CalMAN Home for Samsung - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
post #451 of 482 Old 06-14-2020, 10:13 AM
AnotherDude's Avatar
Quoted: 1195 Post(s)
Liked: 764
I have no problem getting an HDR 21-point grayscale calibration using the Samsung HDR legacy workflow with my 75Q9FN, but I found I need to have the pattern source set to HDR mode before setting the display to HDR mode to get the proper grayscale DDC (low of 34.7 for HDR vs. 7 for SDR). At least that's how it works for me.
EDIT: I have a Home Enthusiast license, maybe that's a limit for the Samsung Home license?
Samsung 75Q9FN, Pioneer UDP-LX500, Outlaw 975, Sony TA-N9000ES
i!Display Plus, VideoForge Pro, CalMAN Home Enthusiast, Win 10 Pro x64 2004
HT Enthusiast Extended Custom WF v22.0.0 - 1/8/2020
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is online now
post #452 of 482 Old 06-14-2020, 10:22 AM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
No, it's because you have a 2018 set. PD explicitly ripped out 20pt HDR Autocal support for 2019 sets.
thoth is offline
post #453 of 482 Old 06-14-2020, 10:25 AM
Liked: 764
Originally Posted by thoth View Post
no, it's because you have a 2018 set. Pd explicitly ripped out 20pt hdr autocal support for 2019 sets.
ouch!
post #454 of 482 Old 06-14-2020, 02:08 PM
WiFi-Spy's Avatar
Quoted: 1989 Post(s)
Liked: 2577
ouch!
The newer Samsung TV’s HDR 20pt adjustments line up differently for each model and for some models, change for each screen size. Unfortunately we cannot account for all the different variations in Calman.
Tyler Pruitt - Technical Evangelist - Portrait Displays/Calman
WiFi-Spy is online now
post #455 of 482 Old 06-14-2020, 02:18 PM
Liked: 764
That would make it impossible to get a proper 21 point calibration. Looks like they need to fix their API ...
post #456 of 482 Old 06-14-2020, 02:49 PM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
Not impossible at all, and getting the info through the API would be marvelous, but it's not the only solution. Saumsung just needs to provide a list of adjustment points for each model and size, and then it's some straightforward UI work, and straightforward implementation. The telling and disappointing thing to me is in email I got from PD support about this last year: "If we do not know the greyscale points used for a given model, it is impossible to perform a multipoint autocal." What's that say about PD's relationship with Samsung, if Samsung can't be bothered to email them a list?
thoth is offline
post #457 of 482 Old 06-14-2020, 03:01 PM
Liked: 764
So you blame PD for what Samsung doesn't supply ... OK.
Good luck getting a calibration point list from Samsung. Be sure to share.
post #458 of 482 Old 06-14-2020, 03:22 PM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
Where exactly did I say that?
thoth is offline
post #459 of 482 Old 06-14-2020, 03:28 PM
Liked: 764
Here?
post #460 of 482 Old 06-14-2020, 03:32 PM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
Here?
Your understanding of the English language is clearly different from mine.
thoth is offline
post #461 of 482 Old 06-14-2020, 03:38 PM
Liked: 764
Your understanding of commercial software design principles is clearly different from mine.
Peace.
post #462 of 482 Old 06-15-2020, 08:13 PM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
I don't know if anyone else is in a position to do this, but FYI: Since I now have two Home licenses, I installed the old Home 2019 R2 Beta on a second PC, since it's the only version that ever had a workable way to do HDR 20pt Autocal for my 75" Q90R. That Beta didn't yet have a C6 meter mode for 2019 QLEDs, but since I now have a profile for my Q90R, that doesn't matter. Also, to get that Beta to have the correct adjustment points, I have to connect as if to a Q900R rather than a Q90R, but it works. So I did an HDR Autocal (which has no 20pt) using the current 2020 release, and then one using that 2019 release, without moving the meter. Here's a comparison, with Pre having no 20pt and Post having 20pt. The Contrast setting is also different between the two, since 20pt gives more wiggle room.
Name:	HDR no 20pt vs 20pt.png
thoth is offline
post #463 of 482 Old 06-16-2020, 07:39 AM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
BTW, the grayscale difference is more significant when looking at DEITP. Ignore the Avg and Max values in this screenshot, they're unfortunately still hardcoded to de2000 in the workflow. Calculated by hand:
Pre Gray: Avg: 7.35 Max: 23.9
Post Gray: Avg: 3.47 Max: 10.7
Pre Color: Avg: 9.81 Max: 15.5
Post Color: Avg: 7.7 Max: 16.7
Name:	HDR no 20pt vs 20pt DEITP.png
thoth is offline
post #464 of 482 Old 06-16-2020, 08:15 AM
Liked: 764
That's why I have my own workflow ...
post #465 of 482 Old 06-16-2020, 08:28 AM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
Which isn't possible with Home ...
thoth is offline
post #466 of 482 Old 06-16-2020, 08:35 AM
Liked: 764
I know ... just showing my appreciation for DEITP ...
post #467 of 482 Old 06-24-2020, 07:55 PM
mikegaudiello's Avatar
Quoted: 198 Post(s)
Liked: 33
Does anyone know if calman autocal is supported for the Q900TS?
Sent from my SM-N976V using Tapatalk
Samsung UN65HU9000 w/ SEK-3500U
Receiver - Yamaha RX-A3050
Left/Right - Polk Audio LSi9
Center - Polk Audio LSiC
Surrounds - Polk Audio LSiFX
Powered Subwoofer - PSA V1500
mikegaudiello is offline
post #468 of 482 Old 06-24-2020, 08:10 PM
Quoted: 5359 Post(s)
Liked: 6564
Not yet.
mikegaudiello likes this.
John
Sony 55A1E, A9F, LG CX
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, LightSpace Pro, ISF Level III Certified
jrref is offline
post #469 of 482 Old 07-04-2020, 07:05 PM
Liked: 0
Calman Autocal for Samsung
Hi I am new to this forum .I have a problem with Autocal for Samsung.I have an 82" QN900RB 8K tv.I have purchased all cables pattern generator and C6 meter from Calman.Printed of the walkthrough and tried to calibrate problem is It shows various errors when asked to find display?? most "notfound" have the correct port etc but thats about it.VideoForge pro is connected and found (do I need to connect the HDMI to tv?it says nothing about this or am I just dumb?) If I am missing something I cannot find what yet.Do I need to switch something on the TV to activate it? Love the advice if possible.
I am in New Zealand there is no help here.
Feedback1 is offline
post #470 of 482 Old 07-04-2020, 07:16 PM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
You're using a serial cable plugged into the ExLink port on the OCB, or connecting via IP? What exactly is the error message?
thoth is offline
post #471 of 482 Old 07-04-2020, 07:20 PM
Liked: 0
Yes have the recommended serial cable etc.Its plugged into the OCB .I will have to go back and write down the error be later this coming week.I have lost too much hair on this need a rest!!! Thanks Chris
post #472 of 482 Old 07-04-2020, 07:22 PM
Nillaz's Avatar
Quoted: 699 Post(s)
Liked: 448
Your VF Pro needs to be connected to your One Connect box via HDMI in addition to being connected to the PC via USB.
On your TV go to Settings / General / Network / Expert Settings and enable IP Control so Calman can connect to your display via IP. Once done when you tell Calman to connect you will get a popup in the upper right corner of your TV asking your permission to let Calman connect to the TV. Choose Allow and you should be in pretty good shape.
82Q90R / Denon X6400H / Polk Audio LSI 7.1.4 / Nvidia Shield Pro 2019 / Panasonic DP-UB820 4K BluRay / Xbox One X / PS4 Pro / Nintendo Switch / Custom Gaming PC / Custom VR PC / HTC Vive Pro HMD (Wireless) / QNAP TVS-873 / Harmony Elite
Nillaz is online now
post #473 of 482 Old 07-04-2020, 07:34 PM
Liked: 0
Well many thanks for that.I thought the VF Pro should be connected via HDMI but I read that I MUST FOLLOW THE WORKFLOW EXACTLY!!! Done what you have suggested and yes enabled IP control. I guess my age has got to me !! Thank you for your help I will proceed with another go tomorrow.
post #474 of 482 Old 07-04-2020, 07:46 PM
Nillaz's Avatar
Quoted: 699 Post(s)
Liked: 448
Best of luck and welcome to the forum!
post #475 of 482 Old 07-06-2020, 04:05 AM
chiquito3's Avatar
Quoted: 79 Post(s)
Hello guys!
I bought the Samsung Q80R 82" and I'm wondering what would be the least expensive meter for DIY calibration?
chiquito3 is offline
post #476 of 482 Old 07-06-2020, 09:05 AM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
It looks like the Q80R has a peak brightness of about 1100 nits, so I suppose you might get by with a meter that's only good to 1000 nits, although one that's good to 2000 nits would be better. But if you don't have a way to profile the meter, and the meter doesn't have a selectable mode that matches the Q80R panel type, accuracy probably isn't going to be that great. You also need to figure out what pattern generator you're going to use, especially if you want to do HDR and/or use Autocal.
Edit: the 55" Q80R peak brightness is about 1100 nits. It's entirely possible the 82" is significantly higher; the 82" Q90R peak brightness is well above the 55/65/75".
Rolls-Royce and Nillaz like this.
thoth is offline
post #477 of 482 Old 07-06-2020, 01:24 PM
Quoted: 198 Post(s)
Liked: 33
Samsung Q900TS IP Connection
Trying to establish an IP connection in order to control DDC. Since no Samsung is listed, I am choosing the 2019 model. Should I be able to connect? It's not letting me establish a connection.
post #478 of 482 Old 07-06-2020, 01:50 PM
WiFi-Spy's Avatar
Liked: 2577
Are you trying to calibrate a 2019 or 2020 model?
post #479 of 482 Old 07-06-2020, 02:50 PM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
DDC and Autocal are not supported for 2020 models yet.
thoth is offline
post #480 of 482 Old 07-07-2020, 05:21 AM
Liked: 6564
If you have the hard wired Rs-232 connection device, there is a Link port on the 2020 Samsung's and it will work with CM just like the previous years units. You have to wiggle the plug into the connector the first time you use it. It's very tight. For the 2020 models the IP connect is not supported and will not work so don't waste time on that.
John
jrref is offline
Reply Display Calibration
