CalMAN Home for LG - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1479Likes
post #31 of 2882 Old 05-19-2019, 12:34 PM - Thread Starter
LeRoyK's Avatar
Quoted: 109 Post(s)
Liked: 136
egandt, If your meter is measuring anything other than 0 y for black your brightness setting is too high. Try 50 before you autocal.
LeRoy
LG OLED65C8PUA, Onkyo TX-RZ920, Panasonic DP-UB820, Apple TV 4K, Amazon Fire TV Stick 4K, AT&T Gigabit Internet & U-verse
LeRoyK is offline
post #32 of 2882 Old 05-19-2019, 03:56 PM
WiFi-Spy's Avatar
Quoted: 1975 Post(s)
Liked: 2573
Originally Posted by egandt View Post
Pattern is either madvr (preferred as it does HDR, and most content plays through madvr) or Calman client III (I like being able to select the pattern here for verification), I've tried using both. As for a delay it auto selects 0.25 when I choose optimize, however I normally use 1, as I never remember to do that, these were with 1 as a result.
I tried using no low light handler (normally this is fine except for HDR), I also tried 3 samples for under 1,3, and 5 cd/m all without any difference. I normally use 3 samples under 1 cd/m for HDR work, as I've found this works best, never needed it previously for SDR.
Edit: I noticed something looking and black once it finishes anything from 24 and down is solid black (not 16 and below as expected), leaving be only 28 and 32 so the Brightness is way off, in fact 28 is where I'd normally expect 16 (so by at least 8 to 12), which could possible explain the issue, but does not explain why Autocal set these so very-very low.
ERIC
This is most likely limited vs. full range issue.
Your PC output should be in full range, The TV should be in limited range “black level Low”.
Tyler Pruitt - Technical Evangelist - Portrait Displays/Calman
WiFi-Spy is offline
post #33 of 2882 Old 05-19-2019, 04:11 PM
egandt's Avatar
Quoted: 88 Post(s)
Liked: 32
I think it may have been the video drivers, I updated last night to the latest Nvidia driver, I rolled back the driver to what I'd previously installed, and things went smoother. Could have been reinstalling fixed the range I guess, as both were set to Full range.
While at it this is a great video for SDR.
SDR:
Just wish they had actually posted the HDR. Also wish I'd watched before trying the process the first time.
Edit: Based on this at 3 and 2.3 I have a Black Crush, that I had to manually handle via DDC as per the instructions enclosed, I assume that it an artifact of the 04.10.55 firmware.
ERIC
Current HTPC (of the moment):
i7 7700K (at 4.9GHZ),32GB RAM
GTX 1080 TI (at 2.085Ghz)
Samsung 960Evo and Adaptec 6805T RAID6 (11.3TB)
ERIC
egandt is offline
post #34 of 2882 Old 05-20-2019, 11:08 PM
Liked: 0
Hi everyone
When using HDR Manual Calibration or SDR Manual Calibration, can I run the Saturation Sweeps?
Can the calibration process for the UH610 be completed with the UHD BD player & UHD Test Patterns BD?
Martin Wang is offline
post #35 of 2882 Old 05-21-2019, 08:00 AM
mdamien's Avatar
Quoted: 16 Post(s)
Hey @WiFi-Spy do the HDFury devices work with Calman Home for LG? I have an Integral 2 that I would want to use when doing HDR/DV calibrating.
Thank you!
mdamien is offline
post #36 of 2882 Old 05-21-2019, 08:46 AM
Rolls-Royce's Avatar
Quoted: 1503 Post(s)
Liked: 1597
Thank you!
No reason why they wouldn't. You may not have direct control of the Integral 2 - devices after the original Integral use different APIs - but you can have the Integral 2 GUI open in another window and operate it that way. You can cut and paste the IF strings needed from CalMAN to the Integral 2 GUI.
mdamien likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #37 of 2882 Old 05-21-2019, 10:30 AM
thepiecesfit's Avatar
Quoted: 270 Post(s)
Liked: 143
I'm assuming everyone is testing the beta. I have a LG C8 with i1 Display Pro. Would I be able to use this what kind of pattern generator is needed can anyone throw some more info my way? Thank you
thepiecesfit is offline
post #38 of 2882 Old 05-21-2019, 10:49 AM
Quoted: 295 Post(s)
Liked: 32
So i have done the calibration for isf dark and isf bright on my lg c9 and i am really happy about the result using i1display pro and calman lg home.
Could you share your opinion on those result if you see anything wrong.
Also i find the calibration for hdr and dolby vision extremely difficult.
Is anyone has a tutorial for this?
How do you set the test pattern in the way that when they change you dont see what is playing on your tv and mess up the reading.
What is the correct white point, gamma, color gamut etc for those mode?
Why do we need an external generator to verify the calibration for hdr and dolby vision and is that important?
ID:	2569694   Click image for larger version
Toto84 is offline
post #39 of 2882 Old 05-21-2019, 10:55 AM
Liked: 1597
It's not a beta.
...Royce...
post #40 of 2882 Old 05-21-2019, 11:42 AM
WiFi-Spy's Avatar
Liked: 2573
CalMAN Home for LG
We are current in the process of creating video tutorial videos for CalMAN Home for LG.
The important part you need to be aware of using the internal pattern generator for HDR/DV calibration is that the TV needs to be in HDR or DV mode during the respective calibrations. This can be accomplished in multiple ways.
1. Using an HDMI source device to send the TV HDR10 content during HDR calibration , and Dolby Vision content during the DV calibration.
2. Play HDR10 or DV content via USB stick using TV’s built in media player application durning the respective calibration process. The reason this works is the pattern generator is rendered on top of the media player app or HDMI video. LG has provided 1hr long full screen 15% gray video files in SDR, HDR, and DV video formats for this purpose. You can download them here:
https://calmankb.groovehq.com/help/l...tern-generator
I am also working on a 10hr long SDR version for people that want to do longer than 1hr 3D LUTs.
Tyler
dwaleke, mdamien, jrref and 1 others like this.
WiFi-Spy is offline
post #41 of 2882 Old 05-21-2019, 04:38 PM
Quoted: 295 Post(s)
Liked: 32
Tyler
Thanks for your reply, i managed to do hdr but i am not sure what are the correct target for dolby vision.
Is it rec2020 or p3?
Toto84 is offline
post #42 of 2882 Old 05-21-2019, 05:28 PM
WiFi-Spy's Avatar
Liked: 2573
The workflow sets that automatically for you.
WiFi-Spy is offline
post #43 of 2882 Old 05-22-2019, 03:11 AM
Quoted: 295 Post(s)
Liked: 32
Can you please confirm what the gamma should be set as for hdr and dolby vision on the lg c9.
Thanks for your help
Toto84 is offline
post #44 of 2882 Old 05-22-2019, 04:55 AM
Quoted: 5346 Post(s)
Liked: 6550
2.2 but the workflow should set it up automatically for you.
John
Sony 55A1E, A9F, LG CX
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, LightSpace Pro, ISF Level III Certified
jrref is offline
post #45 of 2882 Old 05-22-2019, 05:58 AM
mdamien's Avatar
Quoted: 16 Post(s)
Got it, thank you!
mdamien is offline
post #46 of 2882 Old 05-22-2019, 06:34 AM
Quoted: 89 Post(s)
Tyler
that's how i calibrated mine
but these gray videos are 1 hr long but sometimes calibration goes to hr 34mns+
still can't calibrate DV since it gave me green screen
i'm looking forward to your videos.
LG 65 C9 OLED Display
Oppo UDP-203 UHD Blu-ray Player (49-XXXX MODIFIED )
Home Theater 7.1.4 with yamaha RX3070
4klover is offline
post #47 of 2882 Old 05-22-2019, 07:00 AM
WiFi-Spy's Avatar
Liked: 2573
If you got the Dolby Vision green screen then that means you need to update your TV firmware. You might have to download it directly from LG’s website on your computer and load it with a thumb drive.
Rolls-Royce and 4klover like this.
WiFi-Spy is offline
post #48 of 2882 Old 05-22-2019, 07:47 AM
Quoted: 89 Post(s)
thanks for that
i see there's a new firmware update
will update today
WiFi-Spy likes this.
4klover is offline
post #49 of 2882 Old 05-22-2019, 04:42 PM
Quoted: 295 Post(s)
Liked: 32
I measure the peak luminance on hdr game mode at 580 nit !
730 hdr cinema.
Is that normal?
Toto84 is offline
post #50 of 2882 Old 05-22-2019, 06:13 PM
egandt's Avatar
Quoted: 88 Post(s)
Liked: 32
C8 HDR Post calibration, serious loss of details towards black and everything is very-very red. Simply put calibrating using the LG HDR work flow for Technicolor HDR, everything looked good in Calman, but the result is un-viewable, seriously crushed blacks and a massive red tint to everything (in fact uncalibrated game mode is far better), which is surprising as the results are decent for the post calibration check (see attached).
Attached are screenshots of the workflow in calman.
It is hard to get images of the result (tends to brighten up the image from what is really seen) as the cell phone camera is less than perfect, but I tried to get some examples and there included as well.
ERIC
ID:	2570364   Click image for larger version
ID:	2570366   Click image for larger version
ID:	2570368   Click image for larger version
ID:	2570370   Click image for larger version
ID:	2570374   Click image for larger version
ID:	2570376   Click image for larger version
ID:	2570386   Click image for larger version
ID:	2570388   Click image for larger version
ERIC
egandt is offline
post #51 of 2882 Old 05-22-2019, 07:37 PM
WiFi-Spy's Avatar
Liked: 2573
CalMAN Home for LG
ERIC
Has to be a levels is mismatch somewhere with regards to MadVR as the pattern generator. How is the PC output configured? Full range? We have never tested madVR for HDR in house. I can see if I can set up a machine with an Nvidia card and madVR as a pattern generator.
If you use the generic HDR10 workflow to just measure uncalibrated HDR Cinema mode using MadVR as the pattern generator, What do the grayscale and color checker look like? Make sure you’re not connected to the TV has a display.
WiFi-Spy is offline
post #52 of 2882 Old 05-23-2019, 05:09 AM
egandt's Avatar
Quoted: 88 Post(s)
Liked: 32
Yes I'm full range, I selected Madvr as that is what I use to display most conent and figure matching would be best, seems to work well for SDR.
I also have a Vertex, would you suggest using the CalMAN PC patterns and forcing HDR via the Vertex in place of using the madvr for calibrating HDR then?
ERIC
ERIC
egandt is offline
post #53 of 2882 Old 05-23-2019, 09:16 AM
WiFi-Spy's Avatar
Liked: 2573
ERIC
Give me a day or two to get this PC w/ Nvidia GPU and MadVR set up connected to a 2018 LG C8. I will figure out what is the correct configuration with regards to range for the Autocal to work correctly.
You might need to calibrate in limited range and then change the TV to full range after. That is what our professional Hollywood users are doing when they need the LG to be in full range.
Tyler
mdamien likes this.
WiFi-Spy is offline
post #54 of 2882 Old 05-23-2019, 10:43 AM
mdamien's Avatar
Quoted: 16 Post(s)
Tyler
I look forward to seeing what you come back with as that chain will be similar to what I will be using to calibrate my C8.
mdamien is offline
post #55 of 2882 Old 05-24-2019, 07:14 AM
Quoted: 89 Post(s)
is the tutorial still coming ?
i calibrated DV then HDR is now fked LOL
4klover is offline
post #56 of 2882 Old 05-24-2019, 09:19 AM
Quoted: 270 Post(s)
Liked: 143
Assuming one can get their hands on a pattern generator like the Spectracal VideoForge PRO, what kind of results can one expect with a budget meter like i1 Display Pro using the LG Autocal? Would it be able to handle DV and HDR10 as well? The equipment is a lot of money but sometimes pops up used.
HT: LG C8 65" | Denon X4440H | Left/Right: Polk LSiM 705 (2) | Center: Polk LSiM 706c | Rears: Polk FXi A4 (2) | Sub: Rhytmik E15HP | Amp: Outlaw 2200 (3)
post #57 of 2882 Old 05-24-2019, 09:31 AM
Quoted: 89 Post(s)
The c9 has a pattern generator
You just need to load up the hdr and DV files through a USB and the i1 display will do the job for you.
4klover is offline
post #58 of 2882 Old 05-24-2019, 09:33 AM
Quoted: 270 Post(s)
Liked: 143
My TV is a LG C8. Maybe LG will feel sorry for us and give us one as well one day
mrtickleuk likes this.
post #59 of 2882 Old 05-24-2019, 11:27 AM
aflscott's Avatar
Quoted: 21 Post(s)
Liked: 47
Picked up CalMAN Home for LG last night. This will be handy to have. No questions yet as I won't be able to try it out for a couple of weeks. I had my C9 professionally calibrated, but they didn't do HDR or Dolby Vision so that's what I'm after with this.
Any idea on the ETA for the videos? They'd be really useful.
Scott
I own an LG 65" C9. I'm thrilled with it.
aflscott is offline
post #60 of 2882 Old 05-24-2019, 01:46 PM
rswood's Avatar
Quoted: 46 Post(s)
I am recording tutorial videos for CalMAN Home for LG this week. It will probably take a week after that to do all the post production.
I will be covering calibrating SDR/HDR/Dolby Vision on a 2019 LG C9.
Tyler, I am using C6 2000 meter LG C8 TV and spectracal mobile forge for source. I notice when I use RGB output on the Mobile forge fire stick 4K. the color points for the secondary colors are reported way away from standard or normal then if I use YCBCR. I did not have this problem when I used the Calman Enthusiast.
Do you know of this issue? What is the recommended output for my setup.
I have seen recommendations to use RGB output because it is bit perfect and YCBcR output for fire stick 4k is not.
rswood is offline
Reply Display Calibration
