Meter compatibility with Windows 10 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 2 Post By ConnecTEDDD
  • 1 Post By ConnecTEDDD
post #1 of 8 Old 07-13-2018, 01:36 AM - Thread Starter
breadvan's Avatar
Hi all,
Haven't calibrated and followed calibration for awhile, want to pick it up again but noticed my 'older' meters having problem working with Windows 10, that is, not having driver written for Windows 10. My meters are i1Pro and i1Display Pro.
Can anyone advise how I can sort this out before I get upgrade for my calibration software? Thanks heap.
breadvan is offline
post #2 of 8 Old 07-13-2018, 10:08 AM
ConnecTEDDD's Avatar
Quoted: 3249 Post(s)
Liked: 4043
Originally Posted by breadvan View Post
Hi all,
Hi, the X-Rite i1Display PRO (colorimeter) is a USB 2.0 Full Speed (actually is a USB Low Power Device) using USB human interface device class (USB HID class) interface.
Human Interface Device (HID) drivers contained in Windows, there no other drivers required to be installed.
The X-Rite i1PRO1/2 (spectrophotometer) only requires drivers to install to operate it.
Here you can download i1PRO's drivers: https://displaycalibrations.com/file...RO_Drivers.zip
What calibration software you are using?
Rolls-Royce and breadvan like this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3 of 8 Old 11-17-2018, 01:59 AM - Thread Starter
breadvan's Avatar
Sorry for this very late reply. I am using CALMAN 5 Enthusiast version, any advice on that please?
breadvan is offline
post #4 of 8 Old 11-17-2018, 02:04 AM
Liked: 4043
i1Display PRO don't require any driver installation.
For the i1PRO driver, you can install the driver (go to device manager and locate the i1pro if it has icon with question mark or you see it there as unknown device, select manually the driver pointing the inf file of the zip above), of install the CalMAN Device Driver Pack 2.4
breadvan likes this.
post #5 of 8 Old 11-17-2018, 02:21 AM - Thread Starter
breadvan's Avatar
Thanks a lot indeed. Will take note of that, much appreciated.
Sent from my ONEPLUS A6013 using Tapatalk
breadvan is offline
post #6 of 8 Old 11-17-2018, 07:36 AM
Rolls-Royce's Avatar
Quoted: 1153 Post(s)
Liked: 1245
If you have installed any of the X-Rite factory software such as I1 Profiler, you will also need to go into Services and turn off the X-Rite Device Services Manager (right-click This PC then click Manage > Services and Applications > Services) before using CalMAN or other 3rd-party software. The X-Rite Device Services Manager can block access to the meter by those programs...
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #7 of 8 Old 11-17-2018, 07:39 AM
Liked: 4043
If you cannot find X-Rite device services in control panel follow instructions below:
Open in the Administrative Tools / Computer Management /
Look for X-Rite Device Services Manager
Double click on that name and a new window will appear
Click the "Quit" button to close the process.
or:
Run "services.msc". At the bottom of the services list, if you see an X-Rite Device Service listed, turn it off.
Rolls-Royce likes this.
post #8 of 8 Old 11-17-2018, 07:41 AM
Liked: 4043
If you have previously installed ArgyllCMS drivers, see there what to do: https://www.argyllcms.com/doc/Installing_MSWindows.html
Reply Display Calibration
