Samsung CMS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-13-2018, 11:45 AM - Thread Starter
mabrandt's Avatar
Samsung CMS
I recently purchased a Samsung Q8FN which has CMS controls for the RGB and the secondary colors. I have not had CMS on my previous Sony's so I'm not quite sure how to adjust them. In reading articles and posts, most say you need to adjust Hue, and Saturation and Luminance, but on Samsung they are l just red, green and blue sliders. My delta E is high on the green and blue and am wondering how I can tune this in. I have adjusted the greyscale and gamma with no trouble.
mabrandt is offline
post #2 of 6 Old 11-13-2018, 12:00 PM
ConnecTEDDD's Avatar
Quoted: 2910 Post(s)
Liked: 3546
Hi,
Samsung's have RGB calibration controls for it's CMS, unlike other displays which have HSL.
With RGB controls you can have exact same results like HSL, just you will use the controls differently.
For example for Red (Primary).
If you want to remove Luminance you have to reduce the Red Slider.
If you want to de-saturate it you have to add equal amount of Green+Blue (when you will do this, it will increase Luminance also)
If you want to change hue, you add only Green or Blue, this has to do with the direction you want.
For example about Magenta (Secondary)
If you want to de-saturate it then add Green.
If you want to remove Luminance then remove Red+Blue.
If you want to change hue add only Red or Blue according to the direction you want.
Calibration software have RGB bars chart for CMS to help you make decisions.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3 of 6 Old 11-13-2018, 12:57 PM - Thread Starter
mabrandt's Avatar
Originally Posted by ConnecTEDDD View Post
Hi,
That`s kind of what I thought it would do. I'm using Calman. On the Gamut page, What should I look for
mabrandt is offline
post #4 of 6 Old 11-13-2018, 01:19 PM
Liked: 3546
See for a workflow page where it will have RGB balance chart for Gamut, for your measured color.
post #5 of 6 Old 06-04-2019, 01:11 AM
mombasa123's Avatar
Quoted: 100 Post(s)
Liked: 32
Excellent article on Samsung CMS here :
https://support.murideo.com/hc/en-us...or-Samsung-TVs
mombasa123 is online now
post #6 of 6 Old 06-04-2019, 09:57 AM
jdoostil's Avatar
Quoted: 17 Post(s)
Liked: 27
I just came in to post that link. Thanks!
AVPro Edge/Murideo Training and Education
ISF certified in 2008, Level II in 2010, Level III in 2017
ISF instructor certified since 2012
[email protected]
Serving Florida
jdoostil is offline
Reply Display Calibration
