CalMAN Home for LG - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 146Likes
post #331 of 519 Old 07-19-2019, 06:09 PM
Liked: 4
Originally Posted by Toto84 View Post
Thanks for your time and response.
When you say to put the i1display pro on screen mode you mean Raw XYZ?
Should the i1pro2 not be in contact with the screen?
Should the windows size be 10% or 100%
Should the 100% white be 100 nits when taking reading?
Should i use a gamma of 2.2 or 2.4 for creating the profile?
Should i create of profile for hdr and dolby vision as well?
Could you please confirm on the second picture taken that use native gamma for gamut target should be check or uncheck?
Sent from my SM-G950F using Tapatalk
I really think you should just follow the tutorial videos, Ive never used an Xrite i1 pro or calibrated a screen before yesterday and just followed the YouTube videos. Now I have both SDR and HDR calibrated and as I type this I’m in the middle of calibrated DV. All without major issue.
Looks like your using the advance features (which are not required) if you follow the tutorials
jrref likes this.
jdstephens is offline
post #332 of 519 Old 07-20-2019, 07:54 AM
Antarius's Avatar
Quoted: 127 Post(s)
Liked: 58
I have i1 Diplsay Pro and I noticed recommendation to use Raw ZYX mode. But no such mention for SDR workflow. Is it also recommended to use Raw XYZ for SDR?
Antarius is offline
post #333 of 519 Old 07-20-2019, 09:32 AM
Rolls-Royce's Avatar
Quoted: 1154 Post(s)
Liked: 1246
Yes, for both SDR and HDR.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #334 of 519 Old 07-20-2019, 10:55 AM
HiFi4Vision's Avatar
Quoted: 125 Post(s)
Liked: 71
Hey Tyler (ping @WiFi-Spy ),
in the YouTube tutorial video "LG OLED 2019 Calibration SDR with CalMAN Home" you've mentioned that you're going to upload a 10h version of the SDR grey screen media file. I was however unable to find this video.
Is the video available yet and if so where?
If not: do you still plan to upload it?
HiFi4Vision is offline
post #335 of 519 Old 07-20-2019, 12:45 PM
Quoted: 157 Post(s)
Looks like your using the advance features (which are required) if you follow the tutorials
Profiling is not in the tutorial and is critical for my calibration as i have a colorimeter and a spectrometer.
A lot of different people even pro have different method.
I am a perfectionist and i want to make sure i have the best result as this process is not cheap.
I spend countless hours reading the forums and calibrating is now a hobby for me.
Toto84 is offline
post #336 of 519 Old 07-23-2019, 10:27 AM
Iraschwips's Avatar
Quoted: 13 Post(s)
After calibrating for SDR, I then calibrated for HDR and Dolby Vision.
Afterwards, from the media player screen (with the grey pattern still playing) I assigned the calibrated modes to all inputs
I can easily see if the calibrated SDR mode is in effect because the panel brightness is well reduced from pre-calibration.
However it’s a bit tricky to see if the HDR modes have taken the calibration. None of the numbers are different, even going into the color management screen there doesn’t appear to be any adjustments. I am sure the HDR Home and Dolby Vision Home modes are now calibrated but my question is whether there is any way to easily confirm this?
Do the settings show up somewhere in the service menu?
BTW, I’m using a C9 model TV and the internal pattern generator.
Iraschwips is offline
post #337 of 519 Old 07-23-2019, 12:18 PM
WiFi-Spy's Avatar
Quoted: 1549 Post(s)
Liked: 2148
The color gamut and white balance controls will be grayed out For those picture modes.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
post #338 of 519 Old 07-23-2019, 12:47 PM
Iraschwips's Avatar
Quoted: 13 Post(s)
Thank you for this Tyler, and for the three very helpful tutorial videos. I'll have to verify that the two controls you mention are greyed out.
Also, I may have missed it elsewhere but I'm assuming that after defining the Tone Map for the HDR modes dynamic tone mapping must be turned off, or will this option also be greyed out?
I suppose it may be early to ask but speaking of tone mapping has anyone experimented with different roll-off points for 1,000, 4,000 and 10,000 nit mastering levels?
Thanks again!
post #339 of 519 Old 07-23-2019, 01:37 PM
WiFi-Spy's Avatar
Liked: 2148
post #340 of 519 Old 07-23-2019, 01:44 PM
Quoted: 157 Post(s)
Thanks again!
Good luck with that, can't find any recommendation either about that.
A very well kept secret, best to experiment yourself as there is no standard for hdr.
Toto84 is offline
post #341 of 519 Old 07-24-2019, 03:59 PM
Quoted: 157 Post(s)
Hi tyler, this is the dark mode using deitp.
Its still very dark, any suggestion?
Toto84 is offline
post #342 of 519 Old 07-25-2019, 11:28 AM
Guz911's Avatar
Quoted: 18 Post(s)
Originally Posted by Rolls-Royce View Post
Yes.
From looking at the calman workflows i'd say the only method to calibrate DV at the present moment is autocal. HDR is included in the manual calibration workflow but I don't see DV anywhere.
Guz911 is online now
post #343 of 519 Old 07-25-2019, 11:56 AM
Liked: 1246
That's because the previous method used to do manual cals on DV has proven over time not to be consistently reliable. Tyler has mentioned this in an earlier post.
...Royce...
post #344 of 519 Old 07-25-2019, 03:08 PM
Quoted: 4474 Post(s)
Liked: 5488
And incredibly time consuming.
Rolls-Royce likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #345 of 519 Old 07-28-2019, 09:11 AM
Tom Edge's Avatar
Quoted: 17 Post(s)
Re Calman Home (for LG), could somebody confirm, or otherwise, that the Murideo Six-G meter is supported?
It doesn't appear in the drop down menu on source in the evaluation version. Thank you.
Tom Edge is offline
post #346 of 519 Old 07-28-2019, 09:54 AM
Liked: 1246
Some real world stuff may not show up in the evaluation version, which can't use real meters, displays, or pattern sources in any case.
Have you tried looking here: https://store.portrait.com/consumer-...me-for-lg.html
...Royce...
post #347 of 519 Old 07-28-2019, 09:55 AM
Tom Edge's Avatar
Quoted: 17 Post(s)
Real world stuff will not show up in the evaluation version, which can't use real meters, displays, or pattern sources.
It's listed as supported, but I was just running through the evaluation version and wanted to double check. Thank you.
Tom Edge is offline
post #348 of 519 Old 07-28-2019, 11:20 AM
Quoted: 157 Post(s)
Any comment on this?
Toto84 is offline
post #349 of 519 Old 07-28-2019, 11:42 AM
EMINENT1's Avatar
Quoted: 277 Post(s)
Liked: 138
I am also wondering why everyone is dodging our questions about this.
I asked the same thing with no response in the LG oled near black thread too. Like it's some mystery or taboo to talk about it.
Which do we trust.. the black test patterns or the calibration results? And, why are they different?
Is it too much to ask?
Sent from my SM-N960U using Tapatalk
Toto84 likes this.
2016 Vizio P65-C1
2014 Vizio P50-B1E
2011 Vizio E3D420VX
2016 Vizio Smartcast Soundbar 5.1 SB4551-D5, Xbox One S, Roku 3, Mini-itx HTPC w/i7-6700k Plex Server
EMINENT1 is offline
post #350 of 519 Old 07-28-2019, 12:43 PM
Liked: 1246
You guys probably WON'T see 17 or 18. Their luminance is just too close to Black. You can do the math and figure out what they should be based on the gamma target and what Black and White read.
Note that you can see 19...
EMINENT1 likes this.
...Royce...
post #351 of 519 Old 07-28-2019, 01:30 PM
Quoted: 157 Post(s)
So this is normal?
I always heard so you should see until 17 flashing.
Toto84 is offline
post #352 of 519 Old 07-28-2019, 02:05 PM
Liked: 1246
Some TVs never show 17 flashing. If your OLED is one of those with a firmware version that is crushing black, it won't, either.
EMINENT1, jrref and Toto84 like this.
...Royce...
post #353 of 519 Old 07-29-2019, 03:29 AM
Quoted: 157 Post(s)
For calibration for the dark mode would you stick to 100 nits as reference or higher?
Toto84 is offline
post #354 of 519 Old 07-29-2019, 05:16 AM
Liked: 1246
~100 nits would be my personal choice for a dark room environment, unless you cannot get the display to behave and calibrate properly at that level. No need for higher luminance in the dark.
Toto84 likes this.
...Royce...
post #355 of 519 Old 07-29-2019, 02:14 PM
ConnecTEDDD's Avatar
Quoted: 3256 Post(s)
Liked: 4050
These info below will be available to the upcoming LG guide for OLED I will upload to my site soon:
Grade-1 SDR Reference Monitor/TV Calibration Targets
The viewing of accurate images depends on an accurate calibration of the display, control over the viewing environment (lightning and room decor), as well as the appropriate placement of the observer relative to the screen.
The Reference Viewing Environment can be considered one where color critical decisions are made, while the Home Viewing Environment is where finalized deliverables are viewed, with the intent to best match the original artistic intent, as defined by the director and colorist within the Reference Viewing Environment.
The goad of home TV calibration is the Home Viewing Environment to match the Reference Viewing Environment image.
Within the professional industries reference monitors (Grade-1) are the standard for color critical work.
BU TECH 3320 (Version 4.1 - September 2019) - User Requirements for Video Monitors in Television Production, defines the technical characteristics for video broadcast monitors used in a professional TV production environment for evaluation and control of the images being produced.
Its describing the definition of Grade-1 SDR Reference Monitor with Standard Dynamic Range capabilities.
Grade-1 Monitors are devices for high-grade technical quality evaluation of images at key points in a color grading production workflow.
They are used for critical evaluation during post-production.
As a minimum requirement, these monitors shall have the quality properties of the image system they are used to evaluate.
It is expected that all applied technologies are state-of-the-art at this level as the Grade 1 monitor is a 'measuring instrument' for visual evaluation of image quality.
Grade-1 SDR Reference Monitor should be been calibrated and capable to produce a reference luminance level of 100 cd/m2 (nits) for 100% White (235 level @ 8-bit) patch on the screen.
Automatic Brightness Limiter (ABL) functions shall not be used for Grade-1 SDR Reference Monitors, this means that the monitor need to be capable to display 100 cd/m2 with a full field 100% Reference White pattern also.
100% luminance on the screen corresponds to a 10-bit luma signal of digital level 940, and the black level corresponds to a 10-bit luma signal of digital level 64.
100% luminance on the screen is defined as the luminance of a luma signal of digital level 940, but levels 941 through 1019 should also be correctly displayed.
The highest value of 10-bit luma signal is digital level 1019. The luma level 1019 is called 'Super-White' or '109% White'.
For the luminance gamma characteristic (Electro-Optical Transfer Function) of the screen, its recommended that a nominal value of 2.4 gamma to be used.
LG OLED Panel Auto Brightness Limiting (ABL)
But there is an ABL (Auto Brightness Limiter) present at all LG OLED TV's for the purpose of preventing them to consume too much power when displaying content with preponderance of bright elements, and protecting internal components from overheating.
The impact of the ABL, however, is limited to high-APL content such as hockey and winter sports during which can be observed a brightness reduction as the APL increases.
APL is the average level brightness (Luma) of the total numbers of pixel of an video image frame; defined as a percentage of the range between blanking and reference white level.
The LG 2018/2019 OLED TV's are able to reach about 150 cd/m2 on 100% APL using when you will take measurement using an 100% White full field pattern, so there is still some brightness headroom even for high-APL scenes because SDR content is mastered to a 100 cd/m2.
For reference level SDR movie playback for home; for being considered as 'Grade-1'; the TV should display calibrated colors with the color primaries (REC.709 color gamut) and reference white (D65), as specified in the relevant SDR video standard ITU-R BT.709-6 (Parameter values for the HDTV standards for production and international programme exchange - June 2015).
Toto84 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #356 of 519 Old 07-29-2019, 05:11 PM
Quoted: 157 Post(s)
Thank you for sharing your knowledge.
Your help tedd has been tremendous.
Toto84 is offline
post #357 of 519 Old 07-29-2019, 11:26 PM
Liked: 4050
LG OLED Panel Automatic Static Brightness Limiter (ASBL)
LG OLED TV's have a function which we call it in calibration world as ASBL (Automatic Static Brightness Limiter). This function is enabled by default to all OLED's and it will automatically dim the picture when OLED TV will detect that you are displaying static images (like patterns windows during measurements/profiling) after some period of time. ASBL works by detecting APL changes. This function needs to be disabled before taking any measurement because it will affect calibration and panel response. If you like; you can enable it after the end of the calibration, or leave it disabled forever.
To disable that ASBL function ('TCP' is called in Service Menu), you will need to enter to IN-START LG OLED TV Service Menu.
There several methods to access the Service Menu here, or you can buy the LG Service Menu Remote Control from eBay; search for 'MKJ39170828' Remote.
It can be used also the AnyMote App from any SmartPhone equipped with build-in IR transmitter.
Use the IN-START button to access the LG OLED TV Service Menu, it will ask for a password, type '0413', navigate to '13. OLED', and set the TCP to Off.
Its recommended to check if the TCP setting will stay at 'off' after you will install a newer LG OLED TV Firmware Update or when you will perform reset to factory default settings (Reset to Initial Settings).
simistef likes this.
post #358 of 519 Old 07-30-2019, 02:24 AM
Liked: 0
And what about LG nanocell
Hi All,
I recently purchased an X-Rite i1Display Pro colorimeter plus an license for the CalMAN home LG software, to do some calibrating for my LG SM9000 (2019) nanocell television.
Finally there is an affordably solution for the end user, to play with color calibrating
So far most of the topics regarding calman home LG are about calibrating LG's OLED, i want to contribute my findings with the nanocell.
I made several sessions with good results, but also have some questions:
1. Calibrating SDR content
Session setup:
  • Playing the grey screen media file for SDR
  • Energy saving mode: OFF
  • Meter display LCD:LED
  • Windows size: Window 10%
  • Calibration Targets: Default (rec.709/sRGB, Gamma BT.1886 (night), Whitepoint: D65)
  • DeltaE Formula: de_ITP
After pre-cal measurement, i connect to display and select picture mode: Expert Dark, en hit the FULL DCC reset button. And from here i make the calibration steps; luminance, grayscale, colorspace, dynamic range.
At the end i found out that there is an dramatic difference between pre / post calibration. I am not sure there should be so much of an difference?
Screenshot: (look how the blue/red line is of the chart)
Thanks in advance
Herman
Herman_lg_sm9000 is offline
post #359 of 519 Old 07-30-2019, 05:43 AM
Liked: 1246
Thanks in advance
Herman
If your display is not strictly in line with the factory-loaded settings, yes, there could be such a difference. Or if the meter type you used in the CalMAN meter settings was not accurate for your TV...
...Royce...
post #360 of 519 Old 07-30-2019, 07:08 AM
Quoted: 157 Post(s)
Hi Tedd, i calibrate my c9 for a bright room at 200 nits is it sufficient?
For the i1displaypro is the standart exposure mode should be set to 1 or 2 sec?
The low light trigger at 5 or 10 cd2 ?
Thank you
Toto84 is offline
Reply Display Calibration
