Meter for above 2000nits? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-17-2019, 03:52 PM - Thread Starter
BigCoolJesus's Avatar
Quoted: 2092 Post(s)
Liked: 1702
Hey all,
In anticipation of getting the new Vizio PX75 (peak 2700nits, reviews saying it can easily hit ~2400nits even calibrated) I want to get the right meter that can handle such high HDR. I currently have the Revision B model of the iD3, which rates it up to 2000nits. What would be a good replacement without breaking the bank?
BigCoolJesus is offline
post #2 of 10 Old 06-17-2019, 04:08 PM
skschatzman's Avatar
Quoted: 2661 Post(s)
Liked: 1586
AFAIK there isn't anything better in a price range for the normal consumer. The next step up would be commercial grade. $3,000+
skschatzman is online now
post #3 of 10 Old 06-17-2019, 05:12 PM - Thread Starter
Liked: 1702
Dang. I thought there was one for around $800, ConnectTed recommended it to me about two years ago. European in origin. Just can't remember.
EDIT:
This one
https://www.lightillusion.com/discus.html
basICColor DISCUS Tristimulus Colourimeter
Says it can do up to 2500nits?
post #4 of 10 Old 06-17-2019, 05:43 PM
Liked: 1586
EDIT:
This one
I honestly have not heard about that one. The large price jump for such a small performance jump over the i1 doesn't make it ideal for average consumers to consider.
Your decision should also be based on what calibration software you will be using. They should have a list of compatible meters.
post #5 of 10 Old 06-17-2019, 05:59 PM - Thread Starter
Liked: 1702
Would that extra few hundred nits above 2000 make much of an impact on calibrating the brightest whites if I stick with the iD3?
post #6 of 10 Old 06-17-2019, 06:09 PM
Liked: 1586
I don't know bud lol. If I had both to test I could answer that. Based on the numbers I wouldn't think it would be worth it though. Especially since we are seeing large jumps in display brightness from new models every year. I assume it would be a short lived upgrade. The 2000nit i1 has only been out a couple years and it is already seeing limitations. Commercial meters can read much much higher so they will have a longer usable life span.
post #7 of 10 Old 06-17-2019, 10:24 PM
Anger.miki's Avatar
Quoted: 346 Post(s)
Liked: 361
I have both. Discus is like a Klein K10a just (really) slower. If you use CM then it’s more or less fast like the i1D3 but with K10a-like low luminance readings. The sad news is that basICColor recently got out of business.
TVs: Pioneer PDP-LX5090H, LG OLED55C8PLA | SintoAmp: Pioneer VSX-921 | BD Player: Panasonic DMP-BDT260EG | External LUT box: Entertainment Experience eeColor | Softwares: Light Illusion Lightspace HTP, Portrait Displays CalMAN Home Enthusiast 2018 R3, HCFR, DisplayCAL | Probes: x-rite i1 Pro 2 - i1 Display Pro OEM B-02, basICColor DISCUS | Test Pattern Generator: DVDO AVLab TPG
Anger.miki is offline
post #8 of 10 Old 06-18-2019, 06:10 AM
Light Illusion's Avatar
Quoted: 733 Post(s)
Liked: 1071
The Discus will (should) remain available.
It is just the software side of basiCColor that has closed.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #9 of 10 Old 06-18-2019, 10:12 AM
Anger.miki's Avatar
Quoted: 346 Post(s)
Liked: 361
That’s cool. Thanks Steve. By the way, unlike plasma (where due to the subfield drive it is essential to use slower reading settings), with LCD and OLED the Discus is stable even with the fastest setting.
post #10 of 10 Old 06-18-2019, 10:52 AM - Thread Starter
Liked: 1702
Steve
Any opinion on the Discus vs. the Rev B iD3 for the above 2000nits range?
Reply Display Calibration
