Calibration Questions For HDR Newb - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-16-2019, 07:25 PM - Thread Starter
Quoted: 117 Post(s)
Ok, I have a vizio e series 43" HDR tv. This is the first tv with HDR I've owned. I want to know if, 1 - Will rec709 calibrate separately from HDR on this tv? and 2 - can someone tell me a pretty straight forward way to calibrate HDR? I want to make sure I have it set up properly. I've been looking around and feel a little confused with the HDR calibration portion.
toby5 is online now
post #2 of 2 Old 05-14-2019, 07:24 PM
Gjlaplante's Avatar
Quoted: 23 Post(s)
Liked: 2
I also own an E series Vizio and to answer your question(s) yes, you will need to do two separate calibrations. One for SDR (2.4 gamma and Rec709) and the other for HDR (BT2084 gamma and BT2020 color space). THe best advice I can give to calibrate for HDR is to watch Calman HDR tutorials on youtube. Standard calibration is pretty straightforward. Start with going to rtings.com and look up your model number to get the basic settings of what to turn off and leave on. This will help speed up the process and minimize errors when you do calibrate. You will need a pattern generator that kicks the tv into HDR mode. It will do this on top of whatever mode the tv is already in.
Gjlaplante is offline
Reply Display Calibration
