CalMAN Home for LG - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 1407Likes
post #2011 of 2703 Old 04-03-2020, 11:40 AM
Rolls-Royce's Avatar
Quoted: 1468 Post(s)
Liked: 1553
Originally Posted by jednc1 View Post
I'm curious. I have an old Sony rear projection DLP and I was wondering if I could do a manual calibration on it using the manual calibration in CalMAN Home for LG. FYI my main TV is LG OLED C9, this old Sony is in my "game room".
Yes.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #2012 of 2703 Old 04-03-2020, 12:42 PM
jednc1's Avatar
Quoted: 13 Post(s)
Originally Posted by Rolls-Royce View Post
Yes.
Any idea which display type I should select?
jednc1 is offline
post #2013 of 2703 Old 04-03-2020, 12:50 PM
Liked: 1553
If you are talking about an I1D3 or equivalent, none of theirs are for DLP. I'd go with RAW XYZ unless you plan to profile it with a Spectro...
liberator72 likes this.
...Royce...
post #2014 of 2703 Old 04-03-2020, 04:16 PM
Quoted: 113 Post(s)
Liked: 67
Originally Posted by EMINENT1 View Post
Is it the ok to go back after autocal to do do manual adjustments like under 10?
Sent from my SM-N975U using Tapatalk
No. Once you click the Autocal button it will reset to Unity. You can run Autocal and then open the DDC window to make manual touch ups if you like. Fair warning is that calibrating the low end can be a moving target and AutoCal will probably get you just as close.
EMINENT1 likes this.
Emotiva + Energy = Love
Dark-007 is offline
post #2015 of 2703 Old 04-03-2020, 08:56 PM
Liked: 0
Got a silly question. I have the i1Display Pro, does it matter which way I position it on the screen? Vertically or horizontally, I am using a tripod.
I am still trying to figure of my red oversaturation on SDR.
The-10th-Doctor is offline
post #2016 of 2703 Old 04-04-2020, 07:08 AM
Liked: 1553
Vertically with cable at the top is what's been recommended. See posts by #ConnecTEDDD
dwaleke and liberator72 like this.
...Royce...
post #2017 of 2703 Old 04-04-2020, 08:38 AM
mhmercer's Avatar
Quoted: 217 Post(s)
Liked: 59
Vertically with cable at the top is what's been recommended. See posts by #ConnectTEDDD
Do the photons fall out if the cable is down?
Jimmy2Shoes likes this.
LG OLED55C9 | Denon AVR-X3400H | ATV 4K | Sony UBP-X700 | Hsu HC-1 MK2 (C) & HB-1 MK2 (LRSur), Sub VTF-15H MK2, ELAC Atmos | X-Rite i1D3 OEM | 2019 CalMAN Home for LG
mhmercer is offline
post #2018 of 2703 Old 04-04-2020, 08:54 AM
Liked: 1553
As I said, check out the posts by Ted Aspiotis. He discussed this some time ago. IIRC, XRite testing did show a difference in accuracy depending on the meter's orientation, with the best realized while the meter was positioned vertically, cable up. I do not know if this is depending on display type - screen polarization on LCDs led to inaccuracy in an earlier generation of colorimeters primarily meant for CRT, so such things are not unknown.
See here: https://www.avsforum.com/forum/139-d...t-results.html
Make73 and liberator72 like this.
...Royce...
post #2019 of 2703 Old 04-04-2020, 09:41 AM
DaMacFunkin's Avatar
Quoted: 657 Post(s)
Liked: 425
Hi, on Samsung TVs you can play a WAV file via a analogue IR blaster that puts the TV into service mode, is there a similar WAV file for the LG?
My service remote is currently locked down 🙄
DaMacFunkin is offline
post #2020 of 2703 Old 04-04-2020, 11:41 AM
EMINENT1's Avatar
Quoted: 362 Post(s)
Liked: 168
That's what I meant to ask.
So after gray scale autocal, before advancing, click DDC button and then the % patch to adjust? Won't mess with anything?
2019 LG C9 65"
2019 LG SL10YG Soundbar
I1D3 OEM
Calman Home RC1
Lightspace/Colorspace
EMINENT1 is offline
post #2021 of 2703 Old 04-04-2020, 12:21 PM
liberator72's Avatar
Quoted: 556 Post(s)
Liked: 1031
It won’t mess with anything unless you remeasure 100% White. All targets are based off of your 0% Black and 100% White. Provided neither of these change then all values in between will remain constant.
LG OLED65C9MLB**Denon AVR-X3500H**Focal Sib Evo Atmos 5.1.2**Sky Q UHD**Xbox One X**Panasonic DP-UB820**ATV 4K
Klein K10-A**Jeti 1501**i1D3 OEM**LightSpace HTP**CalMAN Home for LG**DVDO AVLab TPG**HD Fury Integral 2
Ted's Disk & Media Files**S & M HD & UHD HDR Benchmark Disks
liberator72 is online now
post #2022 of 2703 Old 04-04-2020, 09:19 PM
wsdriller's Avatar
C6 First Generation
I have a C6 first generation, can I use this for HDR Until I get A different meter?
wsdriller is offline
post #2023 of 2703 Old 04-05-2020, 12:21 PM
WiFi-Spy's Avatar
Quoted: 1911 Post(s)
Liked: 2509
Yes. It will ready fine up to 1000 nits.
Tyler Pruitt - Technical Evangelist - for Calman
WiFi-Spy is offline
post #2024 of 2703 Old 04-06-2020, 12:22 AM
Quoted: 22 Post(s)
Liked: 4
Hi everyone! I would like to ask if it's ok now to an autocalibration on my LG C8. I read that there were some issues with autocal and I'm asking if they have been solved. Thanks.
peppebi is offline
post #2025 of 2703 Old 04-06-2020, 10:30 AM
LiveEvil's Avatar
Liked: 0
Hello,
I was curious if there is a recommended peak brightness setting is for SDR?
LiveEvil is offline
post #2026 of 2703 Old 04-06-2020, 10:45 AM
HiFi4Vision's Avatar
Quoted: 394 Post(s)
Liked: 389
If you are talking about the picture mode setting called "peak brightness": definitely off for reference viewing mode / calibrated TVs.
TV: LG OLED C9 Firmware v04.71.25 | Probe: X-Rite i1Display Pro OEM Rev. B-02 (04/2019) | EDR: FSI_XM55U_23Jan19.edr | SW: CalMAN Home for LG R3 GM v05.10.2.67 | PG: LG iTPG
HiFi4Vision is offline
post #2027 of 2703 Old 04-09-2020, 04:50 AM
Quoted: 657 Post(s)
Liked: 425
Hi,
If I’m referencing my own meter, would you recommend D-Nice custom white point, I find my DV autocal LG C9 pushes red slightly in skin tones.
Cheers.
post #2028 of 2703 Old 04-09-2020, 07:40 PM
Liked: 1
When will calman home LG update to support 2020' TV TPG?
f16leon is offline
post #2029 of 2703 Old 04-10-2020, 02:35 PM
EMINENT1's Avatar
Quoted: 362 Post(s)
Liked: 168
Originally Posted by DaMacFunkin View Post
Hi,
Cheers.
Can't change DV wp at the moment.
I don't know why this is a thing, but it should be fixed.
2019 LG C9 65"
I1D3 OEM
Calman Home RC1
EMINENT1 is offline
post #2030 of 2703 Old 04-13-2020, 10:24 PM
Quoted: 113 Post(s)
Liked: 67
Hi,
If I’️m referencing my own meter, would you recommend D-Nice custom white point, I find my DV autocal LG C9 pushes red slightly in skin tones.
Cheers.
Is this only with the 9 series models? I'm able to do so with the B8 through either a Service Menu adjustment or by setting an alternative white point in Calman.
Dark-007 is offline
post #2031 of 2703 Old 04-13-2020, 11:43 PM
Quoted: 556 Post(s)
Liked: 1031
It's a 9 Series thing. You can target a different white point just fine, but as soon as you load the DV Config file it reverts to D65. Even manually editing the DV Config to contain new WP coordinates doesn't work. Kinda sucks, but I'm getting similar results in DV as I do with HDR with just a SM WB adjustment, with an additional User Menu 2-Point WB tweak
post #2032 of 2703 Old 04-14-2020, 07:51 AM
Quoted: 5246 Post(s)
Liked: 6445
Same with the CX. From what I understand this is controlled by Dolby and they are preventing an alternate WP in that PM.
John
Sony 55A1E, A9F, LG CX
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, LightSpace Pro, ISF Level III Certified
jrref is online now
post #2033 of 2703 Old 04-14-2020, 08:07 AM
Quoted: 556 Post(s)
Liked: 1031
Thanks for clarifying that. I know D-Nice had mentioned this a couple times before and I believe his assumptions was that it was indeed controlled by Dolby, so it’s good to hear someone else suggest the same thing. I did of course try it myself, not because I disbelieved it, but it’s good to see these things for yourself. How else do we learn about these little quirks
jrref likes this.
post #2034 of 2703 Old 04-14-2020, 08:18 AM
Liked: 6445
I found out the Dolby processing comes from Dolby and these TV manufacturers just interface to it at a high level.
Right, D-Nice did a lot of experimenting on this but I got confirmation it can't be changed since it's controlled by Dolby.
John
jrref is online now
post #2035 of 2703 Old 04-14-2020, 08:51 AM
Quoted: 113 Post(s)
Liked: 67
Yeah, I've been sticking with the SM adjustment to ensure I don't lose my 3D LUTs for HDR.
Uploading a Dolby Vision config file is an absolute must for these sets. The EOTF is blown out in all modes without it.
Btw, I confirmed that the Dolby config coordinates on the config file DO affect the picture on my B8, but they seem to offset the wrong direction, so it's not even worth it.
Dark-007 is offline
post #2036 of 2703 Old 04-14-2020, 10:10 AM
Quoted: 556 Post(s)
Liked: 1031
Yes, if I adjust the Config on my C7 it does something similar. On my C9 it just reverts to D65 no matter what I put in it, so as jrref says, it is mandated by Dolby and must be hard coded into it's processing on the 9 series.
post #2037 of 2703 Old 04-14-2020, 10:56 AM
mrtickleuk's Avatar
Quoted: 6097 Post(s)
Liked: 8839
And for completeness, are we assuming it's not possible on the C8s either please?
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #2038 of 2703 Old 04-14-2020, 11:45 AM
Quoted: 556 Post(s)
Liked: 1031
And for completeness, are we assuming it's not possible on the C8s either please? [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Sorry, I can’t comment on the 8 Series. When I did my daughters I didn’t use an AWP
post #2039 of 2703 Old 04-14-2020, 11:45 AM
Quoted: 113 Post(s)
Liked: 67
I wonder if it's an Alpha7 vs Alpha9 chipset thing. It works on my B8. We should see how the C8 and B9 behave since the B9 uses a newer A7 chip, and the C8 uses A9.
Dark-007 is offline
post #2040 of 2703 Old 04-14-2020, 12:08 PM
Quoted: 556 Post(s)
Liked: 1031
Maybe D-Nice or jrref could shed some light there, but I do (after the lockdown ends) have a chance to try it myself on my daughters C8. I honestly can't remember if he said it applied on the 8 Series or not to be honest.
Reply Display Calibration
