ConnecTEDDD's Avatar
Quoted: 3002 Post(s)
Liked: 3701
Hi,
Hi, if you need that specific build for some reason, I have all CalMAN releases to my HDD (about 50GB), so I can upload it for you.
Home/Studio or Business...let me know which one you will need.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #15 of 19 Old 08-02-2019, 06:01 PM
candoan's Avatar
Quoted: 17 Post(s)
Hi,
I have LG 65 C8 and i'd like to have a right software to do it. You can send me a link at [email protected]
Can Doan
candoan is offline
post #16 of 19 Old 08-03-2019, 12:27 AM
Liked: 3701
Hi,
Can Doan
Hi Can,
I have uploaded the file for you using wetransfer.
But its better idea to use the latest software version available for download here: https://www.portrait.com/downloads1/
post #17 of 19 Old 08-03-2019, 02:47 AM
candoan's Avatar
Quoted: 17 Post(s)
Hi Can,
Thank you very much, but don't see any option for LG 2018 to download. Could I use LG 2019 instead?
Can Doan
candoan is offline
post #18 of 19 Old 08-03-2019, 02:49 AM
Liked: 3701
The latest release support both 2018/2019.
post #19 of 19 Old 08-03-2019, 02:57 AM
candoan's Avatar
Quoted: 17 Post(s)
Thank you very much. I'm at work now and I will try later today.
have a wonderful weekend.
Can doan
candoan is offline
Reply Display Calibration
