Calman Home for Sony 2019 - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
post #211 of 283 Old 07-19-2019, 07:13 AM
WiFi-Spy's Avatar
Quoted: 1466 Post(s)
Liked: 2082
Originally Posted by rachmat-d View Post
I have no response from Calman/ Portraid Display and from Wifi spy regarding the licence .
Please contact our support team. We respond to every email.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #212 of 283 Old 07-19-2019, 07:24 AM
rachmat-d's Avatar
Quoted: 56 Post(s)
I already email support and then PM you and then Email sales, but i havent got any reply email until now ?
rachmat-d is offline
post #213 of 283 Old 07-20-2019, 05:44 AM
rachmat-d's Avatar
Quoted: 56 Post(s)
Thanks for the reply Wifi-Spy.
Sadly there is no solution for my situation.
post #214 of 283 Old 07-20-2019, 07:48 AM
kanti123's Avatar
Quoted: 73 Post(s)
Liked: 51
So, after consulting Portrait for some clarification about autocal without doing 2 point white balance vs 2 point white balance. I found that my TV, XBR75X940E have significantly higher dE error as high as 10. So, I took a step back and calibrate the 2 point white balance first again at 30% and 80% white balance then do the autocal again. Portrat display mention that jumping straight into 10P white balance apply the setting to all, which is true. So, I was thinking. To get a better result, it's best to do 2-point white balance first to get the over all grayscale as close as possible, then fine tune it with the autocal. The only down side to this is I have to get into every single input/apps and make sure that 2-point white balance is set for each input and apps, plus HDR/Dolby vision for external and Netflix app. I hope that calman in the future would include 2-point white balance auto cal adjustment. last note, my dE error with 2 point white balance calibrated are all 1 and below, color checker highest dE error was 2, which is blue color. Any inputs are welcome.
Equipment:
C6 Meter
VideoForge Pro
shoman94 likes this.
kanti123 is offline
post #215 of 283 Old 07-20-2019, 02:11 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11111 Post(s)
Liked: 6617
FYI, based on a recommendation from @D-Nice earlier in the Sony Master Series LCD calibration thread, when doing the 2-point white balance on Sony display’s, you should NOT adjust the Bias (30%) settings (leave at default values of zero). Only adjust the Gain settings. Also, I recommend setting the screen for 100%/30% patterns, not 80%/30% patterns.
Edit: Here is the post: https://www.avsforum.com/forum/139-d...l#post57354930
AustinJerry is online now
post #216 of 283 Old 07-20-2019, 02:20 PM
kanti123's Avatar
Quoted: 73 Post(s)
Liked: 51
Thanks for he input, I’ll try it tonight and see if I get better result.
kanti123 is offline
post #217 of 283 Old 07-20-2019, 07:57 PM
shoman94's Avatar
Quoted: 5069 Post(s)
Liked: 3581
As long as you don't raise Bias you'll be fine. Any raising will elevate blacks.
Sent from my LG-H932 using Tapatalk
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #218 of 283 Old 07-20-2019, 09:23 PM
kanti123's Avatar
Quoted: 73 Post(s)
Liked: 51
Following the suggestion, this is the best I can get out of the TV. any further fine tuning will not yield me any more benefit in my opinion. I put in Kong Skull Island and Black Panther to make sure I have no black crush, and I can confirm that there's no black crush any where in the movie like I used to see. So I guess it's good to go! I used to get black crush and a greenish hue on skin color. I also did 2.3 gamma verification and see that there's no significant changes to white balance. Infact it lowered my deltaE. Cheer !
Name:	Color Checker 07202019.jpg
ID:	2592960   Click image for larger version
Name:	Color Space 07202019.jpg
ID:	2592962   Click image for larger version
Name:	Gray Scale 07202019.jpg
ID:	2592964   Click image for larger version
Name:	Validation 07202019.jpg
kanti123 is offline
post #219 of 283 Old 07-21-2019, 12:37 AM
Quoted: 151 Post(s)
Hi everyone, which gamma and which oled light is recommended when profiling meter?
Is the color gamut should be set on wide when profiling a meter?
Sent from my SM-G950F using Tapatalk
Toto84 is offline
post #220 of 283 Old 07-21-2019, 02:08 AM
Quoted: 289 Post(s)
Liked: 92
You committed to writing up a guide for configuring the PC properly. Can we still expect a guide to be published?
yes, but it is not complete yet.
Now that the LG tutorials are ready, can we hope for Sony one(s) next?
priitv8 is offline
post #221 of 283 Old 07-21-2019, 06:59 AM
Liked: 6617
My original question was pertaining to setup of the laptop video system when using patterns generating by CalMAN over a HDMI connection. The setup is independent of the brand of display being calibrated. Perhaps your question is something different?
post #222 of 283 Old 07-21-2019, 12:53 PM
WiFi-Spy's Avatar
Liked: 2082
Early this week. It is already done we are just working on some final graphics.
WiFi-Spy is offline
post #223 of 283 Old 07-21-2019, 01:07 PM
Quoted: 151 Post(s)
Hi Tyler, do you plan to do tutorial on profiling meter?
Toto84 is offline
post #224 of 283 Old 07-21-2019, 06:43 PM
alettiere's Avatar
Quoted: 574 Post(s)
Liked: 348
When I did an AutoCal using Sony Calman, while I set the Gamma to BT1886 (which I believe is Gamma -2 on the A9G), i didn't see any information within Calman about what my Gamma was measuring. Is there some option in the menu that turns this on or at least give me a read-out so I know?
alettiere is offline
post #225 of 283 Old 07-21-2019, 08:09 PM
sgupta's Avatar
Quoted: 247 Post(s)
Liked: 162
I did this a while back to see how mine was tracking, only in my case set to Sony's custom whitepoint and Power 2.2 gamma.
Rolls-Royce helped me figure it out by posting the following: "You can verify by setting up for a manual calibration then doing a "read series" on the gray scale page (without making adjustments). Make sure that your CalMAN target for gamma matches the autocal's then you can see if it's the same."
Basically, you want to look at the Grayscale Multipoint page in a manual calibration mode and see if the line you get matches the EOTF line. (It may say something like "RGB with Luminance.") This verified what gamma I was at for me as the line closely followed it when set to the same gamma I calibrated for (and diverged quite a lot if set to a different gamma instead).
Rolls-Royce likes this.
sgupta is offline
post #226 of 283 Old 07-21-2019, 08:26 PM
alettiere's Avatar
Quoted: 574 Post(s)
Liked: 348
Thanks! I’ll give it a try
post #227 of 283 Old 07-21-2019, 11:23 PM
kanti123's Avatar
Quoted: 73 Post(s)
Liked: 51
I still have the old guide, see he attached pic about BT1886. I’m not sure if it’s accurate anymore though
kanti123 is offline
post #228 of 283 Old 07-22-2019, 01:44 AM
rachmat-d's Avatar
Quoted: 56 Post(s)
HI,
I just have a C6 , can i just calibrate ZD9 with autocal for SDR and get automatic conversion for HDR and Dolby vision automatically ?
RetiredandLovingIt likes this.
post #229 of 283 Old 07-23-2019, 02:33 AM
sgupta's Avatar
Quoted: 247 Post(s)
Liked: 162
HI,
Yup! At least on the Z9F, calibrating SDR automatically ports all of that to HDR and Dolby Vision (as long as you're using the same color temperature, ie. Expert 1). It's one of the really nice features Sony's have where you don't have to worry about calibrating that stuff separately. I think it should be the same on the Z9D, but hopefully someone can confirm that.
The only thing I had to do manually is copy the "Per Color Adjustments" settings (there are only 6) over for Game mode and some of the built-in app modes, but even for those, the 20-pt controls all are tied to Color Temperature, so as long as you use the same preset (ie. Expert 1), you're gold.
sgupta is offline
post #230 of 283 Old 07-23-2019, 02:37 AM
Quoted: 289 Post(s)
Liked: 92
Thanks a lot. Looking forward to it!
priitv8 is offline
post #231 of 283 Old 07-23-2019, 06:15 AM
Liked: 6617
I don’t think the Z9D has the per color adjustments.
sgupta likes this.
post #232 of 283 Old 07-23-2019, 07:03 PM
thirdkind's Avatar
Quoted: 162 Post(s)
Liked: 136
I'm thinking of trying a manual perceptual match on my A9F to one of the traditional displays I have on hand (probably my calibrated laptop since it's easiest to move).
Is it okay to do it with my existing calibration (modified white point of x:0.3067, y:0.318) or should I recalibrate using a standard white point (D65, Judd, etc.) first?
thirdkind is offline
post #233 of 283 Old 07-27-2019, 09:51 AM
destroyer2usa's Avatar
Quoted: 137 Post(s)
Liked: 136
If I want to use a different whitepoint in the Sony autocal workflow where do I adjust it?
If I select Custom whitepoint I get no field to actually put in manually a different whitepoint.
There is no option to put it in the basic workflow options tab.
destroyer2usa is offline
post #234 of 283 Old 07-27-2019, 10:27 PM
sgupta's Avatar
Quoted: 247 Post(s)
Liked: 162
I ran into this too and I'm trying to remember how I solved it. *grabs laptop*
Oh yeah...instead of selecting Custom for Whitepoint, select Custom for Colorspace. I agree it's odd. You can then re-set Colorspace to rec.709 or whatever, but the Whitepoint fields will stay showing. Hope this helps!
destroyer2usa and mirekti like this.
sgupta is offline
post #235 of 283 Old 07-27-2019, 11:31 PM
Quoted: 137 Post(s)
Liked: 136
Thumbs up
Awesome, working just fine then. Thanks for the tip!
sgupta likes this.
post #236 of 283 Old 07-28-2019, 06:13 AM
Quoted: 82 Post(s)
So I have heard Vincent in one video said he calibrates Sony two profiles, one for daylight and one for night time watching.
Do you guys do the same?
Would I need to run two calibrations at different brightness level or I should only calibrate for 120cd/m, and then copy it from Expert1 to Expert2 and raise the brightness and save?
My TV is on the way so not 100% sure on what's possible, but getting ready for it.
mirekti is offline
post #237 of 283 Old 07-28-2019, 12:47 PM
Quoted: 4380 Post(s)
Liked: 5370
I do the same and yes its two calibrations, one dark, one bright.
mirekti likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #238 of 283 Old 07-28-2019, 03:14 PM
shoman94's Avatar
Liked: 3581
You don't need to, you can just use expert 1 with both custom pro 1 & 2.
shoman94 is offline
post #239 of 283 Old 07-28-2019, 09:35 PM
sgupta's Avatar
Quoted: 247 Post(s)
Liked: 162
Personally, I like a one size fits all calibration, so I calibrate for a dark room (which 98%+ of my viewing is in). That said, I also target a higher brightness (160 nits) even for the dark, which is plenty for daytime viewing as well, so that may be why I don't bother with a second setting. I have used the second setting before, but for comparing things like Sony whitepoint to D65, etc.
sgupta is offline
post #240 of 283 Old 07-29-2019, 06:53 AM
Liked: 6617
I agree agree completely.
Reply Display Calibration
