CalMAN Home Samsung Works With JU7500 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By ryandhorn
  • 1 Post By Rolls-Royce
post #1 of 17 Old 05-22-2019, 06:12 PM - Thread Starter
Liked: 3
Lightbulb CalMAN Home Samsung Works With JU7500
First post here, but I think I've got something useful.
I have a 55JU7500 UHD TV from 2015 and, according to the site, CalMAN Home Samsung only works with 2015 and 2016 SUHD TVs (8000 and 9000 series). I can confirm that this is not the case, as I have successfully calibrated my 55JU7500 using CalMAN Home Samsung and a USB to 2.5mm cable. That second part is also important because CalMAN says you need a USB to Serial adapter and a Serial to 2.5mm cable plus some CalMAN drivers. This is not accurate in my experience, as with the USB cable plugged into the EX Link port on my TV, CalMAN recognized the TV as a 2015 SUHD TV and controlled it just fine.
For patterns, I used MobileForge and AirPlay from a 2018 12.9 iPad Pro 512 to an Apple TV 4K 64 connected to input 1 on the Samsung 55JU7500 TV I/O box.
Here's the setup using a Microsoft Surface Pro 2 i7, 16GB RAM, 1TB HDD, and performance base (dGPU):
Spyder5 Colorimeter
CalMAN Home Samsung
Green-utech PL2303TA 6ft Usb Rs232 Serial to 3.5mm Stereo Aj Cable (Amazon)
The TV and colorimeter were both plugged directly into the standard USB A ports on the laptop (no hub).
I've attached my before and after from the final screen of CalMAN Home Samsung's workflow. I used the snipping tool after everything was disconnected by pulling up the saved cal file, so please ignore the "yellow" items in the upper-right. All three are green when hooked up per specifications above. I took a pic and video on my iPhone to share with friends if anyone needs to see it working.
Also, for reference: the "before" data in the CalMAN screenshot represents the cal settings from rtings for the JU7500.
Really hope this helps someone, let me know if there are any questions I can answer.
Name:	CalMAN screenshot.JPG
mombasa123 likes this.
ryandhorn is offline
post #2 of 17 Old 05-22-2019, 07:47 PM
Rolls-Royce's Avatar
Quoted: 1456 Post(s)
Liked: 1535
This really is old news, as one of our Canadian members, @p5browne , has been using the Samsung autocal routines on his 2015 HU and/or JU sets for some months now. By the way, it's true that using two cables, a USB-to-3.5mm and RS232-to-USB, isn't necessary if one uses a single cable that has the RS232 adapter built in like yours. But it's far more flexible to use two if you have other components that require a RS232-to-USB cable such as a Lumagen processor. Many of us do, and already have such a cable. For us, two cables make sense, and the requirement is indeed accurate.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3 of 17 Old 05-22-2019, 09:07 PM
p5browne's Avatar
Quoted: 4175 Post(s)
Liked: 3306
After a VERY short try using Autocal, went back to my more accurate Manual mode. Doesn't take long when most calibrating is just tweaking for differences in FW updates (very, very rare from Samsung these days) and hours on.
UN65KS9800 - Mine
QN49Q70R / UN65HU9000 + SEK-3500U / UN75JU7100 (JS9000 Mod Mode) / UN55HU7250 with SEK-3500U (JS9000 Mod Mode) / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #4 of 17 Old 05-22-2019, 09:10 PM
Liked: 1535
My point was that autocal on the 2015 sets isn't new...
...Royce...
post #5 of 17 Old 05-23-2019, 03:22 AM - Thread Starter
Liked: 3
Thanks for the info! I'll give it a shot on manual.
post #6 of 17 Old 05-23-2019, 03:46 AM - Thread Starter
Liked: 3
Sincerest apologies for the old news, then.
I tried searching AVS Forum and couldn't find this answer specifically for "CalMAN Home for Samsung." Maybe I missed it, but this post was just for folks who might be interested in that specific product. I think it's safe to assume the target demographic for "CalMAN Home for xxx" don't own or know how to use the more expensive CalMAN products, so if your comment is a case of "of course it works with CalMAN Home for Samsung, it works with CalMAN 5," that might not be so evident to laymen like me. The requirements and instructions for this product are very very specific and pointed, no wiggle-room for Lumigens or mentions of other applications for the serial adapter... if what your describing is even supported in the $150 "Calman Home for" series.
Will avoid posting in the future, was just trying to help folks like me without any calibration experience who might want this specific product.
post #7 of 17 Old 05-23-2019, 06:44 AM
Liked: 1535
Welcome to the forum. Please don't avoid posting. As I stated earlier, I wanted to let you and others know that autocal for certain 2015 Samsung models isn't a brand-new thing. In addition, there is another reason to use a two-cable setup rather than a single cable: length. The one-piece cable you referred to is 6' long. While this sounds like a lot, in practice, it isn't. It means that the CalMAN computer has to be relatively close to the TV, and in many setups, this is neither desirable nor possible. Two cables can give you 12' or more of distance from the screen, and this can be useful whether or not one has other components that need a RS232-to-USB adapter.
...Royce...
post #8 of 17 Old 05-23-2019, 07:02 AM - Thread Starter
Liked: 3
Thank you, and your point is taken regarding the advantages of the two-cable setup. To clarify though, the reason I felt the need to mention it is because the website and workflow actually state that using anything other than the serial adapter and extra cable "is impossible." This might make a lot of folks drop extra $$ on the adapter and cable listed on the website/linked to in the workflow. That's before trying to install the drivers for the adapter, which for novices might not be as easy as it sounds. The USB to EX Link cable is a much cheaper and more user-friendly option if 6' of cable is adequate. Here's the excerpt from the workflow:
Serial Connection Cables
  • Display connection is impossible without these cables
  • Listed Below
Serial Connection Information
To connect the CalMAN calibration computer to a Samsung SUHD TV:
  1. Connect an ExLink adapter (3.5mm headphone jack to DB9 serial cable) between the 3.5mm jack on the side of the Samsung OneConnect box labeled “External Sync” and an RS232 port on your PC or to a USB to serial converter.
  2. If you are using a USB to serial converter, in Windows Device Manager, under “Ports (COM & LPT),” look for a “USB Serial Port (COMx)” listing.
  3. Note the listed COM port (COMx) of the serial converter.
3.5mm Headphone Jack to DB9 Female Serial Cable
Buy on Amazon
USB to RS232 Serial Converter
For connecting to a Samsung TV with a computer that does not have an RS232 port, we recommend the FTDI USB to RS232 converter. Extensive testing has determined that this FTDI converter, which includes a data buffer, is the most reliable adapter to use for CalMAN device control.
Buy
Buy on Amazon
USB Driver download for FTDI converter
Or, CalMAN Device Driver Pack
For novices like me, this makes it seem like I absolutely need to buy the specific items linked to in the workflow ($32 for just the adapter as of today) and use the driver links provided to install the adapter. I was just pointing out for novices that this isn't the case, and a $13 cable will do the job with no driver installation required on Windows 10.
post #9 of 17 Old 05-23-2019, 08:21 AM
Liked: 1535
  • Listed Below
Buy on Amazon
Buy
Buy on Amazon
That how-to is probably poorly worded. In point of fact, it IS impossible to connect to the Samsungs without an RS232-to-USB converter in the chain somewhere. People have asked here if it's enough just to use a USB-to-3.5 cable, so that distinction has to be made. I'm also guessing that that particular RS232 to USB cable is what they had on hand. They do communication workups for other devices including the Lumagens I mentioned. Now, they do recommend specific cables based on the chipsets they use. They've found in the past that some of the chips used in these cables can introduce random errors, and those are to be avoided if you're doing an autocal, large 3D LUT upload, or a multi-thousand-point display characterization. They probably have not tested the specific cable you used and so haven't recommended it.
...Royce...
post #10 of 17 Old 04-07-2020, 06:08 AM
kingajit's Avatar
Hello Friends,
I intend to calibrate my SAMSUNG TV 65 inch 4K SUHD JS9500 for HDR /SDR using CalMAN Home Samsung.
I have the X-Rite OEM i1Display and Spyder 5 elite And contemplating purchasing the
Could anyone confirm if the SAMSUNG TV 65 inch 4K SUHD JS9500 (2015 model ) is one of the TV listed in the CalMAN Home Samsung? Thanks
The software price of USD 150 is it an annual license fee?
I do not have a pattern generator. Do I need to buy one? They are quite expensive 2.5K,
Look forward to hearing from you. Thanks
kingajit is offline
post #11 of 17 Old 04-07-2020, 08:49 AM
Liked: 1535
Originally Posted by kingajit View Post
Hello Friends,
Look here: https://store.portrait.com/consumer-...r-samsung.html
You must purchase new every year as you only get 12 months of updates included. If you don't, the software will still work, you just won't get any bugfixes or other updates after your initial 12 months is up. Yes, for autocal you do need a pattern generator. See here for less-expensive options: https://www.avsforum.com/forum/139-d...cy-thread.html
kingajit likes this.
...Royce...
post #12 of 17 Old 04-08-2020, 10:03 PM
kingajit's Avatar
many thanks Rolls Royce for your kind help in getting me started. Contemplating whether to buy the CALMAN HOME SAMSUNG or the CHROMAPURE STANDARD software . From what I read I do not need many cables and a pattern generator if I get CHROMAPURE Standard software. Not surest Chromapure Standard software is capable of both SDR and HDR. Any comments on choosing the software, I definitely cannot afford the pattern Generator.Thanks.
kingajit is offline
post #13 of 17 Old 04-09-2020, 06:59 AM
Liked: 1535
All software packages I am aware of send out their pattern commands in 8-bit RGB. This is fine for SDR, but not for HDR. The pattern generator must be capable of generating a full HDR signal complete with metadata. This is the key point. Just generating the pattern from something like an ATV 4K or a FireTV 4K does NOT do this. You will need either an HDR pattern generator or something like Ryan Masciola's patterns (which are created with HDR code values and include the proper metadata). Chromapure also cannot do the autocal, which is why you don't need more cables. It'll be manual calibration only for your Samsung.
...Royce...
post #14 of 17 Old 04-09-2020, 08:53 AM
kingajit's Avatar
Thanks Again Rolls - Royce. I am a novice and this is my first attempt at calibrating my TV. It appears neither Calman nor Chromapure may help me with HDR calibration and I do not have the budget for a patter generator. Which software do you recommend I should go for - Calman Home Samsung or Chromapure Samsung? Which would be easy to use for a novice? Thanks
Ajit
kingajit is offline
post #15 of 17 Old 04-09-2020, 09:01 AM
kingajit's Avatar
is it worth to go for the Autocal in calman Home for Samsung with the 2 cables? does it help a newbie? thanks
kingajit is offline
post #16 of 17 Old 04-09-2020, 10:04 AM
Liked: 1535
I have no experience with Chromapure, but I believe it comes only in Standard and Plus flavors. The only Samsung-specific software is CalMAN.
Autocal can help. But you would need a pattern generator of some type. Do look at the low-cost pattern generator thread I linked to in my first post. You may find something that fits your budget, such as the Raspberry Pi with the free PGenerator OS. The cables would allow you to "talk" to the set's DDC controls as CalMAN does during an Autocal, but aren't strictly necessary for manual calibration.
You may want to PM user #mombasa123 . He has been working to calibrate a recent Samsung display with CalMAN Home and could give you good feedback.
...Royce...
post #17 of 17 Old 04-09-2020, 09:33 PM
kingajit's Avatar
Thanks again so much for helping me. The Raspberry Pi is definitely a good option. I will get in touch with Mombasa.
kingajit is offline
Reply Display Calibration
calman , calman home , calman home samsung , JU7500
