CalMAN Home for LG - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 145Likes
post #61 of 518 Old 05-24-2019, 01:46 PM
rswood's Avatar
Quoted: 46 Post(s)
Originally Posted by WiFi-Spy View Post
I am recording tutorial videos for CalMAN Home for LG this week. It will probably take a week after that to do all the post production.
I will be covering calibrating SDR/HDR/Dolby Vision on a 2019 LG C9.
Tyler, I am using C6 2000 meter LG C8 TV and spectracal mobile forge for source. I notice when I use RGB output on the Mobile forge fire stick 4K. the color points for the secondary colors are reported way away from standard or normal then if I use YCBCR. I did not have this problem when I used the Calman Enthusiast.
Do you know of this issue? What is the recommended output for my setup.
I have seen recommendations to use RGB output because it is bit perfect and YCBcR output for fire stick 4k is not.
rswood is offline
post #62 of 518 Old 05-24-2019, 05:09 PM
WiFi-Spy's Avatar
Quoted: 1549 Post(s)
Liked: 2148
We have never actually tested the fire stick 4K. It might be doing something weird like always being in 2020 color or something.
We are working on documentation on how to set up your PC HDMI output proper calibration of 2018 LG TVs for SDR.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #63 of 518 Old 05-24-2019, 05:11 PM
WiFi-Spy's Avatar
Liked: 2148
CalMAN Home for LG
It looks like we left some instructions out of the LG autoCAL workflow for HDR and Dolby Vision, if you have a 2019 TV and are using the internal pattern generator.
The proper instructions will be added in the beta release of CalMAN 2019 R2 (Release 2).
You need to select the correct pattern color space if you are doing HDR or Dolby Vision calibration.
Here is a screenshot of the setting.
WiFi-Spy is offline
post #64 of 518 Old 05-24-2019, 07:01 PM
Quoted: 77 Post(s)
Hey guys
Do I have to do a full ddc reset everytime ?
Like if I want to do SDR DV HDR. Doesn't that reset previous picture settings?
Or it's something I need to do once.
LG 65 C9 OLED Display
Oppo UDP-203 UHD Blu-ray Player (49-XXXX MODIFIED )
Home Theater 7.1.4 with yamaha RX3070
4klover is offline
post #65 of 518 Old 05-25-2019, 05:35 AM
Quoted: 4474 Post(s)
Liked: 5487
Originally Posted by 4klover View Post
Hey guys
You have to DDC reset every picture mode you are calibrating and yes it will reset a previous calibration for that picture mode.
4klover likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #66 of 518 Old 05-25-2019, 05:45 AM
Quoted: 77 Post(s)
So if I calibrate cinema, I did hdr cinema. do I do that ddc reset for dolby vision cinema and cinema SDR too? Or only once is fine.
That's why I'm so confused lol
4klover is offline
post #67 of 518 Old 05-25-2019, 05:54 AM
Wjboshart's Avatar
Quoted: 1355 Post(s)
Liked: 1323
Every profile is separate. So if you want to calibrate sdr cinema you will do ddc reset for that. If you want to do hdr cinema, you reset that. If you want to do dv cinema, you do that
4klover likes this.
Wjboshart is offline
post #68 of 518 Old 05-25-2019, 05:59 AM
Quoted: 77 Post(s)
Haha thanks.
I figured that much.
4klover is offline
post #69 of 518 Old 05-25-2019, 06:44 AM
Quoted: 157 Post(s)
Is there anyways to keep the test pattern on the screen longer when finding out the peak luminance for hdr as it does not stay on the screen long enough?
I found my lg c9 using the internal test patten at 730 nits for hdr.
What about yours?
Toto84 is offline
post #70 of 518 Old 05-25-2019, 07:11 AM
Liked: 5487
What about yours?
Anywhere from 700-780 nits is "typical". Some panels are a little brighter and some a little less brighter but it's not significant since your eyes can't see the difference unless the sets were side by side. One of the major reasons why this is, is because you are calibrating the panel from it's native 10K to 6500K(D65) and some sets need more or less adjustments to get there and some panels natively have some variances in peak luminance.
chunon likes this.
John
jrref is online now
post #71 of 518 Old 05-25-2019, 12:37 PM
Quoted: 157 Post(s)
What about yours?
Thanks Sir for sharing all your knowledge.
Is the i1 display pro good enough for tracking Hdr peak luminance ?
Also when measuring peak luminance for hdr the internal pattern doesnt stay long enough, any tips to adjust this?
Does it it matter if i cant verify the calibration in hdr or dolby vision as i dont have an external pattern generator?
Could you guys explain hoe to cali rate dolby vision as i dont understand as i have to create some file for the color..
Perhaps do you guys have a cheap solution for this.
Toto84 is offline
post #72 of 518 Old 05-25-2019, 12:42 PM
Rolls-Royce's Avatar
Quoted: 1153 Post(s)
Liked: 1245
The I1 Display Pro is plenty good enough.
You really don't want the max luminance patterns displayed very long, in order to keep the display's brightness limiters from kicking in and to avoid burn-in.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #73 of 518 Old 05-25-2019, 01:14 PM
rswood's Avatar
Quoted: 46 Post(s)
The only new feature to my setup is the 2019 LG Home program. I did not have this problem with the CalMAN enthusiast. So since it is the new ingredient to the package one would surmise through the process of elimination that the problem resolves in the LG Home program.
Thank you for your response.
rswood is offline
post #74 of 518 Old 05-25-2019, 02:34 PM
rswood's Avatar
Quoted: 46 Post(s)
rswood is offline
post #75 of 518 Old 05-25-2019, 03:03 PM
WiFi-Spy's Avatar
Liked: 2148
Nothing has changed in the MobileForge code In at least a year and a half or two years. The implementation in CalMAN Home and Home Enthusiast is exactly the same.
WiFi-Spy is offline
post #76 of 518 Old 05-26-2019, 11:45 AM
Quoted: 157 Post(s)
Hi Guys,
Could you please explain the step to use the xrite i1display pro with i1pro2 together?
Just to confirm when calibrating with calman for hdr brightness and contrast should be left at 100?
Thank you so much for your help
Toto84 is offline
post #77 of 518 Old 05-26-2019, 11:09 PM
thepiecesfit's Avatar
Quoted: 191 Post(s)
Liked: 97
Forgive me but can anyone confirm if MobileForge supports Calman LG Autocal in any capacity? SDR, HDR or Dolby Vision? Thanks
thepiecesfit is offline
post #78 of 518 Old 05-27-2019, 04:50 AM
Liked: 2
Hi,
What hdfury i need to buy in order to calibrate HDR on my LGC8?
I found integral 4K60 4:2:0 300 hz. Is this enough?
tony_bcc is offline
post #79 of 518 Old 05-27-2019, 06:28 AM
Liked: 1245
Originally Posted by tony_bcc View Post
Hi,
That will be fine. Since it is not producing a test pattern, but only injecting HDR metadata into an SDR RGB test pattern you will be sending to the TV, 300 MHz is sufficient. Be advised, unless CalMAN has corrected the USB driver problem that stopped it from directly controlling the Integral, you will have to copy and paste the needed HDR IF strings from CalMAN to the Integral GUI, which you can have open at the same time.
...Royce...
post #80 of 518 Old 05-27-2019, 06:34 AM
Liked: 2
@Rolls-Royce
Thank you. Maybe someone else can confirm if that is fixed.
tony_bcc is offline
post #81 of 518 Old 05-27-2019, 06:40 AM
Liked: 1245
Several days ago, Tyler stated that they were working on it, but there has been no update about it from him since. They may be waiting on a revised driver from the provider.
...Royce...
post #82 of 518 Old 05-27-2019, 08:55 AM
Quoted: 77 Post(s)
Is the tutorial still coming
I think I got the hand of it
But still would like to see the tutorial
4klover is offline
post #83 of 518 Old 05-27-2019, 08:58 AM
keyoctave's Avatar
Quoted: 76 Post(s)
Liked: 51
Following the line of questions about the Fury, what about the HDfury Intergral 4K 60 4:4:4 600MHz model? Does Calman control it or do you have to copy and paste as well?
LG 55”C8 OLED Oppo BDP-103 Sony X800m2
Denon X3300W 5.2.2 PSB/M&K speakers
Samsung 55HU8550/SEK-3500U
Sonos 5.1 Playbase/sub/surrounds
CalMAN Home Enthusiast/i1display pro oem/i1 pro 2/Videoforge HDMI-2 TPG
keyoctave is offline
post #84 of 518 Old 05-27-2019, 09:15 AM
Liked: 1245
It's still an Integral 1 despite the frequency boost, and the same caveats apply.
...Royce...
post #85 of 518 Old 05-27-2019, 09:41 AM
keyoctave's Avatar
Quoted: 76 Post(s)
Liked: 51
Thank you
post #86 of 518 Old 05-28-2019, 12:57 AM
Liked: 2
One more question. Is there alternative to HDfury?
tony_bcc is offline
post #87 of 518 Old 05-28-2019, 01:24 AM
Liked: 2
tony_bcc is offline
post #88 of 518 Old 05-28-2019, 01:43 AM
Liked: 2
Using autocal on firmware 04.10.31 and 04.10.55, would the result be any different?
Also, I tried sRGB as tone curve for sdr calibration, but it seems autocal didn't handle it properly and the shadow detail of the image went all messed up. I am not sure what was going on there.
2 Deco is offline
post #89 of 518 Old 05-28-2019, 02:12 AM
Liked: 2
sorry, I meant 04.10.15 and 04.10.31/04.10.55 on LG C8
2 Deco is offline
post #90 of 518 Old 05-28-2019, 09:19 AM
WiFi-Spy's Avatar
Liked: 2148
We recommend 2.2 gamma for day mode and 2.4 gamma for night mode. sRGB gamma is not appropriate for a TV.
WiFi-Spy is offline
Reply Display Calibration
