2018 Sony Master Series LCD Calibration Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #631 of 646 Old 03-21-2019, 04:32 PM - Thread Starter
shoman94's Avatar
Quoted: 4876 Post(s)
Liked: 3434
Originally Posted by TheModestGun View Post
Does anyone know if Sony LCD LED TV's have been using PFS Phosphor for a few generations? Or is this the first? I have an X900E I'm trying to calibrate and I'm trying to pick the correct display type. Also does anyone know what the HCFR equivalent selection of PFS Phosphor on an i1 Display Pro would be?
I think the 900e uses GB LED.
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is online now
post #632 of 646 Old 03-23-2019, 07:32 AM
bluemoon737's Avatar
Quoted: 2191 Post(s)
Liked: 2683
My Z9D uses RG Phosphor, would think the 900e (same timeframe) would use the same? Good question for Tyler.
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #633 of 646 Old 03-23-2019, 03:24 PM - Thread Starter
shoman94's Avatar
Liked: 3434
Possible, I was thinking that the 900E being a cheaper model it wouldn't be using the more expensive LEDs.
post #634 of 646 Old 03-26-2019, 10:31 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 10794 Post(s)
Liked: 6416
Just checking--we set Dynamic Range to "Limited" before running the Autocalibration. When the calibration has completed, the setting should be reverted to "Auto", correct?
The reason I ask is that when we run the Post-calibration checker with Dynamic Range set to Limited, everything looks very good. If we switch to Auto and re-run the Post-calibration checker, things don't look as good. If we have normal viewing with the setting in Auto, which Post-calibration results are actually in effect when viewing?
AustinJerry is offline
post #635 of 646 Old 03-26-2019, 05:51 PM
WiFi-Spy's Avatar
Quoted: 1257 Post(s)
Liked: 1862
Auto looks at the HDMI AVI info frame. If your sources has that flag set to full range it will automatically switch to full range. But it will not do that on an actual video source that has the flag set to limited range.
AustinJerry and shoman94 like this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #636 of 646 Old 03-27-2019, 07:10 AM
Liked: 6416
I don't recall a discussion regarding how to properly set the contrast control on the Z9F. I don't think the AutoCal touches the contrast setting, and I am pretty sure contrast has no effect on white balance. Can someone share how to determine the correct contrast setting? Thanks!
post #637 of 646 Old 03-27-2019, 11:26 AM
Quoted: 4146 Post(s)
Liked: 4940
You always want to keep the contrast setting to the default as per Sony.
shoman94 likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G
Calman Ultimate, ISF Level III Certified
jrref is offline
post #638 of 646 Old 03-27-2019, 11:47 AM
Liked: 6416
Since I don’t recall what the Sony default was (it is currently set to 90), how do I know? I would prefer to avoid resetting everything to defaults just to see what the default setting was for Contrast.
Perhaps you or someone would be kind enough to tell me what the default setting should be?
post #639 of 646 Old 03-27-2019, 01:29 PM
Quoted: 21 Post(s)
Liked: 5
90 is the default on Sony TV's. Sony TV's come very good out of the box as far as black level and contrast settings go. when using patterns neither the highest nor lowest grays were clipped. Don't sweat contrast and black level settings as long as you've got them set at 90 and 50 respectively.
shoman94 and JoelArt like this.
TheModestGun is offline
post #640 of 646 Old 03-27-2019, 01:42 PM
Liked: 4940
And Sony doesn't recommend changing these values.
John
jrref is offline
post #641 of 646 Old 03-27-2019, 02:16 PM
Liked: 6416
Well, it seems like I have retained the default setting, thanks for confirming.
On my upstairs 940D, Contrast is set to 96, which I believe I arrived at using the Spears&Munsil test Blu-ray. I'll revert this setting to 90 as well.
shoman94 and jrref like this.
post #642 of 646 Old 04-27-2019, 07:21 AM
Liked: 6416
I don’t recall a discussion on how to determine the correct setting for the Color Control, which is currently set to 50 on my display.
Do the “Per Color Adjustments” fine-tune the Color, regardless of the setting for “Color”. IOW, does it really matter what the Color setting is?
And what about the Hue setting, which is currently at the default setting of zero?
post #643 of 646 Old 04-27-2019, 04:44 PM - Thread Starter
shoman94's Avatar
Liked: 3434
For the most part the Color setting acts like the saturation settings but for all colors.
AustinJerry and jrref like this.
post #644 of 646 Old 05-15-2019, 03:43 PM
njfoses's Avatar
Quoted: 309 Post(s)
Liked: 171
Looks like rolling auto cal was added for the legacy Sony models.
https://www.avsforum.com/forum/139-d...l#post58051404
WiFi-Spy and shoman94 like this.
njfoses is online now
post #645 of 646 Old 05-18-2019, 12:02 AM
Liked: 2683
My Z9D is RG Phosphor according to Tyler but my 950G is PFS Phosphor again, according to Tyler.
-Jeff-
post #646 of 646 Old 05-18-2019, 05:09 AM - Thread Starter
shoman94's Avatar
Liked: 3434
Correct, since we use PCs set to full we have to force the TV to Limited. In Calman, expand to PC levels unchecked and Calman set to Video (16-235) levels.
Sent from my LG-H932 using Tapatalk
WiFi-Spy likes this.
Reply Display Calibration
