2019 LG OLED - Custom HDR10 Tone Mapping with CalMAN. - AVS Forum | Home Theater Discussions And Reviews
 11Likes
  • 2 Post By WiFi-Spy
  • 5 Post By WiFi-Spy
  • 2 Post By BlackJoker
post #1 of 25 Old 01-07-2019, 11:09 AM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1784 Post(s)
Liked: 2385
https://referencehometheater.com/201...ing-explained/
helvetica bold and Jon65 like this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #2 of 25 Old 01-07-2019, 11:18 AM
Ken Masters's Avatar
Quoted: 167 Post(s)
Liked: 99
Now this is interesting:
"There is also an integrated test pattern generator inside of the LG OLED models. If you’re calibrating with CalMAN, it can create its own test patterns so you don’t need to connect anything over HDMI and it can do it with full 10-bit triplets. You’ll still need software and a meter, but it makes the process that much easier and more reliable."
I don't suppose this is something we'll see being implemented on the older 2018 models?
Ken Masters is online now
post #3 of 25 Old 01-07-2019, 11:24 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 2385
Unfortunately the internal pattern generator is a 2019 TV feature only. It does however support SDR, HDR, and Dolby Vision Calibration.
WiFi-Spy is offline
post #4 of 25 Old 01-07-2019, 11:36 AM
Quoted: 1878 Post(s)
Liked: 1135
Awesome feature, hopefully, this is something that will become standard across all displays.
I was wondering about highlights that are associated with color saturation, something I didn't know I was missing, until I actually did a color calibration. At the bottom of the article it is mentioned, but only concerning white boost being disabled. Ultimately, I prefer detail over brightness or a balanced approach.
Sent from my SM-G550T1 using Tapatalk
DisplayCalNoob is offline
post #5 of 25 Old 01-07-2019, 12:02 PM
T( )( )L's Avatar
Quoted: 224 Post(s)
Liked: 116
Any news for sdr calibration,will it retain the 1d and 3dl capabillity?
Lightspace HTP,Klein K-10A,I1pro2,Murideo 6G.
T( )( )L is offline
post #6 of 25 Old 01-07-2019, 12:35 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2385
The same functionality as the 2018 TVs. However now you can reset a CalMAN calibrated picture mode back to factory, without having to factory reset the whole TV.
BlackJoker and T( )( )L like this.
WiFi-Spy is offline
post #7 of 25 Old 01-09-2019, 12:35 AM
Sammie2980's Avatar
Quoted: 242 Post(s)
Liked: 197
Is this something that will be coming to the 2018 models? Resetting a CalMAN calibrated picture mode without needing to do a factory reset?
Also for the 2019 is it possible to have a unique custom tone mapping per picture memory as well as per input?
LivingRoom: LG OLED77C8P /Oppo UDP-203/Denon X8500H/SVS SB16 ULTRA/M5300-PM/Paradigm 85F, 45c, Mythos Gem XL x4, SVS Prime Elevation x4 /PS4 Pro/X1X/Switch/AppleTV 4K
Bedroom: LG OLED65E6P / Oppo BDP103D / AppleTV // Office: Sony 55A9F / X1X
ISF Level III Certified, CalMan VideoPro, ChromaPure, i1D3 Pro, i1Pro, C6 HDR 2000, VideoForge Pro, Murideo Six-G, Lightspace
Sammie2980 is offline
post #8 of 25 Old 01-09-2019, 01:24 AM
northrob's Avatar
Quoted: 111 Post(s)
Liked: 69
Are these patterns visible without CalMAN software?
LG OLED 55B6V, Finnsat FST03PVR, Toshiba 1T HDD, Genelec 6010B, BK XLS200-DF MK2
JVC DLA-X35BE, PS3, Apple TV3, Yamaha RX-V383, Tannoy Mercury F2, Tannoy Mercury F1, BK Monolith
northrob is offline
post #9 of 25 Old 01-09-2019, 03:49 AM
Anger.miki's Avatar
Quoted: 525 Post(s)
Liked: 630
Is this TPG solution inside the TV (DDC) or is it a kind of client3 client?
Will it be usable only with CalMAN or also by anyone who knows how to control/activate it?
T.U.C. Master | TVs: Pioneer PDP-LX5090H, LG OLED55C8PLA | AV Receiver: Pioneer VSX-921 | BD Player: Panasonic DMP-BDT260EG | External LUT box: Entertainment Experience eeColor | Softwares: Light Illusion Lightspace HTP, CM Enthusiast, HCFR, DisplayCAL | Probes: Klein K10-A, Jeti spectraval 1501, X-Rite i1 Display Pro OEM Rev. B-02 | Test Pattern Generator: Riccardo Biasiotto’s PGenerator (RPi)
Anger.miki is offline
post #10 of 25 Old 01-09-2019, 11:17 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 2385
1. Unfortunately it’s only a LG 2019 TV feature
2. Each HDR picture mode can have three custom tone maps. The TV will interpolate in between the three that you set up. Say you set up tone maps for 1000, 4000 and 10,000 nits content, If you play 6000 nit content the TV will interpolate between the 4000 and 10,000.
WiFi-Spy is offline
post #11 of 25 Old 01-09-2019, 11:18 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 2385
The pattern generator is a part of the LG Alpha9 Gen2, and Alpha 7 Gen 2 chips in the 2019 TVs.
WiFi-Spy is offline
post #12 of 25 Old 01-09-2019, 11:19 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 2385
That is a question for LG.
WiFi-Spy is offline
post #13 of 25 Old 05-19-2019, 01:22 AM
Quoted: 249 Post(s)
Hi Everyone, is the xrite i1 display pro meter good enough to calibrate my c9 with calman home?
Toto84 is offline
post #14 of 25 Old 05-19-2019, 03:01 PM
Vishwa Somayaji's Avatar
Quoted: 127 Post(s)
Liked: 113
Yes, it is good enough. But, it will be even better if you can borrow/rent or buy an i1 Pro 2 to profile it on your screen. Then it will be far more accurate.
Vishwa Somayaji is offline
post #15 of 25 Old 05-19-2019, 03:17 PM
Quoted: 249 Post(s)
I wish i could but i live in the UK and i dont know anyone who has one.
What would be the benefit of this?
Toto84 is offline
post #16 of 25 Old 05-20-2019, 10:28 AM
Quoted: 127 Post(s)
Liked: 113
The main benefit is that once profiled, your meter will be far more accurate for that screen. You could do a quick search on Spectro vs Colorimeter and you will get good information.
post #17 of 25 Old 05-20-2019, 05:15 PM
Quoted: 249 Post(s)
Is result good for dark mode on lg c9?
Toto84 is offline
post #18 of 25 Old 05-20-2019, 06:57 PM
Quoted: 127 Post(s)
Liked: 113
I don't have an Oled TV. Someone with that model could chime in whether it is good or if there is room for improvement. Compared to what I have that looks great!
post #19 of 25 Old 05-20-2019, 09:28 PM
BlackJoker's Avatar
Quoted: 387 Post(s)
Liked: 450
Like many others you used the wrong EDR for the meter. The OLED one is for RGB OLED only and not for WOLED like the one you tried to calibrate. You should definitely repeat with RAW XYZ.
L30Z3N and Rolls-Royce like this.
TV: LG OLED 65C8 Sources: Apple TV 4K, OPPO UDP-203 Video Processor: TruVue eeColor
Probe: Klein K10-A, i1 Display Pro OEM Rev.B (2018), i1Pro2 OEM Rev.E Software: Lightspace HTP, Calman 2019 Ultimate
BlackJoker is online now
post #20 of 25 Old 05-21-2019, 04:52 AM
Quoted: 249 Post(s)
Is that Better?
Toto84 is offline
post #21 of 25 Old 06-08-2019, 03:12 PM
Quoted: 249 Post(s)
I did the hdr calibration again with my i1display pro profiled by the spectro i1pro 2 bought almost new on ebay.
I have a few question :
Is the white color accurate with i1pro2revb?
Do you calibrate hdr on D65 white target or i see some pro use a custom point? What's best?
I also think technicolor mode dont use d65.
Any tips to set up the custom tonemapping properly?
After calibration on hdr cinema mode i have a peak luminance of 765 nit.
I read that after upload of the custom tone mapping you should have tone mapping turn off is that correct?
I found the hdr image rather dull without tone mapping on.
Cheers
Toto84 is offline
post #22 of 25 Old 12-27-2019, 12:31 PM
Quoted: 1224 Post(s)
Liked: 793
This is a great explanation. I want to get clarity on 1 point. The roll-off point say is 70% of 1000 nits. Does that mane that anything over 700 nits (70% of 1000) is tone mapped or that say if my peak brightness is 700 nits that the roll-off starts at 70% (490 nits) of my set peak brightness and that everything below the roll-off point is maintained at 1:1 brightness?
LG 77 C9 (Also LG 65 C7 and Sony XBR55X900E)
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #23 of 25 Old 12-27-2019, 12:55 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2385
It’s 70% of peak luminance of the panel for the 1000 nit content metadata.
Most studios that I work with are setting it to 50% to better match the HDR mastering display (mostly Sony X300) (this is with dynamic tone mapping turned off.)
WiFi-Spy is offline
post #24 of 25 Old 12-27-2019, 02:02 PM
Liked: 793
Thanks, that is what I assumed.
What I find interesting, is I currently have a 77 A9G and 77 C9 in the house and I calibrated HDR with the latest RC1 candidate of R3 and the latest LG firmware from this month and I find that the peak brightness was around 680-687 so I set the value in Calman to 675 for the panel peak. I have run the Sony Calman as well using PGenerator . I like to use the video below for some simple testing and if you look at the section 1:45 with the white glass figurine and look at the section I enclosed a SDR screen shot of and the section I have circled the LG tends to still clip that section, but the overall APL is good which the Sony seems to lower the overall APL a bit and maintain more detail in that one leaflet.The LG panel now has over 100 hours on it and I plan on doing another calibration and may set the panel peak brightness to say 650-660 to see of maybe it holds onto more details at the high end.
I am liking the overall DV and HDR presentation of the LG better an currently planning on have BB pick up the Sony, but I have another 2 weeks before they can come get it so I have been doing some comparisons. And while the Sony does handle some more extreme motion challenges better it is not frequent enough for me to keep it.
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #25 of 25 Old 03-07-2020, 04:34 PM
Quoted: 119 Post(s)
Liked: 126
@WiFi-Spy
I would have thought this thread would have got more traction than it has, as it would be nice to share different settings, I'm a bit of a newb to this myself and would have thought many would have posted different settings at this stage. Pity
Jimmy2Shoes is online now
Reply Display Calibration
