Calman Home for Sony 2019 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 116Likes
post #361 of 403 Old 11-08-2019, 02:55 PM
Quoted: 27 Post(s)
Liked: 1
Hey Guys, i habe a big Problem with Autocal my Sony x940e. The x940e have a problem that it has imagerentation. The IRE10 and 20 are because of that too britgh. Have someone a tip?
91DivineAngel is offline
post #362 of 403 Old 11-08-2019, 04:51 PM
Quoted: 4548 Post(s)
Liked: 5541
Without seeing the problem we can't give you a tip but why don't you try e-mailing Portrait Display (Calman) support? Send them you scans and your setup and they will help you quicker.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #363 of 403 Old 11-09-2019, 03:34 AM
Quoted: 27 Post(s)
Liked: 1
Thank you for your answare but i solf this problem
But i have a nother. In the Youtubevideo from calman the guy said that in application measurememt options he use on autocal targets - deltaE formula - de_ITP, It gives him besser results then de2000. Is that truth?
post #364 of 403 Old 11-09-2019, 06:31 AM
Liked: 5541
Try both and see which works better for your setup. deITP should give you a little better accuracy.
mrtickleuk likes this.
John
jrref is online now
post #365 of 403 Old 11-09-2019, 09:16 AM
Quoted: 27 Post(s)
Liked: 1
Yes i try it, but the results are minor. I have now calman home since 4 month. And i figred out that my tv is a rg phophor display type. Calman says that my xrite i1 pro don t have this option in calman, only the c6. At the moment i use LCD(LED Blue Green) Today i read a lot about to profiling my xrite with calman to my tv. Thats how i messured: to creat a profil i choose as refernce meter and target meter my xrite. PG is Mobilforge via firestick. As Display type i choose raw xyz. After that calibrated my tv again. Compare to the calalibration with LED BG its only a slight different, so its baisicly the same it have only slightly more red)
Do i something wrong?
This Are the Profile:
post #366 of 403 Old 11-09-2019, 07:51 PM
WiFi-Spy's Avatar
Quoted: 1608 Post(s)
Liked: 2194
Blue-Green and RG Phosphor Are different names for the same technology. It is also sometimes called GB-R.
shoman94 and mrtickleuk like this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
post #367 of 403 Old 11-10-2019, 02:53 AM
ConnecTEDDD's Avatar
Quoted: 3428 Post(s)
Liked: 4248
X-Rite Device Services v3.1.7.6
Hi, the i1Display PRO has RG Phosphor (GB-LED). This table is coming from X-Rite SDK and X-Rite used for the creation of that spectral correction for RG Phosphor (GB-LED) table the Dell Ultrasharp U2413 (for GB-LED) and AU Optronics B156HW01 Monitors.
CalMAN support had to say to you that its the same as GB-LED table (or the table to be renamed as GB-LED/RG Phosphor generally).
Use your Windows Explorer, enable hidden files/folders and see inside the C:\ProgramData\SpectraCal\Portrait Displays\CalMAN 5 Home\Data\i1D3
There you will see the all the spectral (EDR) files for i1Display PRO.
You will see that file ''RG_Phosphor_Family_25Jul12.edr''.
I have checked the latest X-Rite Device Services v3.1.7.6 or X-Rite i1Profiler 3.1.1 and they both have that file also.
When you are using FireStick you have to check for your display if it will require to select from CalMAN to expand or not expand the Video to PC Levels. One of those setting will be the correct but it can be different per connected display.
You need to have output RGB from firestick, this is possible only if you forced it to output 1080p (not 2160p).
About MobileForge, see there: https://www.avsforum.com/forum/139-d...l#post57067606
https://www.avsforum.com/forum/139-d...l#post58624800
You have to check also your TV to expect Limited range signal to the HDMI input you have connected the FireStick.
The procedure you performed for meter profiling is incorrect. See why we perform meter profiling there: https://www.avsforum.com/forum/139-d...ng-thread.html
Meter profiling will require to have both a spectrophotometer (like i1PRO) to use as reference meter to profile your colorimeter (your i1Display PRO). Since you have only the i1Display PRO, then its useless and wrong to use meter profiling.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #368 of 403 Old 11-10-2019, 01:46 PM
Quoted: 27 Post(s)
Liked: 1
@ConnecTEDDD
Thank you a lot for your help! Its good to know that gb led is the right typ and i dont need to rent a c6.
About the fire stick. I use the old one (only 1080p) my tv output hdmi full range, and i dont find any setting in the firestick to put it on limited. If i use in calman luminace level pc and start autocal, the pragramm says: this operation is not supported for this device.
So i can only use video right?
post #369 of 403 Old 11-10-2019, 04:12 PM
Liked: 4248
@ConnecTEDDD
For calibration you will use video levels, as the workflows by default are using.
Amazon devices with proper settings can generate any RGB-Triplet combination for RGB-Video (16-235).
For MobileForge users, CalMAN by default will send RGB-Triplet patches with Video Levels (16-235) but it has a setting to 'Expand Video Levels to PC Levels', for some TV models this has to be enabled while to other TV models to be disabled.
You have to find out what is the correct setting for your TV, but to know this you have to use some patterns as reference, for that reason I send you the other links to realize by looking the gamma graph how large are the gamma deviation if you will not use the correct setting for your setup.
post #370 of 403 Old 11-11-2019, 06:35 AM
Quoted: 27 Post(s)
Liked: 1
Thank so much, i read all and it helps a lot
But one thing is strange sith autocal. Iff it calabrate 100% grayscal it things that red is to low. It puch than the red slider to max. Greyscale 10-90% looks ok. After the calibration i let the software read the meassurement again and than it shows me that 100% has now too much red. So adjust it manual to bring it in line. Is this correct?
post #371 of 403 Old 11-12-2019, 01:09 PM
Liked: 4248
It can happen many times one adjustment of specific control to affect other areas, so you have always take full grayscale runs and evaluate looking grayscale ramp patterns to find out that all are looking good during your adjustments and at the end of calibration.
jrref likes this.
post #372 of 403 Old 11-12-2019, 03:29 PM
Liked: 5541
Just to add to Ted's comments, I always manually tweak the autocal if it needs it but you can't touch the 100% since as you have seen it effects the other settings. When I use autocal for the grayscale, I always look to see how the 100% looks after the adjustment and if it doesn't look "right" to me, based on my experience, I cancel and re-start the autocal. I don't know why but sometimes the 100% doesn't get set optimally and it throws off the rest of the settings.
Another thing you can do is calibrate the 2pt first then run the 20 pt autocal. This will minimize the amount of adjustments that CM needs to make and may help you get better results.
John
jrref is online now
post #373 of 403 Old 11-14-2019, 02:33 PM
Quoted: 27 Post(s)
Liked: 1
Hey jrref
There is a possible a bug with auto cal. My white point is calibrated. Its nearly perfect. But autocal things every time(yes every time) that my 100% grayscale have not enough red. After the calibration i run the greyscale readings again and than 100% have far too much red. Than i tweak it and run the readings again. I have a average delta error about 0.4 i thing this is a good result
post #374 of 403 Old 11-14-2019, 03:44 PM
WiFi-Spy's Avatar
Liked: 2194
Hey jrref
Can you post a screenshot of your results?
post #375 of 403 Old 11-14-2019, 04:08 PM
Quoted: 27 Post(s)
Liked: 1
Shure
post #376 of 403 Old 11-15-2019, 05:21 PM
TheDuke1980's Avatar
Originally Posted by WiFi-Spy View Post
This is for the previous Bravia workflow, not the new CalMAN Home one.
I am personally recording a tutorial video next week, so it will be on our YouTube page coming very soon.
Never saw the link for the video posted? Did I miss it or still not finished? Thank you
TheDuke1980 is offline
post #377 of 403 Old 11-15-2019, 06:24 PM
WiFi-Spy's Avatar
Liked: 2194
It is up on our Portrait Displays YouTube channel now.
post #378 of 403 Old 11-16-2019, 05:14 AM
mrtickleuk's Avatar
Quoted: 5097 Post(s)
Liked: 7431
You missed it . Uploaded 22nd Aug.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #379 of 403 Old 11-16-2019, 07:50 AM
Quoted: 1024 Post(s)
Liked: 686
Originally Posted by priitv8 View Post
You can build a pixel-perfect PG yourself from Raspberry Pi and PGenerator software. Total cost (incl SD card, enclosure and power supply) around $50.
Does Calman home support using this option automatically sending the correct patterns to the TV? Or do I have to select the patterns? And I know this is a Sony thread, but if I use this on a LG C9 vs the internal pattern generator will I get the validation capability that I loose with internal generator?
LG 65C7P (Also XBR65X900E and XBR55X900E)
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #380 of 403 Old 11-16-2019, 08:08 AM
Liked: 686
Wow, I just spent some time reading this thread and the Calman for LG thread and my head is going to explode. So I own a i1 Pro meter that I used to calibrate my monitors for photo work. I am interested in toying with Calman home, but it looks like the best calibration needs a YCrCr pattern generator, and it looks like there are no cost effective solutions. Am I missing something of it’s there an economical YCrCr pattern generator that will work with Calman Home?
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #381 of 403 Old 11-16-2019, 08:33 AM
Liked: 5541
You need to ask this question over on the Calman thread -> https://www.avsforum.com/forum/139-d...l#post22276312
As for the test pattern generator you need to look at this thread -> https://www.avsforum.com/forum/139-d...l#post57067606
In order not to go off topic, with the Sony, you can use any test pattern generator that gives you RGB or YCbCr since you only calibrate SDR then HDR and DV is generated from the SDR settings. Very simple, CM Home works great. A TPG which gives you YCbCr output is preferred. As far a bit perfect, reference meters, etc..., you will need to read the attached threads. Bottom line, with CM Home you will get a nice result with an i1D3 or a C6 meter and most inexpensive test pattern generators. The minute you star thinking about moving from "good" calibration result to "perfection", prepare to invest a lot of time and probably money. As for the LG, totally different situation since the new LGs have more extensive calibration interfaces.
WiFi-Spy likes this.
John
jrref is online now
post #382 of 403 Old 11-16-2019, 08:48 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11430 Post(s)
Liked: 6767
When the question of pattern generation comes up, I rarely see anyone discuss using CalMAN to generate the test patterns using the Laptop connected to the display over HDMI. While I recognize this may not be of the same quality that an expensive professional external pattern generator would provide, is not using the CalMAN-generated patterns good enough for the typical home DIY enthusiast? This approach has provided excellent results for my Z9F using Autocal. I understand that a professional calibrator may not want to use this approach, but why is it never mentioned, especially since it is a no-cost solution?
AustinJerry is offline
post #383 of 403 Old 11-16-2019, 09:08 AM
Liked: 686
Thanks. I just found that thread as well and reading that. Very interesting and overwhelming.
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #384 of 403 Old 11-16-2019, 11:13 AM
mrtickleuk's Avatar
Liked: 7431
Probably because it's swapping one can of worms for another! There are lots of variables in the signal path in a PC, from the hardware through the drivers and the OS. When using a PC for Dolby Vision calibration for example, it needs to be "bit accurate" otherwise the Dolby Vision signal cannot be carried. Experience has shown is that this is very difficult (not impossible, but difficult) to achieve, and this means that if it's not accurate then, it wasn't accurate for SDR either. Particularly now with the Raspberry Pi, everyone has access to a bit-perfect RGB source, that is normally recommended as the best compromise for a budget SDR generator.
_______________
post #385 of 403 Old 11-16-2019, 11:47 AM
Liked: 6767
But for a Sony AutoCal, the PC is only used for the SDR calibration, not Dolby Vision. Does this change your response? I use PC-based patterns for calibrating my Z9F, and I don’t perceive anything “wrong” with the results, which I can gladly post here if required. I get the feeling that the argument for being “bit perfect” is splitting hairs, and I see nothing wrong with suggesting using PC-generated patterns as an alternative for home users looking for a reasonable cost solution. I certainly would not categorize it as a can of worms.
post #386 of 403 Old 11-16-2019, 12:56 PM
mrtickleuk's Avatar
Liked: 7431
Hmm not really no, because the Raspberry Pi is so cheap now it's just easier all round. (I mentioned Dolby Vision only because it exposed how bad some PC outputs were, and raised a lot of eyebrows of those who had previously trusted those PCs for SDR). There are so many variables flying around with this stuff, the more you can eliminate the better. The "cheap pattern generators" thread has graphs on just how bad some non-bit-perfect solutions can be.
Rolls-Royce likes this.
_______________
post #387 of 403 Old 11-16-2019, 02:31 PM
Liked: 6767
Well, all I have to go on are my results in CalMAN, and how good the display looks to me. I don't perceive any issues.
thomasfxlt likes this.
post #388 of 403 Old 11-16-2019, 05:50 PM
Quoted: 27 Post(s)
Liked: 1
Why you are using ccfl as display type for the zf9? Is not rg phosphor the better choice?
shoman94 likes this.
post #389 of 403 Old 11-17-2019, 06:22 AM
njfoses's Avatar
Quoted: 319 Post(s)
Liked: 184
Is there a step by step guide on using a Raspberry PI as a pattern generator anywhere?
njfoses is offline
post #390 of 403 Old 11-17-2019, 07:01 AM
Quoted: 128 Post(s)
This. I have been researching and would love to actually understand how to use the thing. I've read multiple articles, including the Italian article, but still am not sure I understand connections, and how to get this thing going, but it does really sound like a great to get bit perfect patches cheaply.
toby5 is offline
Reply Display Calibration
