CalMAN Home for LG - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 475Likes
post #991 of 1158 Old 01-08-2020, 08:58 AM
Rolls-Royce's Avatar
Quoted: 1290 Post(s)
Liked: 1370
Originally Posted by grizzledyoungman View Post
Just checking in on this again, as the issue specifically affects my setup. Has there been any progress on testing the fixed grid LUT mode with i1 Display Pro/i1D3? Has anyone successfully used the fixed grid LUT mode with a retail rev B i1 Display Pro/i1D3 and seen an improvement over lightning LUT? Or is the issue widespread?
See Tyler's post #966 above...
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #992 of 1158 Old 01-08-2020, 10:52 AM
SamuriHL's Avatar
Quoted: 238 Post(s)
Liked: 290
Originally Posted by liberator72 View Post
It will be written on the counter weight, but if you got it in November you can assume it probably is.
I'll check it when I get home Saturday. Thanks
Sent from my Pixel 3a using Tapatalk
LG C8 OLED | Pioneer VSX-LX303 | HTPC (9900k, RTX 2070) | nVidia SHIELD 2019 | Panasonic UB820
SamuriHL is offline
post #993 of 1158 Old 01-08-2020, 12:00 PM
grizzledyoungman's Avatar
Quoted: 72 Post(s)
Ah, I didn't realize that enabling AIO is the fix for the fixed point LUT/i1D3. So the summary is that fixed point LUT doesn't work with i1D3 until a new revision? Tyler, can you confirm?
grizzledyoungman is offline
post #994 of 1158 Old 01-08-2020, 01:35 PM
mrtickleuk's Avatar
Quoted: 5397 Post(s)
Liked: 7795
AIO is "All-In-One". It's a sync mode only available within Rev. B I1D3s. CalMAN has been using their own custom meter drivers that don't invoke it.
Which of these modes does calman currently use? I can choose On, Off, or Auto.
I don't get to select sync:
Frequency Mode/CRT,
Period Mode/LCD,
Burst Mode/Plasma/OLED
and obviously not AIO.
Which of those first three does "on/off/Auto" affect?
Hmm, that summary isn't quite as clear cut as I see it. It may not be "the fix" but it is something which is very good to have anyway, and it seems to help an awful lot. We will have to look out for the (shark) Fins in Finland when it's released.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #995 of 1158 Old 01-08-2020, 02:22 PM
Liked: 1370
Frequency Mode/CRT,
Period Mode/LCD,
I haven't the foggiest, Mike. But if I had to hazard a guess, I'd say really "none of the above". AIO was introduced by XRite with Rev B meters, while CalMAN has had the on/off/auto routine for longer and it works with Rev A meters. They use their own custom meter drivers along with the EDRs from the SDK. If they are considering the introduction of AIO mode a potential fix, then wouldn't you think they probably aren't using it, but have been relying instead on the routines in their custom drivers?
mrtickleuk likes this.
...Royce...
post #996 of 1158 Old 01-08-2020, 08:19 PM
SamuriHL's Avatar
Quoted: 238 Post(s)
Liked: 290
Sync on doesn't work for my meter. I let Tyler know about that problem before I went on vacation. It errors when I enable it. Again don't know my revision until I get home in a few days but I just bought it in November.
Sent from my SM-G975U using Tapatalk
SamuriHL is offline
post #997 of 1158 Old 01-08-2020, 09:22 PM
Make73's Avatar
Quoted: 225 Post(s)
Liked: 155
No more beta testing by me.
Shark fins are gone and AIO mode on.
Warmly recommended also for others who struggle with CalMAN.
Name:	LS probe options.jpg
Make73 is offline
post #998 of 1158 Old 01-09-2020, 09:19 AM
lujan's Avatar
Quoted: 4889 Post(s)
Liked: 2892
After about a week after doing my dark room calibration and having no problems, I decided to try the bright room calibrations. Last night I started with SDR and Expert bright room and went through the steps according to Tyler's video and only changing the Picture mode and the Gamma to 2.2 from 2.4. It didn't work correctly where the video now looked red and overexposed. I had to do a "reset" since it obviously didn't work right. Does anyone know what might have gone wrong and I needed to make other changes?
lujan
608 Ultra HD
723 HD
4 SD
lujan is offline
post #999 of 1158 Old 01-09-2020, 09:59 AM
Quoted: 4754 Post(s)
Liked: 5732
Make sure you have the pattern insertion set to 30/5/15 with your meter.
John
Sony 55A1E, A9F
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, LS Pro, ISF Level III Certified
jrref is offline
post #1000 of 1158 Old 01-09-2020, 10:23 AM
lujan's Avatar
Liked: 2892
Do I need to also change the pattern insertion when doing "Cinema Home" rather than "Cinema" picture mode for HDR and DV?
lujan
608 Ultra HD
723 HD
4 SD
lujan is offline
post #1001 of 1158 Old 01-09-2020, 11:49 AM
mrtickleuk's Avatar
Liked: 7795
Woah. Yes, but if you are doing any form of HDR (either HDR10/HLG, or Dolby Vision), then the pattern insertion numbers are completely different. Can't remember off hand, you can look them up, but it's way more often than 30 seconds. If you used the SDR values you have huge image retention risk and you'll get a bad result.
lujan and jrref like this.
_______________
post #1002 of 1158 Old 01-09-2020, 01:17 PM
Liked: 5732
5/5/15 for HDR
John
Sony 55A1E, A9F
jrref is offline
post #1003 of 1158 Old 01-09-2020, 06:09 PM
SamuriHL's Avatar
Quoted: 238 Post(s)
Liked: 290
I use 5/5/0 for hdr and 30/5/0 for sdr.
SamuriHL is offline
post #1004 of 1158 Old 01-09-2020, 06:17 PM
WiFi-Spy's Avatar
Quoted: 1724 Post(s)
Liked: 2317
New HDMI signal override menu for 2020 LG TVs.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #1005 of 1158 Old 01-09-2020, 11:37 PM
venkatesh_m's Avatar
Quoted: 89 Post(s)
Liked: 54
Will this allow SDR2020 Power Gamma 2.4 so that we can use Dynamic Tone Mapping from an external source like Lumagen?
Sent from my VOG-L29 using Tapatalk
venkatesh_m is online now
post #1006 of 1158 Old 01-10-2020, 03:03 AM
lujan's Avatar
Liked: 2892
5/5/15 for HDR
Who knows which one to use? I made the change to the 30/5/15 and the color space calibration was taking so long that I stopped it after around 35 - 45 minutes. I looks good after this 2nd attempt with SDR "Expert Bright". I also got an email back from Portrait Displays:
"My name is Mackenzie, and I work on the Portrait Displays support team.
We've had a few reports of this behavior, specifically with the expert bright mode. We are investigating the cause, but until we can identify what's going on I would avoid calibration of the expert bright mode".
lujan
608 Ultra HD
723 HD
4 SD
lujan is offline
post #1007 of 1158 Old 01-10-2020, 08:36 AM
strawberry's Avatar
Quoted: 173 Post(s)
Liked: 382
You're not going to see an earth shattering difference either way. The interval is the more important variable than the stimulus level, IMO.
strawberry is offline
post #1008 of 1158 Old 01-10-2020, 09:04 AM
Quoted: 72 Post(s)
We have offered you a refund which you have refused.
It looks like most issues people are having are i1 Display Pro related and will be fixed when we add AIO mode. People that are using professional meters or the C6 are not having issues.
Two of the top calibrators in Hollywood are now using the CalMAN fixed grid LUT method, with excellent results.
Tyler - can you confirm that the C6 meter is unaffected by the fixed grid LUT bug? I'm considering getting one secondhand and want to confirm that it would address the issues present with retail i1D3.
Additionally, is custom meter profiling still recommended with the C6?
post #1009 of 1158 Old 01-10-2020, 02:16 PM
WiFi-Spy's Avatar
Liked: 2317
The C6 uses a custom driver for dynamic meter integration time, as compared to the fixed integration times on the i1 display pro.
WiFi-Spy is offline
post #1010 of 1158 Old 01-10-2020, 08:52 PM
Liked: 5732
You will need to experiment. Try both ways and see which works better for you.
John
Sony 55A1E, A9F
jrref is offline
post #1011 of 1158 Old 01-12-2020, 03:56 PM
SamuriHL's Avatar
Quoted: 238 Post(s)
Liked: 290
MFG date is 10/19 and it says Rev B.2 right on it, so, that's fantastic. Now....about that AIO update.
SamuriHL is offline
post #1012 of 1158 Old 01-12-2020, 05:37 PM
WiFi-Spy's Avatar
Liked: 2317
You might want to try changing your low light handler to 3 measurements instead of 1 long reading.
SamuriHL and mrtickleuk like this.
WiFi-Spy is offline
post #1013 of 1158 Old 01-12-2020, 05:55 PM
SamuriHL's Avatar
Quoted: 238 Post(s)
Liked: 290
Thanks! I'll give that a try.
EDIT: Wait, how do I do that? I only see options to enable LLH and give a time of X seconds. Unless I'm misreading what you're saying, you're suggesting to give it 3 measurements instead of X seconds?
SamuriHL is offline
post #1014 of 1158 Old 01-13-2020, 02:33 PM
mrtickleuk's Avatar
Liked: 7795
Yes that is the suggestion.
For the "how" - look more closely. You say you can only see the times. Can't you see the second one in the list, that says "3 samples"? Use that one!
The options in the top half of the list take multiple readings, and then use the average.
_______________
post #1015 of 1158 Old 01-13-2020, 02:48 PM
SamuriHL's Avatar
Quoted: 238 Post(s)
Liked: 290
Nope. I'm on the Calman Home for LG version, and that's not an option for me.
SamuriHL is offline
post #1016 of 1158 Old 01-13-2020, 03:52 PM
mrtickleuk's Avatar
Liked: 7795
Ah right, in that case I understand your confusion. Over to @WiFi-Spy !
SamuriHL likes this.
_______________
post #1017 of 1158 Old 01-13-2020, 05:25 PM
WiFi-Spy's Avatar
Liked: 2317
CalMAN Home for LG
Sorry for the confusion, that is not available on the i1 display pro currently in CalMAN. I will put in a feature request for that.
WiFi-Spy is offline
post #1018 of 1158 Old 01-13-2020, 05:26 PM
SamuriHL's Avatar
Quoted: 238 Post(s)
Liked: 290
Sorry for the confusion, that is not available on the i1 display pro. I will put in a feature request for that.
Great! Looking forward to it. Thanks!
SamuriHL is offline
post #1019 of 1158 Old 01-14-2020, 10:53 AM
lujan's Avatar
Liked: 2892
What changes exactly are made to the C9 after doing a calibration with Calman Home for LG?
lujan
608 Ultra HD
723 HD
4 SD
lujan is offline
post #1020 of 1158 Old 01-14-2020, 10:43 PM
Quoted: 72 Post(s)
Tyler - I could use some help here after a completely disastrous experience last night with new version of Calman Home. After successful calibration attempts in the past, I was trying the new features, especially the fixed grid LUT and meter profiling my retail i1D3 with an i1 Studio.
Profiling went uneventfully, despite the meager documentation. But calibration failed. The fixed grid LUT produced a wildly unusable calibration - pink and strange and posterized badly.
I retried calibration using settings I was familiar with - the same settings that worked well enough last time I calibrated on the previous version - and each time Calman would crash while computing the results of the Lightning LUT mode. Now my SDR daytime mode is basically unusable Rebooting/powercycling both the display and my PC didn't help.
Any thoughts? Again, the crashes occurred using the same calibration settings/modes that had worked on the older revision. Only changes were updating to the new version of Calman Home, using a profiled meter and a custom white point of x0.0309 y0.3290 instead of D65.
Reply Display Calibration
