CalMAN Home for LG - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 84Likes
post #151 of 299 Old 06-12-2019, 01:28 PM
WiFi-Spy's Avatar
Quoted: 1367 Post(s)
Liked: 2021
Originally Posted by Toto84 View Post
I have done the calibrationndoing the deitp formula unfortunetly i still have a little bit of black crush. I cant see the 18 or 17 flashing.
Any other ways to get rid of this?
I guess that raising brightness will mess up the calibration?
Do you have the LLH enabled for the i1 display pro?
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
post #152 of 299 Old 06-12-2019, 02:38 PM
Quoted: 118 Post(s)
Liked: 7
Hi Tyler, yes i did
Toto84 is online now
post #153 of 299 Old 06-12-2019, 02:45 PM
Quoted: 118 Post(s)
Liked: 7
See the attached pictured, is all the setting correct ?
post #154 of 299 Old 06-12-2019, 07:40 PM
WiFi-Spy's Avatar
Liked: 2021
Everything looks fine on your configuration.
I will have to test our C9 on Monday.
post #155 of 299 Old 06-12-2019, 09:12 PM
Liked: 2
I am using an i1d3 rev b retail version colorimeter.
With the sync mode on, my i1d3 can read very low light level until 0.002 nit, but when measuring 0% black, calman will say there is a read sync error and then force stopping all the measuring immediately, which makes it impossible to do an autocal with the sync mode on.
With the sync mode set to auto, my i1d3 cannot measure any level under 0.009 nit, it will only send back 0.333, 0.333, 0 in these levels.
And there is no way to change the sync mode when the autocal process is ongoing. I don't know but why not add a pause/resume function in autocal process? So that we can check or adjust some settings during autocal and don't need to start over when done; so that I can set the sync mode to auto at start and then change it to on when measuring near black levels.
2 Deco is offline
post #156 of 299 Old 06-13-2019, 12:37 AM
Liked: 4
Hi,
I have a 55C8 panel and I'm trying to calibrate it using Autocal for LG. I have a Surface Pro first gen wich runs Autocal for LG and an Nvidia shield TV as a pattern generator with Mobile forge installed. I would like to know which settings I have to use with the Shield tv because I have noticed a huge discrepancy in picture compared to the tv, after calibration. In short, using Plex as media player, the same video looks brighter and less contrasted running on the Nvidia Shield tv while is darker using Plex on the tv. I have used the auto settings on the nvidia shield tv and I was thinking that maybe using rec709 8bit could be more accurate.
I would also like to know if there will be an update for Mobile forge with HDR and Dolby Vision patterns.
In my opinion Autocal for LG is a great tool but is useless if you have to spend a lot of more money to get a proper pattern generator.
peppebi is offline
post #157 of 299 Old 06-13-2019, 05:47 AM
Rolls-Royce's Avatar
Quoted: 1048 Post(s)
Liked: 1173
As X-Rite's own specs say, the minimum luminance level the I1D3 is certified to is 0.1 cd/m. It's possible that your 0.002 is not truly an accurate reading, as it is 50 times lower than X-Rite certifies this meter for. You may be better off setting sync to auto and a workflow preferences fixed black level of 0.0 for your OLED if your license level allows it. In my own experience, sync errors manifest themselves during autocal as readings "stuck" at a certain point with wild swings in Red and Blue on each read.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #158 of 299 Old 06-13-2019, 09:31 PM
Liked: 2
sorry I meant 0.02 and 0.09. My license is calman home LG, it allows me to set the black level to 0 but in autocal it will still do the initial reading which reads the 0% black.
2 Deco is offline
post #159 of 299 Old 06-14-2019, 05:33 AM
Liked: 1173
Looks like the readings sequence doesn't change. It shouldn't use that number in gamma calculations, though. Regardless of whether it does or doesn't, the goal is to keep the readings from hanging up, since you can't complete the calibration when it does. Switching away from sync mode "On" appears to be your best bet despite the higher readings in black.
...Royce...
post #160 of 299 Old 06-14-2019, 08:29 AM
Liked: 0
Guys,
can you set something straight for me? I just heard that using hdfury messing up with hdr calibration. It this true or not. If so then what was the point to release movie about hdfury on YouTube and prepare guide how to connect and control it? I’m super confused now. It looks like Calman. Try to sell their own pattern generator instead going to cheap solution. I bought tv for 1500 and will not pay another 1500 for pattern generator plus colorimeter plus soft. It is getting ridiculous. I start question whole calibration thing after this kind of things.
tony_bcc is online now
post #161 of 299 Old 06-14-2019, 09:23 AM
Liked: 1173
Originally Posted by tony_bcc View Post
Guys,
In what way is it "messing up"? I've used mine several times in the past for HDR manual calibration, with never an issue.
...Royce...
post #162 of 299 Old 06-14-2019, 09:33 AM
Liked: 0
I don't know. I got that reply from Calman and I feel it is just stupid way of selling their hardware. I have email but I don’t want to release it yet.
It basically says that using hdfury messing up calibration and they don’t support hdfury.
post #163 of 299 Old 06-14-2019, 09:46 AM
Liked: 0
Original answer from Calman
post #164 of 299 Old 06-14-2019, 11:40 AM
Liked: 1173
The "data" he's referring to is the metadata that must be there for HDR. Even their recommended pattern generators include it, so that's a disingenuous answer. CalMAN still includes the selection for the HDFury in their Source tab, and the reason that the Integral stopped working with it is that Spectracal/Portrait changed to a different version of the USB driver the Integral uses in order to add support for another brand of spectro. Having said that, there are some things that one needs to know when using the Integral with a pattern generator. For one, the generator must be set to output RGB Full. No pattern generators until recently (and even now only the $$$$ ones) can produce the correct YCbCr for HDR. The math needed for the transform is completely different from that needed for SDR. RGB, however, is essentially the same for SDR and HDR. But if your display handles RGB differently from YCbCr, and some do, that could be an issue for you.
...Royce...
post #165 of 299 Old 06-14-2019, 11:53 AM
Liked: 0
@Rolls-Royce thank you. I will keep that in mind. But I need to understand it. As long as I set it to RGB I’m ok ?
post #166 of 299 Old 06-14-2019, 12:32 PM
Liked: 0
In this move https://youtu.be/Gp_MYTkMSDA Tyler is changing from RGB to YCbCR. Now I’m even more confused.
post #167 of 299 Old 06-14-2019, 01:55 PM
Liked: 1173
That was from 2016. I'm not sure that it was even widely known then that there was a difference in SDR and HDR YCbCr.
In the later HDFury Integral Quick Setup guide versions 1.2 and 1.4, RGB is specifically shown in both the Integral GUI and the Source tab for the Integral. This was after direct control of the Integral was added to CalMAN and the AVTop Controller was no longer needed.
As they gained experience with the sets, Spectracal/Portrait have changed their recommendations for pre-autocal setup on the 2016 Samsungs at least once, so it's possible that their recommendations for the color format to use when calibrating HDR with an SDR pattern generator and an Integral have changed since that video as well.
...Royce...
post #168 of 299 Old 06-16-2019, 10:38 AM
Quoted: 118 Post(s)
Liked: 7
Hi Guys i am using the i1display pro profile by i1pro 2.
Is everything you see on those picture on the correct setting?
Is the meter exposures correct for the i1didplay?
When you foing the grsyscale multipoint, what is the meaning of rolling?
ID:	2580752   Click image for larger version
ID:	2580754   Click image for larger version
ID:	2580756   Click image for larger version
post #169 of 299 Old 06-17-2019, 10:41 AM
Liked: 0
Hi, thx to all of you guys I was able to to finish my first HDR calibration. Today I bought videoforge II. Is 2nd ver. Capable of Dolby Vision?
post #170 of 299 Old 06-18-2019, 06:12 AM
Quoted: 118 Post(s)
Liked: 7
Hi Guys, could you tell me if those reading are correct and if my calibration will be accurate?
I have profile my i1display pro retail with reference i1pro2
post #171 of 299 Old 06-18-2019, 06:18 AM
richardsim7's Avatar
Quoted: 1308 Post(s)
Liked: 1674
richardsim7 is online now
post #172 of 299 Old 06-22-2019, 02:29 PM
Quoted: 77 Post(s)
Jeez
No tutorial still
LG 65 C9 OLED Display
Oppo UDP-203 UHD Blu-ray Player (49-XXXX MODIFIED )
Home Theater 7.1.4 with yamaha RX3070
4klover is offline
post #173 of 299 Old 06-22-2019, 04:47 PM
Liked: 1674
Originally Posted by 4klover View Post
Jeez
No tutorial still
Jeez
No patience still
post #174 of 299 Old 06-23-2019, 07:24 AM
WiFi-Spy's Avatar
Liked: 2021
Jeez
No tutorial still
Launching next week
richardsim7 and 4klover like this.
post #175 of 299 Old 06-24-2019, 09:57 AM
buzzard767's Avatar
Quoted: 1668 Post(s)
Liked: 2459
How about adding high end meters to the Home series? If I could use my K10-A I'd buy your software AND one or two of your "partner's" displays.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #176 of 299 Old 06-24-2019, 11:16 AM
WiFi-Spy's Avatar
Liked: 2021
CalMAN Home for LG
Unfortunately, professional level measurement devices, require the professional level versions of CalMAN.
post #177 of 299 Old 06-24-2019, 01:14 PM
buzzard767's Avatar
Liked: 2459
I saw a chart somewhere that showed the acceptable meters for CM Home For LG but I can't find it. Do you have the reference? Thanks in advance.
Buzz
post #178 of 299 Old 06-24-2019, 02:00 PM
WiFi-Spy's Avatar
Liked: 2021
Most people are using an i1 Display pro or C6.
post #179 of 299 Old 06-24-2019, 02:46 PM
chadwick537's Avatar
Quoted: 45 Post(s)
Liked: 26
https://store.portrait.com/consumer-...me-for-lg.html
Devices are listed under Specifications =)
chadwick537 is online now
post #180 of 299 Old 06-24-2019, 03:49 PM
buzzard767's Avatar
Liked: 2459
Thanks Chad. That's what I needed.
chunon likes this.
Buzz
Reply Display Calibration
