Dimming - LG M2362D monitor/tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-04-2019, 12:27 AM - Thread Starter
MudokonX's Avatar
Liked: 0
Hello guys, i'm one of the many ppl that suffer from the classical dimming that appears on dark scenes etc, i managed to gain access in the hidden menus via the anymote application from my smartphone but i don't see any option about dimming, can anyone help me please?
Btw i already disabled dynamic contrast - auto brightness and there is no power save option setting.
i'll upload photos of the menu, so if anyone knows what i should tweak please let me know, i don't wanna experiment on the hidden menu cause i'm afraid i'll ruin anything.
ID:	2534046   Click image for larger version
ID:	2534048   Click image for larger version
ID:	2534050   Click image for larger version
MudokonX is offline
post #2 of 2 Old 03-04-2019, 02:46 PM
randal_r's Avatar
Quoted: 232 Post(s)
Liked: 131
Hi,
I would recommend that you get out of there. May I suggest the "Auto Bright", that it is turned off. With the display that you have, there is no need to go into the service menu; you will only brick it. Also check for any setting that deals with auto contrast and turn it off as well.
Randal
randal_r is offline
Reply Display Calibration
calibration settings , dimming , monitor , television
