CalMAN Home for LG - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 147Likes
post #511 of 520 Old 10-04-2019, 05:43 AM
Liked: 0
Originally Posted by ConnecTEDDD View Post
Originally Posted by f16leon View Post
I used ColorMunki Photo.
You can’t perform a proper calibration with only a spectrophotometer as a stand alone instrument it’s lucking low light accuracy so you can’t really trust it for readings of grayscale below ~30% gray.
You will need to get a colorimeter to use it for all the measurements and to profile it to improve its color accuracy with your spectro.
I'll buy a i1display,and try again.
f16leon is offline
post #512 of 520 Old 10-06-2019, 12:43 PM
thepiecesfit's Avatar
Quoted: 191 Post(s)
Liked: 97
Can anyone help me understand the differences between HD Fury Integral, Integral 2 and Linker for the purposes of calibrating HDR10 and Dolby Vision using Calmans internal pattern generator. I see both discussed interchangeably Linker and Integral. I have an opportunity to pick an Integral up for $100 want to make sure it will do the job.
thepiecesfit is offline
post #513 of 520 Old 10-14-2019, 10:13 AM
Make73's Avatar
Quoted: 129 Post(s)
Liked: 86
I tried also HDR10 autocal.
CalMAN Home for LG (5.10.1.94), LG OLED77C9 (fw 03.60.30)
Name:	CalMAN autocal LG OLEDC9.jpg
Make73 is offline
post #514 of 520 Old 10-14-2019, 02:01 PM
WiFi-Spy's Avatar
Quoted: 1556 Post(s)
Liked: 2157
LG is aware of this TV firmware bug and are working on a fix.
Make73 and LiLAsN like this.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #515 of 520 Old 10-14-2019, 03:00 PM
HiFi4Vision's Avatar
Quoted: 127 Post(s)
Liked: 71
Do you know if the problem has been fixed in the upcoming firmware v04.70.05 ?
KC-Technerd likes this.
HiFi4Vision is offline
post #516 of 520 Old 10-16-2019, 06:30 AM
Make73's Avatar
Quoted: 129 Post(s)
Liked: 86
i1Display Pro Plus, does it work with CalMAN Home for LG and if not, is there plans to add support?
Can´t find OEM rev B from Europe so planned if that would be my next meter.
Make73 is offline
post #517 of 520 Old 10-16-2019, 06:58 AM
Rolls-Royce's Avatar
Quoted: 1155 Post(s)
Liked: 1246
The Plus currently doesn't work with CalMAN, but probably eventually will. Light Illusion sells the rev B OEM meter.
Make73 likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #518 of 520 Old 10-16-2019, 10:18 AM
Make73's Avatar
Quoted: 129 Post(s)
Liked: 86
Since it´s same meter and I´m not interested i1 Profiler, placed order for rev B OEM from Light Illusion.
Thanks for Ted
Make73 is offline
post #519 of 520 Old 10-19-2019, 07:05 PM
Quoted: 127 Post(s)
Liked: 71
Since this version has been officially released now I can answer my own question: the issue still exists.
I tried to measure the luminance of a C64 test video but at least my i1D3 doesn't seem to be able to handle such low light conditions, i.e. my eyes are better than my i1D3 (at least in this specific situation).
Measurements with a C108 test pattern show ~0.06 nits, but I guess that doesn't tell us anything ...
cremor likes this.
post #520 of 520 Old 10-20-2019, 08:42 PM
Liked: 4
Thanks for the update. Pretty much to be expected. Firmware updates need to be vetted in stages and this may take months. Doubt the raised black levels will be fixed on this one. That is why I was really hoping it wasn't on LG's side. Zzz... I'm sure Calman could have fixed it much faster than a company that follows a corporate hierarchy.
Make73 likes this.
LiLAsN is offline
Reply Display Calibration
