CalMAN Home for Samsung - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
post #31 of 482 Old 05-09-2019, 05:43 PM
jimmyk36's Avatar
Quoted: 108 Post(s)
Liked: 64
Originally Posted by WiFi-Spy View Post
A new build of CalMAN Home has been posted to the website. We have fixed the bug that was affecting the color saturation control.
I downloaded the new version and ran the installation and it said I already have the latest version.
In the "About" page it says I have:
User Interface 5.10.0.49
I/O Manager 5.10.0.49
DLL 19.5.8.846
Workflow 1.0.0.101
Report 1.0.0.0
Are these numbers correct for the latest release?
jimmyk36 is offline
post #32 of 482 Old 05-09-2019, 06:19 PM
WiFi-Spy's Avatar
Quoted: 1989 Post(s)
Liked: 2578
DLL 19.5.8.846
Workflow 1.0.0.101
Report 1.0.0.0
The previous version was 5.10.0.41, so yes, you are running the latest version.
Tyler Pruitt - Technical Evangelist - Portrait Displays/Calman
WiFi-Spy is offline
post #33 of 482 Old 05-09-2019, 08:47 PM
mombasa123's Avatar
Quoted: 208 Post(s)
Liked: 56
Originally Posted by Dave_O View Post
Thanks. On my set, the default Brightness of 0 is perfect, but the default Contrast of 45 gives a pink tinge. I have to reduce it to about 35 to eliminate it.
Same, Brightness at 0 (although for really dark scenes like Gravity & HP, I have to increase to 1 to defeat the the crazy local dimming). Contrast at 35 to remove the pink.
mombasa123 is offline
post #34 of 482 Old 05-09-2019, 09:15 PM
Dave_O's Avatar
Quoted: 77 Post(s)
Liked: 52
Changing Contrast to 35 after resetting the DCC was the only step I needed to get very good results, without the pink tinge issue. Changing Contrast after the autocal introduces a large delta-e error at 100% White.
The pre/post image is Contrast 45 on top, 35 on bottom.
Name:	Capture 6 cont 35.JPG
Dave_O is online now
post #35 of 482 Old 05-10-2019, 07:46 PM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
So I've been trying the software before I get the meter.
At the connecting to the TV step:
  • It asks to select which picture mode I want to calibrate but I have no other modes besides custom.
At the brightness/contrast step:
  • The brightness pattern is just a black background with an almost black square in the center, do I have to keep lowering brightness until its invisible?
  • For contrast same question, do I keep going up until it's not visible anymore?
  • Does mobileforge generate patterns over 100% white?
  • After doing the read series it tells you to click help button for sample results but there are no sample results.
  • After checking help menu, I found instructions for brightness and contrast that make no sense with the pattern mobileforge is generating. It also states in bold that "If multiple points of grayscale/gamma are adjusted (i.e. 10-point grayscale), the Brightness/black level should not be readjusted after grayscale/gamma." and this is the last step of calibration.
  • Where do I select the 100/235 pattern it asks for in step 4?
ID:	2565322   Click image for larger version
Motociclao is offline
post #36 of 482 Old 05-10-2019, 10:20 PM
chopples123's Avatar
Quoted: 13 Post(s)
Liked: 8
[/INDENT]
Hi mate,
On the first screenshot this is a list of whites, select the one which is labelled 100, click the continuous read button and adjust backlight to the luminance level you are after.
Another bug i found is when using pgenerator the contrast and brightness adjustment doesn't show the appropriate slide, not sure whether this is the pi or the unified pattern generator within calMAN, calMAN's own internal patch generator works fine, not tried madtpg yet. Apols if this has been fixed, not tried the new release.
No biggie as I have access to my own slides, but thought it worth a mention
cheers
Motociclao likes this.
chopples123 is offline
post #37 of 482 Old 05-11-2019, 07:59 AM
Dave_O's Avatar
Quoted: 77 Post(s)
Liked: 52
I also found that the AVS HD 709 patterns (the classic flashing bars) are easier to use.
Here's where you can download them
https://www.avsforum.com/forum/139-d...libration.html
and here's a good video on Contrast adjustment,
post #38 of 482 Old 05-11-2019, 08:29 AM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
Thanks, I was expecting a pattern like that but mobileforge doesn't seem to have it. The thing is, if I disconnect from it, CalMAN has actual brightness/contrast patterns where you can see what you have to do. I guess I will have to get a blu-ray player from some friend because I don't have any, I watch all movies from the Plex app.
In any case, are there actual instructions for the patterns mobileforge creates?
post #39 of 482 Old 05-11-2019, 08:50 AM
Dave_O's Avatar
Quoted: 77 Post(s)
Liked: 52
Other than the walkthrough, I haven't found any.
https://calmankb.groovehq.com/help/c...ng-walkthrough
You can download the AVS HD patterns in mp4 format
https://drive.google.com/file/d/0B9F...it?usp=sharing
and play them back like any video file.
post #40 of 482 Old 05-13-2019, 04:25 PM
WiFi-Spy's Avatar
Liked: 2578
We have just posted a new update to portrait.com for CalMAN Home for Samsung that fixes a color saturation bug for HDR calibration.
WiFi-Spy is offline
post #41 of 482 Old 05-13-2019, 05:00 PM
jimmyk36's Avatar
Quoted: 108 Post(s)
Liked: 64
Newer than 5.10.0.49?
jimmyk36 is offline
post #42 of 482 Old 05-13-2019, 06:02 PM
WiFi-Spy's Avatar
Liked: 2578
Yes
WiFi-Spy is offline
post #43 of 482 Old 05-13-2019, 06:20 PM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
Are we going to have to download every update from the website? The software always says it's the latest version even if theres a newer one.
post #44 of 482 Old 05-15-2019, 06:20 PM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
I did an autocal run and ended with pretty bad results, I still can't select anything besides custom on picture mode and it doesn't appear as a new mode either after calibrating (I have dynamic, standard, natural, movie).
Since the first run was so bad, I did another run and these are the results.
Anything I might be doing wrong?
post #45 of 482 Old 05-15-2019, 07:06 PM
WiFi-Spy's Avatar
Liked: 2578
Which exact TV model do you have? I think back with the 2016 models it says custom in CalMAN, but we mean Movie on the TV.
You can also enable Cal Day and Cal night modes.
WiFi-Spy is offline
post #46 of 482 Old 05-16-2019, 06:02 AM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
It's an EU KS7000, I think it's the same as the UN KS8000.
post #47 of 482 Old 05-16-2019, 07:28 AM
Rolls-Royce's Avatar
Quoted: 1509 Post(s)
Liked: 1600
The tag "custom" on the display tab isn't really referring to the picture mode the TV started in. As it was explained to us by SpectraCal months ago, CalMAN cannot read any settings directly from the display through the Samsung interface. So it's essentially telling you that the set is in a custom adjustment mode for the autocal. You do appear to be using a display type for the meter that doesn't really match. Try either profiling the meter to the display with a spectro if you have access to one, or use the "Raw XYZ" meter mode, which could give you a better result. I own a KS8000 that I have done autocals on in the past, so this is familiar territory.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #48 of 482 Old 05-16-2019, 07:47 AM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
Originally Posted by Rolls-Royce View Post
The tag "custom" on the display tab is just referring to the color space the program sets during the DDC reset prior to autocal, to allow the CMS to be adjusted. If you look at the list of DDC settings after the reset, you'll see it. It isn't really the picture mode the TV is in. As it was explained to us by SpectraCal months ago, CalMAN cannot read any settings directly from the display through the Samsung interface. You do appear to be using a display type for the meter that doesn't really match. Try either profiling the meter to the display with a spectro if you have access to one, or use the "Raw XYZ" meter mode, which could give you a better result. I own a KS8000 that I have done autocals on in the past, so this is familiar territory.
Unfortunately I don't have access to a spectro, the meter is rented and they don't have any spectro for renting. I will try Raw XYZ later today and post the results.
Rolls-Royce likes this.
post #49 of 482 Old 05-16-2019, 07:55 AM
Liked: 1600
Additionally, if you start seeing wild swings on the meter readings - say that at 40% you get rapid swings in red and blue and the program won't advance to the next step - try changing the "Sync" option on the meter properties tab. Good luck!
...Royce...
post #50 of 482 Old 05-16-2019, 08:27 AM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
Last night at the post calibration readings it got stuck at the first one, it was like it couldn't see full black.
Do I leave everything else by default? saturation sweep at 75% etc?
post #51 of 482 Old 05-16-2019, 08:46 AM
Liked: 1600
Yes.
...Royce...
post #52 of 482 Old 05-16-2019, 10:45 AM
WiFi-Spy's Avatar
Liked: 2578
Can you tell us what your set up is with regards to measurement device and pattern generator?
WiFi-Spy is offline
post #53 of 482 Old 05-16-2019, 10:53 AM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
The meter is an X-Rite i1Display PRO and the pattern generator mobileforge running on a firestick tv plugged in the samsung onebox hdmi1.
I just ran it again with the profile set as Raw XYZ and the results are horrible
ID:	2567564   Click image for larger version
ID:	2567566   Click image for larger version
ID:	2567568   Click image for larger version
post #54 of 482 Old 05-16-2019, 01:30 PM
WiFi-Spy's Avatar
Liked: 2578
Are you performing a FULL DDC Reset before starting the calibration process?
WiFi-Spy is offline
post #55 of 482 Old 05-16-2019, 01:34 PM
WiFi-Spy's Avatar
Liked: 2578
We have a KS 8000 here in the office so I should be able to set it up tomorrow and test it myself .
WiFi-Spy is offline
post #56 of 482 Old 05-16-2019, 01:36 PM
Motociclao's Avatar
Quoted: 12 Post(s)
Liked: 1
Yes,
if it makes any difference the firmware is 1233
post #57 of 482 Old 05-17-2019, 10:08 PM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
In version 5.10.0.50, on the Post-Calibration Verification page, under Grayscale Performance, it looks like Avg Error is being reported incorrectly; it appears to be reporting the same as Max Error.
thoth is online now
post #58 of 482 Old 05-18-2019, 06:03 AM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
The CalMAN Home for Samsung Walkthrough says to use Full 100% pattern size for SDR AutoCal. The CalMAN Home Manual Calibration Walkthrough recommends using Constant APL 10 for LCD. Why the difference? Which one should I pick for manual calibration of a 2019 Samsung Q90R?
thoth is online now
post #59 of 482 Old 05-18-2019, 08:29 AM
AnotherDude's Avatar
Quoted: 1195 Post(s)
Liked: 764
What workflow are you talking about?
Samsung 75Q9FN, Pioneer UDP-LX500, Outlaw 975, Sony TA-N9000ES
i!Display Plus, VideoForge Pro, CalMAN Home Enthusiast, Win 10 Pro x64 2004
HT Enthusiast Extended Custom WF v22.0.0 - 1/8/2020
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is online now
post #60 of 482 Old 05-18-2019, 08:33 AM
thoth's Avatar
Quoted: 345 Post(s)
Liked: 147
Sorry, Manual Calibration, SDR.
thoth is online now
Reply Display Calibration
