2019 LG OLED Calibration and User Settings (No price talk) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1171Likes
post #31 of 1783 Old 03-18-2019, 02:01 PM
MrSniper1401's Avatar
Quoted: 83 Post(s)
Liked: 69
Originally Posted by jrref View Post
Here are the Post Manual calibration Calman scans.
Please note, I'm aware there are more in-depth scans needed which i'll take next time i'm working on the set at the store. This is to give everyone an initial look.
Update: I added the HDR scan. Please remember that I didn't calibrate HDR and need to update the code values but just wanted to give it an initial look.
Have you had a chance to see how LG's new smooth gradation feature compares to Sony's implementation?
Sony 65" A1E
MrSniper1401 is offline
post #32 of 1783 Old 03-18-2019, 02:08 PM
Anger.miki's Avatar
Quoted: 578 Post(s)
Liked: 738
Originally Posted by WiFi-Spy View Post
I don’t recommend using that feature for SDR unless you think 260-280 nits is too dim for your Day mode. That feature enables the “white boost” HDR panel mode for SDR. It will make the display become non-additive.
I agree. By the way, I thought that even with Peak luminance off the white subpixel couldn’t be switched completely off, so even with a 100 nits white peak luminance it still is a non-additive display, of course not as much as with 800 nits peak but still non-additive.
T.U.C. Master | TVs: Pioneer PDP-LX5090H, LG OLED55C8PLA | AV Receiver: Pioneer VSX-921 | BD Player: Panasonic DMP-BDT260EG | External LUT box: Entertainment Experience eeColor | Softwares: Light Illusion Lightspace HTP, CM Enthusiast, HCFR, DisplayCAL | Probes: Klein K10-A, Jeti spectraval 1501, X-Rite i1 Display Pro OEM Rev. B-02 | Test Pattern Generator: Riccardo Biasiotto’s PGenerator (RPi)
Anger.miki is online now
post #33 of 1783 Old 03-18-2019, 02:11 PM - Thread Starter
Quoted: 5194 Post(s)
Liked: 6384
It's very similar in it's effectiveness.
MrSniper1401 likes this.
John
Sony 55A1E, A9F, LG CX
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, LightSpace Pro, ISF Level III Certified
jrref is offline
post #34 of 1783 Old 03-18-2019, 03:31 PM
Quoted: 981 Post(s)
Liked: 1063
In the 22pt they added two additional IRE controls at 2.5 and 7.5 which enable you to make more low IRE adjustments to get better blacks. You will need to use the CM levels editor to create a new series to calibrate in this mode.
I was always wishing for an IRE 2.5 adjustment point. But am I understanding this correctly, I have to pay for some extra software (calman) just to use it? Seriously?
jk82 is offline
post #35 of 1783 Old 03-18-2019, 04:12 PM
Rolls-Royce's Avatar
Quoted: 1445 Post(s)
Liked: 1528
He mentioned CalMAN because he uses it, as do many of the people who are active in the thread on calibrating the 2018 LGs, and who are now watching this new thread.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #36 of 1783 Old 03-18-2019, 07:13 PM
guitarguy316's Avatar
Quoted: 2137 Post(s)
Liked: 822
Robert Zohn got an LG C9 at the store which i calibrated and wanted to post my first impressions.
I took scans of the set OOTB then manually calibrated ISF Bright with the default settings which results in approximately 255 nits. I calibrated ISF Bright because these sets are on display in the showroom and need the Bright Picture Mode.
My preliminary opinions:
1) LG improved motion handling for 2019 and now the set provides BFI which has three settings, Low, Medium and High. I found if you set it to Low, you get only slight dimming of the picture, no flashing and really good motion. Overall a nice improvement.
2) The set we got was very good calibration wise. I feel the gray scale controls on the 2019 may be slightly finer than previous LG OLEDs BUT now you have a choice of 2pt, 10pt and 22pt gray scale adjustments. In the 22pt they added two additional IRE controls at 2.5 and 7.5 which enable you to make more low IRE adjustments to get better blacks. You will need to use the CM levels editor to create a new series to calibrate in this mode.
3) Although the CMS controls all worked, it was very hard to get the CMS lined up but it could have been an issue with this specific panel. With this particular set a new Autocal 3D LUT, or even a matrix would have corredted this. The good news is all the SDR CMS controls appear to work without causing artifacts but as always, you want to keep adjustments to a minimum.
4) There is also a new feature called Peak Luminance in the Expert controls. You can set it to Low, Medium and High. From what I now understand it boosts the peak luminance using the white sub-pixel. If you go from Off to High, the SDR picture gets brighter and it looks like there is more contrast but it also lifts the black level slightly, visible with dark content. Neil Robinson says in the CES video that the most color accurate setting is OFF for SDR. For HDR it's set to HIGH.
5) I couldn't find any controls to enable the internal TPG so i'm not sure if it's enabled yet or this is something you need CM to turn on. I believe there will be new firmware enabling the feature soon.
6) HDR looked good and the peak luminance read 861 nits, with a 10% window. This is the brightest OLED panel I've ever measured. I don't have the new CM for 2019 so I couldn't test any of the new tone mapping options. Although I didn't calibrate HDR, it looks like LG is still overdriving HDR because the colors still look a little oversaturated. I'll have to see how it looks once i'm able to autocal HDR with the new process that Neil Robinson described at CES.
7) I didn't have time to look a DV but DV content looked fine.
8) The set came with Web OS 4.5. LG moved all the menus to the left side, a little more streamlined than the old WebOS.
9) The 2019 comes with eARC and VRR and a couple of other gamming features. Robert Zohn said there is a HDMI 2.1 port or ports but I have no idea how functional they are beyond what LS has reported and if they are 48 MB ports.
After calibrating the set and looking at content, the 2019 is definetly a step up in PQ vs the 2018 when compared side by side with the same content. The picture quality was nice and sharp, near blacks were perfect, motion was good, colors were accurate to the calibrated Sony's right next to it. BUT in my opinion the picture doesn't have as much POP, (highlights) as the A9F probably because of the A9F's pixel booster in SDR. I didn't measure the color volume but i'll bet the Sony is still much higher accounting for this observation. I also needed to turn the Peak Luminance control to High to make the C9 look as close as possible to the A9F even though it's set to Off by default. HDR on the other hand looks better than ever. Really bright and vibrant but you get the feeling that the picture is a little “over done” since the colors, in my opinion, were a little oversaturated. Once I’m able to calibrate HDR, we will be able to take another look.
My preliminary impression, the 2019 LG C9 is a “significant improvement” over the 2018 LG C8 although it’s reported to be using the same panel but with the new Alpha9 processer. When I say significant, everything is relative. The 2018 LG OLED was an excellent set and the improvements for 2019 make it that much better. HDR is definetly brighter, motion is still not quite as good as the Sony, but with BFI it gets really, really close. Upscaling is improved and i didn’t notice any unusual artifacts and or noise in the picture which was sharp and crisp. I'm very interested to see the PQ after using Calman Autocal to see if the result is any better with all the new finetuning LG apparently did. There is no question that LG seems to be pushing the panel "harder" this year to get more brightness but that could be at the expense of greater possibility of burn in. The logo protector is set to High at default vs Low in the 2018 sets. Some may want to know if it “blows away” the Sony A9F? in my opinion, no, but the two sets are so close with the LG giving a brighter HDR picture and having additional gaming features, that you can’t go wrong with either set.
I believe the 55 and 65 inch C9's are available at retail this week.
Any comments on the new anti glare filter?
guitarguy316 is offline
post #37 of 1783 Old 03-18-2019, 07:24 PM - Thread Starter
Liked: 6384
It looked about the same to me but i'll take a closer look and let you know.
John
jrref is offline
post #38 of 1783 Old 03-18-2019, 07:52 PM
helvetica bold's Avatar
Quoted: 1964 Post(s)
Liked: 1276
Is the C9 on display at Value Electronics?
I held off buying the A9F for the C9-more bang for your buck with LG. I really wanted the HDMI 2.1 gaming features.
LG65C9, XBOX ONE X, PS4PRO, APPLE 4K, SONY STRDN1070, Q Acoustics: 3010i & 3090Ci
helvetica bold is online now
post #39 of 1783 Old 03-18-2019, 08:12 PM
Quoted: 83 Post(s)
Liked: 69
Have you noticed any improvements made to the active hdr (dynamic tone mapping) function or does it behave the same way as last year?
Sony 65" A1E
post #40 of 1783 Old 03-18-2019, 08:27 PM
BlackJoker's Avatar
Quoted: 418 Post(s)
Liked: 515
Hi John thanks for you're first impressions I hope I get a review sample too in the next days. Don't you use ICtCp for your measurements? I mean at least for HDR because your scans shows that you use dE2000.
TV: LG OLED 65C8 Sources: Apple TV 4K, OPPO UDP-203 Video Processor: TruVue eeColor
Probe: Klein K10-A, i1 Display Pro OEM Rev.B (2018), i1Pro2 OEM Rev.E Software: Lightspace HTP, Calman 2019 Ultimate
BlackJoker is offline
post #41 of 1783 Old 03-19-2019, 06:06 AM - Thread Starter
Liked: 6384
Yes If you can bring your game and try it out.
helvetica bold likes this.
John
jrref is offline
post #42 of 1783 Old 03-19-2019, 06:08 AM - Thread Starter
Liked: 6384
It works the same as last year.
John
jrref is offline
post #43 of 1783 Old 03-19-2019, 06:23 AM - Thread Starter
Liked: 6384
I only manually calibrated SDR, used deltaE 2000 and didn't calibrate HDR. When I use Calman Autocal to do a more detailed calibration of SDR/HDR/DV, I'll have my workflows set up for ICtCp. Tyler indicated a while back that he would be changing all the workflows in Calman to ICtCp where appropriate in the next release.
When we got the set, with everything we had to do to see what changed, calibrate and then do a preliminary evaluation, I only had so much time. I'm planning to stop by today to take another look at the new screen filter and closer look at the menus to see if I missed anything.
Overall, it looks like a really nice set but again, you have to remember it's an improvement on an already excellent set so everything is relative. As I mentioned in a previous post, the LG and the Sony OLEDs are now, in my opinion, pretty much the same with a slight edge towards the Sony due to it's pixel booster and maybe motion and upscaling but the LG has HDMI 2.1 ports, extra gaming functions, brighter HDR and a better calibration interface to Calman. So at this point some people are going to like the way Sony implements their PQ and some will prefer the way LG implements their PQ since they take different approaches to achieve what each believes it the best. Also, nothing is 100% perfect so i'm sure there will still be some complaining for both sets as more people do a more detailed review.
John
jrref is offline
post #44 of 1783 Old 03-19-2019, 08:05 AM - Thread Starter
Liked: 6384
Some people asked about the following:
1) The panel filter on the C9: To me, it looks about the same as the 2018 sets. If you look closely with light reflecting off it, you can still see that slight magenta tint with the panel off. Comparing it to the Sony A9F, the Sony looks slightly more black and a little less reflective. I'm not seeing any major change.
2) The C9 has a separate Smooth Gradation control that you can set to Low, Medium and High.
Below are some menu screen shots on the C9
ID:	2541366   Click image for larger version
ID:	2541368   Click image for larger version
John
jrref is offline
post #45 of 1783 Old 03-19-2019, 08:30 AM
Liked: 5
Tks!
Any referrence on the menus for game related settings like VRR, ALLM, QMS?
Zumb is offline
post #46 of 1783 Old 03-19-2019, 08:42 AM
Liked: 822
Is the bezel/trim still the dark gray like the C8 or is it a lighter gray like the C9 stand? It's hard to tell in pictures which shade of gray/black the metal bezel is, while the C9 stand is clearly silver.
post #47 of 1783 Old 03-19-2019, 08:49 AM - Thread Starter
Liked: 6384
Originally Posted by Zumb View Post
Tks!
These are the only Game related setting I could find.
ID:	2541382   Click image for larger version
helvetica bold and Zumb like this.
John
jrref is offline
post #48 of 1783 Old 03-19-2019, 08:51 AM - Thread Starter
Liked: 6384
It's the same as the C8
Zumb likes this.
John
jrref is offline
post #49 of 1783 Old 03-19-2019, 09:09 AM
Liked: 5
A pitty there isn't an Xbox One there to test those settings.
Don't have one myself, though... :/
One other question: I had spotted in a youtube video a button on the remote named "Movies" or similar - any idea what's it for?
Zumb is offline
post #50 of 1783 Old 03-19-2019, 09:18 AM
Liked: 2
Hi jrref,
Thank you for your latest information.
Btw, how do we choose 3 different type of HDR tone mapping curve from TV? Will TV detect ST.2084 signal and choose automatically when HDR video is received?
Thanks in advance!
realhd1080 is offline
post #51 of 1783 Old 03-19-2019, 09:36 AM
Liked: 822
Thanks, good to know. Last question...
In order to use the "AI Picture" database, is there a specific preset for this, or does it automatically apply to all modes? The reason I ask is I want to have the AI picture for the image database, but not necessarily the ambient light where they said it would also adjust the gamma curve according to surroundings. I guess I'm trying to understand is this just one preset, are they individual options, etc?
Ideally you can watch ISF/Technicolor preset while still using the AI database for picture processing/upscaling, but not any lighting adjustments.
post #52 of 1783 Old 03-19-2019, 09:40 AM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 5303
861 Nits at 10% pretty much matches what rtings.com measured on the C8 (876 Nits sustained; 918 Nits sustained). Do you have an easy way to measure 3% or 1% windows next time you are with the set?
fafrd is offline
post #53 of 1783 Old 03-19-2019, 10:32 AM - Thread Starter
Liked: 6384
There is an option for each PM to turn the AI database on or off. I'm not sure exactly how it works yet. I haven't noticed any lighting changes when turning it on.
John
jrref is offline
post #54 of 1783 Old 03-19-2019, 10:39 AM - Thread Starter
Liked: 6384
I'm always skeptical when I read these peak luminance values, even from rtings since your readings will change significantly unless your meter is profiled correctly for the screen you are testing. I know for the C8's that I calibrated all year, I was reading 725-800 nits depending on the panel. I also know D-Nice measured a couple in the 800 nit range. I've never seen one at 918 even at 1%.
I'll be recalibrating the C9 with Autocal as soon as I get the beta and will re-measure peak luminance at different window sizes.
In order to determine if the peak brightness is higher for the 2019 panels we are going to have to look at a lot of samples and see where they read. As Neil Robinson said, he believes the 2019's use the same 2018 LG panel but they might be driving it a little harder to get some additional brightness.
John
jrref is offline
post #55 of 1783 Old 03-19-2019, 10:43 AM - Thread Starter
Liked: 6384
Originally Posted by realhd1080 View Post
Hi jrref,
Thanks in advance!
I won't know the answer to this until we get the Calman Beta software that enables you to calibrate this feature.
John
jrref is offline
post #56 of 1783 Old 03-19-2019, 10:46 AM
Liked: 2
maybe interrnal TPG also will be only available once autocal is activated by Calman? If it's not available on the user menu then at service menu?
post #57 of 1783 Old 03-19-2019, 11:06 AM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 5303
Yes, beyond the panel structure itself, the most important factor is whether the ABL limits have been further loosened or not.
Here is what LG presented about the ABL limit changes they made between 2016 and 2017. That's the last LG has had to say on the subject.
So it would be great if you could characterize peak HDR brightness at window sizes of 3% and 1%...
1% may seem smal, but it corresponds to 10% screen width x 10% screen height, which is still very large for a highlight. If you have any easy way to measure below 1%, say 0.25% (which is 5% screen width x 5% screen height), I'd be interested to understand whether the ABL limits saturate at 3% as LG presented or they now keep increasing as window size continues to get smaller...
jrref and mrtickleuk like this.
fafrd is offline
post #58 of 1783 Old 03-19-2019, 11:49 AM
mrtickleuk's Avatar
Quoted: 6029 Post(s)
Liked: 8726
No.
The adjustment points are in the menus for everyone to use.
He is saying that if you have calman at the moment, until the new version is available which uses the extra points in the upgraded calman workflows, you have to add them in yourself to the workflows in your version of calman which thinks the TV only has 20pt adjustments.
Rolls-Royce, jrref and jk82 like this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #59 of 1783 Old 03-19-2019, 11:51 AM - Thread Starter
Liked: 6384
On the set we have I couldn't find any controls in the user or the service menus to turn it on. I'm assuming once the Calman Beta is available there will be a firmware update to enable the feature.
John
jrref is offline
post #60 of 1783 Old 03-19-2019, 12:03 PM
Quoted: 398 Post(s)
Liked: 236
So you think the A9F still has the edge in motion? This is without motion interpolation, right? Because in that case I would expect the C9 to perform better with oled motion pro set to high. Should halve the persistence time.
jrref likes this.
Sony 55A9F
LG 55B6
Micolash is offline
Reply Display Calibration
