Projector Calibration (6040UB) - Second Look - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 100Likes
post #271 of 282 Old 06-18-2020, 11:07 AM
Grayson73's Avatar
Quoted: 27 Post(s)
Are people still using the settings in the first post? Have there been any updates?
Grayson73 is offline
post #272 of 282 Old 06-18-2020, 09:43 PM
Grayson73's Avatar
Quoted: 27 Post(s)
Can someone give a quick and dirty on when to use the 2.2 vs. 2.4 settings? I have a light controlled room so I should use 2.4, correct?
Also, for HDR, when do you use the 500 nits vs. 1000 nits settings? Do you just select the setting that looks best to your eye?
Sorry for the elementary questions. This is my first 4k projector. I haven't even heard about HDR until I started doing some research!
post #273 of 282 Old 06-18-2020, 10:50 PM
Zoltrix's Avatar
Quoted: 112 Post(s)
I have a light controlled room found that AdamAttewell's HDR 500 nits (High) settings worked best for me.
Grayson73 and AdamAttewell like this.
Zoltrix is offline
post #274 of 282 Old 06-18-2020, 11:15 PM - Thread Starter
AdamAttewell's Avatar
Quoted: 873 Post(s)
Liked: 228
Try both gamma's & see which you prefer, there is no right or wrong here as its down to personal preference, what the content was graded to & lighting conditions in the room.
I just save all the different settings under their own memories & then you can switch between them to see which one you prefer.
What source device are you using?
I myself am using a Panasonic UB820 which allows me to tone map HDR content down to 500 nits hence why I have a calibration for 500 nits.
Movies from Hollywood are either 1000 or 4000 nits depending on the display they were mastered on, I would say 1000 nits is the most common.
On the UB820 you can see in the picture settings menu what the content you are watching was mastered to.
Again a little trial & error is needed as there are so many variables that you will need to experiment to see which fits your setup best.
Grayson73 likes this.
AdamAttewell is offline
post #275 of 282 Old 06-19-2020, 06:03 AM
Grayson73's Avatar
Quoted: 27 Post(s)
I have a Roku Ultra and Xfinity X1 4K DVR (XG1v4). I stream Xfinity On demand, Amazon Prime and Disney+ with those devices.
post #276 of 282 Old 06-19-2020, 02:30 PM - Thread Starter
Quoted: 873 Post(s)
Liked: 228
I am not familiar with those device but I am going to go out on a limb & say they do not tone map.
Like I said give both 1000 & 500 nits a try & see which you like.
Using someone else's settings will always be a compromise compared to doing a calibration yourself with the right equipment.
post #277 of 282 Old 06-19-2020, 06:39 PM
inspector's Avatar
Quoted: 309 Post(s)
Liked: 201
The 420/820 only tone maps a physical disc, right?
...finally retired and spending time in my dedicated HT!!!
SPARKSPLEX HT - Epson 6040 3D/4K UB Projector; 110" .09 16x9 Dalite HD Progressive Screen; Sammy 3D/4K K8500 (r-free); Panny ub420; 7.2.4. Def Tech speakers, Earthquake P12v2 Subs; Auto Source 100vs Amp; Denon 4300H; MX990 Remote; .
inspector is offline
post #278 of 282 Old 06-19-2020, 07:25 PM - Thread Starter
Quoted: 873 Post(s)
Liked: 228
I am pretty sure that it works for the apps to like Netflix.
post #279 of 282 Old 06-25-2020, 09:56 AM
Grayson73's Avatar
Quoted: 27 Post(s)
Thanks for the calibration! The 1000 nits was dark, but seemed to have better black levels than the 500 nits. I was thinking that the 1000 nits would be brighter.
post #280 of 282 Old 07-09-2020, 08:04 AM
b_scott's Avatar
Quoted: 759 Post(s)
Liked: 317
in the original post, for the 820 it says "I use a Panasonic UB820 with the HDR optimizer switched on using the HDR TV Type "Basic Luminance LCD & Projector"
I have no such setting on my 820. Am I looking in the wrong spot? Help!
Shadow Theater Build: https://www.avsforum.com/forum/19-dedicated-theater-design-construction/3141596-shadow-theater-build.html
b_scott is online now
post #281 of 282 Old 07-09-2020, 09:09 AM - Thread Starter
Quoted: 873 Post(s)
Liked: 228
You can see that menu option here is this video at 1:28, the setting is called " HDR TV Type"
Watch from the start to see how to access that setting.
post #282 of 282 Old 07-09-2020, 09:11 AM
b_scott's Avatar
Quoted: 759 Post(s)
Liked: 317
thanks! i didn't see any of those settings when I pushed the settings button before.
Reply Display Calibration
