Calman Home for Sony 2019 - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 362Likes
post #1051 of 1057 Old 03-15-2020, 07:52 AM
Quoted: 4959 Post(s)
Liked: 6030
Originally Posted by toby5 View Post
I have a new question. Since profiling the i1 display pro the calibration is doing something different with the grain. On some aspects, I really love what it's doing, on others I just feel like it's too sharp? The TV itself had been feeling like it was too sharp before this, but I'm not sure what happened to create this. Any ideas?
Maybe you are seeing more near black detail and thus the picture looks sharper?
John
Sony 55A1E, A9F, LG CX
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, LightSpace Pro, ISF Level III Certified
jrref is online now
post #1052 of 1057 Old 03-15-2020, 01:24 PM
Quoted: 174 Post(s)
Liked: 33
This sharpness I'm speaking of is actually there calibrated or not. It could actually be noise. With the meter profiling, everything looks cleaner. It's like the calibration looks cleaner, if that makes any sense.
toby5 is offline
post #1053 of 1057 Old 03-16-2020, 11:33 AM
Quoted: 174 Post(s)
Liked: 33
Ok, no answers on the CMS question, so which point on the 21 greyscale do you think affects skintones the most?
toby5 is offline
post #1054 of 1057 Old 03-16-2020, 11:48 AM
Rolls-Royce's Avatar
Quoted: 1371 Post(s)
Liked: 1451
All of them. The gray scale/black and white parts of the picture provide the underlying image, the "structure", while the overlying colorization is provided by the color decoder/CMS. The gray scale will affect secondaries more than primaries, and since you don't (or shouldn't) have large areas of primary colors in skin tones, they are all important, from highlights down to shadows.
shoman94 and mrtickleuk like this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #1055 of 1057 Old 03-16-2020, 12:58 PM
Quoted: 174 Post(s)
Liked: 33
Thank you for the response. I tried manually cleaning up the gray scale after autocal did its thing, by making sure everything was inside the box without hanging out. I just wish I knew better how to correct errors in the CMS.
toby5 is offline
post #1056 of 1057 Old 03-16-2020, 01:29 PM
Liked: 1451
Most manufacturers' CMS implementations suck, so I gave up on that long ago. I keep my Samsung KS8000 in Auto. It isn't perfect, but it measures close enough for me.
mrtickleuk likes this.
...Royce...
post #1057 of 1057 Old 03-16-2020, 03:45 PM
Liked: 0
Hello all. Just got my new A9G (Coming from the A1E) and I have noticed that the black levels seem higher in all content on the A9G. Is that normal? I wouldn't expect the newest top tier Sony model to have worse black levels than their 1st generation model.
It is fully calibrated in both Cinema and Custom Pro 1 modes.
I did calibrate them at a high brightness (around 70 FL) so could that be the issue? I used an I 1 Pro2 Spectro and Calman Home for Sony. And by all content, I mean literally all content. The A1E has darker blacks on everything that I am playing on the A9G. Verified that either are crushing with the black level flashing bar pattern from Ted's Patterns. 17 is flashing on both, but all bars look considerably darker on the A1E.
Both calibrations below were done manually with Contrast at 100% and gamma set to 0 while doing the grayscale. Contrast was dialed back to 90 while doing the CMS. CMS was done with 75%/75% Ted's Patterns with a Calman setting of "75% Only"
RGB graph was completely flat and lined up perfectly.
Gamma was perfect for EOTF curve, but
for the point gamma line graph, it was perfectly flat (with RGB breakout) except for 95% IRE which had a spike toward either 2.4 or 1.9 (can't remember which lol)
Custom mode:
Brightness MAX
Contrast 90
PL MEDIUM
Black level 50
Gamma -2 (2.4)
Color 50
2 Point Grayscale:
Only -8 Blue Gain
Color temp Expert 1
(With calibrated values)
CMS
Red -1 1 6
Magenta -3 3 7
Blue 0 1 7
Cyan 1 8 3
Green 3 4 3
Yellow -5 4 6
______________________________________
Custom for Pro 1:
Brightness 34
Contrast 90
PL HIGH
Black level 50
Gamma -2 (2.4)
Color 50
2 Point Grayscale:
Only -8 Blue Gain
Color temp Expert 2
CMS
Red -1 1 6
Magenta -3 3 7
Blue 0 1 7
Cyan 1 8 3
Green 3 4 3
Yellow -5 4 6
Cap'n pntppr is offline
Reply Display Calibration
