2018 Vizio PQ65-F1 Calibration Thread - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 40Likes
post #421 of 452 Old 06-09-2019, 09:16 AM - Thread Starter
skschatzman's Avatar
Quoted: 2823 Post(s)
Liked: 1628
Originally Posted by DisplayCalNoob View Post
@skschatzman Netflix has two HDR test patterns, you can use the colors to the right to see if there is any color clipping. The last two are in HDR, lower contrast to see if the edges of each color, becomes more distinctive, like sharpening.
Sent from my SM-G550T1 using Tapatalk
Are you talking about the test patterns with the little girl and colored toys all around her? If so, then there is no color clipping. I can see all colors and gradients distinctively.
Lowering contrast each step down to 40 does not have any impact on clipping over the default of 50.
skschatzman is offline
post #422 of 452 Old 06-09-2019, 10:49 AM
Quoted: 1851 Post(s)
Liked: 1116
So you have clearly defined steps between 2000 and 4000 nits, thats interesting. I wonder if Vizio calibrates cast only, then universally apply the settings across the board.
DisplayCalNoob is offline
post #423 of 452 Old 06-09-2019, 03:34 PM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
FW 2.1.7.1 calibration settings
Below are my calibration settings for SDR on firmware 2.1.7.1. This is a complete Grey Scale and Color Gamut calibration using an i1Display Pro. Post-calibration charts from HCFR are attached. Signal source for SDR calibration is madTPG being driven by HCFR. I verified the results using R.Masciola's Advanced Calibration Disc sourced by an Oppo UDP-203.
In the SDR RGB curve you can see a bump at 15% white. The 11-point white balance tuner on the PQ65 doesn't allow me to tune that out.
In the HDR10 RGB curve there is a bump at 75% and dip at 85%. Using the 70% and 80% controls allowed me to flatten those out, but doing so led to visually obvious posterizaton in bright areas so I reverted the 70% and 80% settings back to default.
Vizio PQ65-F1 / Firmware v2.1.7.1
meter: X-Rite i1Display Pro OEM (4" distance) Tripod Mounted
pattern source: madTPG (SDR), Mehanik HDR10 calibration and test patterns set via Oppo UDP-203, MaxCLL 4000 (HDR10)
calibration tool: HCFR (v3.5.1.4)
==={GLOBAL}===
Picture Mode: Calibrated Dark based custom mode
Auto Brightness Control: Off
Backlight: 6
Brightness: 50
Contrast: 50
Color: 50
Tint: 0
Sharpness: 0
Color temperature: Normal*
Black Detail: Off
Active Full Array: Off (for calibration), Low (for viewing)
Reduce Judder: 0
Reduce Motion Blur: 0
Clear Action: Off
Reduce Signal Noise: Off
Reduce Block Noise: Off
Game Low Latency: Off
Film Mode: On
Color Space: Auto
Gamma: 2.2
==={SDR}===
Colorspace Target: ITU-R BT.709
EOTF Target: Gamma law 2.2
Target Peak Brightness: 120 nits
Measured Peak Brightness: 122 nits
Color Tuner
...........,R,G,B,C,M,Y
........Hue,0,-3,2,0,-1,0
.Saturation,-1,-1,-1,-6,4,0
.Brightness,0,3,-2,0,1,0
White Balance
......,R,G,B
Offset,0,0,0
..Gain,6,-9,3
....5%,-15,-20,-46
...10%,-4,-7,-11
...20%,1,0,-3
...30%,2,2,-1
...40%,2,3,2
...50%,1,2,2
...60%,1,2,1
...70%,-4,1,-2
...80%,-5,-10,-7
...90%,2,-6,-7
..100%,7,-4,-5
==={HDR10}===
Colorspace Target: BT.2020 HDR
EOTF Target: ST 2084 HDR(PQ)
Measured Peak Brightness: 2133 nits
Active Full Array: Medium
Backlight: 50
Color Tuner
........Hue,0,0,0,0,0,0
.Saturation,0,0,0,0,0,0
.Brightness,0,0,0,0,0,0
White Balance
......,R,G,B
Offset,0,0,0
..Gain,11,-31,-37
....5%,25,25,29
...10%,-2,-2,6
...20%,-2,1,1
...30%,-5,1,2
...40%,-7,1,5
...50%,-8,0,2
...60%,-10,0,2
...70%,0,0,0
...80%,0,0,0
...90%,0,0,0
..100%,0,0,0
Name:	SDR CIE diagram.jpg
ID:	2578100   Click image for larger version
Name:	SDR grey scale.jpg
ID:	2578102   Click image for larger version
Name:	HDR10 Luminance.jpg
ID:	2578104   Click image for larger version
Name:	HDR10 CIE diagram.jpg
ID:	2578106   Click image for larger version
Name:	HDR10 grey scale.jpg
Life's a party, let's get out and strut.
PhilB is offline
post #424 of 452 Old 06-09-2019, 04:58 PM - Thread Starter
Liked: 1628
I added this to the posted calibration links.
post #425 of 452 Old 06-26-2019, 11:28 AM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
skschatzman,
Did you make any adjustments to the 11-point greyscale settings in the HDR10 or DV calibration, or did you just adjust the RGB Gains?
-phil
PhilB is offline
post #426 of 452 Old 06-26-2019, 12:11 PM - Thread Starter
Liked: 1628
Originally Posted by PhilB View Post
skschatzman,
-phil
I have only made adjustments to the gain for now. The DVGR really doesn't match what my panel is outputting so I am going to leave it like that for now. Golden Reference is not the best method so I am hoping Vizio will adapt with the newer more accepted method. I still want to do a full HDR10 calibration when I get some time.
post #427 of 452 Old 06-26-2019, 06:14 PM
shoman94's Avatar
Quoted: 5071 Post(s)
Liked: 3581
Why not at least align the RGB?
Sent from my LG-H932 using Tapatalk
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #428 of 452 Old 06-26-2019, 06:22 PM - Thread Starter
Liked: 1628
I did. In the post you quoted I said I adjusted gain.
post #429 of 452 Old 06-26-2019, 06:55 PM
shoman94's Avatar
Liked: 3581
I saw that but wondered about doing an 11pt as well? Unless it's balanced well with just gain.
shoman94 is offline
post #430 of 452 Old 06-26-2019, 07:06 PM - Thread Starter
Liked: 1628
I believe we discussed the issue with the DVGR targets and my unit output do not match. I have nothing but issues with any method I try. I utterly hate the DVGR method as there is no clear tactic to accurately bring the unit output into target range. My unit outputs well over 2000nits based on my readings and there is no way to take advantage of that with calibration using DVGR.
post #431 of 452 Old 06-26-2019, 07:13 PM
shoman94's Avatar
Liked: 3581
Yes we did and I remember that your TV techs above the EOTF. I was just thinking if you left that part alone but aligned the RGB only with both 2pt and 11pt. I get your frustration though......
shoman94 is offline
post #432 of 452 Old 06-26-2019, 07:16 PM - Thread Starter
Liked: 1628
Ah yah. Gain brings the RGB balance to within acceptable levels.
shoman94 likes this.
post #433 of 452 Old 06-27-2019, 08:08 AM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
Speaking of which, would you mind posting your RGB level plots for HDR10 and DV after applying Gain adjustments?
I'm curious to see how they compare with mine.
-phil
PhilB is offline
post #434 of 452 Old 06-27-2019, 08:09 AM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
I've not paid too much attention to DV calibration as I don't have the tools to perform one, but I'm interested to learn the process. Can you point me to a source that describes the new method?
-phil
PhilB is offline
post #435 of 452 Old 06-27-2019, 08:11 AM - Thread Starter
Liked: 1628
-phil
It is something that has to be implemented by Vizio. Other manufacturers like LG and Sony have already done so.
They either use the SDR calibration as a base or use a profile created by Calman that is loaded onto a USB drive and plug into the TV.
post #436 of 452 Old 06-27-2019, 08:14 AM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
Understood. Does it require special/specific tools such as Calman, or can it be done with any calibration tools? Is it an automated procedure?
-phil
PhilB is offline
post #437 of 452 Old 07-21-2019, 01:59 PM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
@skschatzman ,
For the HDR10 calibration, did you use the DVDO as your pattern source or R.Masciola's HDR-10 UHD Test Patterns? What did you choose for MaxCLL and MaxFALL for greyscale calibration?
-phil
PhilB is offline
post #438 of 452 Old 07-23-2019, 06:42 PM
Liked: 0
I am tech-challenged and trying to calibrate my pq65. I have read through tons of posts (very helpful!) but some (much) is over my head. If I understand correctly, there are different settings for SDR, HDR and DV. A few questions.
1. SDR is what I get from my cable box, HDR and DVT are what I get from 4K sources like Amazon or Netflix, correct?
2. How do I enter separate settings for SDR, HDR and DVT. The calibration menu screens just follow one another and I don't see fields for "SDR" "HDR" or "DVT." What am doing wrong?
3. Since they have different settings, do I have to manually toggle between settings depending on what I am watching (i.e. switch to SDR when watching cable sourced material and switch to DV when watching Netflix)? Or does the TV detect the source material and automatically default to the correct setting?
Thanks in advance.
GreyC is offline
post #439 of 452 Old 07-23-2019, 07:37 PM
beardontwalk123's Avatar
Quoted: 1568 Post(s)
Liked: 904
Thanks in advance.
Hello,
1. Yes, SDR will be mostly anything 1080P and below. Cable Box for sure, a lot of Amazon, Netflix, and Hulu shows are still in SDR as well. Some shows on Netflix or Amazon can be 4K with HDR and some will just be 4K SDR.
2. You have to enter settings while watching SDR, HDR, DV. If you hit info it will do a drop down that tells you what mode your TV is in. You’ll have to enter separate settings for each mode (they will not carry over to the other).
3. TV will detect source material and automatically switch.
beardontwalk123 is offline
post #440 of 452 Old 07-24-2019, 04:01 AM
Liked: 0
Originally Posted by beardontwalk123 View Post
Hello,
thank you
GreyC is offline
post #441 of 452 Old 07-24-2019, 01:05 PM
Ario816's Avatar
Quoted: 137 Post(s)
Liked: 42
I’ve already gotten my set calibrated for SDR/HDR but DV was left alone at the time since there was no way to properly do it at the time.
My question is now that the DVGR is out for this set should I email my calibrator and have him come in to calibrate the DV as well? It seems from reading in the thread here people have had mixed results with using DVGR
Ario816 is offline
post #442 of 452 Old 08-18-2019, 03:42 PM
Quoted: 23 Post(s)
Liked: 2
Anyone still calibrating with the new firmware that’s rolled out?
thezrb is offline
post #443 of 452 Old 08-18-2019, 03:43 PM - Thread Starter
Liked: 1628
I will be performing a calibration within the next few weeks.
post #444 of 452 Old 08-19-2019, 06:36 AM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
I'm in the process of calibration using HCFR and madTPG with the addition of Spears & Munsil's new disc. Between the late sunset and getting my kids ready to head off to school it's been hard to find enough hours to perform a calibration in one session. It'll probably take me a couple of weeks before I post my results.
-phil
PhilB is offline
post #445 of 452 Old 08-25-2019, 11:00 AM
PhilB's Avatar
Quoted: 113 Post(s)
Liked: 46
skschatzman,
After you factory reset your TV, can you please capture Grey scale, luminance and CIE plots for HDR10 source patterns? I'd like to see how your results compare to mine to understand if some of the strangeness I'm seeing is a result of the firmware or if it's unique to my TV.
I've attached the same plots I measured with the latest firmware. I wonder if your set shows the same hump in luminance at the 75% and 80% white inputs.
-phil
Name:	Rec2020-P3 ST2084 factory reset CIE diagram.jpg
ID:	2607632   Click image for larger version
Name:	Rec2020-P3 ST2084 factory reset Gray Scale.jpg
ID:	2607634   Click image for larger version
Name:	Rec2020-P3 ST2084 factory reset Luminance.jpg
PhilB is offline
post #446 of 452 Old 10-08-2019, 03:03 PM
Quoted: 23 Post(s)
Liked: 2
Eagerly awaiting calibrations....
thezrb is offline
post #447 of 452 Old 10-08-2019, 03:46 PM - Thread Starter
Liked: 1628
Yah I have had some life experiences get in the way. I was electrocuted by a faulty piece of equipment. I grabbed a door handle and couldn't let go for like 5 seconds. My legs bent forward and allowed me to lean back to fall and let go of the door. I was in a lot of pain. I'm getting better now. Thankfully it doesn't look like I sustained any permanent damage.
I should be able to perform a calibration soon.
post #448 of 452 Old 10-08-2019, 03:49 PM
Quoted: 23 Post(s)
Liked: 2
Damn, sorry for the rush. Take all the time you need to get better man.
thezrb is offline
post #449 of 452 Old 10-08-2019, 03:50 PM - Thread Starter
Liked: 1628
No worries.
post #450 of 452 Old 10-08-2019, 04:48 PM
Liked: 1116
No worries.
Maybe you will become a superhero.
Sent from my LGMP450 using Tapatalk
skschatzman likes this.
Reply Display Calibration
