CalMAN Home for Samsung - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
post #301 of 309 Old 01-07-2020, 12:19 PM
AnotherDude's Avatar
Quoted: 1093 Post(s)
Liked: 673
Originally Posted by Rschmitt View Post
So what you're saying is that the 5% setting in the 20pt white balance configuration via on-screen menu actually controls 34.7% on the grey scale for HDR? And that 50% setting controls 73% grey scale?
I see those odd levels, not 5% levels, and that's what is getting controlled by CalMAN when I AutoCal or do manual tweaking.
Samsung 75Q9FN, Pioneer UDP-LX500, Outlaw 975, C6-HDR, VideoForge Pro
Win 10 Pro x64 1909
HT Enthusiast Extended Custom WF v22.0.0 - 1/8/2020
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is offline
post #302 of 309 Old 01-07-2020, 12:29 PM
Liked: 673
Sorry, you meant the TV's settings menu, so yes I imagine so. But it's speculation at this time unless Samsung can clarify.
Win 10 Pro x64 1909
post #303 of 309 Old 01-07-2020, 01:25 PM
WiFi-Spy's Avatar
Quoted: 1724 Post(s)
Liked: 2317
Yes.
AnotherDude likes this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #304 of 309 Old 01-08-2020, 12:11 PM
Liked: 0
Is it ever advisable to adjust the CMS settings when doing a manual OSD settings HDR calibration for Samsung sets (that don’t support autocal)? Or should the color space be left to Auto and only white balance (2 & 20 pt) adjusted?
Rschmitt is offline
post #305 of 309 Old 01-08-2020, 01:40 PM
thoth's Avatar
Quoted: 213 Post(s)
Liked: 95
Definitely give CMS a try.
thoth is offline
post #306 of 309 Old 01-08-2020, 03:41 PM
Liked: 0
Samsung only allows CMS access if you switch the Color Space setting to Custom (as opposed to Auto or Native) and then set either DCI-P3 or BT.2020 as the color gamut.
Now I believe the color gamut setting in there is actually setting/forcing the color gamut, as opposed to just allowing you access the CMS settings for that gamut (kinda like how changing the 20pt white balance scale between 5%,10%,etc. isn’t setting anything, just allowing you to configure that setting). But I’d be happy to be corrected here.
So then if I’m trying to adjust CMS during a manual HDR calibration, do I set Color Space Custom and BT.2020 gamut? If so, what’s the point of DCI-P3 gamut?
Rschmitt is offline
post #307 of 309 Old 01-08-2020, 03:56 PM
thoth's Avatar
Quoted: 213 Post(s)
Liked: 95
Yes you want to use Custom. You might want to try both BT.2020 and DCI-P3, to see which gives you better accuracy. On the Q90R, using DCI-P3 produces better results, even though CalMAN calibration target is BT.2020.
thoth is offline
post #308 of 309 Old 01-15-2020, 04:18 PM
Quoted: 27 Post(s)
Liked: 2
Few questions
1. What do I need for a Samsung Q80 and is the auto calibrate possible?
2. What is the best at home pattern generator without spending tons?
3. I see some pattern generators are on blue ray, how does this work and is it auto?
4. What meter is the best and do you really need two meters?
5. My video single is going through my Denon receiver to my tv. Are you calibrating Just the tv or the receiver also?
6. Can you calibrate the SDR and HDR10? Do I need anything additional to do so.
Thanks for all the help.
promtber is offline
post #309 of 309 Old 01-18-2020, 09:19 AM
thoth's Avatar
Quoted: 213 Post(s)
Liked: 95
Autocal isn't currently supported for the Q80R, but see this post for hope, although I wouldn't count on it until a new CM version and firmware supporting it are actually available. For SDR calibration, you can use the Client3 pattern generator for free, including with Autocal. You can use test patterns on blu ray or USB drive for manual calibration, but not for Autocal. You can use HDR test patterns on disk for manual 2 pt white balance and CMS, but not 20 pt white balance. If Autocal does become available for Q80R, I assume it won't support 20 pt white balance, same as other 2019 Samsungs have lost out. If your pattern source goes through your receiver to the TV, then in effect you are calibrating the device chain, but only altering settings in the TV. If you want to do HDR calibration, you'll probably want a meter that can do more than 1000 nits HDR, since it looks like the Q80R can do ~1100 nits.
thoth is offline
Reply Display Calibration
